      12-08-2022, 07:58 PM   #1
Ralph123x
18
Drives: 2018 BMW 330i (F30)
Transmission Oil Change interval for Automatic?
Hey all,
I have a 2012 BMW 128i, automatic trans. About 65k miles in USA.
I'm confused on if I need to change my automatic transmission fluid or not. Every place says different things. Some say I don't need to change it for auto. Mike Miller and etc. says change every 60k miles. Others say change every 100k miles. I'm not sure which one is true.
I do want to mention that my car shifts very smooth currently imo. If it's working smooth, leave it alone?
Thanks for the input!
      12-09-2022, 10:11 AM   #2
gjm120
2183
Drives: 2013 128i, 2021 230i
Originally Posted by Fer123x View Post
Hey all,
I would definitely change it. Did mine at around 50,000 miles only as a preventative measure. Shifted fine before and was a bit better afterwards. Just whoever does it, make sure it is refilled correctly.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
      12-09-2022, 11:24 AM   #3
Ralph123x
18
Gotcha! And I'm assuming you have automatic transmission as well?
May I ask which fluid you've used? I've read people here recommend "Redline ATF-D4" but that seems like it's only for the manual gearbox.
      12-09-2022, 12:39 PM   #4
gjm120
2183
Yes AT and I think you're correct about the Redline ATF-D4 being for MT.
I think any good synthetic Dexron VI would be fine to use.
My car was still under wtty when I did it so I used Genuine BMW fluid & filter. It was probably foolish to spend the extra vs something else. I mean, would BMW have done a forensic evaluation of my AT if it failed?
      12-09-2022, 01:12 PM   #5
Ralph123x
18
That's awesome, thanks for the details.
I just bought the genuine Transmission Filter Kit (Part #24152357284). Will probably just use Valvoline MaxLife Dexron VI.
gjm1202183.00
      12-12-2022, 09:31 AM   #6
gjm120
2183
If you are going to DIY and haven't already done it, this is pretty good.
https://www.1addicts.com/forums/showthread.php?t=995991
PS: I'm not sure his adaptation reset procedure works and from what I've gathered, isn't necessary on the GM AT.
      12-22-2022, 05:44 PM   #7
Ralph123x
18
Got it changed with Valvoline MaxLife ATF - DEX VI.
The first change it shifted rough and made noises. Took it back to the mechanic and we found out it wasn't filled at the proper temperature with the car running. The fluid was low (Only took 4 qt). Tried to fill more after letting car run for awhile; this time it took more fluid in.
First it took only 4qt, but when doing it while running, it took 2 more qt. Total it took 6qt.
Now shifts the same as before. Which is very well and smooth. At 65k miles, my old fluid wasn't too bad.
I did the whole fluid, pan gasket, and transmission filter.
      12-23-2022, 11:11 AM   #8
gjm120
2183
Glad you got it filled correctly. At least you / your mechanic caught the error quickly. I've heard of people wondering why their car shifted poorly and being surprised it had to be filled running at a certain temperature.
      12-23-2022, 02:32 PM   #9
Ralph123x
18
oh for sure! I got really worried on the drive home. Started researching and thought my transmission was toast or something. Then people were saying you have to fill it while running which I don't think they did. And later we found out that was the case.
gjm1202183.00
      12-24-2022, 08:37 PM   #10
Blau
J
Blau's Avatar
Drives: BMW 128i
2011 BMW 128i  [6.00]
2013 BMW X3 28i  [0.00]
I'm not doing the fluid change on my trans b/c I want it to granade so my wife won't question it when I manual swap.
Join me brother.
gjm1202183.00
      12-25-2022, 02:51 PM   #11
gjm120
2183
Join me brother.
I keep wanting a manual but then appreciate the laziness of the auto. I'd love to have a 2nd 128i with MT but talk about impractical.
      01-03-2023, 10:02 AM   #12
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
We did an oil & filter change at 50k miles. Had to fight with the dealer to get them to do it. There was a big improvement in the shifting. Did it again at 100k miles. This time they only changed the oil. Had to fight with them to change the filter. Plan to do oil & filter again at 150k.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
Artdnj394.00
      09-26-2023, 08:12 AM   #13
Artdnj
Artdnj's Avatar
Drives: 2023 X3 X30i
What was cost for filter/fluid change at the dealer?
