335xi Exhaust Options. Show me them.
05-14-2009, 11:22 AM | #23 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
I had RDSport back in the day and they worked fine. Those were axle back (mufflers only), but they do offer a full down-pipe back.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
05-14-2009, 11:56 AM | #24 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
i'm pretty damn sure that all the exhausts are compatible with i or xi. The only difference with the exhausts is whether you have an E90 or E92.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
05-14-2009, 07:32 PM | #25 |
26
Rep 177
I can't seem to find them now, but I know I saw a few on **********s that specifically said they wouldn't work on XI models. I'm not sure what the reasoning is, but I imagine it has something to do with the AWD system getting in the way.
05-18-2009, 09:00 AM | #26 |
Air India
145
Rep 1,834
HKS outperformed the Autobahn Exotic exhaust system in the last issue of Grassroots Motorsports.
The price, sound, look, quality, and performance #s, exceeded AE set up. If I hadn't gone with a muffler delete, I would of done HKS. Stock Muffler Delete Muffler Delete Cabin
PKumarM3 |
05-24-2009, 11:57 PM | #27 |
Rep 1,288
Drives: 135i
In case anyone missed it, VK Motorwerks is holding a ridiculous group buy on their downpipes which have been tested and proven to fit the 335xi.
You can purchase them here for $300!!!! http://vkmotorwerks.com/downpipes.html
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
09-02-2009, 10:52 AM | #28 |
Rep 292
While it has already been posted on the list I wanted to verify that the Borla exhaust for the XI fits. The version that comes for the XI is the revised separate mufflers type not the original large single muffler design.
An advantage or disadvantage depending on perspective is that the Borla revised exhaust does not eliminate the secondary Cats. It is therefore fully emission legal in design. The pipes start after the secondary cats and require the muffler shop to cut the pipes and slip joint them after the secondary cats. Build quality is excellent and any decent muffler shop can install them without major headaches. |
09-02-2009, 10:53 PM | #29 |
Rep 1,079
Billy Boat
I just did the Billy Boat on my 335ix and it is down right awesome.
They are the only company to use the existing pneumatic flapper valve like the factory system does. I will have a full write up tomorrow. Steve
2020 X3MC, 2018 Porsche Macan, 2019 X3 3.0i, 2016 981 Cayman S
09-03-2009, 01:44 PM | #30 |
Rep 292
Well two days with the Borla and I honestly hate it. The vibrations from the exhaust is causing the rear console lid to make an annoying rattle at 1500-2200rpm range. The entire car vibrates in that rpm range and drones on the highway since the steptronic keeps the rpms right near 1500 to 2000rpm range. Everytime I step on the gas from a stop or trying to go from 55-65mph I get vibrations and rattle and loud exhaust rumbling.
The louder noise does not sound any better and if anything sounds worse than stock. Yet, after 2500rpms the exhaust magically gets quieter again and sounds much better but really not much louder than stock. The problem is I spend far more time cruising in drone and vibrations and the tradeoff stinks. I am going to research my options to reduce or eliminate this annoying low rpm drone. If all else fails I'll have to buy a whole new system or reinstall the stock mufflers. Good thing I anticipated this and kept the stock mufflers. Update: I talked to Borla and it seems their website failed to indicate I could've ordered the milder sounding unit. They are looking into some venturies to see if I can use it to change the pitch and tone of the exhaust and change out the effect. Last edited by Turbomatic; 09-03-2009 at 05:29 PM.. Reason: update |
09-30-2010, 09:58 AM | #31 |
Back to drive auto... sigh
Rep 20
How about Agency Power?
'10 Bayerische Motoren Werke e92 Alpine White 335xi M-Sport / Bilstein B8 Sprint / Eibach Pro-Kit / Smoke Anodized Front Grill / Body-coloured Reflectors / MTech Rear Trunk Lip Spoiler / AFE Stage 2 DCI / ER Chargepipe / HKS SSQV BOV |
10-02-2010, 12:16 AM | #33 | |
Rep 51
I took a pair of winter gloves and shoved those bitches in there and forced the lid closed so the gloves held pressure on it. Problem solved. Oh and you can add the Turner Motorsports Exhaust to the list. I have it on my E92 335xi and it will fit E90 xi's as well. http://www.turnermotorsport.com/html...MS-EXH-E92335S |
10-28-2010, 03:06 PM | #34 |
76
Rep 291
I am noticing the same thing as awdftw and Turbomatic with the Borla exhaust. I am thinking about switching it back to stock and then doing the AR downpipes instead. I do believe I would gain more power with DP's than with the exhaust anyway.
I will say that overall I do like the sound of the Borla exhaust though, but I don't love the rattle in the midrange. |
10-28-2010, 05:33 PM | #35 |
/r/trees
50
Rep 875
This is an old thread but I thought I'd add my 2 cents.
Any exhaust system from the downpipes back (full exhaust) is not guaranteed to fit the xi. The xi's transfer case may get in the way. Heres a couple more datapoints for a couple obscure exhausts: Milltek e92 exhaust -- does not fit the xi. Britalman e92 exhaust -- fits fine. And the lid in the back storage compartment will rattle like a bitch with any exhaust on any 335. Stuff it with something. |
11-01-2010, 01:50 PM | #36 |
Rep 415
Drives: 2011 335i X-Drive Sedan
Anyone have any experience with the BMW Performance Exhaust? Also, I have a 2011 335i x-drive sedan with the new N55 motor. Any of the above options fit my car? I'm just looking for more performance and not something real loud. Any thoughts? Thx!
06-08-2011, 05:18 PM | #37 |
New Member old BMW M owner
Rep 85
Drives: 07 335Xi Sedan
Vanguard Exhaust will not fit the e90 335XI. The transfer case gets in the way. For those of you who think the only difference is between coupe and sedan and that XI to non-XI does not come into play, you need to do your homework. I didn't do mine and I am paying for it now.
Can we start a confirmed list of those that don't fit? 2007 335XI Sedan 6MT - VANGUARD will not fit. |
11-17-2011, 09:39 AM | #40 |
Rep 790
anyone kno if titek downpipes will fit on the x
2011 Volkswagon Touareg - Current
2005 Evolution 8 FBO E-85 365whp - Sold 2009 135i Alpine White/Terracotta 6mt - Sold 2009 BSM lci e90 335i 6mt xdrive - Sold |
04-10-2013, 12:06 AM | #42 |
100
Rep 307
I'm running VK downpipes and the VRSF 3.5" exhaust. I love it. No drone, tons of turbo whistle, and nice rumble. It's much better than the VK downpipes and muffler delete combo I was running previously...
Blake - 2024 M3 Competition xDrive
Square 826M 20" Wheels, Dinan HAS, Dinan Midpipe, Dinan Axle-Back Exhaust, Dinan 10/12mm Spacers, SST Valve Controller |
04-10-2013, 08:59 AM | #43 |
Rep 414
Here are a couple vids of my BMW PE setup.
Current: 2016 M3 | Mineral Grey on Black Retired: 2010 E92 335xi, 2007 E90 328i, 2010 A4, 2003 E46 325xi |
04-12-2013, 12:45 PM | #44 |
21
Rep 396
Drives: e90 335xi
Stock Mufflers VS. Dinan Fee Flow For everyone
