BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      10-14-2020, 01:14 PM   #23
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Originally Posted by SaNGRia View Post
Hello guys,
Long story short I have done my CCC to CIC retrofit and my journey started right after I wanted to have Front + Rear PDC + iPhone Videos + Reverse Camera + iPhone Apps, BMW Live + Internet Everything that you can imagine its possible to have on CIC Professional.
Which I did at the end, except BMW Live + Internet due to discontinued BMW Portal on E and F series. But I know a guy who is trying to MIT Attack to G series server to gain access on E and F series but let's see.
So today I would like to share the first DIY guide of OEM Reverse Camera retrofit on E9x series. I have gathered a lot of information online but there was no DIY topic on this application. So I would like to share all the information here so can be helpful for anyone who wants to do it OEM way.
Since the E9x series getting older, the parts are very cheap. Also it is very easy to do if you have PDC (Even only rear one).
The Required Items :
1- E84 X1 PDC (Must) P/N : 9252636
2- E70, E71, E84 TRSVC Module / Camera Module (Search On Ebay)
3- TRSVC Camera Retrofit Cable : 61122183660 (I used this seller several times he is great. Just tell him to use faster shipment. It will cost $30 more but worth it. I have waited like 40 days with regular shipment due to Covid19.
5- Chinese Reverse Camera Handle (If you do not want to cut your trunk)
6- F10 Reverse Camera (9240351) Ebay IT
7 - Edited PDC file for NCSExpert to code your e84 PDC on E9x. You will not able to read or code your PDC without this files, and if you can not default code it you will not able to activate your Parking Menu. (I attached the files as .txt just download it and change to .rar so you can see the files. Read the ReadMe file so you know where to put this files) Credited : Andy and Superwofy
I have totally paid $170 . Got good deals on Ebay. pacific-motors is a good seller as well.
Let me explain what I have done to accomplish this project.
I already had e9x Front + Rear PDC retrofit with Chinese Emulator and was working perfectly fine. Since I am OEM maniac I decided to do OEM application. Not just that but additionally gain Parking Lines + Obstacles + Unnecessary Towing Hitch Feature to be manageable on CIC screen. And I believe nothing looks better than OEM.
Having Chinese Emulator and PDC made my job a lot easier because my VO list already updated with $3AG (Reverse Camera) and $508 (Front and Rear PDC), If you have $507 (Only rear PDC Keep it as is, as soon as you default code the e84 Front + Rear PDC, it will cancel the Front part and will work like your Rear e9x PDC without an issue with the OEM camera module)
And my CIC was coded like this :
MACRO_PDC
aktiv
MACRO_REARVIEW
aktiv
RVC_CIC
wert_21 (FBAS1 Pin 18+ Pin 28- Pin 27 Shield)
MACRO_L6_PARKMENU
aktiv
PDC_DIRECTION
vertikal
For the Trailer Hitch Zoom Function, Code the MACRO_TRAILER_COUPLING aktiv on CIC . Now you will see Trailer Hitch icon on the parking menu. (I like to have it all)
Additionally If you have Front and Rear PDC, The Front PDC beeps slower than Rear PDC sensors. If you want to match the beep sounds in the same rate do a coding on PDC (Thanks to my very good friend Chris (cbozzz) :
FREQUENZ_TONGEBER_HINTEN
wert_01
FREQUENZ_TONGEBER_VORNE (Front)
wert_01 (This usually set for wert_02)
Because I have already done this As soon as I installed the e84 PDC (Default Coded) + OEM wiring harness + e84 TRSVC Everything worked without doing anything.
Important points are :
CIC Professional OEM Camera installation requires FBAS1 pins with RVC wert_21. It is mentioned on OEM instruction which I did. (Chinese one was Pin21-24 And RVC wert_23)
If you buy a different Camera Retrofit cable, regardless of the different colors on the cables, Follow the diagram above to connect your FBAS pins correct places using this diagram. Some cables has Yellow and White in different place. But as you can see on diagram Pin 2 of the TRSVC goes to Pin 18 of the FBAS. and so on...
After you have successfully connected the FBAS cables, run this cable all the way to the trunk. In my case because I own E93, the PDC is behind the rear seat. So I run the cable there.
Then make a Y cable from PDC power and Ground and attach that to TRSVC cables Positive (Pin 7) and Negative (Pin 1).
Then use the Can cables on PDC module. Attach the TRSVC CANBUS cables tightly using the M connector that comes with the kit. And you are done with the TRSVC cable installation.
For people who owns e90 and e92 use combox bracket on the trunk to install the TRSVC other side of the bracket and install it back its place.
My case was little different due to e93 design. The HSD cable that goes to trunk handle was not long enough to run the cable all the way to the combox area. So I put it next to the tire inflator for now. I will probably cut the HSD cable and extend with a video cable later on to install under the combox. (Done it after couple days after with this cable)
Trunk Handle Installation :
I have seen couple of OEM retrofits but they were cutting the trunk to fit F series trunk handle and I was little upset with that since I don't like to cut my car for even OEM retrofit. I decided to do something different which worked amazing.
I already had my Chinese handle from my Chinese retrofit. I have remove the camera that was on the handle. And tried to install the OEM camera on that tiny place which did not work at the first time
Then I did this :
Just a little note here. After installing the camera, please use a clear silicone (waterproof) and put all around the camera, just make sure it will not over run from the 19mm camera hole. And then let it sit for a day. And use the silicone cover that comes with the Chinese handle to hide your imperfections. Thats it.
The tricky part is because the oem camera has a humangous back part, it is really not too easy to install the handle like Chinese one. So you need to first make sure HSD cable comes out like this :
The position of the HSD cable really important. If that cable comes from the bottom of the trunk it will not clear and wont fit. There is tiny square hole in the trunk and you have to feed this cable from there. I did not take a picture of this hole but you wont miss it. After the cable properly installed attach to the camera. Also do not forget to attach trunk handle power cable.
And other tricky part is do not try to install the handle straight like you would do on Chinese handle. Put the handle 90 degree where the camera part down and the other side is up. Insert the camera's back first then start tilting. You will start feeling at this point. I suggest you to use your other hand from the inside of the trunk. Reach to the Hsd connector with your fingers to adjust the camera while you are adjusting the handle with your other hand. I was able to do it in 10 min. And it fit perfectly fine. But wasn't too easy. When you also want to remove the handle you need to use your other hand to grab HSD connector from inside. But I don't think this camera will fail anytime soon. They are top notch quality comparing to Chinese ones.
Another Trick will be installing the HSD cable to your trunk. Many people cut their cable to fit their HSD cable at this narrow rubber tube. I did something better so no need to cut your cable.
The oem wiring harness comes with Ground Point in the middle . I bent this part and tape it before running in to the tube.
Once you have done installing the PDC and TRSVC properly, grab your laptop. Open the NCSExpert. Do not forget to copy files that I attached here. After copying this files in place Turn on your ignition but no need to start the car. (PDC module only works when ignition is on, because of the Y cable TRSVC also turns on when the ignition is on) read the PDC file and default code it. And switch your gear to reverse. You should be all set.
And here is the pictures :
For the E93 series like me please make sure your HSD cable runs correctly. I made couple of tests before install in place (I had experienced from Chinese Kit Thank God. And the Original cable was too tight so causes an issue at the very first time. Then I corrected it) :
The HSD Cable that comes with the kit originally made for X1 vehicles and fits good for E90/92. But it is not long enough for the E93. So You need to get specifically this cable to extend the HSD cable by soldering 4 wire with the shield.
Then Install your TRSVC under the combox with a single zip tie
Hope you guys enjoy. This was one of the best mode I have ever done to this car :
NOTE : At the end I had a very strange issue, My TRSVC module can not communicate neither on Tool32 nor ISTA. Ista shows the module with 2 error stored, but when I click " Call Up Funtions" ECU can not communicate. Only INPA UIF shows STVR/TEBF Job Status OKAY with the part number 9291385 which is X1 TRSVC. Other than that It works without any issue. I might do e84 SSD file on NCSExpert to see if I can default code it but no need to do anything and not effecting the functionality.
INPA UIF
UPDATE :
I have found the issue why the TRSVC can not be recognized with my system. I have JBBF H3 Junction Box and I need to upgrade this to minimum JBE 3R H2/H3/M in order to communicate with TRSVC :
jbbf81 K-line (cars older than march 2007) also knows as JBE
jbbf70 D-can (cars newer than march 2007) also knows as JBE2
jbbfr3 D-can (cars newer than march 2007) also knows as JBE3
Versions of JBE:
There are a few versions available
L1 (low range type, low range version)
L2 (low range type, medium range version)
H1 (high range type, low range version)
H2 (high range type, medium range version)
H3 (high range type, high range version -> used in E91 and E93)
H4 (high range type, very high range version)
M (Master Version, Supports ALL)
That means New Project is on the way if it is just a PnP upgrade.
Here is the JBE I ordered. It is the "M" version which means Master. It has all connection types listed above :
FINAL :
Alright guys i have done the JBE3 Swap today. Everything working like a charm and TRSVC getting recognized. The amazing part was before i have flashed the JBE3 with my VIN, i checked the INPA UIF to see how many module was disconnected with the swap process, Oh well, all was connected and saying OKAY. It was a 1:1 Swap and the module came from e90 335i.
I was so pleased with that but i went ahead and flashed with my vin and defaulT coded on NCSExpert.
Since i removed my glovebox i also went ahead and installed the TRSVC positive cable to Pin10 with 5amp fuse (K15 ignition on).
I just done the calibration on ISTA and drove on highway and came back. Calibration done properly.
I now just need to find a way to default code the TRSVC (prob with ICOM). And thats all
For INPA Calibration Add the files in INPA.rar to EC-APPS/INPA/SGDAT and also this :
C: / EC-APPS / INPA / CDGDAT /
edit the appropriate file for the vehicle series
1 series = E87.GER / ENG,
3 series = E90.GER / ENG.
GER if INPA is in German
ENG if INPA is in English.
Open it with a text editor and add the entry
"ENTRY= RFK_70, Rückfahrkamera-System," to "KAROSSERIE", then you can select and calibrate the camera in INPA under your vehicle class.
For the Englisch file it's called "RFK_70, Rear Driving Camera System RFK_70,"
Save and Calibrate (Thanks to Dubstar)
RKF files in German so follow the guide on INPA :
Press F6
Then F7
If you see this That means Learning Completed (Anlernen erfolgreich)
Now go and drive alittle then come back park the car and let it sleep. Wake her up to see how she is behaving after this butt operation! You are all done!
(I will be adding more members name later. I have got alot of information from everywhere)
What did u do the trunk handle other than drill the hole to get it fit
      10-15-2020, 12:04 AM   #24
SaNGRia
SaNGRia's Avatar
986
Drives: LCI E93 M3 + F85 X5M
Thats it nothing else!
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
      10-16-2020, 04:14 AM   #25
unrulyteach
Drives: 2011 335i
Blank
How far back was the cam in the hole? And did the x1 pdc hav 3 connector instead of 2 like on e90?
      10-16-2020, 09:23 AM   #26
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Is PDC a must to do this? I was thinking of adding the rear OEM camera but I have no interest in the pdc. I’d like to run the always on rear camera at the track. I saw the emulator option but it wasn’t clear whether it can run for extended periods without frying the wiring.
      10-16-2020, 01:43 PM   #27
unrulyteach
Drives: 2011 335i
Not sure if pdc is a must but the module is as it didn't work with my oem one but i hav one on the way
      10-19-2020, 12:03 AM   #28
SaNGRia
SaNGRia's Avatar
986
You cant adjust the OEM camera in that hole. Chinese handle doesnt allow you any space. It is so tight and you need to dremell it. I have seen only F+R PDC on X1 !
Also i have mention that x1 PDC is must! You cant do this without!
, F85 ACC Retrofit
      10-19-2020, 08:04 PM   #29
unrulyteach
Drives: 2011 335i
I'm
Currently getting no communication fault to pdc when i tap pdc wires to trv module, is it a possibility that it's not getting enough power from pdc to power module.
      10-19-2020, 09:16 PM   #30
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Can any PDC module work? I found several that provide the rear PDC only for a great price. Here is the pic.
      10-20-2020, 01:22 AM   #31
unrulyteach
Drives: 2011 335i
It has to be the part number he mentioned, it needs to hav 3 connectors
SaNGRia986.00
      10-20-2020, 07:47 AM   #32
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Ok thanks
      10-20-2020, 12:21 PM   #33
unrulyteach
Drives: 2011 335i
Turns out hav the same jbe as u did, where did u get Master version
      10-20-2020, 10:48 PM   #34
BFZ4M
10
Drives: E92 M3 ZCP
I got mine from eBay. Just search the listing photos for a unit with the "M" printed on it. I bought 61359286790-02.
I haven't started on this job yet so please post any installation tips or tricks!
      10-21-2020, 01:13 AM   #35
unrulyteach
Drives: 2011 335i
What did u pay? If u don't mind telling
      10-21-2020, 02:36 AM   #36
BFZ4M
10
Drives: E92 M3 ZCP
$75 shipped. OP has some serious bargain shopping skills! I paid quite a bit more for all the needed parts.
SaNGRia986.00
      10-21-2020, 07:55 AM   #37
unrulyteach
Drives: 2011 335i
Tell me bout it the pdc alone was $100
      10-24-2020, 11:55 PM   #38
SaNGRia
SaNGRia's Avatar
986
My buddy got all of them $50 actually. I thought i was getting good deals He also DIYed his TRSVC cable kit. SO there is always another way to do it.
The best bet is find a local x1 and pull all the parts from that vehicle.
, F85 ACC Retrofit
      10-25-2020, 04:25 AM   #39
unrulyteach
Drives: 2011 335i
With the dremel i used oem cam fits Chinese handle damn near perfect, but ima test fit with the picture showing before i permanently seal it in one place.
BFZ4M9.50
      10-26-2020, 10:39 AM   #40
chuzo
Panama
15
Drives: 2016 M4
Sangria, thank you very much for your detailed write up for this retrofit.
I retrofitted the camera on my e92 m3 and all worked really good.
Based on the pictures I believe the e92 has more room in the trunk for the cable connector.
The parking aid lines came after the calibration with inpa and a short drive.
I used:
e70 TRSVC
cable harness from the ebay seller
chinese ebay backup camera for e90
f25 oem backup camera (modified to fit on the chinese camera handle)
x1 pdc
JBE "M" version
Appreciate 3
      10-26-2020, 12:11 PM   #41
unrulyteach
Drives: 2011 335i
I used:
e70 TRSVC
x1 pdc
JBE "M" version
So me the the cam in the handle without silicone cover
      10-26-2020, 05:17 PM   #42
unrulyteach
Drives: 2011 335i
Ok install jbe m today and I'm still having the same issue, Pdc is not communicating with car with i borrow power and can h/l from it to power tr module. Is it a possibility that Pdc can't supply power or can h/l for tr module?
      10-26-2020, 08:03 PM   #43
unrulyteach
Drives: 2011 335i
Hav u started ur install yet?
      10-26-2020, 11:11 PM   #44
BFZ4M
10
Drives: E92 M3 ZCP
No, not yet. Trying to learn more about coding modules before I get started.
m3post
