      05-31-2011, 07:20 AM   #23
aacabriolet
aacabriolet's Avatar
118
Drives: '14 435i Coupe
Thanks for the pic.
Well it's bi-xenon so it must have a "shutter". When you flick to high beams, the shutter opens and lets more light out, basically changing the cut off of the D1S to allow more light out, thus becoming the "high beam".
See here:
Now I don't know in your pic if that arrow is the shutter, or some other thing, but it must have a shutter.
What's the Red wire in the bottom of your pic for?
You said you could tap the high beam and low beam wire? Do you mean Shutter wire and Low beam wire?
If you tap the shutter and low beam wires, won't every time your low beams come on, the shutter will open?
You will want to tap the shutter wire to the high beam cable from the FRM Footwell module somehow.
      05-31-2011, 07:59 AM   #24
Drawn05
Australia
67
Drives: Yes
Well then I guess it must be the shutter, cant really see inside very well but it seems to be similar to what is in that video.
So the wires on that shutter are wire 5 on the headlamp socket. So adding a new wire to position 5 on the car socket and splice it with wire 6 should work.
      05-31-2011, 08:12 AM   #25
aacabriolet
118
I would think so. But do you really want to splice/tap into stock car wires?
I would rather do it from the inside of the xenon headlight if possible, behind the xenon car connector/socket??
So if possible, add a new wire to empty pin slot #6 of the Xenon Headlamp Socket using the pin contacts i posted one page back? And then splice the shutter wire to this new wire inside the headlight? I dunno though, do you think you can fill the empty pin slot like that from behind the socket?
That way you preserve stock wiring and don't have to modify/splice/tap into stock wires.
What do you think?
      05-31-2011, 08:27 AM   #26
Drawn05
Australia
67
Drives: Yes
I was wanting to work from inside the headlamp but now that I got them it seems very cramped and difficult to work in. Disconnecting the socket inside the headlamp looks like a real PITA. I think adding a wire and using self stripping wire taps would be far easier and wouldnt be very difficult to undo
      05-31-2011, 08:33 AM   #27
aacabriolet
118
Perhaps you're right. Can't wait to get mine and give it a go! You should try hooking your lights up anyways and see what happens? You dont have to remove the bumper just yet, just rest the headlights in your engine bay and plug the connector out of your halogens in (if it reaches that is). I guess you have to disconnect negative from your battery in the boot while disconnecting/connecting just to be safe though (standard BMW procedure).
Do you think the low beams will come on if you just plug them in, or do you have to connect them to the new ground wire?
Itching to get mine now!! Keep me updated plz
Also keep the thoughts coming, seems like we might be getting somewhere.
      05-31-2011, 04:49 PM   #28
Elliott@DetailAddict
Drives: E90
Looks like you're making good progress Ari!
Don't forget once it all wired up correctly, you'll need to add in the Xenon retrofit in coding for full functionality.
      05-31-2011, 04:54 PM   #29
aacabriolet
118
Thanks Don't worry, you will hopefully be sorting that out for me
Are we on the right track in terms of wiring you think? Got any experience with wiring?
      05-31-2011, 08:44 PM   #30
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
Hey guys.
Got directed here by aa. Looks like you guys are doing the halogen to xenon conversion.
My e90 has the conversion and coded it to work like OEM. You guys are on the right track. Gonna read it over and add to it if necessary :-)
      05-31-2011, 10:53 PM   #31
CentralPA E82
Rookie
Drives: 2009 128i
Based on the pictures provided by Drawn you will need to tap wire 6 and wire 5 to enable the shutter for high beams. One thing to note, you will need to disable the drls if applicable otherwise the shutter motor will hum constantly. Will keep you posted.
      05-31-2011, 11:10 PM   #32
aacabriolet
118
Thanks guys appreciate the thoughts here.
Thanks for that. That's what we thought. Is that what you did on yours?
Alsojust wondering - why would the shutter motor hum if DRL's are on? Surely they're not linked in terms of wires?
My car doesn't have Automatic headlights at the moment. You said "if applicable". - does that mean I don't have DRL's?
Also how did you wire the low beams? Any wiring modification needed apart from the new ground wire?
Thanks!
      06-01-2011, 12:03 AM   #33
Drawn05
Australia
67
Drives: Yes
I just ordered the contact pin connectors from my local dealer, I have to pick them up tomorrow. What I ordered was:
2 x 0.75mm connector
2 x 1.00mm connector
2 x 1.5-2.5mm connector
I am pretty sure that the one needed for wire 2+4 is 2.5mm but the smaller ones could be either .75 or 1.00 so I got both sizes just in case.
      06-01-2011, 12:06 AM   #34
aacabriolet
118
Cool thanks, I'll order the same. Even though I will have the proper xenon wiring harness in the retrofit kit... But I'm not gonna get all the way to the footwell module to plug that in lol. Well maybe if I knew how I would..
Any specific type of wire you're thinking of using??
      06-01-2011, 04:09 AM   #35
toto4dwin
15
Drives:
Sorry aacabriolet for not answering your questions earlier. Out station again.... I can't come in here a lot cause of my work schedule
So to make it up, I got the official retrofit instructions. I hope you find the wiring information useful.
      06-01-2011, 04:32 AM   #36
aacabriolet
118
Toto you are awesome!! Thanks so much. Will def come in handy.
Keep checking back when you have a chance how's the status of your lights?
      06-01-2011, 06:37 AM   #37
aacabriolet
118
Hmm ok regarding socket contact size:
Thats from the official retrofit guide that toto kindly posted.
So here are the part numbers I think we should be looking at?? (from http://realoem.com/bmw/showparts.do?...=61&fg=15&hl=1)
For Pin #5 (Bi-Xenon Shutter)
08 Socket contact ELO-Power 2,8x0,63 0,35-0,5 MM² 61138377162
10 Rubber grommet ELO-Power 2,8x0,63 0,35-1,0MM² 61138369722
For Pin #2 (New ground wire)
08 Socket contact ELO-Power 2,8x0,63 1,5-2,5 MM² 61138364834
08 Socket contact ELO-Power 2,8x0,63 1,5-2,5 MM² 61138369634
08 Socket contact ELO-Power 5,2x0,63 1,5-2,5 MM² 61138369642
10 Sealing grommet ELO-Power 5,2x0,63 1,0- 2,5 MM² 61138372628
So it's probably one of those, but maybe just order all to be safe??
      06-01-2011, 11:14 AM   #38
CentralPA E82
Rookie
Drives: 2009 128i
DRLs on the US cars with halogen use the high beam at a reduced voltage. The problem with a xenon conversion is anything under 12v to the shutter will cause the motor to hum (needs 12v to trigger the open position for high beams). You can disable the DRLs through the turn signal stalk (scroll through the settings for the key icon with a checkmark, select using the button on the end of the stalk, scroll for the headlight icon with the sun like symbol next to it and select the off setting). As a side note, the E82 Euro setup does not use an H7 bulb. The inner bulb you see through the glass is the H8 for the rings.
      06-01-2011, 12:15 PM   #39
aacabriolet
118
Aah thanks for that! Makes sense now!
I was wondering what that bulb in the inner projector was! cos it looked like an H7 to me.
So do I not need to worry if I don't have DRL's currently on my car? I have a EURO build.
Thanks!
      06-01-2011, 12:40 PM   #40
CentralPA E82
Rookie
Drives: 2009 128i
To AA: the low beams only require the add'l ground wire to work properly (with coding of course). The high beam requires a tap of wire 6 to wire 5.
If we can figure out the coding we are good to go. I have NCS Expert however the OBDII cable I purchased was junk. Waiting to hear back from Autologic before I spend funds on another cable.
      06-01-2011, 12:56 PM   #41
aacabriolet
118
Perfect. Thanks. Is coding only to remove errors?
I ordered this cable which seems to be the one everyone is using. He accepts $90 if you make an offer. http://cgi.ebay.com/ebaymotors/BMW-I...QQcmdZViewItem
It should be arriving in a few weeks. I think coding might be the easy bit somehow
Do your low beams still flicker when you turn the car on? Does it go away or keep flickering?
      06-01-2011, 01:52 PM   #42
amancuso
amancuso's Avatar
726
Drives: 330it, 428ix, 430i
You sure about the DRL? My halogens have a small (what looks like a 194) bulb that is the DRL, not high beams at reduced voltage.
2016 428ix, r, 2018 430iC, 2018 330it
      06-01-2011, 03:06 PM   #43
AW128i
AW128i's Avatar
Drives: E82 N51
The halogens actually do run the high beam at reduced voltage for the DRLs (if enabled). The small 194 bulb located in the high beam reflector is the city light, or parking light in the U.S. On the HIDs, the corona rings are the city lights...aka parking lights.
There are two versions of the OE HIDs, adaptive and non-adaptive. The adaptive lights (standard U.S. HIDs) do not have a halogen high beam at all and instead have a "cornering" light in place of what would normally be a standard high beam. These lights rely solely on the bi-xenon projector for low- and high beam functions, including the flash-to-pass function. The non-adaptive HIDs (not available in the U.S.) use a standard halogen high beam (albeit, in a projector) in addition to the bi-xenon projector. Whether this is only used for flash-to-pass or if it's also used as a high beam supplement to the bi-xenon projector, I'm uncertain. I'm guessing that the latter is true, as this is common practice on other German makes in Europe and the U.K.; e.g., VW and Audi.
Both versions of the OE HIDs have the corona rings implemented at city/parking lights. That being said, the pics posted in this thread of the back of the headlight assembly are confusing. Are we looking at the adaptive or non-adaptive lights? It would seem, from the bulb layout alone, that we're looking at the adaptive lights as I don't see a bulb for the halogen high beam.
      06-01-2011, 03:17 PM   #44
aacabriolet
118
I don't know, it's all very confusing to me as well..
From what I understood, the Adaptive has the high beam H7 bulb, and the Bi-Xenon doesn't have the high beam H7 bulb.. But then you say it's the opposite? I guess i'll find out tomorrow when my Bi-Xenons arrive. Will let you know.
You've done the halogen --> Xenon swap haven't you?
Any tips you can add?
