BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
BPM
      11-23-2023, 10:44 PM   #1
bosstjm3
bossteej86
79
Drives: E92M3(2), F30 340, F150&X5 45e
E92 M3 Track Build
Hi BMW Community,
My name is TJ and for the past 12 months I have been building my E92 M3 to be a track toy with plates. I am just sharing what I have done YTD and hoping to get feedback and advice from all the seasoned e9X track enthusiasts. I purchased a bone stock 2012 DCT E92 M3 with 85k miles December 6th of last year with no receipts haha. I have gone to a couple shops for a wide range of maintenance and upgrades. The shops I have gone to are preformance eurowerks in Chicago area as well as Seems Legit Garage in Shelby. I have only done 8 track days this season to shake the car down and see the progression but hoping to double that next season
Maintenance & Cosmetic
- Rod Bearings with new motor mounts ( BE w ARP)
- TA's ( EAE rebuilt)
- Aluminum Vanos covers
- Valve Cover Gaskets
-DCT Full service
-Fuel Breather Valve
-Brake Vacuum Pressure Sensor. Failed on track
-Lux Amber Angel Eye
-Paint Correction
-Carplay
-Rear seat delete kit
Performance Upgrades
-DO88 full kit
-Dyno Tune and Trans Tune @PE by Alex
-Eventuri Plenum and Intake
-AP 9660 and AP 9449
-EAE PS Upgrade and undertray
-GT4 Aero from MKtrackparts
-BW x pipe resonated w corsa muffler
-Fall Line Half Cage w Sparco Evo L and Lifeline
-KMP Gen 1
-MCS 2 Way Remote w GC Plates
- Apex Vs-5rs ( 18x10 et25 square)-285 pzero scrubs
- Apex Vs-5rs ( 18x9.5 and 18x10.5)- re71rs
Things I am seeking Advice & feedback on from anyone who is willing to help.
1.What are the best bushings for this chassis ? Planning to redo with solid subframe and poly everything else?
2. Is SPL full kinematics the best solution for kinematics or BW/ turner? Heard they are little tricky to install/ maintain
3. Does the diff make a crazy difference? Heard great things about 3.62 Diffsonline if keeping NA but lot of cheddar
4. Is ESS G1 the best SC to get for this chassis for 15 minute DE sessions? If so, what is the ideal diff ratio to pair with or could keep stock?
5. Weight reduction? - Is anti gravity a no brainer? Any easy big ticket items/ suggestions as current at 3550#s w half tank and no driver.
6. Anything else? Is this too much too soon? I think the car is in a great spot after all new bushings to just be a NA track rat w full interior ...
Made an insta for the car @bosstjm3 if want to follow along on this journey
Thanks in advance - TJ
Appreciate 9
      11-24-2023, 06:58 AM   #2
Andy1M3
32
Drives: 2008 E92 M3
You've been busy!! Car looks great. What'd it make on the dyno? I assume the tune was done once the Eventuri was installed?
      11-24-2023, 01:47 PM   #3
bosstjm3
bossteej86
79
Hi Andy,
Yes, was tuned after plenum and intake. Car made 383whp and 297 wtq if i recall correctly.
      11-24-2023, 02:35 PM   #4
kolosy
1493
Drives: over potholes
nice build. and -- love the PE guys, Alex did my E60 6 speed swap and all the work on my E90.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3
I think I have an M3 problem.
      11-24-2023, 11:30 PM   #5
roastbeef
roastbeef's Avatar
Drives: E92 M3
thats a nice start. looking good.
Instagram; @roastbeefmike
      11-27-2023, 06:01 PM   #6
GinTonic
126
Drives: E92 M3
Mint!
      11-30-2023, 10:18 AM   #7
MineralWhiteF80
Dont listen to me
Drives: F82, E92 M3, G30 M550i, E46
just an FYI for weight reduction, there aren’t many “big ticket” items to drop weight easily other than the front seats and battery. It’s more of an “ounces turn into pounds” situation with the e92 where you can’t get real noticeable weight loss unless you take out a bunch of small things or replace everything with lighter parts that eventually add up.
The question becomes “Where do you draw the line and is it really worth it?”
I removed every bit of the basic interior panels/rear speakers/etc. from the B pillar back and it all weighed 127 pounds and now looks like this:
Instagram: @thatwhitem4
Appreciate 4
      02-11-2024, 09:21 AM   #8
bosstjm3
bossteej86
79
Dyno Graph w Tune & forward X
Dyno graph and sheet. Not the best fuel used speedway 93 and not shell .. LOL
Thought i would share . Values are WHP and pull was done in 5th
      02-11-2024, 10:59 AM   #9
M3SQRD
M3SQRD's Avatar
2164
Your torque curve is atypical for a s65. From about 5k rpm, your torque starts to taper off and then at 6k rpm the torque really starts dropping off all the way to redline. Typical s65 torque curves are flat from ~3k-7k rpm. Check out the s65 dyno database:
http://www.s65dynos.com
Click on the “Find all STOCK cars” to get to stock dyno plots.
As for your original questions:
Any solid Al subframe mounts will work. I’d recommend BimmerWorld solid Al subframe bushings
Yes but Ground Control has a good set too. I have the BimmerWorld front and rear arms. Widens track by 10 mm. I’m unsure whether BW still offers their front arms.
Adding a DCT 3.62 FD LSD + Epic DCT software was the BEST mod I’ve done to my car! It is absolutely worth the money and a clutch-type diff is far superior to the oem LSD.
I can’t answer the SC question for you; however, I’d recommend staying stock to maximize your driving skills and use 100% of the stock power before adding a SC. As for the diff, if you add a supercharger, I’d probably go with a 3.45 FD over a 3.62 FD. At a minimum I’d get a clutch-type LSD with the stock 3.15 FD.
Easy ones are removing interior trim with sound deadening material, front seats (replace with race seats), rear seats and the battery. It all depends on far from a street car you are willing to go.
I’d recommend extracting all performance from a NA engine before turning it into a SC engine.
      02-16-2024, 08:40 PM   #10
Oreo Cat
Drives: E90 M3
I like my ess g1 but I’m not sure id do it on a track car, it does heat soak on the street. Maybe the Do88 stuff will help especially with a hood that has a lot of large vents
      03-20-2024, 10:42 PM   #11
bosstjm3
bossteej86
79
2024 Track Season Wrap
Hi all,
Wrapped my track car and just wanted to share on this thread.
Appreciate 4
kolosy1493.00
CTMike262.00
PACarGuy683.50
      03-26-2024, 06:26 PM   #12
bosstjm3
bossteej86
79
Changed out KMP wheel to Zestek Wheel
Hi All,
I changed the wheel out of my track e92 m3 to a zestek. Will keep this thread updated once i get a track weekend under my belt next month.
      03-29-2024, 07:27 AM   #13
bosstjm3
bossteej86
79
Upgrades for track season 2
Hello Everyone,
I had some upgrades installed at Seems Legit Garage in Michigan this past week and half to prepare the car for track season 2. I had the Precision Monoball Front Upper Control Arm Bearing Kit installed, ap racing 9449 rear bbk with Cobalt racing pads, gt4 high wing risers, solid diff and subframe bushings, aim solo 2 DL and finally aim smartycam 2.1. I cannot wait to see how the car feels now with these simple but hopefully effective upgrades.
      04-11-2024, 12:38 PM   #14
bosstjm3
bossteej86
79
Ready for the season
Hi All,
Car is prepped and ready for gingerman raceway shakedown on 4/27 & 4/28.
I am just hoping for a smooth clean weekend of HPDE driving and shake the rust off from the winter.
      04-11-2024, 01:52 PM   #15
kolosy
1493
can you show me the underside of the spoiler mount? how much does the trunk lid flex?
      04-14-2024, 11:27 AM   #16
bosstjm3
bossteej86
79
I don't know how it was mounted but there were supporting mods needed. I believe there is going to be flex unless you go chassis mounted.
      04-17-2024, 11:45 AM   #17
kevine1785
Drives: 1988 325i
These track mods are inspiring... would be a dream to have an e92 just for track day
m3post
