BMW M3 Forum (E90 E92)
      07-22-2010, 07:14 PM   #45
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
Originally Posted by hammbone50 View Post
Where are you guys getting your alignments done? The dealership? If so what are they charging you?
Like others said, avoid the dealership for a performance alignment. I have some recommendations, but likely california is a little far for you.
If anyone else reading the thread in the bay area is looking for an alignment, Contact Orlando at Auto Innovations in Milpitas. he's GOOD.
      08-01-2010, 02:55 PM   #46
STALKER
Drives: 997.2 GT3, Golf R
Just had my alignment done after installing Moton Street Sports. I had the care lowered roughly 1/2" all the way around, and corner balanced. I have to have the cross weights sent to me still.
Front Camber
Left -2.2 Right -2.3
Total toe in is 1.0mm(they gave me some toe in on the front)
Rear Camber
Left -2.1 Right -2.1
Total toe in is 3.0mm
Car turns in beautifully.
      04-16-2011, 03:57 PM   #47
RichardCranium
RichardCranium's Avatar
28
Drives: 2013 M6
Here are mine, have eibachs. Anything need to be adjusted?
      04-16-2011, 04:16 PM   #48
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
Dinan Stage 1 w/ camber plates
-2.0 deg camber front and rear
      07-12-2011, 05:46 AM   #49
pogi_1
Drives: 2008 M3 Red
should i get re-aligned post spacer install? i have eibachs, oem 19s, 245/35 and 275/35. i am planning to get 15mm spacers up front and 12mm in the rears. thoughts..?
      07-12-2011, 09:36 AM   #50
Richbot
Drives: Jerez Black E90
Camber
-1.6 front
-1.8 rear
Zero toe front
3/32" toe-in rear
Stock suspension with front alignment pins pulled
      07-12-2011, 09:54 AM   #51
Singletrack
4th down; 4th quarter? Renegade.
Singletrack's Avatar
Drives: 09 SSII E92 M3; 19 FG M5C
Originally Posted by Richbot View Post
Camber
-1.6 front
-1.3 rear
Zero toe front
3/32" toe-in rear
What's the motivation for the -1.3 in the rear? Better rotation? TIA.
      07-13-2011, 08:40 AM   #52
Richbot
Edited, I remembered wrong. Rear is about 1.8. But if I were going to do anything within the constraints of the stock suspension to make the car rotate better, dropping to about -1 in the rear would be on the short list of things to do. No reason not to stand up the rear tires as most of the oversteer on this car seems to come from a lack of forward grip, not lateral grip
      07-13-2011, 09:05 AM   #53
Singletrack
Roger. Thanks.
      08-16-2011, 02:15 PM   #54
persian54
persian54's Avatar
Drives: M760/G83M4
I'm thinking of doing max front camber with pins removed, -1.7 Camber in the rear
0 Toe front, 1-2mm toe rear
Will be on Dinan stage 1
Thoughts?
Will street wear be increased a lot?
how about track performance?
I track about once, sometimes 2-3 times a month
Thanks
      08-16-2011, 04:24 PM   #55
STALKER
Thoughts?
Thanks
That sounds alright. I would add the Dinan camber plates in the front personally.
      08-16-2011, 04:32 PM   #56
ex10psi
Drives: 2011 E90 M3
GC adj camber plates and H&R race springs. ZCP e90 m3 sedan.
street:
front: -2.4 camber and just a hair of toe-in
rear: -2.2 camber and bit more than a hair of toe-in (sorry no actual figures )
track:
front: -4+ camber (i just max the camber plates out) and toe-out a decent amt but nothing too bad
rear: static to street
tire wear on the street after 1k miles or so, perfectly fine!
performance on the track, EPIC!
2011 E90 M3
2004 996 GT3
      08-16-2011, 05:57 PM   #57
persian54
persian54's Avatar
Drives: M760/G83M4
$$$ I don't want to spend right now
$250 for -.3-.5 isn't worth it
when the time comes, I'll do a full KW CS and use adjustable camber plates and push the front to -2.5 to -3 for the track
      08-16-2011, 09:57 PM   #58
STALKER
They will give you a bit more then that with my experience without pulling the pins. Im not a big fan of pulling the pins, I would rather spend the $250 on the plates. But thats just me.
      08-16-2011, 11:02 PM   #59
persian54
persian54's Avatar
Drives: M760/G83M4
If I would be going plates I'd do GC :P
Pulling pins, from what I've read, been told by people on this forum as well as my BMW master tech is perfectly fine.
I'll eventually do a full coilover set up (probably by next summer)
I wasn't going to modify the suspension but a friend was selling his Dinan kit so I picked it up for the time being. Something is better than nothing
      08-29-2011, 05:56 PM   #60
llis
octane chick
llis's Avatar
Drives: ex-M
2013 BMW M3 ZCP  [10.00]
2003 BMW M5  [0.00]
Camber:
Front: -3º left, -3.1º right
Rear: -1.9º left, -1.9º right
Toe:
Front: .12º left, .11º right
Rear: .11º left, .14º right
Stock ZCP suspension w Ground Control camber plates. Once I'm more accustomed to my setup, thinking of reducing the rear toe.
      08-29-2011, 06:44 PM   #61
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
Originally Posted by llis View Post
Camber:
Toe:
How old are they? Any squeaking or rattling?
      08-30-2011, 04:30 PM   #62
llis
octane chick
llis's Avatar
Drives: ex-M
2003 BMW M5  [0.00]
Nary a peep.
      10-06-2011, 01:11 AM   #63
Eugene-TAIWAN
Eugene-TAIWAN's Avatar
Taiwan
249
Drives: E92 M3 Coupe
here is mine!
KW competition with competition camber plates (from M-World)
[IMG][/IMG]
Past: Gintani stage3 M3, Cayman GTS
present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW
      10-12-2011, 11:26 PM   #64
Eugene-TAIWAN
Taiwan
249
got he car redone again
front : -2.4
rear: -2.1
total toe: .20
      10-20-2011, 12:39 PM   #65
wwjd15
Drives: 11 E92 M3 MR
F -2.2, toe +0.03 total
R -1.8, toe +0.08 total
Front end is under during mid-speed cornering entry
rear end can be flat out without oversteering.
Next move, give it negative toe and more camber, also lower the front a bit.
      11-16-2011, 04:49 PM   #66
quads
Drives: bac mono
zcp with edc
gc plates
-3 front
-2 rear
for street and track.
m3post
