01-07-2013, 06:20 PM | #23 |
84
Rep 2,792
I edited my post above. I spoke to the previous owner and the damage to the wheels was caused by pebbles getting stuck between the barrel and the caliper. While it's not directly the brakes or wheels at fault, it's still good information IMO because it's obviously a tight fit and similar damage is possible.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
01-07-2013, 06:58 PM | #24 | |
Scythe-Meister
90
Rep 1,053
01-11-2013, 09:55 AM | #25 | |
Future Classic
263
Rep 995
Running the following: 18x9.5+15 18.10.5+20
FUTURE CLASSIC | | Follow Us on Instagram
Melbourne E90 M3 | Jet Black E46 M3 | Techno E36 M3 | 997.2 C2S | 958 Cayenne GTS |
04-04-2013, 06:56 PM | #26 |
Rep 5,483
Just curious if anyone has anything to add to this thread? It's been a while since anybody added to it. Going to need new front brakes soon and might just go ahead and get a big brake kit since new OEM parts are $1k anyway
04-04-2013, 07:10 PM | #28 |
Rep 8,076
Drives: 11 E90 M3 Individual
Well...I've been told that the APEX ARC8 17x9.5 et35 will clear a Stoptech 355mm BBK with a spacer. I'm going to use this wheel square with 12mm spacers on both axles. On my E46 M3, I'm about to install the ST 355/4pot BBK. I may do the same on the front of my E90 M3 in the future as well.
Why? Well...275/40R17 NT01s are abour $200 cheaper per set vs 275/35R18s. I can keep one set of track wheels and tires for both cars.
2018 F30 320iX Melbourne Red
04-05-2013, 02:22 AM | #29 |
Rep 3,178
Great thread.
From the limited research and feedback had from AP directly and members here is that the AP Racing 368mm fronts will clear the front 260Ms (18x8.5 ET29) but require spacers with the front 219Ms (18x8.5 ET29). Rear AP kit no issue with either 260M or 219M.
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
04-05-2013, 01:59 PM | #30 |
Rep 1,570
Drives: 2013 LRP M3 Coupe
Volk TE37 Tokyo Time Attacks Front 19", 9.5, +15mm offset
Brembo GT 380mm fronts barely clear... you can't even put a piece of paper between the caliper and the spokes but it somehow clears without scratching.. I put a 3mm spacer on just in case rears are fine 19" Rear 10.5, +20mm offset Advan RS-D Front 19", 9.0, +22mm offset Brembo GT 380mm fronts, top caliper bolts rubs against rim barrel and needs to be shaved down a couple of mm.. caliper face is fine however and no spacer is needed. rears are fine 19", 10.0, +20mm offset |
04-05-2013, 02:23 PM | #31 | |
Rep 980
So what ur saying is the Alcon Super Kit w/384 front rotor CLEARS the Apex EC-7 18" rim??? If so, i just found my new rim + bbk package right there.
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
04-05-2013, 02:53 PM | #32 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
HRE R43
Stoptech Trophy STR60 Front Caliper (380mm) and STR40 rear caliper (355 mm) 18 x 9.5 et 22 - Clears ST Trophy 380mm 18 x 11 et30 - Clears ST Trophy 355mm
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
04-07-2013, 02:57 PM | #33 | |
Rep 7
It can be my lucky day, I've found Alcon Superkit at bargain price, and probably 18" wheels which clear Alcon calipers. By the way, has anyone ordered Alcon BBK from this website : http:/http://www.jdl-brakes.com/alco...mw-m3-e92.html |
04-07-2013, 10:59 PM | #34 | |
Rep 980
04-08-2013, 01:10 AM | #35 |
Rep 19
04-08-2013, 06:05 PM | #36 |
Rep 980
Perhaps, although the price I was quoted from Vivid was less than what JDL had on their website.
04-08-2013, 08:04 PM | #37 | |
Rep 6,734
18x8.5 et29 front wheels cleared the 380mm front brakes with 12mm spacer. 10mm may have been sufficient but I did not have one. 18x9.5 et23 rear wheels cleared the 380mm front brakes without the need for a spacer.
'23 X7
06-16-2013, 04:51 AM | #38 | |
Rep 1,179
The rim nicely clears the caliper, only the rear US spec bolts stick out too far. For that reason Brembo USA uses already shaved bolts - see red circled areas of a US 380mm Brembo kit: Options are to shave off the bolts a little more, which is no big deal or use custom bolts. |
06-16-2013, 12:57 PM | #39 |
Rep 1,179
OK, to make it clear. These rims are customized for M3 GTS. They clear without any mods. For US spec brembos custom rear bolts are required, for Brembo GTR custom rear brackets are required. All no Big Deal ;-)
06-16-2013, 06:40 PM | #40 |
Rep 8,076
Apex ARC8 17x10 et25 wheels clear Stoptect ST40/355mm BBKs. You can also go 17x9.5 et35 with a 5-12mm spacer. You should use a hub extender with a 5mm spacer.
I went with a 17x9.5 so I can use these wheels on my E90 and also run a 255/40R17 on my E46 M3 with the same wheels. One set of track wheels...2 cars.
06-17-2013, 09:46 PM | #41 |
Rep 1,373
I'm looking to get a bbk soon I guess in a few months. Just curious if my rims would clear them? I'm looking to get either brembo or stop tech 6piston front 4piston rear but I don't track my car so would it be a waste??
HRE P43SC FRONT 19x9 ET 22 REAR 19x10.5 ET 27 Thanks
2018 F80 M3 ZCP Mineral White- Extended Shakir Orange - Full Suntek Ultra Wrapped - ///M Performance Spoiler - RKP Front Lip - RKP Side Skirts - Vorsteiner GTS Diffuser -AA Mid-Pipe-///M performance HAS kit - HRE P101
11 E90 M3 JEREZ BLK METALLIC ZCP SOLD |
06-17-2013, 09:50 PM | #42 | |
11817
Rep 23,187
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
06-18-2013, 06:05 AM | #43 | |
8300
19
Rep 573
if you think looks is worth many thousands of dollars, go for it. I really like how mine look, but i wouldn't have bought them if I weren't tracking my car. The extra safety margin at the track is worth it though. Especially after 2 pedal to the metal incidents. |
06-18-2013, 10:00 AM | #44 | |
Rep 1,373
Yea I figured that much.. Ill see I guess.. |
