BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - Homelink Retrofit (post production 09/06 without vehicle option #430 or #431)
      10-22-2010, 06:22 PM   #45
AndyM
AndyM's Avatar
134
Drives:
Originally Posted by tylerdurdon View Post
Quick question if anyone still reads this thread. I purchased the upgraded mirror on e-bay and installed it without realizing I would have to do a wiring retrofit. (just ordered the kit from Evan)
My question is this: Does anyone know if the clown-nose should operate without the retrofit being done? When I plugged in the new mirror, nothing worked (the compass/dim/homelink shouldn’t have)...not even the clown-nose (I installed the alarm). Does it work after the retrofit or should it have been blinking beforehand at least?
On my 135i, the wiring was different between the non-autodim mirror and the autodim one so nothing would work without the retrofit kit.
      10-23-2010, 12:05 AM   #46
tylerdurdon
tylerdurdon's Avatar
22
Drives: BMW 335i
But afterwards everything was kosher?
      10-23-2010, 07:24 AM   #47
AndyM
AndyM's Avatar
134
Drives:
Once the retrofit kit was installed, everything was fine.
      10-23-2010, 09:27 AM   #48
tylerdurdon
22
Drives: BMW 335i
Much appreciated
      10-31-2010, 01:04 PM   #49
gadgio
France
Drives: 335D (E90)
Hello!
I'm from France and I saw that the Homelink is not the same in Europe than in US.
Do you know if a software flash is possible?
Because here it's impossible to find a mirror with homelink (except at my BM dealer and it's very expensive).
Thanks in advance!
      10-31-2010, 06:38 PM   #50
tylerdurdon
22
Drives: BMW 335i
Originally Posted by gadgio View Post
Hello!
Thanks in advance!
Hey hey! The homelink upgrade does not require a software flash. There is a difference in the wiring, but both versions (EU & US) are in the PDF on page 1.
I'm not sure if you need the same wiring harness as we do, but studying the instructions, you should be able to tell if you can use the same one (the added wiring harness for the upgrade).
Good luck!
      11-01-2010, 03:41 AM   #51
gadgio
France
Drives: 335D (E90)
Sorry for my english there is a misunderstanding.
I've understood that the retrofit itself doesn't not require a software flash of the car.
But there is differences between US homelink and Europe one.
My question is : do you know these differences? (hard or soft) and if it's possible to easily switch from a US Homelink to and Europe Homelink.
Thanks!
      02-23-2012, 12:20 PM   #52
gizmo335i
gizmo335i's Avatar
Drives: 07 SBM E92 335i 6MT
2007 E92 335i  [9.42]
Subscribed
In the process of restoring an 07 335i
      10-29-2012, 12:31 AM   #53
MysticblueX3
36
Drives: 135i
Does anyone have the wiring diagram for the mirror side? I recently purchased a auto dim mirror with homelink but it didn't come with a connector. The mirror just have 9 wires coming out of it. I was able to use the connector from my old mirror but don't know which color wire goes where? Again this is the female connector on the mirror side.
Red
White/Black
Green
Orange
Brown
Purple
Grey
Black
White
      05-12-2013, 12:28 AM   #54
cpe90
nemo
cpe90's Avatar
Drives: 2008 328i
2008 E90 Sedan  [0.00]
Is there a chance to get the picture and pdf reposted again in here, guys?
This summer I finally would like to do the DIY after my car warranty is out.
Thanks!!
      05-13-2013, 07:53 PM   #55
jasonn
JDM Slut
jasonn's Avatar
Drives: 07 e90 335i
Thanks!!
yeah sure np
find it attached herein
snohman RIP
      05-24-2013, 06:13 PM   #56
cpe90
nemo
cpe90's Avatar
Drives: 2008 328i
THANKS!!!
      09-12-2015, 12:37 PM   #57
Pilot1981
Pilot1981's Avatar
Italy
Drives: Bmw 320d xdrive lci
Hi,
I have #430 and #431 option.
Anyone could suggest howto retrofit homelink?
I have to replace entire rear view?
There isn't only homelink button retrofits?
e90 homelink, garage door opener, homelink, homelink retrofit, retrofit
