BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 F30 Catless Downpipe
ARMA SPEED
      04-26-2024, 11:53 AM   #1
midnight335ix
midnight335ix's Avatar
Drives: 2013 F30 BMW 335i XDRIVE
I am trying to figure out the best sounding exhaust that isn't ridiculously expensive. I have watched/listened to so many soundclips and I can't seem to figure out what i'm wanting to do. I have seen and heard that the best way to really open things up and to get a great sound is simply to just go catless downpipe. My only concern is that if I do go catless, will I have to tune right off the bat with BM3 , will i need to have already gotten a cold air intake, will stock manual clutches be okay if i do end up going FBO stage 2, etc.
      04-27-2024, 03:51 PM   #2
thejeremyman9
thejeremyman9's Avatar
4376
Drives: 2015 BMW 335i
1. You dont need an intake for any tune
2. You can run catless DP without a tune but you will get a CEL, and if you've never smelled a catless car, be prepared for the fumes and smell. You also may not be able to pass emissions depending on your local requirements
3. Upgrade your IC and CP before tuning
      04-28-2024, 07:27 PM   #3
midnight335ix
Perfect! I had an Audi I went catless with and no tune so Ill be okay with the CEL and thankfully my location doesn’t do emissions. But that’s good to know regarding intake and all of that. I’ve always been told stock intake is the best besides having a muffled turbo sound. Definitely planning on doing IC and CP soon. Will probably do my CP when I do down pipe
      04-30-2024, 03:17 AM   #4
luca.aluigi
luca.aluigi's Avatar
Italy
Drives: M135i F20, Maserati Biturbo
i have catless downpipe paired with the standard cat back exhaust, for the CEL question i installed the MHD stage 0 and just flag the "aftermarket downpipe" and no CEL or issue (now stage 1).
The sound is a little bit raspy with too content of high frequency and not drone effect even an 35600rpm, very confortable set up and on full throttle is very satisfying.
For the perfect sound you have to upgrade only the axle back OEM muffler made by resonator chambers (works well at lower frequencies), because you need more low frequency tone you have to switch on absorptive type muffler.
2015 BMW M135i F20 LCI, man box, adaptive, HK, decat, MHD Stage 1, F21 underbrace retrofit, MP LSD, M4 LCA & TS, M Performance BBK, MSL oil Tstat, MPPK Airbox, CDV delete, Wagner EVO II, FTP CP, MST V2 turbo inlet, M2 sump and pumps.
... "beauty is the splendor of truth"...
      04-30-2024, 10:32 AM   #5
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
I recommend the REMUS exhaust with a high flow or catless downpipe for the best sound.
thejeremyman9 answered all your questions in his post
https://x-ph.com/sale/
Phone number 702-494-9435
      04-30-2024, 01:32 PM   #6
midnight335ix
mike@x-ph.com isn’t the Remus set up something I’d have to create. I feel like I’ve seen that somewhere in a similar type of post.
      04-30-2024, 04:42 PM   #7
mike@x-ph.com
Im not sure i understand your post. What do you mean by you have to create it?
      04-30-2024, 05:51 PM   #8
midnight335ix
mike@x-ph.com I mean more if like put the connections to the mid pipe and for the exhaust tips. I could be totally wrong but I could’ve sworn I saw it somewhere the other day.
      05-01-2024, 10:52 AM   #9
mike@x-ph.com
the REMUS will easily connect to the stock midpipe using the clamps thats provided with the axle back. you do not need to do any modifications except cutting the stock midpipe which is fairly simple.
