BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
EXXEL Distributions
      06-04-2021, 11:15 AM   #45
Silos
Silos's Avatar
556
Drives: M2 Comp
Originally Posted by mrvedit View Post
Wow ProTool sounds like a fantastic easy-to-use alternative to NCSExpert; too bad it is only for Android phones. I haven't used NCSExpert in 10 years; not looking forward to learning it again.
you can find a Samsung tablet for like $100 new, it can double as gauge/data logging.
      06-04-2021, 08:11 PM   #46
mrvedit
48
Drives: 2013 M3
Thanks for the suggestion. I have at least one such tablet lying around; it may be too old for the software, but even new ones are cheap.
Hopefully I will be able to use my OBDLink MX+ OBD2 Bluetooth adapter which I bought for BimmerCode.
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater)
1981 Camaro Z28 - 427 LS3 - 10.94 @126mph
2006 Corvette (streetable track car)
1986 535i "24 Hours of Lemons" also streetable
Silos555.50
      08-18-2021, 08:46 AM   #47
CAMBO_M3
CAMBO_M3's Avatar
Drives: E90 M3, E70 X5D
Just use ProTool - I was able to code out the light for my seats with it.
Yo, i put in recaros yesterday and my ocd is driving me insane.
opened up protools and followed some forum directions... still have these codes popping up and my warnings.
Now my seatbelt light wont turn off and its plugged in.
note that its only the driver side installed. the passenger is still stock!
      08-18-2021, 10:54 AM   #48
Silos
Silos's Avatar
556
Drives: M2 Comp
These are the codes you want to disable (for left and driver side only). As for the belt, if you used the stock buckle, you can remove the plug from the stock seat harness and plug it directly to the harness in the car - that is what I did. You will be able to search for the codes in their search bar.
SIDEBAG_LINKS_1 -Side Airbag (left)
SIDEBAG_RECHTS_1 -Side Airbag (right)
AKS_LINKS_1_CD -Active head restraint (left)
AKS_RECHTS_1_CD -Active head restraint (right)
OC3_1 -Seat occupancy mat
GK/OC3/POL -Not sure exactly but related to the occupancy mat
GURTKONTAKT_BEIFAHRER_1 -Seat belt contract/connection (passenger)
GURTKONTAKT_FAHRER_1 -Seat belt contract/connection (driver)
GURTSTRAFFER_BEIFAHRER_1 -Seat belt tensioner, active restraint (passenger)
GURTSTRAFFER_FAHRER_1 -Seat belt tensioner, active restraint (driver)
SPSBF_1 -Seat position sensor (passenger)
SPSF_1_CD -Seat position sensor (driver)
      08-29-2021, 05:39 PM   #49
mrvedit
48
Drives: 2013 M3
With some effort using ProTools, I now have both seats in my 2013 M3 disconnected and no codes.
It required one non-obvious step. (See below)
1. I first disabled all the mentioned codes which in ProTools are found under Safety->Airbags->Coding->Expert->Equipment.
(The search only works when you are in the correct category.)
Upon saving the changes I of course got the Airbag light.
2. I then shut off and disconnected the seats.
3. Unfortunately I still got the Airbag light and codes 93BF, 93AE, 93AF; the last two are the Active head restraint codes. I double-checked that AKS_LINKS_1_CD and AKS-RECHTS_1_CD were disabled and they were.
4. Next I added RECA to the VO. In ProTools this is under Vehicle->Vehicle Order->Edit->Options. I saved that, restarted, but still got the Airbag light.
When I added RECA and saved it, ProTools noted that this changes factory settings in both Airbags and Footwell module and asked if I wanted to change those to the factory settings. Since I didn't want my Airbag settings changed again I declined.
5. SOLUTION - I went back to the VO in ProTools, disabled and re-enabled RECA and it again asked if I wanted to change Airbags and Footwell to factory settings. This time I unchecked Airbags, but left Footwell checked and selected "Re-Code". Seconds later the Airbag light turned off and it stayed off after a restart.
So, it appears there is another code in the Footwell module which I (we?) don't know about. At least on a 2013 M3. That might be why the OP had success by adding +RECA.
Sorry, I don't know if ProTools would have correctly disabled the relevant Airbag settings for +RECA if I had let it.
Thanks to everyone; I could not have done it without the info in this thread.
dozaiya236.00
      09-29-2021, 02:15 AM   #50
kyippee
kyippee's Avatar
Drives: E92 M3, Supra MK5, F44 235GC
Thank you - this helped a lot. Already had my driver seat swapped and coded remotely by a tuner to get rid of errors. Removed my passenger seat as well now, and got a bunch of new errors. I went through the items in your list, ignored the driver-specific ones and now the errors are gone. Did it with Bimmergeeks protool
Silos555.50
      11-08-2021, 08:57 AM   #51
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I'm not trying to install a race seat, but some really good info in this thread and I am hoping someone can point me in the right direction to get my issues sorted out. I just swapped fox red seats into my 2013 E93 (convertible) and the issue I am having is the replacement seats came from a 2008 donor car. 2008 cars did not have the active head restraint system, so I was told all I had to do was to code the headrest restraint out for both front seats and I should be good. Let me also add in that the fox red drivers seat also had a deployed side airbag when I purchased it.
To begin I replaced the side airbag in the drivers seat and also learned that I needed to replace the seat belt receptacle (tensioner). I replaced that as well. The airbag in the passenger seat did not deploy, so I left that seat belt tensioner in place. I had a remote coder code out the active headrest restraint system using Tool32, but we were unable to clear the airbag restraint system errors. He also tried INPA with no success.
I brought the car to a local shop that has ISTA and he is saying that both seats are still showing a seat belt tensioner fault. This is weird as I swapped the seat belt tensioner from my fully functioning 2013 drivers seat, so I am 100% sure it was not "blown". Now the car has an additional 2nd harness (in addition to the large seat harness) that plugged into the original seat, which the replacement 2008 seats does not have. I was assuming this harness was for the active restraint system, but maybe it has something else in the harness as well that needs to be connected. Right now I just have it disconnected because the new seat does not have anywhere to plug it into, but perhaps this is causing the issue? Here is a picture of this second harness on the original 2013 seat.
Any guidance you can provide would be greatly appreciated as my car is now overdue for state inspection and it won't pass with this fault error. Thanks for reading!
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      11-25-2021, 12:03 AM   #52
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
With protool is adding RECA to the VO sufficient? I will be removing the pretentioner as well.
      12-07-2021, 10:21 AM   #53
mrvedit
48
Drives: 2013 M3
I experimented by restoring all settings back to stock and then just selecting RECA, but it was not quite enough. I don't recall which settings were missing for race seats, but a few still had to be changed in addition to RECA.
      12-07-2021, 11:01 AM   #54
roastbeef
roastbeef's Avatar
Drives: E92 M3
Good thread.
Instagram; @roastbeefmike
derbo3610.00
      02-23-2022, 03:55 PM   #55
stevejin
@sugu.m3
stevejin's Avatar
48
Drives: E90 M3, G05 X5, AP2 S2000
Bumping this thread since I'll be tackling this myself within the next couple of weeks.
Just to get myself prepared for installing a pair of Recaros and coding the parameters, I wanted to see if anyone who's done this successfully via NCS Expert or ProTools could give me some guidance:
1. Does the coding (listed by the OP) need to be performed prior to taking the stock seats out?
2. Do all of the connectors under the seat stay disconnected after the aftermarket seats are installed, even though I'll be keeping the stock 3-point seat belts?
Thanks in advance!
      02-23-2022, 09:37 PM   #56
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Thanks in advance!
1. No.
2. Disassemble the yellow plug and plug in the factory seatbelt buckle pretensioner if you are retaining the 3pt and don't code the pretensioner out.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      02-23-2022, 09:49 PM   #57
stevejin
@sugu.m3
stevejin's Avatar
48
Originally Posted by derbo View Post
1. No.
Thanks for the clarification!
      07-22-2022, 05:55 PM   #58
joeyzou
joeyzou's Avatar
China
Drives: bmw e93 m3
2009 bmw m3  [0.00]
good
      10-10-2022, 02:18 PM   #59
Jphud
Drives: BMW 335d coupe
Evening all. I have swapped my bmw e92 335i sests to bmw f80 m3 seats. My car is pre lci but an 09 plate the seats have the white module required to retro fit into an e92.
As expected when I turned the engine on I got all the codes listed above.
I have pro tool and tried to code out but no luck at all. Emailed their support team who have given advice which covered some of the options above.
I'm unclear though am I meant to unplug the sests then code or leave connected.??
No matter what I do the lights persist and I can not clear the codes.
Any help advice or pointers welcome.thanks.
      10-14-2022, 02:37 PM   #60
mrvedit
48
Drives: 2013 M3
As I mentioned in my post #49, I successfully disabled all codes on my 2013 M3 Coupe.
I repeated the process on a friend's 2010 M3 Coupe, but the seat belt giver/extender arms (or whatever they are called) still try to move out when starting the car.
Anybody know what coding it takes to turn this off?
UPDATE - I figure it out. Thanks to info here:
https://www.e90post.com/forums/showthread.php?t=1610796
In ProTools, it is under
FRM->Coding->Expert->Automatic seat belt hand-over
Then disable ENABLE_GURTBRINGER_FA, ENABLE_GURTBRINGER_BF, GB-TRIGGER_KL_R AND Gb-TRIGGER_KL_15.
The last 2 might not be needed, but this is what worked for me.
      04-17-2023, 11:58 AM   #61
kerrit
Drives: Melbourne Red e90 M3
2008 E90 M3  [0.00]
2014 M5 CP  [0.00]
Originally Posted by Bartledoo View Post
Thanks for the info on this. Was very quick and easy. Added the +reca to both CAS and NFRM and the edited the ABG coding as in the OP.
+1, this worked well for me.
6MT | 11:1 Forged 4.1L | ESS-G1 | KW ClubSport | Sparta 380/355 BBK
      04-23-2023, 11:41 PM   #62
gh0stE92M3
gh0stE92M3's Avatar
Drives: BMW E92 M3
Okay so I installed my driver side bucket and retained the oem seat belt receptacle. I coded everything minus the passenger stuff, I’m still getting the airbag light. I also did the +reca in the vo.
So weird thing now is that when I did the ignition cycle my headlights to this weird check lights and drl flashing alternating left and right and saying malfunction on the cic after check is done. It’s never done that before.
Can someone shed some light here please? My tablet was running out of juice so I’m waiting for it to charge and I’ll go back out there and check the frm and see what’s up with the lights.
But I’ve flashed everything back to factory coding for the airbag module and vo.
Also I have the seat belt receptacle plugged into the car harness. I’ve read on here that keeping that unplugged worked for some. I’d want to keep it plug in and working since I’m gonna be using it.
Thanks in advance for the assistance.
      08-17-2023, 11:02 PM   #63
71velle
71velle's Avatar
Drives: f30 bmw
Can the seat airbags be coded out with bimmercode?
      08-25-2023, 12:43 AM   #64
san40k
21
Drives: 2008 E90 335i N54 6MT
coding out airbag errors on E90 335i with race seats
This thread was tremendously helpful, thank you rocket_science !
I got a 2008 E90 335i "track" sedan with Racetech buckets and 6 point harness. I kept oem front seat belts and tensioners for the street. Front tensioner cable is plugged to the socket under the seat. Rear seat tensioners removed.
My experience
- I did not code VO (+RECA), didn't want to re-code all the modules
- I only succeeded if I coded against FRM ECU (not CAS), writing to CAS didn't error, but didn't take any effect - stumbled me for a while
- I changed the following to nicht_aktiv via NCS Expert/NCS Dummy following instructions from LMB335IS
, in order they appear in FSW_PSW.TRC:
CC_GURTWARNUNG_1
GURTSTRAFFER_FONDLINKS_1
GURTSTRAFFER_FONDRECHTS_1
OC3_1
SBR_FAHRER_1
SIDEBAG_LINKS_1
SIDEBAG_RECHTS_1
GK/OC3/POL
AACN_1
O_GW_F_1
SBR_BEIFAHRER_2_CD
This might be too much, but I tried to match parameters in my car with original post and additionally disable rear tensioners. No airbag errors/warnings on the dash at the moment.
Below is the whole NCS Dummy export from airbag module (ABG) after the changes were applied.
      12-22-2023, 10:55 AM   #65
Jerezblack.m3
Jerezblack.m3's Avatar
149
Drives: BMW E92 M3
the car is still showing an airbag error but I changed everything to not active. am I missing something?
did it at FRM
here are the codes showing up on INPA
93AA - seatbelt tensioner, passenger
93BA - seatbelt-catch contact, driver
93A9 - belt tensioner, driver
93AD - side airbag, right
93C3 - seat occupancy, passenger
      12-26-2023, 04:40 PM   #66
san40k
21
Go through every module (ie airbag, dsc) and clear all existing errors.
amg6975500.00
m3post
