FrankenTurbo
02-24-2016, 05:52 AM | #89 | |
Real Car Enthusiast
288
Rep 2,081
02-24-2016, 11:01 AM | #90 |
173
Rep 280
Excellent info! I have a lot of friends in the VAG scene and am very familiar with your products. It's great for me to read through your development process. You often don't get a chance to see why something is done a certain way. Nice job!
02-25-2016, 08:38 PM | #93 |
257
Rep 109
Exhaust system mods underway. We went with VRSF 3" units. They are inexpensive, well-made & install just as they should. In other words, they are a great value for this kind of mod.
They didn't stay intact for long, however. Bungs for EGTs and back-pressures got added before the installation. Side-by-sides Installation EGT probe post-turbine With the primary cats gone there's no longer any rationale for monitoring temps at that location. So the probe now lives post-turbine... until the first modified turbos get fitted. |
02-25-2016, 08:44 PM | #94 | |
Rep 3,338
Drives: X5 & E90 WTCC Racecar (SOLD)
02-25-2016, 09:39 PM | #95 | ||
21
Rep 40
02-25-2016, 09:48 PM | #97 |
First Lieutenant II I know enough to be dangerous
76
Rep 465
Doug- thanks for taking the time to document and share. I'm learning quite a bit just from observing.
2010 E90 LCI N54 335xi / AR DP's / KW V1 / Stoptech Slotted Rotors / SS lines / EBC Yellowstuff / Fuel-it stage 2 LPFP / Fuel-it Bluetooth Content Analyzer / ETS FMIC / VRSF CP / TurboSmart Dual Port Kompact kit / MHD / WEDGE E60 ProTune / CORSA Exhaust / Alpina TCU / VTT Outlets / MMP Inlets
02-26-2016, 01:39 PM | #98 | |||
Macgyver
208
Rep 942
Good day sir ...good day.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
02-26-2016, 03:34 PM | #99 |
66
Rep 246
Ignorance
Good work Doug, some people justify there unhappiness by just shitting on everything around them. All we can do is smile and pray for those people . Keep up the good work
02-26-2016, 03:36 PM | #100 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Go away troll, no one likes you.
02-26-2016, 05:47 PM | #101 | |
Rep 3,338
02-26-2016, 05:49 PM | #102 |
Rep 1,155
I am loving this thread. will definitely be watching very closely now that my turbo seals are going out.
02-27-2016, 03:12 AM | #103 |
257
Rep 109
Before startup I'd feared the modified exhaust system would sound awful. Especially during the warm-up cycle. But after lowering the lift and turning it over I was happy. The exhaust note was not ruined. In fact it seemed to be simply a louder version of its old self. That suited me fine, so I grabbed the laptop and took the car straight to our top-secret testing spot. At wide open throttle the new system again presented itself attractively: a slightly more pronounced throatiness, but no rasp or sharpness.
So what of the exhaust system back-pressures? Did the removal of the primary cats change the readings? On the stock system the pressures went above 7psi. But with the upgraded down-pipes, we now have this: Unmistakably the post-turbine pressures are lower. The exhaust system flows measurably better with those primary cats removed. But...here's the thing: the data logs aren't showing much of any benefit. Here are the principal data points: And here are those same measurements weighed against those from the full exhaust system: Air/fuel, ignition advance & boost duty are all identical between the pulls. And intake air temperatures are slightly in favor of the most recent pull. Nevertheless, actual boost falls off just as sharply as before. The other data point to the same thing. here is the time-to-speed chart: But the most illustrative of them all is the 4200-6500rpm sweep. The time calculation for that comes in like so: Exactly the same as the stock exhaust system delivered. In my view, for any hope of gains made by modifying the exhaust, ALL of the cats have to be removed. We'll test for that next. Last edited by doug@frankenturbo; 02-27-2016 at 03:18 AM.. |
02-27-2016, 06:13 AM | #104 | |
Real Car Enthusiast
288
Rep 2,081
02-27-2016, 09:03 AM | #105 |
46
Rep 231
I for one, am glad that Doug is taking the time to test out these "upgrades". What happened to the 15-20 extra hp gain from just swapping in a set of catless kitties? Don't get me wrong, I'm running these kitties as well and frankly, I'm disappointed by Doug's results but at least my exhaust sounds meaner than before lol.
Looking forward to more testings and results
I don't drive fast, I just fly low...
02-28-2016, 08:09 PM | #106 |
Rep 22
Thank you for making this thread. As a brand new 335i owner, I find it very informative and helpful. It's nice to see a methodic study of the car from scratch. The exhaust issue you've found sort of confirms my initial theory with the downpipe you chose to use as well. However, your readings might be misleading- if your sensor is in the 3" section of the pipe, Bernoulli's Principle dictates that the pressure here will be higher than if it were measured at the exit of the turbo, which I believe is 2.5". I'd be interested in a test with a pipe that was of consistent diameter from the turbo to further back in the system where the exhaust gas temperatures begin to fall off.
02-28-2016, 08:18 PM | #107 | |
Rep 1,659
Since you already have MHD, it would be interesting to see the time comparisons in this state of hardware - backend flash/JB4 vs Stage 2 MHD flash. Edit: I've been watching this platform evolve since late 07. It is refreshing to see someone new to the platform validate for himself what is considered "truth". Last edited by mwahlert; 02-29-2016 at 09:32 AM.. |
02-28-2016, 10:32 PM | #108 |
Rep 1,665
Great work! But why does everyone keep quoting every post with pics. Just useless and repetitive! Lol
2011 335IS Alpine White|Coral Red|DCT|BuraQ E60 Tune|DCI|VRSF 3" DownPipes| ER ChargePipe w/ HKS SSQV BOV|VRSF 7" FMIC|RB PCV| BMS Oil Catch Can|NGK 5992|AQUAMIST HFS-4 w/Twin Methanol Tank|Custom Exhaust| ST Coilovers| and a METAL FOOT
02-28-2016, 11:26 PM | #109 |
Rep 574
You do realize the dme targets load, and flash tune/jb4 alike are effected by this right? So you measured a 2+psi drop in exhaust pressures, which is nice considering it's on both banks (what is that a 30% reduction?), and you now notice a drop in boost at the same wgdc due to an increase in airflow through the motor. You just proved what everybody already knows, downpipes make the same power at lower boost. Post turbine changes are different than pre turbine. Post turbine increase ve and make the turbos work harder, pre turbine help efficiency and reduce pressure drop.
02-29-2016, 11:12 PM | #110 |
257
Rep 109
Secondary cats are now deleted, replaced with a pair of Vibrant resonators.
Resulting data in a bit. |
