01-14-2024, 08:22 PM | #23 |
Rep 3,411
Always and forever, I can listen to that thing. Insanity.
Not a Doctor, those are just my initials.
01-15-2024, 07:26 AM | #24 |
130
Rep 196
The E63 M6 coupe manual with this V10 weighs 3900 lbs, that’s about 250-300 lbs heavier than E92 M3 coupe.
Given this, plus the engine swap adding considerable weight up front, I’d personally get an E63 M6 manual coupe to experience the S85! Other than the SMG, the S85 cars have almost similar reliability issues compared to S65 cars.. |
01-15-2024, 09:13 AM | #25 |
Rep 5,551
With people having made e30 and e46 S85 swaps work and handle well, putting a S85 into an e92 should be easy, however, I’d want it paired with a DCT. S65 + DCT is the perfect match. S85 + DCT might be an even better match.
DarkstarZero1013.50 CurbBender'9071.50 |
01-15-2024, 09:50 AM | #26 |
Rep 1,721
I've driven both S65 with DCT and 6MT and the DCT is more fun by far both on the street and track. I told this to another track instructor and he whispered back "I agree" as if he didn't want anyone to hear him.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
01-15-2024, 10:02 AM | #27 |
Rep 5,551
lol I’m not afraid to admit that I love the DCT! Another reason to not like the G8x! ZF8 AT, which is an awesome AT (have one in our 240ix), but it’s no DCT. Problem was too many people thought the DCT was an AT in the F8x and complained about it to BMW. So BMW decides to eliminate their best performing transmission
01-15-2024, 10:42 AM | #28 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Could also drop an LT4 Z06 motor into an E92 M3 like these guys did. Probably a bit cheaper too.
. . https://www.driftworks.com/row/
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
cotmfk2053.50 ///M Power-Belgium63463.00 |
01-15-2024, 11:17 AM | #29 | |
Rep 471
Drives: 2009 E93 M3 DCT
Sinister84035.00 Jon H391.50 |
01-15-2024, 11:42 AM | #30 |
Rep 5,551
01-15-2024, 12:17 PM | #31 |
Rep 6,114
There is a local one in Jacksonville, FL. Of course it sounds awesome. It's a performance shop owner that did it, so who knows what the costs are/were. I can't recall the name of the shop, but maybe this is enough to go on for you to find it. Good luck.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
ILikeBimmers114.50 DrFerry6728.50 |
01-15-2024, 12:19 PM | #32 | |
Rep 6,114
01-15-2024, 12:41 PM | #33 |
115
Rep 108
Drives: (G42) m240ix
Yeah I feel that 😂. I guess the known issues with the e60/63/64 isn't purely the S85, but also the SMG transmission which has some very expensive known failures. Presumably if you're swapping a S85 you're already preemptively upgrading the internals, particularly the famous rod knock issues.
01-15-2024, 12:43 PM | #34 | |
Rep 1,721
01-15-2024, 04:53 PM | #35 |
Rep 10
ILikeBimmers114.50 |
01-15-2024, 05:52 PM | #36 | |
Brother
710
Rep 594
Almost similar The S65 has issues with the main bearings (after 2010.5, correct me if I am wrong) that the S85 does not. Simultaneously, I have not heard of VANOS failure on the S65 as is "common" on the S85. |
01-15-2024, 07:51 PM | #37 |
Rep 5,551
Incorrect. S65 and S85 have issues with rod bearings which can be addressed with preventative maintenance (once replaced with extra clearance bearings you’re good). Any year S65 is susceptible to rod bearing failure. Bearing material change in 2011 but no change in clearance. Main bearings on S65 wear but much slower than rod bearings. Main bearings cannot be preventatively replaced.
01-15-2024, 08:15 PM | #38 | |
Rep 3,411
01-15-2024, 08:27 PM | #39 |
Rep 5,551
01-15-2024, 08:30 PM | #40 |
Lord Scrip
1816
Rep 3,013
Drives: 2011 M3 Coupe
The E92 M3 S65 & DCT are a perfect match for me but the thought of an S85 DCT is pretty enticing! This is impressive that everything works and the effort was made towards the detail there. To have a functional MDM on a Frankenstein build like this is an impressive build accomplishment! Very cool, thanks for sharing!
DrFerry6728.50 |
01-15-2024, 09:15 PM | #42 | |
Rep 5,551
https://www.m3post.com/forums/showthread.php?t=1504062 |
01-15-2024, 09:39 PM | #43 | |
Brother
710
Rep 594
At no point did I mention rod bearings. We all know everything about those. |
01-15-2024, 09:49 PM | #44 | |
Rep 5,551
Please read below: https://www.m3post.com/forums/showthread.php?t=1504062 Last edited by M3SQRD; 01-15-2024 at 10:09 PM.. |
