TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Photo/Video/Audio Gallery
      01-21-2015, 06:45 AM   #23
Cattivo
FDNY Engine 55
Cattivo's Avatar
Drives: X5M, X5 50i Msport, EscaHoe
LED's look amazing...how hard would it be to revert back to stock if you decide to sell the truck? did you have to cut and splice any harness wires or is it simply just plug and play? I'm looking into doing this mod in the near future since every aftermarket "LED" lights( LUX V4, Cree, even tried bright white halogen PIAA) I've used so far really don't come close to that OEM look I'm after
      01-22-2015, 03:23 PM   #24
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
There is no cutting and/or splicing required for this retrofit. All is accomplished with harness, which you can just remove when you want to reverse it back to a factory original. In my case, I plan to keep the car for a while; therefore I am not planning to put the old (original) lights back in. Extremely happy with results of this retrofit and how smoothly it all went. After LED light, I cannot even drive another vehicle at night with xenon yellow lights.
      01-22-2015, 11:11 PM   #25
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
The LEDs look so much brighter in person. I like the light temperature
      01-23-2015, 04:59 AM   #26
Cattivo
FDNY Engine 55
Cattivo's Avatar
I went by my BMW certified indy shop to find out how much the conversion would cost me and was quoted just over $4k...they said it takes around a month to get the new harness from Germany...I also found out while I was admiring them working on a Lambo, they have a water solution machine so my ugly brown wood trim will soon be either piano black or cf
      01-23-2015, 10:49 AM   #27
igorbmwx6
igorbmwx6's Avatar
Piano black is the way to go, that's what I have in my X6M Also, I hope that $4k includes parts and labor, not just labor ...
      01-23-2015, 10:54 AM   #28
igorbmwx6
igorbmwx6's Avatar
They do look much brighter in person. Drivers in on-coming vehicles think that I have high-beams on, when I do not. They have not seen high-beams yet
      01-23-2015, 01:04 PM   #29
Cattivo
FDNY Engine 55
Cattivo's Avatar
Yea the $4k includes all parts and the coding to post 4/11...I would of done this on my own but I don't know coding
      01-23-2015, 04:40 PM   #30
UnicornM
UnicornM's Avatar
388
Drives: M
I've been followed and had on coming cars with LED headlamps.
I'll be the first here to admit they take the term 'dazzling' to new heights. Not cool for others around you.
Still, I wouldn't say no to having them
      01-24-2015, 02:03 PM   #31
igorbmwx6
igorbmwx6's Avatar
I guess that it is all a matter of preference. Once you've driven for long periods of time at night with LED headlights, you will never go back to the old yellow Xenons again. If you've never driven with LEDs, then you are fine. "Once you go LED, you don't go back"
      01-24-2015, 02:05 PM   #32
igorbmwx6
igorbmwx6's Avatar
$4k for parts, installation and coding is very reasonable. Go for it. As I have mentioned earlier, it is all plug and if needed, unplug type of retrofit. Therefore, you will always be able to reverse it and go back to the original lights.
      01-25-2015, 10:23 AM   #33
Cattivo
FDNY Engine 55
Cattivo's Avatar
I guess that it is all a matter of preference. Once you've driven for long periods of time at night with LED headlights, you will never go back to the old yellow Xeons again. If you've never driven with LEDs, then you are fine. "Once you go LED, you don't go back"
The main reason I want this mod done is...looks obviously and coming from my 2011 335 with LED headlights its exactly like you said...night time driving with LED's compared to Xenons is literally night and day, the LED's really illuminate the road with true bright white light
      01-30-2015, 10:07 AM   #34
UnicornM
UnicornM's Avatar
388
Drives: M
I'm getting tempted to do this retrofit. I've got all the pieces to do X5M front and rear conversion on my X5 35D., will be in the body shop in 2 weeks. My car didn't originally come with Xenon lights (halogen) I've looked up the wiring via WDS and have the wiring figured to retrofit X5M/X6 headlights to my car with bit of coding on the FRM2.
Anyone forsee anything else I would need apart from the list below to retrofit the LED headlamps?
- Left LED light with modules
- Right LED light with modules
- FRM3 module
- Wire harness
      02-01-2015, 10:53 PM   #35
igorbmwx6
igorbmwx6's Avatar
- FRM3 module
- Wire harness
Other than coding after the physical installation, that is all that you will need to complete this retrofit.
      02-03-2015, 02:51 AM   #36
jiudia
China
Drives: X1
Gorgeous. The headlights are awesome.
      02-20-2015, 04:45 PM   #37
PARTS@STBMW
PARTS@STBMW's Avatar
2702
Drives: BMW
Headlights, tail lights, interior lights, license plate lights - all LED now
Perfect, just perfect!
      02-21-2015, 01:28 AM   #38
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1050
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
This is on my to do list.
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      03-06-2015, 08:18 PM   #39
gixxerboy63
1050
2017 m4  [0.00]
PM sent...
Do the LED headlights on 2013 X5s have the same shape as the 2010 X6M and X5M?
      03-07-2015, 10:25 AM   #40
empwrd
Drives: 2012 Bmw X5m
nope... only x6
      03-08-2015, 08:05 PM   #41
gixxerboy63
1050
2017 m4  [0.00]
Originally Posted by empwrd View Post
nope... only x6
Are you talking Base X- headlights?
X5M X6M obviously have different fenders than a regular x_ and the headlights are pointed instead of rounded at the fender....
I was just wondering if they all became pointed at some point (no pun intended) in 2013 or 2014?
      03-08-2015, 08:54 PM   #42
Kerrazy
Drives: X6M
Ignore long time no talk to, glad you're enjoying your LED conversion. Once installed with the new upgrade does your auto high beam function work?
Thx.
      03-09-2015, 07:51 AM   #43
HPIA4v2
Drives: F80, F86
Igor, I've got question on removing headlights.
you have to take off the front fender right, but to do so do you have to take the running board as well?
Thanks.
The LED headlights look awesome BTW.
      03-20-2015, 11:01 AM   #44
Sim-Sima
Wider is Better
Drives: 2007 E70 X5 4.8i
Can you please provide link for the wiring harness. I am doing this retrofit on my 2007 E70 4.8I. I already knew about the FRM3 module but didnt know about the LED module. Does that replace amother module, or is that new addition, if so should there be a harness pre-wired? Thanks
headlights, led, tail lights, x6m
xbimmers
