Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > LSD on xDrive
      02-17-2020, 02:17 PM   #67
E91Swagger
31
Drives: E36S52; E91N52
Originally Posted by Soravia View Post
I got $150 quote to put in LSD into open diff. $150 for used diff, $750 for Torsen, plus $150 labor, and under $50 for seals and flange bolts, I'll be spending $1,000+ to put in a Torsen
Please do a review of the lsd when you have a chance.
      02-18-2020, 08:30 AM   #68
Soravia
Drives: 2011 E91 Silver xDrive 6MT
It will be a long while. Car is still in shop for brake lines, and I piled up quite a bit of money just to replace many stock parts that were rusted out. But it is in the future, after summer is most likely.
If you don't have LSD, you're wrong is what I have to say. I've driven without and with LSD on RWD, FWD, etc. AWD masks the need but it's still there.
      02-19-2020, 11:01 AM   #69
carguy138
146
Drives: E90 335i
Originally Posted by Nick.B View Post
I understood your point from your earlier description, but the video was a fun few minutes.
As someone familiar with control systems, it's going to be a pretty big compromise when a control system is unaware of what the driver sees and is trying to do, and it's trying to keep the driver safe.
Where'd you find the info for coding out the torque cut and braking?
RWD with decent snow tires served me fine before we moved out here. Winters and road conditions here are much more severe. My house is on a hill. Small residential streets are never plowed. The road has three inches of ice, and a bit of packed snow on top. The RWD E90 with open diff and Conti snows will do it, but only barely some days. Thinking LSD and some winter rally tires for that car next year.
After adding the LSD in the back of the WRX, it drives great. Too bad it's got other.... issues... that shouldn't be effecting a 6 month old car with 10,000km on it.
Here you go. I copied it a while ago before the site went down.
How To Actually Make your BMW Fun
1/23/2016
In my last post, I promised that the next blog update would be about the DIY carbon fiber aero plans we have for the car. Unfortunately, due to a scheduling mishap that will have to wait until next weekend. That’s okay though, because I want to write about something I think will be useful to every single BMW track enthusiast – electronic nannies.
BMW likes to market their cars as “The Ultimate Driving Machine.” Indeed, I even used that phrase (in a partially joking manner) in my last post. Unfortunately, this is far from the truth. While modern BMWs have many elements that make them outstanding driving machines, there is one primary thing holding them back from achieving true greatness – electronic nannies. What are electronic nannies?
Electronic nannies are a veritable alphabet soup ​of joy-sucking, fun-killing, brake-destroying awfulness. DSC, DTC, HBA, EVB, HPS, and Maximum Brake Support are all BMW acronyms that stand for the same thing – SLOW. Each and every one of these electronic safety devices are designed for the average consumer; not your hardcore automotive enthusiast. It is surprising to me that information on how to disable these “features” is not more widely available.
While the race to integrate technology into cars has cost us some raw dynamic pleasure, one benefit is that almost everything in a modern car is programmable – if you know how to do it. In the BMW world, we call it “coding.” Coding is essentially the act of using BMW diagnostic software to access computer “modules” that control various parts of your car. This software allows you to read out the various options available and change them to suit your preferences. Generally there are two types of options for each coding parameter: “aktiv” or “nicht_aktiv,” and level based entries where you will choose “levels” such as “wert_01,” “wert_02,” etc. Coding can be confusing to set up, but a little perseverance can go a long way towards customizing your car. Luckily for us, all of these electronic nannies can be found and modified in your DSC (dynamic stability control) module. The name of this module varies depending on what car you have, but as an xDrive N55 car these nannies were located in the DSC_84.C04 file of my XDSC module. Explaining how to set up your computer for coding is beyond the scope of this blog, but I will provide which options you need to disable, and what the proper setting is.
I hope it will be useful to have the description of these nannies consolidated in one place. This information is scattered all over the internet; I would have appreciated having it in one place when I was doing my own research. Each of these nannies are present on N52, N54 and N55 vehicles, including the 128i, 135i, 238i, 335i, 535i, and X1. The following chart is organized with the name of the electronic nanny followed by the acronym it is listed as in BMW’s DSC module files.
Please note – if the option in your DSC module appears different (for example, it you have various “werts” as an option instead of “nicht_aktiv” or “aktiv”), you can examine the hex data in the entry to see what the various “wert” levels are. For example, the N54 335i electronic differential setting is not a simple on/off setting, but the hex data for “wert_01” is equivalent to “nicht_aktiv.” You can refer to this thread for more info: ​http://www.e90post.com/forums/showthread.php?t=944126
The Definitive Guide to BMW’s Joy-Killing Nannies
Engine Power Reduction to Prevent Brake Disc Overheating (FLR)
N55 X1 Parameter: e84_FLR
N54 335i xDrive Parameter: FLR_C0F
N54 135i Parameter: C0F_FLR
On: wert-01 – value 01 (default)
Off: wert_00 value 00 and wert_02 – value 02
This is the worst of them all. Modern BMWs will actively cut the throttle in the middle of your track day if it has reason to believe that your brake pads are overheating. Normally, this wouldn’t be such a bad thing – nobody wants to crash into ARMCO going 140mph. The problem is, your BMW doesn’t actually have temperature sensors anywhere in the braking system. The computer relies on a “calculated” brake disc temperature based on several inputs including ground speed, brake pedal application force, and the frequency with which the electronic differential applies “torque-vectoring” braking. Your BMW has no way to know that you installed a Stoptech Big Brake Kit with Castrol SRF fluid and Performance Friction PFC01 pads. It just assumes you are running the stock system and cuts your throttle based on values that would overheat the OEM brake pads. Unacceptable to say the least, and occasionally dangerous. It was not a good experience braking from 145mph down to 45mph with a GT3 three feet off my rear bumper, only to have zero power coming out of the turn. This could very plausibly cause an accident on track.
To disable, set to “nicht_aktiv.”
Brake Fading Compensation (HPS)
N55 X1 Parameter: e84_HPS
N54 335i xDrive Parameter: HPS
N54 135i Parameter: C0F_FBS
Off: wert_00 – value 00
It is insane that a “performance” car has this feature. Brake fade compensation “calculates” the temperature of your fluid in a similar manner to the above “Engine Power Reduction to Prevent Brake Disc Overheating” parameter does. The higher the calculated temperature of your brake fluid (remember, there is no real sensor), the more hydraulic assist will be added to your brake pedal. In theory, this masks brake fade on the street. On the track, it makes a consistent brake pedal literally impossible. If you are tracking the car, you should have upgraded pads and fluid; you should never experience brake fade. Disabling this feature maintains the pedal’s linearity and enjoyable feel throughout an entire 45 minute track session.
To disable, set to “nicht_aktiv”.
Hydraulic Brake Assist (HBA)
N55 X1 Parameter: e84_HBA
N54 335i xDrive Parameter: HBA_DXC_8
N54 135i Parameter: not able to find
In the event of an emergency braking maneuver, the average driver does not brake hard enough to sufficiently stop the car. Thus, BMW implemented hydraulic braking assist. This feature monitors ground speed, brake pedal pressure, and rate of deceleration to understand when the car is in an emergency braking situation. It then increases pressure up to the threshold of ABS to assist the driver in stopping safely. Once again, on the street this is a good idea. In Cincinnati, there is utter carnage on the highway whenever the slightest rain falls. The Ohio River runs red with blood from traffic accidents, and the roads look like a battle scene from Game of Thrones. Implementing an additional safety feature such as this probably helps most people, but on the track it is a disaster. It ruins your ability to brake hard and quickly, assuming the end of each high speed straight is an impending accident. Disable this feature for a super-linear pedal that will require noticeably more effort towards the end of the pedal travel. Be careful with this on the street the first few times you use it – you will find that it activates more often than one would expect. You will have to use a bit more braking pressure towards the end of the pedal than you are used to, but you will be rewarded with a wonderful, linear feel.
To disable, set to “nicht_aktiv”. You can also set three levels of assist; “wert_01”, “wert_02”, and “wert_03”. Default value is “wert_03”.
Brake Standby (EVB)
N55 X1 Parameter: e84_EVB
N54 335i xDrive Parameter: EVB
N54 135i Parameter: C0F_BB_RAB “Ready Brake Alert”
This is another ridiculous feature that works well on the road, but terribly on track. If your car detects an aggressive throttle lift-off, it will pre-tension the brakes in anticipation of a hard braking maneuver. This would actually be great if it wasn’t for what it does next – if you don’t brake within 8 seconds of throttle lift-off, it un-tensions the brakes. I have a theory that people who think they are experiencing pad knock-back on the track are actually just being victimized by this “feature.” Turn it off for a more consistent brake pedal that responds predictably.
Maximum Brake Support (HVV)
N55 X1 Parameter: e84_HVV
N54 335i xDrive Parameter: HVV
This feature alters the front/rear split of the ABS braking system under emergency braking. At threshold braking when the front tires get into ABS before the rears lock, maximum brake support will increase the brake pressure on the rear pistons to equalize with the front. In theory, this reduces stopping distance. On the street, it probably does – particularly when the car has a heavy cargo load. On the track, it can upset the balance of the car and reduce reaction time. During threshold braking, sometimes one activates ABS accidentally and quickly backs off; maximum brake support will interfere here and get you “stuck” in ABS for a second or two. I recommend turning this off on the track, but it does not have as big of an impact as the other settings do.
Dynamic Performance Control (FDB)
N55 X1 Parameter: e84_FDB
N54 335i xDrive Parameter: FDB
N54 135i Parameter: C0F_CBC
On: wert-00 – value 00 (default)
Off: there is not box in NCS Dummy to change to wert_01
(I presume this can be done in the .man file but have not confirmed)
This feature encompasses two things – corner braking designed to “torque vector” and redirecting the power through the xDrive system for a 20/80 FWD/RWD torque split. I am conflicted on this option, and need to do more testing on the implications. Without a doubt, this feature accelerates brake pad wear – if you are driving with a decent amount of slip angle, it will be almost constantly corner braking. Traditional logic holds that corner braking is a worse way to torque vector than mechanical LSDs are and that’s probably still true, but recently supercars such as the McLaren 650S started coming with corner braking torque vectoring. Granted, the software in a McLaren is hopefully more advanced than that in an entry level sedan (BMW 335i) but the point holds – there must be something to it if supercar manufacturers are going in that direction. What is frustrating about the X1/335i is that you can’t separate the 80% RWD bias (an unquestionably good thing) from the brake-based torque vectoring (possibly a bad thing)? So, what’s the upshot? I think it probably goes something like this:
1. Base car without this option – code it on for a nice performance boost!
2. M-sport pack that comes with it enabled, but no mechanical LSD – leave it on
3. Car with an upgraded mechanical rear LSD – ?????
I will experiment more with this feature, but my gut says that with a mechanical LSD installed in the rear, having the 80% RWD split will outweigh the drawbacks of the corner braking in terms of lap time.
Electronic Differential (AX_Ref_Diff_Lock)
N55 X1 Parameter: e84_AX_Ref_Diff_Lock
N54 335i xDrive Parameter: AX_Ref
N54 135i Parameter: C0F_DIFF_LOCK
On: wert-02 – value 02 (default)
Off: wert_00 – value 00 and wert_01 – value 01
Let’s be honest, this is really why you’re reading the blog. Everyone who has installed a mechanical limited slip differential wants to disable the rear electronic differential. This option is similar to the X1s “Dynamic Performance Control,” but on a more basic level. The premise is that with an electronic differential, your BMW will brake the spinning wheel to send torque to the wheel with traction. The problem is, this isn’t a very good torque transfer in terms of mechanical efficiency. Installing a mechanical limited slip differential such as a Wavetrac (my choice) in the rear will allow you drastically better traction and mid-corner adjustability. The problem is, unless you disable this e-diff it will be fighting the mechanical LSD and never really allow your actual differential the freedom to do it’s thing. If you have a mechanical LSD installed, do yourself a favor and disable this. If you don’t have a mechanical LSD, leave it on. At least, until you immediately run out and buy a real LSD (you should).
Here is an example of what the stability control module coding looks like in the program NCS Dummy. There are many more options than I have identified here, but I believe I have highlighted everything that has an impact on performance driving.
Turning all of these options off gained me about two seconds on a 1:45 second track. More importantly, it made my car extremely fun to drive. There are not many crossovers that you can kick the back end out at 100mph, drift into a decreasing radius corner, and then dance with it via throttle inputs as you adjust mid corner and power through. Thanks to the magic of “coding,” my X1 is now one of them. Hopefully, this helps you enjoy your car just as much as I enjoy mine.
Thanks for reading, and check back in a few days for the promised post about DIY aero on the car.
      05-16-2021, 12:13 AM   #70
vrizzotti
Drives: E90 325xi, 1988 528e
Originally Posted by carguy138 View Post
To give you guys something cool to watch and illustrate the point a bit better, here you go. This is the type of driving that I am talking about. The Audi torsen Quattro system feels almost identical to the older 50/50 torsen subaru AWD systems.
For reference on their channel they have an AWD mini cooper with a similar but reverse setup as BMW xdrive. Front powered with haladex clutch sending power to the rear. Similar to BMWs Xdrive that is RWD and uses a clutch to send power to the front. Point being it's an electronic reactionary system vs a mechanical proactive system. Reactionary systems are tough to predict when your messing around with left foot braking, weight transfer and stuff like that in slick conditions.
Not knocking BMW at all, it's just a different system designed more to get you home than anything else. I imagine after a few hours of sliding around you could overheat the transfer case oil in the xdrive and put it into limp mode.
For what it's worth I'm actually heading back to Team O'Neil Rally school this weekend with the 335 and will have plenty of time to play around with it again. Frankly the Xdrive annoyed me enough that I used Xdelete to turn it off and run it RWD. I've also coded off a lot of the throttle cut and braking systems.
With Blizzak WS90s and 100% RWD it does a great job in the snow and is pretty darn predictable. A rear mechanical LSD would be even better but not sure I want to dive into that.
If I were to do it all over again, I'd just get a RWD and run good snow tires in the winter.
I can confirm 10 min of sliding and burnt out a tcase. Granted it was at 180k and the only fluid I had Not changed upon buying a $1000 06 325xi with solely a valve cover gasket leak lol South Carolina car so maybe the first NY winter it saw. Snagged a junkyard tcase for $300 and been fine since. 186xxx and I beat The piss out of it ¯\_(ツ)_/¯ (auto trans unfortunately, but for a g? I’ll take it)
      08-17-2023, 12:25 PM   #71
MechEngineer
Drives: M235i xdrive
Sorry to revive an old post, did you ever get this LSD installed? And this was for the front differential?
      03-13-2024, 12:14 PM   #72
jackalz9
jackalz9's Avatar
Drives: 2011 BMW 335i xdrive
Originally Posted by nsjames View Post
hold the button in longer for DSC off and it will let you slide sideways in a power slide.
it will not let you do a complete donut. Cuts the throttle about 3/4 the way through.
personally verified in my 08, YMMV depending on whatever.
the only time I've ever felt shudders from my transfercase was on hard surfaces in a tight turn, it had 110K miles on it and had never been serviced.
I changed it's fluid and did the reset and I've never felt it since. Currently at 155k. Two winters.
I don't know why they would feel the clutches engage and disengage, they're already engaged. The system splits 70/30 all the time.
there's currently 2" of slush on the roads and it's all going to freeze tonight.
I will do more testing, for science.
edit:
you know, that guy has a 335, so it's possible that with the aditional horsepower it simply overwhelms the ability of the case to cope, maybe even hits parameters BMW has programmed in to protect it from exploding.
I am a lowly 328.
Sorry to revive an old thread. I’m on my second 335 xdrive. First one was a 2008 with the auto and now I have a 2011 with the manual. I live in Canada and we get some good snow here. I find the car to be very manageable in the snow with great traction (it would make it through 2 feet of snow). Never really experienced any of the transfer case being weird like that and I was able to do really tight donuts. I’ve never driven the Audi but I had an old Subaru Impreza 2.5i and this awd system was definitely better that that one. Driving on the highway doing about 120km/h when I car pulled out in front of me and I went sideways. A little bit of counter steering and throttle and it straightened right out. I’ve also spent many hours in parking lots and back roads for research purposes.
