BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
Mporium BMW
      04-16-2021, 01:41 PM   #45
M3ANMACHINE
Admiral
M3ANMACHINE's Avatar
Drives: 2011 E90 M3 + 2014 F15 X5
Originally Posted by nyc4runnin View Post
Does this support fast wireless charging ? 15w ?
Not to my knowledge.
2020 FORD RAPTOR
2014 F15 X5 | M-SPORT
SOLD
2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3
      04-16-2021, 07:48 PM   #46
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Thanks for this thread it's been very helpful. I just got the charger and installing now but stuck on the final step of connecting to the 12v lighter (I'm in an e90 as well). Do I only disconnect and connect the bottom piece or both top and bottom? If both, how do I disconnect the top piece?
      04-24-2021, 08:10 PM   #47
punisher12b
32
Drives: 2011 135i
How long did this take to install it looks like the wires are super short so not really feasible to get all the way to the back seat, just reading the instructions
I am highly interested in this. Have an s21+
      04-25-2021, 01:26 AM   #48
M3ANMACHINE
Admiral
Back seat? What are you talking about?
2020 FORD RAPTOR
SOLD
      04-25-2021, 12:46 PM   #49
punisher12b
32
Drives: 2011 135i
then apparently im reading the destructions wrong .... looks like the rear of the center console came off
      04-26-2021, 09:44 AM   #50
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
The install should take 5-15 minutes, remove the upper cover of the center console (which pop off with a trim tool), remove your shifter trim (if needed), unscrew the cigarette tray from the cover, and connect this to the plug that is going into the cigarette lighter.
Reinstall and done. Getting the console cover properly popped back in will probably be the most time consuming part if you haven't done it in the past.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      04-26-2021, 12:07 PM   #51
B8bydesign
B8bydesign's Avatar
Drives: '11 BMW M3
2011 BMW M3  [10.00]
I'm pretty sure the instructions on their website are very outdated. They've made some modifications since then and now it's very easy to install as Cyberdemon posted above.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak
      04-26-2021, 06:19 PM   #52
NascaBmw16
NascaBmw16's Avatar
Drives: M3 E90
wonder if my Samsung galaxy note 9 with supcase will fit 🤔
      06-08-2021, 03:41 PM   #53
cae93
257
Drives: 2013 E93 M3
So I've had mine installed for a while now and I have to say that overall this product has much better feedback on this site than it deserves. Either the performance of some modules is much worse than others, or it's generally "a bit crap".
It's quite nicely made, and given that the adapter from the cigarette lighter socket to the charger is only 15W max output (why? the lighter is capable of waaay more), it is never going to be a fast charger. All of the Qi chargers in my house are much faster.
I've tried mine with:
Iphone 11 : connects but charges very slowly, OK if the phone not in use
Pixel 4 : connected to my radio by BT, does not charge fast enough to keep the phone charged, just slows the discharge down. As this is my main phone this is most disappointing. Also sensitive to which way around the phone is.
Moto edge+ : does not charge, but the phone is huge.
Galaxy S7: charges slowly but probably the best of the ones tried.
Oneplus 9 : does not charge
2013 E93 DCT, Jerez Black "OEM+" : M359's, MPE V2, AFE filter, Stage 1 Alpine, Auto Tecknic paddles, Pedal Haus, PS4's, Smart Top, Mporium undertray, "VRS" style lip, occasionally RW carbon diffuser
      06-12-2021, 10:42 PM   #54
tbuck
tbuck's Avatar
1186
Drives: 2011 E92 M3, 2016 F23 M235i
So far I have found it works fine for all of the phones in my family (iPhone8, iPhone12, S21), in that it charges all of them. None have any problems with location, charges fine turned either way or one end or the other of the pad. Charging speed is not great, as mentioned many times in this and other posts, but for my needs is adequate. The car is not used often or for long distances, so as long as it keeps my phone from discharging while streaming music and what not then I am happy with it. Perhaps at some point they will have an upgraded model, but in my case that would not be needed.
      06-13-2021, 01:28 PM   #55
Cyberdemon
Cyberdemon's Avatar
1538
It's not super fast. But I took a 4 hour cruise with Carplay, GPS and Waze running the whole time and I got back with my iPhone X (with a terribly old battery that gets about 4 hours to a full charge on a good day) mostly charged.
For what its worth, the coil alignment may or may not be a problem on some phones. If I spin my iPhone and it slides too far off to the side, its no longer over the coil so high G turns may knock it around. I can see on the carplay when it's not charging though and I just nudge it a half inch over.
I have an Edge + I haven't tried in the car, but it sounds like you might be dealing with alignment issues and spinning the phone 180 might help get better alignment with the coil.
Some of these big mega phones now use a ton of juice, for my day to day this is still a great addition and it's a lot handier than an ash tray.
If I really need more juice (for example if my phone is nearly dead and I'm only going to be in the car for 20 min) I have the fast 12V charger in the console just in case.
      06-14-2021, 01:00 PM   #56
genebike
genebike's Avatar
63
Drives: 2011 e90 335i
2011 BMW 335i  [0.00]
I had this in my e90 335 for ~6 months, as others have said it's super easy to install and looks native which was what I wanted. However, when I got my M3 I didn't install it again because the charging issues discussed above happened to me with my iPhone 11. If it wasn't centered it just wouldn't charge.
I wanted something I could turn on and off, and which would hold the phone during "spirited driving". I installed a Pitaka magnetic mount(https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) on this arm (https://www.ecstuning.com/b-rennline...8aAqNwEALw_wcB) along with this case(https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) so I could still use any wireless charging pads. I ran the cable under the center console and have a QC charger in my armrest which I can plug in or leave out. The magnetic mount works all the time. BONUS: the stand has a fan to cool the phone/charger if needed, which living in Florida comes in handy.
      08-03-2021, 12:31 AM   #57
The-Traveler
Drives: E92 M3 & G30 530e
I would buy it if the design retained the original lid.
CLUBBER988.50
      08-10-2021, 07:59 PM   #58
The-Traveler
I ordered the OEM wireless charger that replaces the snap in adapter. It's for an F30 but I'm 90% sure it's going to fit just fine. Got it on Ebay for 70 EUR which is dirt cheap. There are a few more on there, just offer less money.
      09-05-2021, 10:03 PM   #59
Nazty Naze One!
Nazty Naze One!'s Avatar
Drives: 2010 M3 E92
Mines for sale. $140 lmk
      02-15-2022, 04:16 PM   #60
triax37
130
Drives: 2017 F31, 2014 F15, 2002 M3
Quick question before I purchase this: from the pictures, it looks like the screen is tilted towards the dash. Ideally, I want the phone tilted towards me, so that I could see the screen while it charges. Would someone be willing to test if the mount can just be rotated 90 degrees? Thanks!
      02-16-2022, 08:11 AM   #61
Cyberdemon
Cyberdemon's Avatar
1538
Not sure what you're referring to. The surface of the charger is completely flat. It doesn't rotate unless you rip it out of the tray and try mounting it at an angle.
      06-16-2022, 10:10 AM   #62
Jerezblack.m3
Jerezblack.m3's Avatar
149
Drives: BMW E92 M3
Originally Posted by Fooksdaddy View Post
For anyone looking to DIY this, it's actually called an oddments tray
Mfg Part #
51169198283
I initially ordered a sunglass tray that has the cover and that wouldn't work unless you have a smaller phone
Made the same mistake ! Now i have to exchange it
      06-16-2022, 01:47 PM   #63
drwankel
drwankel's Avatar
1049
Drives: 2012 E92 M3 ZCP, 2021 M340i
I'd like to see a version of this that leverages magsafe for apple users, so the phone doesn't move and gets faster wireless charging.
      07-21-2022, 01:03 PM   #64
nah dude
Pingu
nah dude's Avatar
237
Drives: White V8 Sedan Car
I just bought one of these. Just so people are aware what you are getting now is a different product from what OP shows.
When you buy this there are two options, you can get just the wireless charger for $99 if your car has the oddments tray already. Or for $139 they include the oddments tray which is what OP shows. What's different now is that Induktiv no longer uses the OEM BMW oddments tray. You can see the BMW markings on the tray that OP posted.
What they are using now is a cheap copy of that tray and are selling it for more than what ECS/FCP charges for the OEM part. When mine arrived I took it out of the box and was disappointed right away at the quality of the cheap shiny plastic tray part which had scratches and marring on the finish. I figured whatever it's just a tray and pulled my center console apart to install. The fitment is awful and there were noticable gaps no matter how it was adjusted. The mounting screw holes in their tray are oval so you can move it around in the console to adjust it to fit but no matter what there will be uneven gaps. The OEM part has smaller circular mounting holes because the tray fits perfectly and doesn't need adjustment and there are no gaps as you can see in the OP.
I reached out to Indukiv and explained, they said the new tray is an exact copy of the OEM part. It's not. The material is different, it's not a good fit and it looks like shit. So I am going to try to get a refund on the $40 cost of the tray to replace it with the OEM part and put their wireless charger in it. The charger itself works fine.
So yeah buy the OEM oddments tray (51169198283) separately, get the induktiv charger by itself and you'll be happy.
      03-21-2023, 06:43 PM   #65
Ich_liebe_mein_Auto
Ich_liebe_mein_Auto's Avatar
Drives: 2013 E92
Any luck with keeping the original lid?
      12-13-2023, 09:43 PM   #66
pathall1
Drives: Nothing yet!
Does anybody else find that this thing sucks? Installed it in my car and it's unbelievably finicky. The phone has to be on the EXACT perfect spot in the tray for it to work, and taking even moderate turns during completely normal driving runs the risk of moving the phone slightly and disconnecting it from the pad. Even when it is charging, it charges hilariously slowly (I'm talking like 2% over a 90 minute drive) and even sometimes drains the battery from my phone. I also sometimes get warnings that the phone needs to cool down before it'll continue charging. I'm constantly fidgeting with my phone to get it in the exact correct placement. Has anyone else found that this is a waste of time? And if so, does anyone have any alternatives? I love the concept, just not sure that this product is it.
m3post
