04-01-2021, 01:35 PM | #111 |
Save the Manuals
1714
Rep 2,937
Burble tunes 🙄🙄
great way to ignite the rear of your car
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
Assimilator1595.50 |
04-01-2021, 04:59 PM | #112 |
Rep 404
As usual, no OEM is insane enough to take it as far as the aftermarket does. OE burbles/pops/bangs are rarely much louder than the rest of the exhaust, and I don't think any other than Lamborghini will shoot flames stock.
04-05-2021, 03:22 PM | #113 |
1949
Rep 1,908
Drives: E92 M3
04-05-2021, 04:57 PM | #114 |
General
63992
Rep 24,844
Mate . You nailed it ...
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
Assimilator1595.50 DrFerry6731.50 |
09-13-2023, 12:07 PM | #115 |
28
Rep 149
09-13-2023, 04:15 PM | #116 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
So 5 years have gone by since your B.E. bearing spun. I read the whole thread and am still wanting to know, "did a main bearing fail or not?"
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
09-13-2023, 04:52 PM | #117 |
Rep 1,040
Drives: BMW M3 e92 08 & 330d e90 10
Same!
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
02-27-2024, 03:04 PM | #118 | |
Rep 1,040
Did you ever hear back from the buyer about your old engine?
I belatedly noticed this ad (after I'd PM'd him) by him for the old engine parts. He states there and in the PM that the mains had indeed failed. Quote:
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 02-27-2024 at 03:32 PM.. |
DrFerry6731.50 |
02-27-2024, 03:25 PM | #119 |
Rep 1,040
Updated my previous message.
02-29-2024, 12:22 PM | #120 |
104
Rep 304
I wonder how many engines had failed main bearings after fitting the larger clearance rod bearings?
charliev68204.50 |
02-29-2024, 03:04 PM | #121 |
205
Rep 205
03-03-2024, 10:17 PM | #122 |
2631
Rep 2,142
Drives: 2011 E92 M3
You change them again? If so, how did they look?
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
03-03-2024, 10:20 PM | #123 | |
2631
Rep 2,142
Drives: 2011 E92 M3
Also, all of the oil that goes to the rod has to go through the mains.
RocketyMan230.50 Assimilator1595.50 |
03-04-2024, 03:08 AM | #124 | |
104
Rep 304
Didn't BE measure and report a drop in oil pressure when running with extra clearance bearings? Or have they since edited the original report to remove it. Dropping the pressure at the rod bearings will have an effect on the upstream pressure at the mains. Increasing the flow to offset the drop in pressure at the rod bearings carries its own problems. Last edited by Sneaky Pete; 03-06-2024 at 03:16 AM.. |
charliev68204.50 |
03-04-2024, 04:59 PM | #125 |
Rep 8,077
Drives: 11 E90 M3 Individual
Have not. Forgot I made this empty promise. But I swear…I’m getting close. I’m at 107k now. Making arrangements to do this and bunch of stuff in Apr/May/Jun.
2018 F30 320iX Melbourne Red
Scharbag2631.00 |
03-13-2024, 02:40 PM | #126 | |
Rep 1,040
If not, their data shows (from memory) just a 3-4% drop in pressure. The rod bearings are up stream of the mains, not the other way around (maybe you just typo'd?). I don't see that increasing the flow (to compensate for faster oil loss at the rod bearings) would cause any problems, other than quicker removal of heat. What problems do you think it could cause? Very few, literally just a few, which is far fewer than the engines that have failed with OEM rod bearings.
03-13-2024, 05:47 PM | #127 | ||
104
Rep 304
Didn't they just have a flow/pressure meter after the oil filter? Not exactly that much use in measuring oil pressure at the bearings themselves. Quote:
Anyway lost interest in this story now...I can see that folk still want to believe the too tight RB clearance even now. So I'll leave you all to carry on...much to the relief of some people no doubt. |
charliev68204.50 |
03-13-2024, 09:42 PM | #128 |
Rep 10,373
Sreten from M539 Restorations mentioned during his S65 rebuild that the timing chain pulls up on the crank and consequently causes more wear on that main bearing and the wear decreases are you move down the line.
He pulled the mains on a S65 and you could see a reduction in wear moving from front to back.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
03-14-2024, 04:12 AM | #129 | |
Rep 7,123
Btw bumped into another main fail here, VAC non extended RBs in this case (who later upgraded donor engine with VAC again). https://youtu.be/4be6Dyu_990?si=CdkwbP-jlp2GcqOw |
F32Fleet3606.00 Assimilator1595.50 |
03-16-2024, 03:48 PM | #130 | |
Rep 1,040
I can't see anyone being able to measure pressure at the main bearings, maybe BMW if they tapped into the oil feed to a mains?? Whatever the oil pressure is in the main oil gallery will be what it is at the mains oil feed (near enough). I'm pretty sure that their are individual oil feeds for each main bearing (same with pretty much any modern-ish engine AFAIK), each main bearing then goes onto feed a pair of rod bearings. So their would not be less flow to the mains as the rod bearings are in series to the mains (and after), not parallel. If the oil pump couldn't keep up with the increased flow at the rod bearings, then yes pressure would drop at the mains (& throughout the system). But that isn't the case with BE v1, bar a few %. Btw, FWIW, I think the case for too tight clearances has been weakened, but not written off yet. Bearing in mind that Mahle MS bearings have increased clearance anyway. But the corrosion damage to bearings definitely warrants more thought and investigation (something that could be done with oil analysis).
03-16-2024, 09:36 PM | #132 |
Rep 1,040
Yea AFAIK it does, but by a miniscule amount, IIRC 2-3 microns.
charliev68204.50 |
