11-29-2020, 03:13 PM | #1 |
128
Rep 163
Drives: F31 M Sport, 6MT, Alpine White
2021 Road Map EUROPE Next - Download Links
Just in case somebody need it, here are the torrent download links for the EUROPE Next 2021/1 Maps.
- EU West: https://mega.nz/file/3QZ0RDII#s4H5bn...ra-pU8xvH14HTE - EU East: https://mega.nz/file/7EZGTZoJ#3lPb-E...foOJkmtqQJOe8U
14
IAmATeaf237.50 HarryMrn15.00 cramsnik394.50 PTBimmer12.00 Tommi_Mav65.50 EvilDrPorkChop950.50 KoTuK0.00 Haldi0.00 Tijtsie0.00 intranet0.00 jaspanesar2.00 x-m4n148.00 Ravedave4.50 pavelpilek0.00 |
12-05-2020, 10:21 AM | #2 |
Rep 878
Thanks very much, just downloaded West 2021-1, if anybody needs it, the bytes from Info_Map for West are A9 50, if you want to generate your own FSC code for this update.
01-22-2021, 04:28 PM | #4 |
Rep 878
Is there a password? Don’t remember there being one when I downloaded.
01-23-2021, 10:51 AM | #5 | |
128
Rep 163
Probably asking in advance thinking that there's one.
01-28-2021, 11:48 AM | #6 |
Rep 4
01-31-2021, 06:14 AM | #7 |
Rep 15
Hello! On my BMW it says Road Map EUROPE Next 2017-2 NBT. Can someone please help me find the updated maps with that code I need for the installation? Thank you!
01-31-2021, 11:55 AM | #8 |
128
Rep 163
FSC Code is generated separetly using your VIN. It doesn't come with maps.
01-31-2021, 02:23 PM | #9 |
Rep 15
01-31-2021, 03:39 PM | #10 |
588
Rep 2,302
Ask here or buy an ENET cable and do it yourself with the right software.
https://f30.bimmerpost.com/forums/sh...d.php?t=949582 |
03-03-2021, 05:59 PM | #12 |
Rep 4
Hello,
I have downloaded Europe West and copied it to a usb 32FAT formatt. I extract all the files from the folder root and copy them to the usb. When I insert it, my car doesn't recognize it as a maps file, but as music file or smth.. Any idea why it might happen? Any step by step tutorial? Cheers and Thanks |
03-04-2021, 03:02 PM | #13 |
Rep 7
Can I ask if these updates risk bricking the drive? I was told a while ago by a leading BMW independent that any updates of this type or coding for CarPlay etc. Leads to bricking the unit when serviced by BMW as the unit has been “corrupted”
03-05-2021, 11:53 PM | #14 | |
128
Rep 163
I have done multiple services and BMW never told me anything.
03-09-2021, 04:09 PM | #15 |
Rep 878
Any update could potentially brick something if something goes wrong. I’ve done map updates on my car 4 or 5 times so far without any issues except the very first time when I had an incorrect FSC code. If your hard drive is on the way out then updating the maps could tip idrive over the edge?
03-19-2021, 04:15 AM | #16 | |
Rep 3
Same problem here. Did you find a solution? Thnx |
03-23-2021, 04:59 PM | #17 |
Rep 878
Does the usb have any other files on it? I have a specific usb drive that I use only for map updates with nothing else on it except for the map update files.
03-31-2021, 02:50 AM | #18 |
Rep 7
I seem to be having a problem with this.
I have a 64gb USB key formatted as FAT32. Extracted the contents of the map file to the root of the USB key. I then plug this into the centre arm rest of my F30.... Nothing happens. The USB key shows up as external media but nothing at all happens? This must be something I have done but for the life of me I can't figure out what. Any assistance would be appreciated. |
04-05-2021, 03:42 AM | #19 | |
45
Rep 155
iRACKERS4.50 |
04-05-2021, 08:50 AM | #20 |
Rep 7
Thanks for the response.
Yes it looks exactly like that. I can’t figure out why it’s not working. The car reads the usb stick as it shows up but it doesn’t automatically start the update |
04-06-2021, 03:46 PM | #22 |
Rep 7
**UPDATE**
I finally sorted this. Successfully updated my maps. The problem turned out to be that I was using a Mac not Windows. The Mac places hidden files on the USB stick that stops the car from reading it. I took the USB stick to a windows 10 pc, removed the hidden files from the root and bingo it updated. What I remain unsure about is wether exFAT formatting will still work or whether it HAS to be FAT32 only. Hope this helps someone else. |
TogoJatoba0.00 EvilDrPorkChop950.50 |
