10-19-2017, 12:27 AM | #23 | |
1078
Rep 2,358
I had a much higher oil consumption on 10w30 compared to 10w40 - never using that thin horse-pis again and no more BMW oil. I am doing Motul Excess 8100 only going forward!
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
10-19-2017, 12:33 AM | #24 | |
Rep 469
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
10-19-2017, 02:07 AM | #25 | ||
37
Rep 122
Ideally you want a thin oil on cold starts to improve flow to critical engine components, and an oil thick enough when warm that it provides adequate flow and pressure without altering the engine's operating temperature (or wandering outside of manufacturer recommended viscosity/properties). Also, the larger gap between cold viscosity and operating temp viscosity will change as the viscosity modifiers wear. The larger the gap, the greater potential of viscosity modifier wear (changing your 10W40 to, for example, a 10W30 weight oil). I don't think I remember the last car that's called for 10W weight oil; everything here in Toronto is generally 5W or even 0W. |
10-19-2017, 07:06 AM | #26 | |
Rep 3,947
10-19-2017, 10:20 AM | #27 |
37
Rep 122
10-19-2017, 01:44 PM | #28 | |
Rep 10,358
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-19-2017, 01:47 PM | #29 |
Rep 10,358
Unlikely over a 10k mile OCI.
10-19-2017, 03:25 PM | #30 | |
Rep 3,947
I replace every 5,000 miles if there's track usage. Every 7,500 miles if no track usage. |
10-19-2017, 03:35 PM | #31 |
37
Rep 122
And you've both conducted oil analysis tests? I think most industry professionals consider 10,000 mile intervals to be extreme. The problem is only compounded by having more broad multi-viscosity oils.
I'm curious how much a multi-viscosity modifier wears at 5k vs 10k intervals in oils with broad weights. Mind you, my arguement is from a theoretical position. Last edited by Bestodabest; 10-19-2017 at 03:58 PM.. |
10-19-2017, 05:03 PM | #32 |
Rep 1,782
Well I'm at 67-68k miles now. I should probably be cautious but I drive my car like I stole it 24/7 so we shall see. Sometimes it sees E85 and or 110 octane fuel and sometimes it's just regular 93. Tranny was replaced under factory warranty (6MT) and then I got an extended. Had mods on the car I have Now and they didn't say anything. My dealer is super cool. Hopefully I don't have any issues with my car however if I do I have a feeling they will take care of me. All my service work is done at the dealer.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
10-19-2017, 10:00 PM | #35 |
1078
Rep 2,358
Only using 5W because temps never fall below 10°C where I live
In Motul I trust
(A Dane in China) Last edited by harkes; 10-19-2017 at 10:10 PM.. |
03-02-2018, 03:57 AM | #36 |
Rep 9
saw this was not an realy old thread so i did like to respond.
here to a new enigne replacement.... runned JB4 with first only intake.. then i putted dp and in2 weeks i blow my rod bearings. Did change them.. 300miles ... again a knock at 2500rpm .. did put an complete new engine. i was sick of it. my car only did had 99K km's Now i want to tune again because maybe it was the fault of JB4 because i was running that 2 weeks map 2. and now after a lot of researche they said you need an bigger intercooler for map 2.... Always did good oil service . every 10-15k. Castrol 5W-30 LL-04 .BMW Dealer did nothing . They just swiped it away and says that they never heard of it and its not possible , let them checked it and had to pay 100,- for looking in te il filter... stupid guys there. Its sure a common thing at the n55. but is see people run 450pk 500pk and i run 360pp-380pk for 2 weeks and i broke directly ?? Mosselman here says that it was related to the JB4 (ofcourse they wil because want to sell there own) More people with this problem with the JB4 . car is now complete standard . only got intake and Bastuck end muffler. Drives better and much stronger than the old engine . My turbo was been set over from the old engine. was in very good shape. did pay total 6500,- for an engine with 3 km's . dealer did send me a 16,5K reparation... Like to year from you guys. |
03-02-2018, 04:26 AM | #38 | |
Rep 1,252
something was wrong with your old engine.
Docrace 6266
03-02-2018, 05:07 AM | #39 | |
Rep 9
I think it maybe ls wel ... but its strange some people stil got the issue . Its a expensive choiche if its happens again .. Engine now got 4k-5k km’s |
03-02-2018, 05:08 AM | #40 |
Rep 9
03-02-2018, 11:57 AM | #41 |
Rep 5,372
Rod bearing failures aren't totally uncommon to BMW motors, including the naturally aspirated and turbo motors (all models). While I don't believe it's a very widespread issue with the N55, I have read about it on the 2 and 3/4 series forums and I've read of it happening in stock and modified cars.
BMWs have historically run pretty tight bearing clearances. With modified cars and/or stock cars running poor quality fuel and/or low octane, I can totally see how a really bad detonation event (i.e., "super knock") could hit the piston so hard that it hammers through the thin oil film between the rod bearing and crank, thus spinning the bearing. It's happens all the time in turbo Subarus and heavily modified GM LSX motors. With extra power from a JB4 or other mods that significantly increase power, teamed with a bad knock event, and/or bad or poor quality fuel, I can see how more failures could happen in modified motors. Just because we can turn up the power substantially over stock power levels doesn't mean the motor and ancillary systems can reliably handle it over the long term. You're also operating DME outside it's safeguards to some extent. 90%+ of the motors will likely be fine running a quite a bit more power than stock, but you can be assured the chances of the motor lasting nearly as long as an unmodified one are much lower. That's just the way it goes.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-02-2018, 11:04 PM | #43 |
70
Rep 206
Oddly enough, since my engine failure last fall, my dealership has changed from 10w-30 to 0w-30 for their default oil (it's Colorado afterall and so far we've seen about -10F this winter). The tech that changed out the engine later suggested considering 10w-40 for summer if planning on track days or a lot of hard driving. I broke in my new N55 as recommended, and now have about 3200 miles on it. Had the oil changed at about 1200 miles and everything looked clean.
03-03-2018, 04:06 AM | #44 |
1078
Rep 2,358
I have an oil report from Blackstone showing lower than average wear dispite running +500hp. I really think it is all about the oil/or just being unlucky.
(A Dane in China) |
