TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > aFe Intake Fix/Solution | Surging & Power Loss Issues Resolved
      01-21-2013, 12:03 AM   #133
Dylanize
Captain Dutch Rudder
Dylanize's Avatar
204
Drives: AMG
Is this seem to only affect 330i's? I have a 07' 328i.
      01-26-2013, 07:11 AM   #134
eNineZero
eNineZero's Avatar
175
Drives: 2015 328i xDrive
I had a 325i when I came up with the fix. I believe it affects the majority of 325's, 328's, and 330's (3.0L N/A ones).
Alpine White 2015 328i xDrive | H&R Sport Springs | 20" Niche M146 Essen | My Build Thread | Follow me on Instagram: @peternowacki
      01-26-2013, 11:41 AM   #135
Dylanize
Dylanize's Avatar
204
Drives: AMG
Hmm, Cause i just bought an 07' 328i, Installed the afe intake a few days ago. I have not had any of the mentioned issues. It runs great actually, no CEL, no surging. Some shifts are a bit rough, but im sure it will adjust to that after a while.
Did you guys clean your MAF sensor before install? That could have might have been all you needed to do.
No more E92 or E82
      01-26-2013, 12:54 PM   #136
eNineZero
eNineZero's Avatar
175
It seems as though not all cars are effected. But the ones that are need this fix.
Basically there is surging and a lack of power because the computer leans out the air/fuel mixture which is really detrimental to the life of the motor. Even if you don't have surging, your car might be running too lean.
Others have tried cleaning and replacing the MAF and still had issues. It's not the car, it's the design of the AFE intake.
      01-26-2013, 06:40 PM   #137
geyer25
Drives: 2008 BMW 328 xi
If the car is running too lean to hurt the motor then you would definitely get a CEL with a code. I have had the AFE intake on for a few months and haven't had any issues at all. Sounds like a V8 when you romp on it.
      01-29-2013, 06:34 PM   #138
digz
Drives: 2006 325xi
you can see how low the mas sits on the afe. look at your stock and see how much higher it is. once the space went on it ran like new. 325xi does sound sick when you punch it. just wish i could add even more power to the XI....
      01-30-2013, 03:44 AM   #139
Abcd
Drives: 2009 128i
I frequent 1addicts and I saw this spacer come up. How much are they and how do I go about getting one for my 128i? Thanks!
      02-02-2013, 05:08 PM   #140
digz
Drives: 2006 325xi
the best way is to buy one from someone on here or you can have it made from a machinist or who ever works on your car might be able. i would use aluminum it will last longer. check the first post for diagram..i paid $175 installed. look at your stock and see how much higher the MFS sits and then look to see what the difference is. i also had the throttle cleaned.
      02-13-2013, 11:32 AM   #141
Dylanize
Dylanize's Avatar
204
Drives: AMG
So are you saying it would be a good idea to get one of these spacers regardless?
I have a hard time beliving the aFe intake has a critical design flaw like this...
No more E92 or E82
      02-16-2013, 10:59 PM   #142
KiX1911
Blah
KiX1911's Avatar
49
Drives: Awesomeness
Hey guys so iv been looking high and low for the hi temp rtv stuff but cant find it anywhere.
Iv always been using the normal Hi temp stuff but it takes more then 24 hours to cure.
Anything else you guys are using?
      02-18-2013, 02:10 PM   #143
eNineZero
eNineZero's Avatar
175
It does. Very simple, take a stock intake box & tubing and take a look at the positioning of the MAF compared to an Afe Intake. It is quite apparent that the sensor sits way lower in the Afe. When the spacer is installed, all problems go away.
It is not magic!
It's not like Afe is some company with a huge racing heritage. Not much engineering or testing goes into their products, they use the same cookie cutter technique for all cars:
- Create a free flowing intake duct
- Add a high flow filter
- Apply Afe sticker
- Next car
My $.02
      02-18-2013, 02:39 PM   #144
Dylanize
Dylanize's Avatar
204
Drives: AMG
It is not magic!
- Apply Afe sticker
- Next car
My $.02
Alrighty, Well I don't notice any issues,
But if it can only help, Is someone on here still selling these?
No more E92 or E82
      02-18-2013, 05:40 PM   #145
Brian_TII
Drives: 06 e90 330i 6spd
It is not magic!
- Apply Afe sticker
- Next car
My $.02
Amen! Thanks again for posting this fix. My car runs so much better after making a spacer for it. Mine is ugly and made from Delrin but it works perfect.
      02-19-2013, 08:54 PM   #146
Steve Holloran
Drives: bmw 325i 2006
AFE Surging/ Spacer Fix
I too was having the same issue with my BMW 325i 2006 E90, i read the post and had a spacer made. It fixed my problem and the car runs great with lots of power. Thanks for the info
      02-24-2013, 11:12 PM   #147
Cuba
Cuba
Cuba's Avatar
Drives: 07 328xi
anyone know where i can get one of these spacers?
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
      02-25-2013, 07:28 AM   #148
Tim603
Tim603's Avatar
Drives: 2007 335i E90
2007 335i  [0.00]
I've been making them for members if u want one, just pm me
      02-25-2013, 11:19 PM   #149
saiyolang
Drives: 2006 330i
Sent you a PM. Interested to get one of the spacers.
thanks
      02-27-2013, 07:31 PM   #150
Tim603
Tim603's Avatar
2007 335i  [0.00]
pms replied
      04-18-2013, 05:05 PM   #151
jutty61
Drives: 325xi
I'm a new member want to get some posts in so I can PM. I recently bought an Afe intake for my 2006 325xi, and I saw this thread so I decided to also get a custom spacer, so I am looking forward to trying it out.
      04-18-2013, 07:24 PM   #152
kdk2641
Drives: BMW 335i
Why don't you guys get the sealed box afe magnum stage 2 intake? No need to worry about spacer or surging.
Just my .02
      04-18-2013, 08:39 PM   #153
Tim603
Tim603's Avatar
2007 335i  [0.00]
Just my .02
A lot of people get this intake for the sound, the sealed box would be much quieter
      04-18-2013, 09:45 PM   #154
apptwins
apptwins's Avatar
Drives: e90 2006 325xi 6MT
Never a bad idea. Padding the post count is an honorable thing.
I call my spacer the "Tim Shim". Going on 1 year with the system and flawless performance with no fault codes.
Thanks again Tim, hope all is well on your side of the fence.
Cheers-Bill
2006 E90 (early build 11/05) 325xi 6MT Alpine White, DeBadged, Rogue-ICON, stainless brakelines, Power Slot rotors, CDV delete, post-CAT delete, aFe intake+MAF TimShim, LED interior lighting, Escort Passport 8500 x50
afe, issues, power, problems, surging
