The Tire Rack
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Lighting / Electronics / Audio / Security > LuxAngelEyes ˃˃ LUX H8 Angel Eyes, Version 3.0
      02-10-2011, 11:13 AM   #111
LuxAngelEyes
LuxAngelEyes's Avatar
Drives: BMW
Originally Posted by rob_h10 View Post
i currently have weisslicht installed (with the unequal length v-shaped arms).. either i installed incorrectly or the LEDs are not bright enough to evenly 'light up' the rings..
They might be installed correctly, but double check first. It will be hard to see those during the daytime still since they are not nearly as bright as the LUX H8's
PM me please.
thanks,
rob_h10
On its way.
Originally Posted by teknostar View Post
pre order payment sent
thanks!
Thank you!
      02-10-2011, 02:57 PM   #112
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Even when the Weisslichts are installed properly - they aren't that brite (get washed out in the daylight) & the AE's are never gonna be lit up evenly due to the design (even with the LUX - but they are much better)
From my experience (trials) on my E92:
Factory Halogen --> well we all know they suck
GP Thunder V2.0 8500K Xenon Platinum White Halogen
12V/35W 'HID Look' Halogen - yielding 60W
  • Daytime Vis: Not much better than stock
  • Nighttime Vis: Better than stock, but not great
  • Even Distribution: NO - same as stock
  • Pros: Can change color with different K values, EZ install, cheap pricing
  • Cons: Poor daytime vis, uneven distribution
MTEC 4750 Cosmos Blue White Halogen
12V/35W 'HID Look' Halogen - yielding 65W
  • Daytime Vis: Not much better than stock or GP Thunder
  • Nighttime Vis: Better than stock, slightly better than GP Thunder but not great
  • Pros: Can change color with different K values & I particularly liked the color of these, EZ install, cheap pricing
Weisslicht LED v1.0
(2) LED 12V/??W Emitters
  • Daytime Vis: Better than all above so far, but not spectacular
  • Nighttime Vis: Better than all above so far, but not spectacular
  • Even Distribution: Slightly better than stock due to design
  • Pros: Low power consumption, no errors or flickering, cheaper pricing for LED AE variants
  • Cons: PITA to install, still uneven distribution, I had DS LED go out after 2 weeks and had to go thru warranty replacement
LUX H8 LED v2.0
Multiple LED 12V/??W Emitters
  • Daytime Vis: Actually fairly good - best so far
  • Nighttime Vis: Great - better than all so far
  • Even Distribution: Best of all so far due to design
  • Pros: Fairly EZ install, good daytime vis, great nighttime vis, best dist so far, low power consumption, no errors or flickering
  • Cons: Could not run power supply internal to headlamp housing as originally designed due to overheating, pricing a little high for some folks
NOTE: these are purely my opinions/observations based on my personal experience. I didn't bother to take comparsion pics because it is fairly difficult to set correct exposure to accurately compare - viewing by eye is better, & it is too easy to sway results toward one or the other based on the angle of the pic when taken.
>> I actually have a new set of Alpine 8000K True HID AE's waiting to install to compare, but haven't been able to get to them due to weather. From all reports & pics they will be the brightest of all during daytime & nighttime - maybe a little too bright during nightime for people's tastes.
I can say that their harness is very professionally done and the HID capsules they use are hi quality versions that run cooler than normal HID capsules.
>> Gonna pick up a set of the new LUX H8 v3.0's also - I would expect the same great performance as the v2.0's, but with the added convenience of internal mounting of power supplies due to even higher quality units
I am also going to turn in my v2.0's for conversion to v3.0's, but they are already sold to a buddy...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      02-10-2011, 03:32 PM   #113
InsanePineapple
Shenanigans
InsanePineapple's Avatar
Drives: See Signature
Thanks for the review 1QuikWS6, very informative!
      02-10-2011, 11:07 PM   #114
Pons1012
13
Drives: 2007 E92 328xi
I want to pre-order
Marc sent you an e-mail on the site since I cant PM yet. Please let me know the info at Pons1012@hotmail.com and I will send payment in the AM. Thanks!
      02-10-2011, 11:31 PM   #115
01 IGY
Australia
Drives: 2009 E92 335i M-Sport DCT
So we can start ordering these now?
      02-10-2011, 11:32 PM   #116
LuxAngelEyes
Drives: BMW
1QuikWS6 - Thank you for the review and it contains a lot of good information for everyone here.
for the LUX H8 V2 you had a couple negative things, which hopefully all of those have been addressed and fixed in this new version. Thanks again
Please PM me for the information. Thank you
      02-11-2011, 01:32 AM   #117
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Well, it was no offense Marc, I just tried to be objective & report both the good and the not so good observations from all I tested.
Out of all I actually installed, the LUX was still the best hands down - and I wouldn't be ordering another set if I didn't like the 1st set
      02-11-2011, 10:54 AM   #118
WWONG
Drives: 2012 BMW X5 xDrive35d
Product Compatibility: Cars and models that NEED to be tested still:
• X6 - E71
• Z4 - E85
• 6 Series LCI - E60
• 7 Series - E65
E60 = 5 Series
      02-11-2011, 10:58 AM   #119
LuxAngelEyes
Drives: BMW
Originally Posted by WWONG View Post
E60 = 5 Series
[/INDENT]
OOps. updated and fixed. Thank you
      02-11-2011, 02:56 PM   #120
belal242
belal242's Avatar
32
Drives: 11 F10 550xi
2011 550xi  [0.00]
I want to pre order but dont see the option
      02-11-2011, 02:58 PM   #121
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
You have to PM a request for the pre-order info from LuxAngelEyes
      02-12-2011, 03:21 AM   #122
01 IGY
Australia
PM sent.
      02-12-2011, 08:21 AM   #123
jster
Drives: E92
Pre-order payment sent!!
      02-12-2011, 11:23 PM   #124
01stang
01stang's Avatar
Drives: E92
I pm you for info for the pre order can u pm me
Mods: Black out kidney grill, 6000k d1s, 6500k foglight, mtech angel eyes and cornering light, m6 reps, m3 tri color steering wheel, somewhat matching shift boot and brake boot, led lisence plate, led interior, led rear signal, led side marker, aero front lip, cf emblem overlay
      02-13-2011, 11:23 AM   #125
TiAg335i
Trance Life
TiAg335i's Avatar
Drives: 2007 E92 335i
Are these still shipping in March?
      02-13-2011, 07:48 PM   #126
LuxAngelEyes
Drives: BMW
Replied to your PM
Yes the expected shipping date is still 3/1/11
      02-13-2011, 08:14 PM   #127
Universal_Magnetic
Universal_Magnetic's Avatar
34
Drives: E92 335xi
pm me price shipped to Toronto, Ontario, Canada.
BMS E92 335xi | PROcede | K&N | KW | VMR | LUX | Bastuck |
      02-13-2011, 08:35 PM   #128
LuxAngelEyes
Drives: BMW
http://www.e90post.com/forums/showpo...82&postcount=1
Please read Post #1
      02-14-2011, 09:41 AM   #129
MyE92
El Presidente
MyE92's Avatar
Drives: your mom wild.
Marc, any way I can come pick these up sooner than March. Maybe I can get Matt and Scott to go with me, and we can have a little meet up in CT.
-Ryan
      02-14-2011, 09:54 AM   #130
LuxAngelEyes
Drives: BMW
-Ryan
Hey Ryan,
Well the last of my parts are going to be shipped to me this week, so it will take me some time to even get them built. I'm expecting to have them built by 3/1/11 but i dont think they will be ready much before then. If you want to take a ride up with Matt and Scott though i'd say definately - we can all go out and grab some food and hang out for a while!
      02-14-2011, 01:41 PM   #131
MyE92
El Presidente
MyE92's Avatar
Hey Ryan,
Sounds good. I'll definitely try to set something up with Matt and Scott and try and figure out when we can head up there. I'll keep you posted.
      02-14-2011, 03:12 PM   #132
huyner328
Former N54 Fanatic
84
Drives: Slow
PM me please, would like to pre-order.
angel eye, lux, lux h8
