BMW M3 Forum (E90 E92)
EXXEL Distributions
      12-09-2020, 10:44 PM   #23
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
If there's another 2-3 guys interested in the tapered washers (aside from those already on waitlist), I will check to see if we can get a other batch of 10 sets done up.
Please put your name in this thread if you're interested:
https://www.m3post.com/forums/showthread.php?t=1781246
      12-10-2020, 06:59 PM   #24
911r
911r's Avatar
891
Drives: slowly
Can anyone comment as to how labor-intensive swapping out all of these bushings will be? Would dropping the subframe (most likely) be necessary?
      12-10-2020, 07:35 PM   #25
b4hand
Drives: 2011 ZCP M3
The subframe side already has bearings, so this would be for the hub side. You wouldn't need to drop the subframe for this
911r891.00
      12-10-2020, 07:40 PM   #26
911r
911r's Avatar
891
Drives: slowly
Yup! You're totally right — only inboard subframe bushing that would need to be replaced is on the trailing arm, which is easily accessible. Was worried about removing and replacing the rear guide arms & rear wishbones but it seems possible. Cheers!
      12-10-2020, 07:46 PM   #27
b4hand
Drives: 2011 ZCP M3
And it looks like I didn't read the table fully either
911r891.00
      12-10-2020, 08:46 PM   #28
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
If you are aiming to remove the upper arms, those bolts require the subframe at least to be loosen to get those inner bolts out. It hits the chassis if you don't.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
b4hand661.00
911r891.00
      12-14-2020, 05:58 PM   #29
Redd
I'm trying to get another batch of washers done up. Pls let me know if you're keen in the link above.
      12-25-2020, 07:52 PM   #30
Redd
I've been good this year so Santa dropped by with the rest of the goodies for this conversion.
Meyle 3147100005 Bearings (Item B)
Meyle with tapered washer
Meyle with ECS rear trailing arm (fits nicely!)
Edit - These Meyle bearings are from the 'Meyle-Original' product line and there's a 'Made In Turkey' sticker on the box (so, not a China product that some people are concerned about).
Comparing the Meyle bearing with a Lemforder bearing I have (for the rear camber arm, hub-side). The Lemforder has a polished outer shell whereas the Meyle one doesn't. However, the Lemforder shell shows rust spots. The Meyle inner ring looks higher quality than the Lemforder one. I tried to spin both bearings and both are tight. Maybe not meant to be spinnable by hand. Hopefully the Meyle ones will last.
BimmerWorld Rear Camber Arm Bearing Kit (Item A)
The BW rear camber arm bearing kit has 3 components - the bearing itself, an inner sleeve (2 pcs per bearing) and an outer sleeve.
Will post more when I have them installed.
Appreciate 4
Bartledoo2691.50
911r891.00
///Mobbin1478.00
Rochen_00349.50
      12-26-2020, 11:30 AM   #31
slicer
slicer's Avatar
2740
Drives: 'E46 M3 Race Car, '23 X7
You can get them out without touching the SF. I have done so. The only issue is fitting the torque wrench when re-installing.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
derbo3610.00
      12-26-2020, 02:49 PM   #32
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Did you cut the bolt?
IG:ruhrohz_m3
Journal: Link
      12-27-2020, 08:54 AM   #33
slicer
slicer's Avatar
2740
I did not need to cut the bolts for the upper arms. The only rear bolt that needs cutting is the sway bar end link bolt where it attaches to the hub assembly.
'23 X7
      01-03-2021, 01:08 PM   #34
wootloops
wootloops's Avatar
356
Drives: 2013 E92 M3 Lime Rock Park
Question - when replacing the rear trailing arm bushings, do you guys have a specific tool (or method) you recommend?
I was looking at the Bav auto tool kit # B8800101 but wasn't sure if this was the best option, or if it was necessary.
      01-04-2021, 05:15 AM   #35
atopa2002
atopa2002's Avatar
Drives: Z3M, 2013 e92 M3, F15 X5
https://youtu.be/wg2TrTI2ySE
Clip showing how the tool is used , I used the same tool to do mine . Made it super easy
      01-04-2021, 08:48 AM   #36
wootloops
wootloops's Avatar
356
Perfect. Thank you!
      01-12-2021, 01:57 AM   #37
Redd
Just installed the BimmerWorld rear camber arm bearing kit. The outer sleeve slides in freely by hand and needs to be tack welded to the subframe. Also pressed out the rear trailing arm bushing on the subframe (inboard) side and pressed in the Meyle spherical bearings. No drama, and no NVH to speak of. Haven't driven the car hard so can't comment on any differences yet.
The stock rubber bushes were in surprisingly good shape despite having 137k kms on them. The rear camber arm bush was compressed slightly on one side probably due to the weight of the car, but otherwise looks to be in good shape. It wasn't dried out or brittle.
Also pressed the Meyle bearings into the wishbones and guide rods. Again, no complications - they went in straight and smooth. Will find some time to get the arms installed soon together with new wheel bearings.
      01-19-2021, 08:41 PM   #38
911r
911r's Avatar
891
Drives: slowly
Anyone know where I can get the bushings? Meyles are back ordered on FCP, and there are only 4 Lemforders left on eBay.
      01-19-2021, 08:54 PM   #39
Redd
I guess everyone found out Schirmer sells the same Meyle bearings at 2-3x the price and ordered them off FCP.
      01-22-2021, 08:41 PM   #40
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Well either someone else found out about this or all you guys bought all the bearings
None available that I can find.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      01-22-2021, 09:06 PM   #41
Redd
Got all the new arms with sphericals installed with no issues. The blue circlips are Meyle bearings. Replaced the camber arm outboard bearings with new Lemforders as there was play at 137k kms. Camber arm inboards are BW Camber Arm Bearing Kit.
'While I was there' I also did rear wheel bearings, ECS trailing arms, Powerflex Street (Yellow) rear shock mounts, and also recond the half shafts since some of the CV boots were torn. So basically a whole rear end refresh.
Then we discovered that the power steering rack was leaking so I had to get that done, too. Car's still up in the air waiting for the rack. Can't wait to drive it!
DRLane3990.00
      01-23-2021, 01:18 AM   #42
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Great job. Looking good. My power steering rack is leaking too. Slow leak but it's like internal leak. Please update on the rack replacement
      01-23-2021, 02:14 AM   #43
Redd
Mine's getting reconditioned by a local specialist. Won't be replacing it per se.
      01-23-2021, 10:25 AM   #44
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Wow I didn't know that was possible. I'll looking into that as well in my area.
m3post
