      04-20-2019, 09:13 PM   #1
rennwerkes
rennwerkes's Avatar
Drives: 2014 335i, 2013 135i, 1999 Z3M
Third Brake Light Cracking
The third brake light lens on my 2013 135i with only 34k on it has started to crack.
I took it into the dealer and asked them if this could be covered under my extended warranty. They were quick to deny my request.
What do you guys think? To me, this is definitely not a wear and tear item and shouldn't exhibit cracks so soon. Or am I wrong?
Thanks!
      04-20-2019, 10:05 PM   #2
Rikx1M
MSgt (ret)
Rikx1M's Avatar
Germany
563
Drives: VO 1M #739/740
Search will save u $$
Thanks!
Do a search for 3rd brake light service bulletin, print it out and take to BMW. There is a well documented problem with these lights....
      04-20-2019, 10:20 PM   #3
NorthernDancer
850
Drives: 08 Sedona 128 & 06 330xiT 6MT
This happens to all 1 series. I think your car is too old now to get a free replacement but do search for the bulletin (right here and via google). Mine was replaced once or twice under 1st owner. Mine is cracked now. Stayed that way for years but last year I put a bead of Gorilla glue on it. I also have a new one just in case this cracked one goes really bad.
This 3rd light is unique to the 1 series so eventually new supply will dry up.
      04-21-2019, 07:03 AM   #4
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
It depends on what your warranty covers. If it's CPO and bumper to bumper then it might be covered. If it's aftermarket like mine it's probably not covered.
That said the light is pretty inexpensive on Amazon and/or FCP Euro's site. I replaced mine and it was pretty easy to do. $50 for the part and about 30 min of my time.
Here is a thread. On page 2 or 3 there are links to a DIY by Dackel.
Gd.Dam Third Brake Light https://www.1addicts.com/forums/show....php?t=1496808
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
      04-21-2019, 03:09 PM   #5
rennwerkes
rennwerkes's Avatar
Thanks everyone for the info.
My warranty is CPO but dealer said no to replacement.
      04-21-2019, 05:16 PM   #6
gjm120
2183
Drives: 2013 128i, 2021 230i
I was thinking about buying one put in my spares for when mine breaks. Any guidance on whether BMW genuine or aftermarket like Dorman is the way to go? There is about 2x price difference for the BMW genuine.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
      04-21-2019, 05:18 PM   #7
rennwerkes
rennwerkes's Avatar
Is the Dorman part still available?
I can't seem to find it.
      04-21-2019, 09:22 PM   #8
gjm120
2183
I found it on ebay and at Parts Geek.
      04-21-2019, 10:32 PM   #9
Gangplank
Gangplank's Avatar
2011 135i  [0.00]
It's available on Amazonia and other sites. You might even be able to order it at Autozone...
      04-21-2019, 11:33 PM   #10
rennwerkes
rennwerkes's Avatar
How are you guys searching for it on Amazon?
I've tried and come up with nothing.
      04-21-2019, 11:39 PM   #11
rennwerkes
rennwerkes's Avatar
LOL! I found it on both Amazon and Ebay.
I was using the BMW part number when I should have done a more generic search.
Thanks!
      04-22-2019, 09:47 AM   #12
Jason G
Drives: 2009 128i
Can somebody tell me the size of the 3rd brake light lamp nut? My replacement lamp is oem from ECS and the threading of the post is different from the original. Thanks!
      04-24-2019, 12:31 PM   #13
NorthernDancer
850
http://www.realoem.com/bmw/enUS/part...&q=63259128043
M5; it's been on almost every BMW since 1972.
      05-02-2019, 06:18 PM   #14
Horigan
Drives: 2011 135i M-Sport
To improve longevity of the new light, don't crank the nuts all the way down and fully compress the spring. Just compress the spring a little bit so that the perimeter foam creates a seal. I think over torquing the nuts is a major factor in cracking this weak design.
      05-02-2019, 08:11 PM   #15
rennwerkes
rennwerkes's Avatar
Can someone confirm if installing a new lens requires new nuts? Or can you just reuse the original nuts? I recall someone mentioning that the threading is different.
      05-03-2019, 11:30 AM   #16
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Re-use, Not sure where why that one person above said it was different.
      05-21-2019, 10:19 PM   #17
rennwerkes
rennwerkes's Avatar
Updating this thread.
Bit the bullet and bought a factory lens. Also bought new springs (because most of the DIY's mention that) BUT my springs were already updated. Not sure if it's because my car is a 2013 (late production) or because it's been changed before.
What was even more interesting is that the lens fit perfectly. Others were mentioning that you had to modify the lens to get it to fit. I guess I lucked out with my car so no mods necessary. Pretty straight forward and took very little time. No gotcha's at all.
One interesting observation was that the nuts on the original lens were really tight! To a point where I unscrewed the the mount out of the light. I have no idea why anyone would want to tighten it that much. In fact, I could finger tighten the nuts all the way down to the base and then I back off a bit hoping it'll prevent future cracking. Now I just hope it won't leak.
I did clean the opening of any residual dirt and dust.
Thanks again for all the advice and comments.
      07-03-2019, 12:30 PM   #18
atch417
atch417's Avatar
20
Drives: 2011 BMW 135i
Mine is also cracked on a 2011 with 41k miles 🤬
      09-27-2020, 01:04 PM   #19
PCNewman
Drives: 2009 128i Coupe
Anyone figure out a way to prevent or at least prolong this issue? I thought about hitting it with a heat gun prior to install to help it mold to shape.I'm replacing mine after 16 months. Thinking Doorman or China next time around.
      09-27-2020, 06:27 PM   #20
BMWCCA1
BMW Owner Since 1971
2258
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
BMW made modifications to the trunk lid at some point and the "tab" in the brake-light opening was removed. The replacement lamp BMW supplies now won't fit the trunks with the tab. The factory bulletin for replacement instructs to grind off the tab on older cars but I didn't like the idea of introducing rust into an historically vulnerable area on older BMWs when I replaced the light on my wife's '08.
This is what I used which will fit both versions, it is inexpensive, requires no modifications for either version, and cannot be distinguished from the OE part:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You can see my post on the thread here. I also replaced the springs, but the nuts worked on the new light perfectly
      09-27-2020, 08:32 PM   #21
rennwerkes
rennwerkes's Avatar
I did notice that the nuts on my original lens were really tight upon removal. So on the install I just snugged the nuts down gently and so far no problems.
      09-27-2020, 09:57 PM   #22
c0bra
Commander ;)
c0bra's Avatar
Drives: E88 N54
Recently replaced mine, and the nuts were on way too tight. I ended up pulling out 2 mounts and couldn't even get the nuts off the mounts, so I was lucky I had replacement nuts. The prior replacement was done at a dealer.
Recently installed, so idk how long it's going to last... Hand tightened the nuts from inside out (torque is supposed to be 2.5 Nm), filed down the tab more than it already was (dealer had filed some and used new springs), and used Dremel to remove notch on OEM replacement.
https://www.newtis.info/tisv2/a/en/e...lights/PoMpSk4
2009 N54 1er Cabrio
2021 C8 Stingray Z51
2022 Audi Q3
