BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Share your BimmerTech PP82DSP Amp Tune Files **Updated 01/15/18
ARMA SPEED
      03-11-2016, 11:35 AM   #67
yoandry
yoandry's Avatar
693
Drives: G80 M3CX & X5 M50i
Now on bavsound website the amp is $997 and it says not compatible with my 13 f30 HK. The bimertech website has it for $849 and doesn't specify fitment by oem audio, just fit all f30. Is it work with HK or not?
This setup comes like this.
$800 for 14 speakers
$500 for 2 subs
$850 for amp.
$2150 total
If it is night and day compare with my oem HK will do it. But if is NOT. I dont think is worth it.
      03-11-2016, 12:27 PM   #68
fhlh
fhlh's Avatar
Drives: 2013 BMW 335i M-Sport
2013 BMW 335i  [0.00]
$500 for 2 subs
$850 for amp.
$2150 total
Stick with the H/K (unless you really dislike)... you already spent the extra coin in the option sheet.
Search the forums for folks that have HK, but just replaced speakers. I hear they like the results.
2013 335i M-Sport 8spA
2011 M-B GLK350
2000 Dodge Ram 2500 QC 4x4 CTD
      03-11-2016, 12:53 PM   #69
yoandry
yoandry's Avatar
693
Yeah I was thinking just to change the subs first to check the result, then some speakers not all. HK sounds good just not the same as my old e90 and e70 with the logic7. This one is logic7 also but don't know why doesn't sound the same.
      03-11-2016, 08:55 PM   #70
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Originally Posted by saaltonen View Post
This has taken forever for me to finally post here, have been running this tune for quite a while now and happy with it for the wide variety of genres I listen to.
My current setup is LHD, Bavsound Stage 1 Mids and Tweeters, Bavsound Ghost Underseat Woofers, and an Infinity 10" trunk subwoofer in a sealed enclosure powered by a 500 watt mono amp. I would say that this tune might not be the best for people with no trunk sub, as I have the setting for the underseats geared towards a setup with a true subwoofer in the trunk to handle the heavy stuff. If you do happen to be running a subwoofer, just adjust the gain on that amp to suit.
Hopefully this helps someone out, I haven't really had time to go back and fine tune it but hopefully this will get you guys close.
Loaded this one up today!! Well done
My Build Thread can be found HERE
      03-11-2016, 10:30 PM   #71
Nelson@BimmerTech
Drives: 2014 M6 GC
$500 for 2 subs
$850 for amp.
$2150 total
Our amp is only compatible with Hifi system in the US and Base and Hifi system in the rest of the world.
      03-13-2016, 08:03 PM   #72
saaltonen
saaltonen's Avatar
Drives: 2014 F31 328i xDrive
Saaltonen,
Nice tune.. very dynamic!
I'm using it as a base with the Bavsound stage 1, stock 8's and a single RF Punch 10S2on in 1cf sealed pushed by a RF PBR500x1.
Question, I have to utilize Channel H to get signal to my trunk sub setup and noticed your tune had this channel off. How are you getting signal to your Infinity setup? I know I made changes to your i/o but didn't pay attention to what you originally had setup, I just remember H was "not assigned"
Once I get my Musicar enclosure and AudioFrog GS10D2 installed, I'll tweak and post the results.
fhlh
It has been a while since I have messed around with the tune, and don't recall exactly. I just checked my tune file and I believe it is running off of Channel G, because I had the crossover set lower for the true subwoofer than Channel F which I believe is the under seats.
2014 F31 328i xDrive - Alpine White - KW V2 - 19" MORR VS8.2 - BSW Stage 1 - BSW Under Seat Woofer - BimmerTech Amp - Infinity Kappa 100.9w/500W Mono Amp - M-Sport Rear Bumper - M-Performance Diffuser - M3 F80 Style Front Bumper
      03-13-2016, 08:05 PM   #73
saaltonen
saaltonen's Avatar
Thanks ronanz! Appreciate the the comment. I will probably be fine tuning t hings further when I get a chance, as I have noticed some areas that could use some tweaking after running this tune for a while.
Will update with a version 2.0 in the near future when life isn't so crazy, but glad you like it so far. Thought it might be a little rough as this was my first stab at it.
      03-13-2016, 08:58 PM   #74
ronanz
ronanz's Avatar
As soon as you put up 2.0, I'll replace your previous one with the new one!
      04-11-2016, 11:06 AM   #75
Matt338
39
Drives: 2016 535i M Sport
Hey everyone,
I've been doing a lot of reading recently and I have a few questions that have not been covered in great depth or at all. I just installed my my BSW Stage 1 speakers yesterday in my HiFi equipped F30 and am already impressed, but know I can do better. I got lucky and was able to snag a great deal on the Bimmertech amp from a forum member in the Member's Classifieds who already had the Stage 1 speakers and the amp is tuned as such. I currently own a JL 12W3V2 sub and a 500/1 amp that I plan to install but may upgrade in the near future for a 12W6 and a 600/1 since I work for a company that sells JL's home products and can get a great deal. Here are my questions:
1: How does having a trunk sub affect the tuning? I realize it changes the dynamic of the sound so I'm sure I'll want to take that into account.
2: What tuning files are out there for a BSW stage 1, OEM underseats and a trunk sub?
3: If there are multiple ones, is anybody running either of the specific JL subs and amps mentioned above?
4: Since the amp has RCA out and the battery is in the trunk, I'm thinking I should be able to do the install myself. I haven't seen anything about there being a 12v trigger output to go from the Bimmertech to my sub amp. Is there one? If not, does the amp have some other way of signaling the sub amp to turn on? Do I need to tap in somewhere on the harness?
Sorry for the long post but in a nutshell I have BSW stage 1 and Bimmertech amp and want to know all the best practices for adding a trunk sub. Any and all help is greatly appreciated.
--Matt
      04-27-2016, 10:29 AM   #76
Culichor
Drives: 2016 Sienna 11' 335is vert
Great info here, Works perfectly on my Helix P SIX DSP.
      04-28-2016, 12:49 PM   #77
535d1420
Drives: 535d
Anyone having problems with flutter in the bavsound subs? I have bavsound speakers and subs and the 3rd version of the dsp. The f30 community on bimmertech amps is much larger so i thought i may get more help with tuning here. I need an audio tuning for dummies book!
      05-08-2016, 08:02 AM   #78
PuterPro
15
Drives: BMW 2015 320i Alpine White
Originally Posted by Matt338 View Post
Hey everyone,
Here are my questions:.... Any and all help is greatly appreciated.
--Matt
Hi Matt!
That sounds like it will be an awesome setup!
However ... I think you should post this in a separate thread, as THIS thread is dedicated to the TUNING FILES of the PP82DSP.
By putting this out as it's own thread you'll get a LOT more eyes on it and have a lot better chance of getting a reply than in this small, dedicated thread...
Just IMHO ...
All the Best, PuterPro
      05-09-2016, 09:58 AM   #79
jrod33084
jrod33084's Avatar
10
Drives: 2013 328i M sport
Any suggestions on a specific tune I should use with a Morel speaker setup with the bimmertech? I have morel virtus 402 components in the front doors and morel ultra integra 402 in the rear doors. Oem woofers under seats.
      05-11-2016, 04:30 PM   #80
constantin_md
Drives: 2014 F15 X5 sDrive35i
Hi Jrod, I'd cross the front at 110hz -24db attenuation and rear at 120 -24db Center speaker at 240hz -18db, -1 or -2db gain.. Subs at 120hz -18db. +1 or +2 gain.
Break-in your speakers for a week or two than try adding +1 or +2 gain on the front and rear speakers.
Leave the EQ flat and lower only the points closer to the attenuation.
Tune your speakers in pair (click both front right and left speaker/ rear left and right / both subs together) click mute on individual channels to get an idea what is what.
Setup time alignment by ear.
Tuning is easy once you understand what are you speakers capable of.
Downloading and installing tunes is a great reference, but most of them would not suit you. For example you might listen only on medium volume (lower crossover points possible, better mid sound) or higher volume (lower crossover points not possible, weaker mid)
Also depends on the genres of music you are playing , speakers may distort on some genres if you crossed them/EQ too aggressively but same configuration will sound great on other genres.
      05-11-2016, 11:04 PM   #81
jrod33084
jrod33084's Avatar
10
Hey constantin! Thanks for giving me the advice for these speakers. I had a feeling there wouldn't be many people out there with them. I'll try that tune out tomorrow.
P. S. Thanks again, they sound great!
      05-12-2016, 02:44 PM   #82
constantin_md
You are welcome! I'm glad that you like them.
Please post a video on youtube whenever you get a chance.
      05-20-2016, 12:45 PM   #83
arminvb
Drives: F30 Estoril Blue
Thought I'd post my tune too in case it helps anyone! I listen to mostly trance/electronic, but some rock music as well (Jimmy Eat World, Blink-182). I set the car's stock equalizer treble and bass all the way to the max, and then I based my tuning of the amp off of that.
FYI: I have a '13 328i with stock speakers and Bimmertech Amp.
Remember to rename the file extension to "afpx" after downloading.
      06-07-2016, 09:44 PM   #84
IXVXI
IXVXI's Avatar
Australia
132
Drives: G01 X3 M40i & F30 328i
Originally Posted by Nelson@BimmerTech View Post
Hi all,
Are these available in RHD? In particular in after the:
F30 Bavsound stage one, stock subs, RHD
Thanks.
      07-23-2016, 11:35 PM   #85
RoarinRow
RoarinRow's Avatar
Drives: 2012 328i Glacier Silver
2012 BMW 328i  [0.00]
2014 BMW X1  [0.00]
Just got my amp 2 days ago and loaded the bsw bimmertech file yesterday. Sounds very good but would like more samples for my F30 Hi-Fi with Bavsound Stage 1. Ghost subs expected to arrive this Wednesday.
      07-25-2016, 04:34 AM   #86
MSportTune2
Aland Islands
80
Drives: F30 MSport
Hi Nelson, it has been a while so pls advice any RHD tunes with BimmerTech amp, full stage 1 Bavsound (as per HK setup using BSM) and Bavsound ghost sub?
      07-26-2016, 04:05 PM   #87
parksy85
15
Drives: 2014 428i coupe
is there gonna be anything significant to adjust (aside from minor personal prefernce sound tweaks) from the bimmer tech F30 BSW tune if I am using it for an F32 with BSW (from a Hifi system)
2014 428i Alpine White M Package, H&R Sport Springs, Gloss Black Grill, 30% ceramic all around, Painted M Sport Style Trunk Spoiler, LED reverse lights, Brushed Finish 19" F14's, Bavsound S1 speakers, Bimmertech Amp
      07-28-2016, 12:56 PM   #88
messiry
messiry's Avatar
Drives: F15 X5 35, E60 530
Hi, please anyone can share his F32 tune for stock HiFi and LHD. Thank you
