2010 2011 BMW 5 Series Forum F10 F10 M5 Brakes on 528/535/550 ??? |
11-16-2023, 10:17 AM | #155 | |
18
Rep 142
Hey Mike, do you know if the 20inch m343 m5 rims will clear the m5 caliper on a 550? Seems like a straight forward answer but i want to make sure because the lci 550 doesnt allow the m343 wheel to mount without a spacer due to the differences in a lci caliper |
11-16-2023, 10:42 AM | #156 | |
18
Rep 142
11-16-2023, 12:28 PM | #157 |
Rep 1,084
Drives: 2013 BMW F10 550 Xdrive Msport
Well i have 20 x 9 Dinan (BBS) rims on the car with no issues. Mine is an XI so i have to have all 4 rims running the same size for AWD. If you can compare the 343 rim size to a bbs 20 x9 you should see if it will fit.
11-16-2023, 12:33 PM | #158 | |
Rep 1,084
11-16-2023, 10:49 PM | #159 |
64
Rep 21
I have done the conversion. installation was pretty stright forward. No fitment issues.
ordered rotors, pads and sensors from FCP Tronik adapters My set up is: Front 20x9.5 245/35 et 20 Rears 20x10.5 285/30 et 26 |
11-20-2023, 04:13 AM | #160 |
122
Rep 93
Drives: BMW 550 xdrive
wheels
hi, tell me your opinion. I want to put these wheels on my green one, I tried it on the gray one
11-20-2023, 04:16 AM | #161 | |
Rep 1,084
I like the way it shows off the Drilled rotors on the car. Nice Choice |
02-27-2024, 12:27 PM | #162 |
18
Rep 142
Hey Mike,
Do you know if the master cyclinder needs to be upgraded post m5 caliper and brake retrofit? Its part# 34336799903 which isnt interchangeable with the 550 according to realoem. I wonder if its a direct fit |
02-27-2024, 02:06 PM | #163 |
Rep 951
I believe you can also FDL code your DSC/ABS module to know it has the bigger brake kit. My DSC is preLCI so I may not have the most uptodate parameters but you can see the screenshot and select based on your brake size :
02-27-2024, 05:03 PM | #164 |
24
Rep 38
You can if you change one brakeline. Did that myself together with the G11 M Performance brakes.
