Tuner Shootout (Procede / JB) - The Bench Tests
12-30-2008, 01:59 PM | #45 |
Rep 151
Hi Scalbert,
First, thanks for the testing and posting. Second, you say "The JB3 sinks the signal through a transistor. Meaning that the DME is still directly connected to the solenoids but the JB3 has the option of adding duty cycle. The benefit to this is that in the event of a JB3 component failure, the DME can still run stock boost levels." Wouldn't this "fail safe" depend on whether the transistor or a component controlling it caused the transistor to be open or closed (shorted)? Again, thanks for the information. |
12-30-2008, 02:03 PM | #46 | |
60
Rep 2,014
apparently we do not know why.... Care to explain? We are here in this post to learn about the tunes.. BTW Scalbert.. Excellent info! Thanks |
12-30-2008, 02:05 PM | #47 |
Rep 5,780
That is true, if it failed closed you would essentially be at 100% DC all of the time. Great for response but not good for the turbos or engine. But looking at the circuit, I do not see it happening.
12-30-2008, 02:31 PM | #48 |
Rep 1,283
as a tuner on this car, on these turbos i would rather run 15-16 psi and more timing than 17-18psi and less timing AND the lower boost car in this situation "should" make more power. Timing can be advanced or retarded a number of ways directly and indirectly ie ait temps, less exhaust backpressure and by manipulating the crank trigger signal to name a few
12-30-2008, 02:45 PM | #50 | |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
In the case of the BMW, the engine costs about $20k+labor to replace. The turbos about $4k+labor. And if an engine fails, bits of ring land, piston material, valve bits, etc,. it will probably take out the turbos anyway. Also, in the the comparison mentioned above, one thing that wasn't mentioned is that the supposedly less boost car (again, no boost logs to support that claim) was a 6MT running every possible mod versus a 6AT running dual intakes, Helix FMIC and a home brew catless exhausts. Shiv |
12-30-2008, 02:50 PM | #51 | |
Rep 1,283
im on the fence in this discussion but what you are saying in regards to "first to fail" is true. Personally i would err on the side of caution and tune my 93 octane maps on 91 to be safe in regards to BOTH boost and timing and allow the dme to auto adjust the timing back up for the increased octane.
12-30-2008, 02:58 PM | #52 | ||
1750
Rep 17,960
Drives: A Lot
Also, there is no question that the timing is eventually retarded with the JB3. The question one should ask is if this timing retard is induced proactively by the JB3. Or reactively by the factory ECU's knock control system. Both approaches end up at the same power level. And both approaches provide roughly the same seat-of-the-pants performance. But its the later approach that will shorten the life of the engine by the damaging cumulative effects of knock. There is a reason why the Attache, Xede, E-manage, etc,. ALL actively retard timing through CPS (Crank position signal) offset. Not offering that would make those devices little more than glorified boost controllers that don't address everything needed for a proper safe tune. The temptation to omit this feature is tempting as it accounts for at least 75% of the work required to design a full functioning piggyback. It's one of those things that you can't do "well enough". it has to work perfectly. Or else the car simply wont run, misfire, throw crank sensor related codes, etc,.) Sure, in all fairness, there is always a chance that BMS is employing a previously undiscovered way of proactively retarding timing that doesn't involve CPS offset. But if that is the case, why does the press release that Terry posted say this: Quote:
My 2c, Shiv Last edited by OpenFlash; 12-30-2008 at 03:30 PM.. |
12-30-2008, 03:09 PM | #53 |
Rep 726
awesome thread.
Everyone should be really paying attention to this as these are typically things kept fairly close to the chest by tuners. Scalbert and Shiv are providing invaluable information about these tuning systems and they should be commended for it. Honesty in this industry is hard to come by. I also hope Terry can come in here and shed some light on his system as well as I believe there is a great deal of speculation going around and nothing right from the horses mouth. We are eager to try the proceed system here at the shop knowing what the JB3 is capable of and honestly seeing this breakdown by scalbert makes me want to try it even more. Eric |
12-30-2008, 03:55 PM | #54 |
Joint Chiefs of Staff
4927
Rep 116,037
That was a great read and an amazing job on pulling that together. I think I can speak for everybody in thanking Scalbert for taking the time to do this testing. I can't offer much technical insight but there is a parallel thread for those who are interested in BMS' comments.
12-30-2008, 04:01 PM | #55 |
94
Rep 2,339
We need less incite and more insight anyway.
Steve is da man. I just wish I knew what the heck he was 'splaining.
What do I know? I'm insane.
12-30-2008, 04:06 PM | #57 | |
1750
Rep 17,960
Drives: A Lot
On his forum, Terry is very vocal when it comes to pointing out completely fabricated design "flaws" in the PROcede. Such as: 1) Elimination of all ECU provided safety features (untrue) 2) Diagnostic visibility of Torque Targeting logic (untrue) 3) Diagnostic visibility of speed delimiter (untrue) In fact, he bans people for even contesting his statements. And now when scientific data is presented that questions his claims, he stays quiet. Shiv |
12-30-2008, 04:10 PM | #58 | |
94
Rep 2,339
12-30-2008, 04:17 PM | #59 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
12-30-2008, 04:18 PM | #60 | |
60
Rep 2,014
Irrelevant to the technical sides of the tunes...... |
12-30-2008, 04:23 PM | #61 |
866
Rep 2,897
With all due respect to this forum which I love, it is very unfair and biased that Shiv gets to respond and make all kind of claims whereas Terry is shut out...
Whaterver the past or the reasons are .. Just my 2 cents Great thread though, lots of great info and I would agree that BMS does need to shed more light of the whole timing issue... I am an example of a potential customer on the fence still undecided which tune to buy, and I am getting a bit skeptical about how the JB3 works in terms of timing retard... |
12-30-2008, 04:27 PM | #62 | |
Rep 2,014
You clearly know your stuff, but your stirring of the pot is completely unnecessary and makes you look like a bitch. Keep this thread clean! |
12-30-2008, 04:30 PM | #63 | |
Rep 5,389
Ever since Terry went out to do his own thing with his Juice Box, there has always been a very competitive arena for the N54 "piggyback." However, I can say (being here when Shiv began tuning the 335i when he first bought his own 335i on 9/1/06) that Shiv has always been very forthright on how the N54 engine works and how he can tune it with a piggyback computer. Scalbert is doing an AMAZING thing for all of us here, going into the complete technical differences between the top two piggybacks for no monetary compensation from anyone (I hope j/k). It would just be great if the consumers could get ALL the facts from BOTH tuners about how their respective piggyback boxes work.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
12-30-2008, 04:33 PM | #64 | |
1750
Rep 17,960
Drives: A Lot
On a serious note, Terry has responded to scalbert's results on his forum. Just not with any worthwhile info. Also, Terry routinely asks his vendors to speak for them by actually giving them text to post as their own (see N54tuning.com's post above as an example). Terry is here and perfectly active on this forum. Shiv |
12-30-2008, 04:34 PM | #65 |
Rep 10,587
I'd love to see both sides really give full disclosure here, but it isnt going to happen IMO.
and Shiv, no reason to get too up in arms over this
12-30-2008, 04:39 PM | #66 |
1750
Rep 17,960
Drives: A Lot
