      02-03-2017, 01:20 PM   #1
Alcor
Alcor's Avatar
Drives: 135i 2013 DCT
Smile fluid change 135i dct transmission, pentosin vs ravenol
i need to change oil of my gearbox, i need the best fluid, what is the best opcion in your experience ?
RAVENOL:
http://www.ravenol.de/en/products/us...ebe-fluid.html
PENTOSIN:
https://www.ecstuning.com/b-genuine-...r/83220440214/
      02-04-2017, 12:46 AM   #2
Katkarot
29
Drives: 2010MDX 2012135i
Good question as I want to change my DCT fluid as well, but I have not see any DIY guide.
Do you know the steps to to changing the DCT fluid?
      02-04-2017, 05:41 AM   #3
HomoPirate
HomoPirate's Avatar
Drives: Always BMW
Pentosin is the OE DCT fluid for bmw dct. I did my DCT fluid change in dealership so they use genuine bmw DCT fluid which is bmw branded Pentosin and they have to order the fluid because not every dealers have it in stock(They claim it "lifetime"). I would like to stick with Pentosin, there's no reason to try other brands than OE in our DCT.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust |
Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) |
Current: F87 M2 Competition Long Beach Blue | Completely Stock |
Dackelone10588.50
      02-04-2017, 06:36 AM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I think I would go with PENTOSIN since its OE. Never heard of RAVENOL.
You might check with The California Transmission Supply Company... they sell ZF fluid at a reasonable price for the ZF auto gear boxes.
http://www.thectsc.com/catalog/6-speed-bmw-61.html
another ZF place is... Eriksson Industries.
http://www.zftranspart.com/
Dack
      02-04-2017, 11:15 AM   #5
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Few of diys.
http://www.m3post.com/forums/showthread.php?t=746269
http://e89.zpost.com/forums/showthread.php?t=442369
http://www.m3post.com/forums/showthread.php?t=457178
Appreciate 3
Dackelone10588.50
OTN5538.50
lab_rat394.50
      02-05-2017, 01:28 PM   #6
Yeineken
Yeineken's Avatar
Drives: '11 135i M Sport
'11 135i  [8.20]
'16 Ford Hatchback  [0.00]
'15 X5  [10.00]
I used BMW OE Oil. No hiccups.
The first diy posted above is what I used when I did mine. I also replaced all the filters. The suction filter is easy as it just pops out. The pressure filter is a pain with the clamp seal.
I was also able to get away with cleaning my belly pan thoroughly and not messing the gasket up.
Only took an hour or so. I would recommend getting extra oil if you do switch the filters out. They allow more oil to drain out.
Dackelone10588.50
Blu3RSX27.50
      02-06-2017, 08:12 AM   #7
HomoPirate
HomoPirate's Avatar
Drives: Always BMW
Do you put on a new plastic transmission fluid cover during your fluid change? The dealership found my transmission fluid cover has oil seepage/slow leaking so they put on new cover/gasket as well while doing the fluid change.
      02-06-2017, 09:15 AM   #8
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Anything visible in the filter that made it obvious it was a good idea to change it? Did you have to by any gaskets for the pressure filter cover?
      02-06-2017, 09:20 AM   #9
Yeineken
Yeineken's Avatar
'11 135i  [8.20]
'15 X5  [10.00]
I did not put a new cover, you can't buy the gasket separate from the cover. I found no cracks and had no previous leaks so I cleaned it thoroughly and has held up for the past 40k with no leaks.
They were white, a little gunky. The oil was still spotless and still looked new at 55k. However it was just easy daily driving, no track time. The filter comes with a new o-ring similar to engine oil filters.
https://www.ecstuning.com/b-vaico-pa...28107842840kt/
ECS has a kit: https://www.ecstuning.com/b-assemble...3220440214kt1/
      02-06-2017, 09:27 AM   #10
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Oh nice! Thanks brother.
So what did you use to clean the gasket and pan? Just a little dish soap and water? My pan was replaced probably 5k miles ago so I am assuming the gasket is still in good condition. I'm pretty sure the dealership reused the oil in the transmission though, so I'm thinking about servicing it.
      02-06-2017, 11:53 AM   #11
Yeineken
Yeineken's Avatar
'11 135i  [8.20]
'15 X5  [10.00]
Oil wash and finished with carburetor cleaner. I can't remember what brand carburetor cleaner I used. But you want the brand that dries completely via air. No oil residue leftover.
If I venture into the shop I'll tell you the brand. I use it all the time to clean the engine components up and when my OFHG was leaking.
OTN5538.50
      02-08-2017, 10:01 AM   #12
Alcor
Alcor's Avatar
does anyon know how mych oil i need ? 5 or 6 litres ?
      02-08-2017, 10:21 AM   #13
tyhackman15
21
Drives: 2012 AW 135i
How much did you end up using? I have the ECS kit with fluid / filters sitting in the garage, but I'm debating on grabbing another bottle or two if it ends up needing more than 5qts.
One other question on the process, I get the 2k rpms for a minute to pump the fluid through the lines, etc.. But then when you add the additional fluid, is this with the car on at idle in P, or with the car off? Curious to hear from someone who has done it already.
      02-08-2017, 12:31 PM   #14
katsooba
katsooba's Avatar
85
Drives: bmw 135i
i switched to Motul DCTF fluid about 6k miles ago
no issues yet
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
OTN5538.50
      02-08-2017, 03:27 PM   #15
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
no issues yet
Good to know. You drop the pan and replace the filter too? How many quarts did you need? What steps did you follow?
      02-09-2017, 10:07 AM   #16
Alcor
Alcor's Avatar
no issues yet
this is the correct oil ?
this one ? http://articulo.mercadolibre.com.ar/...n-1l-nolin-_JM
      02-13-2017, 10:27 AM   #17
katsooba
katsooba's Avatar
85
Drives: bmw 135i
Alcor, yes this is the fluid i used
houtan, i gave it to my mechanic,
i provided 12 bottles of the Motul DCTF and a DCT bottom filter
he gave me back about 3 bottles, so i am guessing around 9 liters went in
i didnt have time to follow the process, sorry
      02-13-2017, 10:36 AM   #18
Alcor
Alcor's Avatar
9 liters ??? why ecs kit comes only with 5 liters ??
      02-13-2017, 12:29 PM   #19
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Thanks for the info.
      02-18-2017, 03:38 PM   #20
katsooba
katsooba's Avatar
85
Drives: bmw 135i
hi,
my my mechanic did a full fluid replacement, including the cooler lines and oil cooler
he said 9 bottles were used
i gave him 12 got 3 back, so unless he spilled 4 whole bottles on the floor, he used 9 liters.
i will check with him later this week to be sure
      02-22-2017, 09:43 AM   #21
Alcor
Alcor's Avatar
did you check that information ?
hi,
      02-23-2017, 08:32 AM   #22
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
At What mileage is everyone doing the DCT fluids? I'm targeting 55-60k. It sounds like it could go further but my mantra has always been that maintenance is less than repair.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
