      08-01-2010, 07:49 PM   #1
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
calling all 6MT SSK guys...
Hi Gang,
So the other day I got borded and decided to measure my stock 2010 (N54) 135i 6MT gear lever throws. I measured the throws from 3rd - N - 4th, gears. I measured at the bottom of the shift lever at the silver ring/M-shifter.
The throws from 3rd to 4th - comes out to exactly 8 cms. Or 3.14 inches.
I would like people who have a SSK to measure their throws and post the results. BMW Perf, UUC, B&M, ect...
I would also like someone with a N55 to measure their throws so we can confirm that the N55's have a shorter shifter.
TIA,
Dackel
      08-01-2010, 11:40 PM   #2
egainer
Drives: 2011 135i
Just measured my 2011, Msport 6mt 135i. Picked it up two days ago
Travel of 3 - N - 4 measured at stitching line at base of metal ring is 2.75inches
Travel from 1 - 3 horizontal is .75 inches
Here are some photos for fun
      08-02-2010, 04:28 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Ok, Thanks egainer.
2.75 inches times 2.54cm is 69.8mm or 6.98 cms.
So my N54 was at 80mm. I was thinking the difference would have been more. Thanks though. Lets keep this thread going!
      08-04-2010, 03:39 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Anyone else with a SSK care to measure their throws?
      08-04-2010, 04:33 PM   #5
N55 Power
N55 Power's Avatar
Tajikstan
Drives: 2011 135i
Off topic but am i the only one who dislikes the amount of gear resistance there is when shifting? My 81' delorean and 86' 325e both have very little shifter resistance despite enormously long throws.
      08-04-2010, 07:04 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
It gets better with miles. At first, the shifter is really tight. Many people have said it takes 10K miles before it starts to feel silky. My car has about 12K on it now. Even that said, my 1st/2nd shifts feel a bit notchy still. BUT WAY better than when it was brand new!
Another thing.... have you done the CDV mod? You really should. Go look under the DIY CDV delete for it.
      08-04-2010, 08:06 PM   #7
N55 Power
N55 Power's Avatar
Tajikstan
Drives: 2011 135i
Yea Ive done it and think its great... feals like a new tranny.. Love it. that fu!@ing CDV is one of those things that makes me pull my hair out: NO DIPSTICK/ NO Key for trunk/CDV. To me those are the big three.
      08-05-2010, 08:29 AM   #8
GaryS
37
Drives: 2009 135i 6MT
2009 135i  [6.50]
On my car, the CDV delete helped a little, but a clutch stop helped a lot. I felt ridiculous paying $20 for a screw, but I love the improvement it made.
About SSK's, when I first looked at them, the BMW SSK was too expensive, so I tried B&M. The B&M SSK has very short throws, but it was too sticky shifting in and out of 2nd - I hated shifting 2-3. Then Tischer cut the price for the BMW SSK, so I replaced the B&M. The BMW SSK has throws a little longer than I'd like, but it isn't sticky in any gear, so I'm happy.
      08-05-2010, 08:42 AM   #9
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
great idea for a thread!
on my 2010 N54 w/ 9k miles, its been butter smooth shifting ever since I got it
no CDV either
      08-06-2010, 09:21 AM   #10
davemohan
Drives: 135i
I have an 08 with the BMW SSK, but I'm not sure how you are measuring this.
At what point on the shift lever are you measuring the throw? In the first set of pictures they appear to be directly above and it looks like you can see about 80mm of travel at the cross line of the shift pattern on the top of the knob. Are you eye-balling it from that point? If so, not only is it tough to be accurate, but the height of the shift knob comes into play. (The BMW SSK comes with a shorter shift knob as well, so the throws will measure shorter at the top than if the SSK is used with the stock knob.)
The only alternative I can think of is to measure at the level of the tape stretched across the boot, but then what do you use as a reference point on the lever? The seams on the boot move relative to the lever and cover it at that height, so you would have to remove the leather boot and place a reference mark on the shift lever at the chosen height.
The "shortening" claims I've seen for SSKs range from 8% to about 25%, and we are talking numbers of less than 3" (much less as you move down from the top of the lever), so it is going to take some pretty exact measurements.
I would guess that the above comparison is pretty good as it looks like both have the same knob (looks can be deceiving, though) and measured at the same point. But to take it any further you need to standardize the measurement and take the "knob height" out of it.
      08-13-2010, 03:59 PM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I measured the throws from 3rd - neutral - 4th gears. I used the edge of the silver collar on the shifter for reference. I found that by putting the measuring tape under the armrest area... and then just taking note of the position of the shifter & the measuring tape.
I would like to know what an N54 with a Perf SSK does.
My stock N54 throws are 80mm.
A stock N55 throws are 70 mm.
PLEASE report back!
      08-13-2010, 06:26 PM   #12
I M LEGEND
Drives: M
[QUOTE=GaryS;7778816]On my car, the CDV delete helped a little, but a clutch stop helped a lot. I felt ridiculous paying $20 for a screw, but I love the improvement it made.
QUOTE]
This Clutch Stop is well worth it...and not a screw.
      08-13-2010, 06:40 PM   #13
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
So... does the Performance Short Shift kit have throws any shorter than 70mm? ???
      08-13-2010, 07:15 PM   #14
GaryS
37
2009 135i  [6.50]
Well I tried, but I really don't understand where on the shaft you're measuring. I laid the ruler across just as you did. Measuring where the shaft touches the ruler, I measured 40-45mm from 3rd to 4th.
That seemed way too short compared to your 80mm, so I tried eyeballing the position of the bottom of the silver ring. That way, it looked like 50-55mm.
Sorry, that's the best I can do, except to say that, from looking at egainer's pics, I can promise that my SSK's throws are much shorter.
      08-13-2010, 07:37 PM   #15
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
It does not matter WHERE you measure from... just be consisitant. I used the back edge of the silver ring. I kept the measuring tape secured by placing it under the arm rest. As long as the measuring tape stays still... and you measure from the same refference point. You are good to go!
      08-13-2010, 07:55 PM   #16
GaryS
37
2009 135i  [6.50]
The distance from 3rd to 4th at the level of my ruler laid across the flattened boot is 40-45mm. I can't measure it more precisely because of the boot flopping around. (I have more excess boot than you because my lever is shorter.) But I don't believe my SSK really has 40-50% shorter throws than stock. It's more like 25% shorter.
Anyway, I have to admit, I'm glad to see that davemohan is confused in exactly the same way I am.
      08-13-2010, 07:58 PM   #17
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Thanks GaryS!
      08-13-2010, 10:11 PM   #18
mshahidz
Drives: M4, 991 GT3
[QUOTE=I M LEGEND;7827374]
QUOTE]
more info?
JRZ RS2 | Capristo | Eisenmann | Volk Racing TE37SL | Endless Brakes |
      08-14-2010, 01:12 AM   #19
I M LEGEND
Drives: M
[QUOTE=mohammadz;7828135]
Originally Posted by I M LEGEND View Post
more info?
reduces the dead space between your clutch pedal and the floor
http://cgi.ebay.com/ebaymotors/E9X-B...mZ230502700485
      08-21-2010, 09:29 PM   #20
gadget12345
gadget12345's Avatar
Drives: 135i
BMW Perf SSK - N54
Best measurement I could get for you with the BMW SSK.
3rd to 4th throw distance measured from center of silver ring (I kept the //M gear knob and boot) was [7.125 - 5.125] = 2 inches
Seems that's about 50mm or so.
BTW: From my first gear change with it installed it was really, really noticeable.
Yr1 E82 CSM - 6MT, Premium Package, Sport Package
BMW - SSK, Perf Exhaust, Perf Suspension, Shadow Grills Inners, Mudflaps, Alarm, Cargo Liner, Grocery Gripper, Aluminum Pedals, Front + Rear Perf Rotors, MSD80 PowerKit, E93 Sway Bar
Misc -Euro Headlight Switch, Warning Triangle, iBrights, LoJack, Wheel Roundels, Tint, Escort 9500i, Hyper Black ARC8's, Pilot Super Sports
      11-09-2010, 05:52 AM   #21
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
TTT
      11-11-2010, 02:20 PM   #22
kc_skyrider
kc_skyrider's Avatar
Germany
13
Drives: 2009 135i M-Sport
I hate to thread jack but Clutch stop FTW I love the difference it makes and it's so natural that I don't even notice it anymore. I just know it's better lol.
