09-11-2021, 05:30 AM | #89 |
53
Rep 44
Look on the first page of this thread. I gave an example of a workaround that would in theory allow you to just replace the CCC display with a CIC version of a higher resolution, without needing to do the full CIC retrofit. It would cost around $200.
09-11-2021, 03:43 PM | #91 |
15
Rep 31
Yeah could certainly be (way) better but an infinite improvement over my jankey aux>bluetooth and ipod adapter added so long ago. This is my lowly shared DD duty N52 e90, so this was already a stretch relative to it's value.
09-12-2021, 11:21 AM | #92 |
28
Rep 96
I was finally able to hook up my rear camera to this unit. It took much longer than I expected because the "Gear Position" option under Reverse Option setting somehow did not work (probably because this is an install in a e60 6MT M5). I had to hook up a separate wire from one of the reverse light wire from the rear and connect it to the 12V reverse wire on the Mr12Volt unit. I then changed the Reverse Option setting to "Reverse State". The rear camera now works when I shift into reverse, except the reverse track lines and PDC display are off center to the left. Does anyone know how I can center them? Does this have something to do with my camera? I am using a 720p rear cam.
E93 Mineral White M3 DCT
E60 Sapphire Black M5 6MT E39 Black M5 E34 Alpine White II M5 E28 Black M5 |
09-13-2021, 03:56 AM | #93 |
308
Rep 308
Drives: 2008 BMW M3
Thank you to everyone working on this project and for all of the great advice. Got CIC mostly installed with some cuts on my hands as souvenirs. Still need to do some coding and adapting to loop out HD Radio. Backup camera arrived yesterday and still awaiting OEM Mic splitter (thanks to 2009550imsport) and Mr12volt unit. Does anyone think that Mr12volt will be able to detect the old ccc setup? What coding system do you folks use.
09-13-2021, 08:23 AM | #94 | |
28
Rep 96
georgebmwM3308.00 |
09-13-2021, 12:09 PM | #95 | ||
308
Rep 308
Drives: 2008 BMW M3
09-16-2021, 08:38 PM | #96 |
308
Rep 308
Drives: 2008 BMW M3
Well, big shout out to my fellow BMW enthusiast Devin Sukhu (Mizta insane). He sourced me out a complete CIC unit and sent it to me. He helped me through the installation process and when we hit obstacles, such as an HD radio that needed a MOST loop, he sent that free of charge and the entire coding set. Then he went through the coding process and help set up HD radio, SiriusXM, and Nav. I'm now waiting for the OEM mic splitter from 2009550imsport and the mr12volt. Devin is standing by to help me with that install. Really looking forward to it!
09-16-2021, 08:46 PM | #97 | |
31
Rep 124
Thanks George! Happy to help! |
georgebmwM3308.00 |
09-18-2021, 02:29 PM | #98 |
28
Rep 96
An update to my off center reverse track lines
I have been in contact with Mr12Volt regarding my issue with my off-center reverse track lines. They initially told me to just turn off the lines but after I requested a fix, they promptly send my a software update the next day. The update was easily done via a USB stick in seconds and corrected my problem I gotta say I am pretty impressed with Mr12Volt's service! Seems like they designed these units in house so they can make changes/updates very quickly.
E60 Sapphire Black M5 6MT E39 Black M5 E34 Alpine White II M5 E28 Black M5 Last edited by SocalM3; 09-18-2021 at 02:35 PM.. |
09-18-2021, 06:47 PM | #100 | |
47
Rep 71
09-18-2021, 07:40 PM | #101 |
28
Rep 96
I don't think it was a firmware upgrade but rather a small software update file because I used an USB instead of the SD card to update it.
09-18-2021, 08:05 PM | #102 |
47
Rep 71
Oh, I see. Their site still have an older version for the general software update for all P2000 (last update 20210802). Would you be able to share the one they sent you? I'll like to have it available in case I also have problems with the backup camera lines when I get my unit. Thanks.
09-18-2021, 09:01 PM | #103 | |
28
Rep 96
Here's the update file. Please prepare a USB not bigger than 32GB and FAT32 formatted Procedures: 1. unzip the file, you will see 4 files, put them into the root directory of an empty USB stick. DO NOT alter the filenames; 2. insert the USB stick into P2000, press "OK" of the BMW knob for 8 seconds, this will reset the P2000 and start the update process; 3. the update process shouldn't take longer than 10 seconds, the P2000 will restart again after the update; 4. unplug the USB stick, press "OK" for 8 seconds again to reboot the P2000; 5. After the reboot, you should see the tracking lines in the right positions; It is interesting to note that you can soft reset the unit by pressing down (OK) on the knob for 8 seconds.
09-18-2021, 09:17 PM | #104 | |
Rep 3,988
I got a blank screen once but was driving and didn't want to pull over an try to get it working. I parked the car and came back and it was working. Knowing how to reboot it while driving would have got me working sooner. Thanks. |
09-18-2021, 10:12 PM | #105 |
28
Rep 96
For those with the Mr12Volt unit installed, how do you find the microphone quality on phone calls? Here are my experience with 3 different options:
1) I tried the mic splitter for the OEM microphone but was told that the sound on the other end was horrible and they can barely hear me and there is a lot of background noise. 2) I then switched to the supplied microphone and rigged it to attach to the blank microphone plate on the sunroof panel. It seems to work well when the engine is off but my car is fairly noisy with an aftermarket exhaust so it does not sound very good with the engine on. 3) The last option was to bluetooth the phone separately to the OEM bluetooth for phone calls. This has the best sound quality but the only issue is that while I am on the phone call, the screen switches from Carplay back to the OEM idrive phone screen. Any other suggestions to improve the sound would be much appreciated!
09-19-2021, 06:35 AM | #106 |
Rep 2
Some Dr. Google searching led me here. I ran into the issue where install is complete but the CD Changer is not showing in the menu. Guessing it's due to the same issue referenced in the thread.
In my haste I purchased an OBDII bluetooth adapter thinking I could use Bimmercode to activate the CD Changer. Is this possible or will I need to go the ICOM/K+DCAN Cable and NCS Expert route to accomplish? The lack of any info on it would lead me to believe I have to go the latter route. Cheers for the thread and great discussion, it's the only place I've found where others have installed the P2000. |
tdott3950.00 |
09-19-2021, 08:55 AM | #107 | |
47
Rep 71
Headunit -> Expert Mode -> 3000 HMI Find CDMM_CHANGER_3 option and change it to mp3_cdc CODE -> START CODING Note: This is for my 2010 E92 M3, so hopefully it's the same/similar with other models Last edited by djan9el; 10-10-2021 at 07:23 AM.. Reason: Adding note |
09-19-2021, 09:35 AM | #108 | |
Rep 1,047
Maybe try reaching out to mr12volt? They seem to have been receptive with other feedback and providing software fixes. Maybe the issue can be fixed? |
09-19-2021, 11:37 AM | #109 | |
Rep 2
Up and running now without any issues. Look forward to no longer propping my iPhone up against the nav screen to use Waze |
09-19-2021, 02:26 PM | #110 | |
15
Rep 31
