BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      07-04-2023, 09:31 AM   #1
georgebmwM3
georgebmwM3's Avatar
Drives: 2008 BMW M3
2008 BMW M3  [9.00]
2017 Camaro ZL1  [0.00]
CCC to CIC now looking to upgrade Combox
Upgraded 2008 m3 to CIC. Looking to upgrade combox. I have a TCU, what else is needed? Thank you in advance for your help.
      07-05-2023, 05:18 PM   #2
RocketyMan
RocketyMan's Avatar
Drives: E53 X5, E83 X3, E93 M3
2008 BMW M3 E93  [10.00]
You need the kufatec wire harness adapter. The comboox takes place of the MULF2 and the TCU. The CIC screen, head unit, screen harness, USB and harness. But sounds like you have those.
2008 BMW M3 E93 MT
R135
..246
      07-05-2023, 08:51 PM   #3
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
You need a the combox and a combox connector. About $50 in parts total.
      07-09-2023, 06:39 AM   #4
georgebmwM3
Drives: 2008 BMW M3
2008 BMW M3  [9.00]
I found a new combox from a BMW dealer for $150. I’ve seen cheaper on eBay, but I like the new part also. Where do you find a connector? Any links?
      07-10-2023, 11:33 AM   #5
RocketyMan
RocketyMan's Avatar
This is the cheapest I've seen for the kufatec adapter harness.
BMW Combox retrofit wiring harness for TCU and MULF to Exx- and Fxx-series
https://www.ebay.com/itm/32487625400...Bk9SR6ritYmoYg
There's no point to getting a new combox from the dealer. I'm not sure you can register the imei anymore--and it'll be difficult when BMW sees your vin as a pre-LCI anyway (I think someone did it here on the forum and it turned out being a huge PITA to get it to work).
Here's "the latest" combox that is 4G with GPS:
84102447925
https://www.realoem.com/bmw/enUS/sho...diagId=84_0800
I would NOT pay anymore than $75 off of ebay as it would be a rip off:
https://www.ebay.com/itm/17568583563...3ABFBM9rTTiahi
2008 BMW M3 E93 MT
R135
..246
      07-10-2023, 06:55 PM   #6
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
All 4G combox units are deactivated as of 02/2022.
Go buy any used combox that does not look like it was under the ocean (a lot get water damaged). It is best to buy one with the connectors included with the module.
If you do not get the connectors with the combox you can order them at the dealer. Get the black and green connector with the white insert and not the blue one with the black insert. I can't find the part numbers.
Do not get the kufatec adapter. In my experience they connector doesn't seat properly causing issues. The pin in method of install is the superior way to install a combox.
The antenna wires will need to be adapted with a cheap $7 cable: https://www.ebay.com/itm/383103945523?var=651682258708
If you have the center console USB you will need an extension cable for the combox: https://www.ebay.com/itm/264664294201
and a most bus loop (OEM one is 61136917541): https://www.ebay.com/itm/20308037098...3ABFBM8unCoqhi
The install is super easy and I installed a full CIC + combox in the previous owners condo garage immediately after I bought my M3.
1. Remove the trunk floor.
2. Remove the two 10MM nuts holding the bracket to the car.
3. Disconnect all of the electrical connections.
4. Remove the TCU and MULF (if equipped) 4 8MM nuts per module.
5. Install the most terminator to the MULF most lines (if equipped).
6. Plug in the USB extension cable to the black HSD line.
7. Swap over the power, ground and three microphone wires from the TCU connector to the combox connector.
8. MULF equipped cars will need an extension harness pinned in if you want to retain aux. (None MULF cars can code aux back in)
9. Bolt the combox to the bracket with the 4 8mm nuts.
10. Plug in the main combox connector, TCU most lines, black USB extension cable, tan BT antenna with adapter.
11. Bolt the bracket back to the car.
12. Code the car for combox.
      03-13-2024, 02:33 PM   #7
AlsoBoris
Drives: 09 335i OEM M3 Clone
I ordered everything else that you mentioned in this. I can't find the instructions on the Pin in method though. I too thought that the kufatec adapter is ridiculous. Wondering if you could please link me to that method?
      03-13-2024, 09:30 PM   #8
RocketyMan
RocketyMan's Avatar
You have to modify the kufatec connector. It's not at all a big deal.
2008 BMW M3 E93 MT
R135
..246
m3post
