03-19-2024, 06:49 AM | #45 |
417
Rep 299
Hmm, maybe I meant to link the b16s instead: https://www.bimmerworld.com/Bilstein...49-237108.html
03-19-2024, 12:27 PM | #46 | |
74
Rep 66
03-19-2024, 04:18 PM | #47 | |
Rep 5,550
https://f80.bimmerpost.com/forums/sh....php?t=2061531 |
beckumf4.50 |
03-19-2024, 06:14 PM | #49 | |
74
Rep 66
I definitely wouldn't doubt that the elecTRON kits could outperform the Bilsteins but it would just come down to if the cost is worth it. |
03-19-2024, 06:30 PM | #50 |
Rep 417
Can I Hijack for a question?
Non EDC e90. Looking for a refresh. Thinking of the b12 pro kit. Thoughts? I don’t want to go the coil over route just yet. Thanks! |
03-19-2024, 06:44 PM | #51 | |
Rep 5,550
I don’t follow your statement about “justify $5900 for electronic adjustment when I touch the knobs maybe once every couple of weeks” - the R1 e-TRON requires no adjustments and is controlled by the EDC controller or, eventually, Nitron’s DCU (damper control unit). The R3 adds independent LSC and HSC manual damping adjustment. If you already have Nitron R1 1-way conventional dampers, which are similar in price to the R1 e-TRON, why are you looking at B6 and Tractive edc options? If you’re considering Tractive edc options then I’d strongly recommend you look at the Nitron options. |
03-19-2024, 07:06 PM | #52 |
Rep 5,550
I’d consider the ISC street kit (they offer a track kit with higher spring rates and valving) as another option to the Bilstein B12. The price difference is $200-300. The B12 is a non-adjustable damper with Eibach springs that lower the car 40 mm. ISC allows you to set the ride height you prefer as well as provides 1-way adjustable dampers. Just another setup to consider.
beckumf4.50 |
03-19-2024, 08:03 PM | #53 |
Rep 3
Engine and Tran mounts.
My e93 has 126k and it runs strong, once I replace the engine and transmission mounts. I purchased my m3 with 26k miles and 126 thousand miles later when the clutch goes out it sounds like the rod bearings and you will think your engine is shot but it is the flywheel. Very expensive lesson to learn. I went to do the rod bearing just to find out it was done before I purchased the car. The guy said they did not need to replace them. But I did anyway because the labor price to pull it down is still the same.
03-19-2024, 08:52 PM | #54 | |
74
Rep 66
going off of TracTive's site, they are listed for 3795 eur. the R1 eTRON and R1 conventional aren't that similar in price. I got my kit for 4200 last year, 5900 is a good chunk higher. at the time, I was eyeballing the TracTives and Ohlins as well, but ended up going with the R1s. to be clear, my point was that at the price point for the people looking into B16's (mid 3s) it might be worth looking at the TracTives (low 4s after currency conversion) as well if EDC is something they are looking for. for me personally, I felt like the eTRON setups are a bit too pricy - I didn't feel that I would be getting $1700 worth of value out of electronic adjustment, since I don't adjust the suspension very often. edit: I do agree with you that if you're willing to spring for it, the eTRON setup would probably be the ideal kit to have.
03-21-2024, 03:16 PM | #55 | |
Rep 5,550
I was looking at a different price sheet when I quoted the price of the conventional R1 dampers. Low $4k is correct. The “advantage” of the edc plug-n-play options is that the controller (BMW EDC, Nitron DCU or Tractive ACE; DSC Sport started to develop a controller but stopped because I don’t think the demand is high enough to justify development but the Porsche guys love their DSC controllers!) is doing the adjusting for you in real time (adjustments every 6-10 msec). If you want zero adjustments then the Roadsport version is for you. Personally, I’ll stick with 2W/3W conventional dampers. |
