05-12-2017, 12:07 PM | #23 |
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
Experienced the same vibration OP is talking about shortly after doing this conversion on my 135 only to find out I had two small hairline cracks in the bushings of my guibo disc. Replaced the guibo disc and vibration was gone. Not discrediting OP's analysis, it was a really interesting read and I have heard of the same thing being needed but I would take everyone else's advice and look at a simpler solution first.
DR-JEKL899.50 |
05-13-2017, 12:27 AM | #24 | |
Rep 6,285
https://www.ecstuning.com/b-genuine-...r/26102284017/ |
05-13-2017, 12:59 AM | #25 | |
Rep 1,525
2008 335i FFTEC ST 6266,), Boostbox, VRSF 3.5 exhaust, mtech front and rear, KWVll, APEX 18x9.0, 18x12= 305/35/18 NTO1s, BMS OCC, Rb PVC, M3 tri-color stitched S-wheel,MT SWAPPED, M3 LSD diff
2008 135i mods coming soon! |
02-28-2018, 09:02 PM | #26 |
2639
Rep 2,145
Drives: 2011 E92 M3
26112284154 - black prop shaft screw (for blue marked diff - system A cars after 09/2009)
26102284017 - black washer for prop shaft (for blue marked diff - system B cars up to 09/2009) 33217571990 - silver prop shaft screw 26112284153 - green prop shaft screw (for yellow marked diff - system A cars after 09/2009) 07119907114 - silver washer for prop shaft (for yellow marked diff - system B cars up to 09/2009) 33211227944 - axle screw Above for complete list of parts.
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 02-28-2018 at 09:09 PM.. |
roastbeef11591.50 |
03-21-2018, 09:16 PM | #27 |
2639
Rep 2,145
Drives: 2011 E92 M3
Does anyone have one of these in their back pocket? Back-ordered from ECS. Not sure why this washer is such a hard item to find...
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
03-22-2018, 07:59 AM | #28 |
Rep 3,140
Drives: 2014 M5 6MT
It's interesting to see this thread. Out of the hundreds of cars I've serviced, I've never seen color coded drive shaft flange hardware. Neither has a vibration occurred from not putting the hardware back exactly where it comes from. I'm gonna keep my eye out for this from now on.
2014 M5 6MT
03-22-2018, 12:32 PM | #29 | |
2639
Rep 2,145
Drives: 2011 E92 M3
Only the Germans would over complicate a prop shaft...
Solo_M_Tech1687.50 |
03-22-2018, 12:36 PM | #30 | ||
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
03-23-2018, 09:37 PM | #31 | |
Rep 413
03-24-2018, 11:06 AM | #33 | ||
Rep 3,140
Drives: 2014 M5 6MT
Seeing how it's only the E9x and E82 M3 and 1M driveshafts, that limits my sample pool to 20-25 removals and installs. Including my personal M3. That said I still haven't noticed these bolts and even if I missed a random colored bolt, I've never induced added drivetrain vibrations by putting the bolt in the wrong location. If I even did.
2014 M5 6MT
Theodore672.50 |
04-11-2018, 08:36 PM | #34 |
Rep 6,285
FWIW I've done some research on the bolts and this is what I've found.
It seems that the thread is just cut longer on the standard bolt to reduce the mass slightly. As you can see for the dedicated counterbalance bolts there's not much difference in mass between the standard bolts. Also this is for system A, earlier year models have system B which use washers. |
10-08-2021, 10:19 PM | #35 |
149
Rep 254
Came across this thread by accident as I'm on the CF driveshaft group buy and I shoved my phone camera under the car while it was on the ground and saw I have a blue line on my 2011 e92 M3 dct, so will need a black bolt:
View post on imgur.com |
11-05-2022, 01:56 AM | #36 |
90
Rep 363
Just did the pinion seal job today. What a pain in the ass to remove the full exhaust and shielding, etc. I do have one concern. I did find on black bolt of the 6 securing driveshaft to the pinion. I made a mistake my not marking the bolt all the way down to the pinion.
My pinion is marked blue, that means it has a black bolt. BMW tis says to line up the black bolt with the mark however the mark on my pinion is in the middle of the two bolts and not exactly lines up seen below. The only logical place to put the black bolt was where I put it. Road test went smooth, no sound from drivetrain at all but still curious to hear your thoughts here. |
05-16-2023, 05:42 PM | #37 | |
46
Rep 221
I have a similar situation except it's with a yellow marking and a green counter balance bolt. I also didn't pay attention to this marking nor the initial position of the counter balance bolt when I disassembled the CV joint from the diff. In my case the yellow mark is only like ~1/3 away from one of the holes. So that's where I'm putting the green bolt. It also turns out that particular hole is very to the drilled "balance dimple" on the diff shaft... Fwiw.
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) |
04-16-2024, 09:42 AM | #38 |
just another M3
514
Rep 1,152
I'm a bit confused about mine. No markings at all on the diff flange or flange disc behind the flange, also checked inside the flange. Zero marking and my diff flange is not drilled for balance.
Currently has the silver bolts with no washer on any hole. Experiencing a vibration, will replace the flex disc, center support bearing and CV Joint. Found a local shop to balance the driveshaft. Will see if that solves it.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
