TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      04-01-2024, 12:09 PM   #1
xALO
Drives: 2013 BMW X5 e70 xDrive50i
Concerning oil consumption on high mileage 50i
Got my first car about a month ago with a very high mileage (181k+) but in very good conditions, I already put around 1.5k miles on it and about to add a second quart of top up of oil, the oil level keeps gradually falling and the exaust system is all oiled up, with excess blue ish smoke constantly coming out of the car (might be cuz of the weather, we are still in the 30-40 degrees during the day). I believe the problem is in the valve stem seals as there is absolutely no oil leaks whatsoever. I am afraid of the cost of replacing the seals and wonder if liqui moly has a good synthetic oil that could minimize the oil consumption.
      04-01-2024, 02:41 PM   #2
Jables92
Jables92's Avatar
Drives: 2012 BMW X5 35D
2012 BMW X5 35D  [0.00]
How does the enging sound while running? I would assume that if the valve seals are that worn you would hear a little excess valvetrain noise like maybe some rattling.
I'm not sure if changing oil types would help much especially if it's burning that much oil, that seems like a lot to me.
xALO0.00
      04-02-2024, 08:04 AM   #3
wcs531
97
Drives: E90 335xi / E70 X5d
Did you buy the car from a dealer? I would look into state laws on selling used cars with existing issues.
The N63 v8 is notorious for valve stem seals before 100k miles, the issue didn't just pop up in the last 1500 miles.
xALO0.00
TTV8M123.50
      04-03-2024, 10:19 AM   #4
cayx5
Drives: 2012 X5 5.0i
Try Liquid Moly Motor Oil Saver. Need 2 cans for your N63. If your seals are beginning to harden this product will swell the seals and help defer the need to replace the seals. Worked for my N63 and my indy BMW shop uses this as well. This product will not work if your seals are gone. The way I see it no harm in trying. Also, normal to need to add a quart of oil every 1,500 to 2,000 miles. Since I used Motor Oil Saver, I've been able to go 3,000 miles before needing to add a quart.
For cars with really bad seals, my indy uses the 10-60 weight Liquid Moly. I'm told it stops the smoking. Most important thing with this N63 engine is frequent oil changes...5,000 mile intervals or less.
xALO0.00
      04-03-2024, 09:21 PM   #5
SlowX6M
SlowX6M's Avatar
288
Drives: 2021 X6M, 2012 X5, 2018 M2
The dealer did my valve steams and everything associated, and the car still burns a quart every 1000 miles. It used to burn a quart every 200 miles before the valve job.
The valve job was done nearly 4 years ago, and other than oil consumption I don't notice any adverse issues, the engine runs strong. I don't see any blue smoke during idle, can't tell if there is any under load as I can't see it.
xALO0.00
      04-16-2024, 11:19 AM   #6
heatmizr
Drives: E70 X5 50i M-Sport
There are a couple 'official' and informative threads on this forum about the "recall - not a recall", Customer Care Program, Bang class-action lawsuit or whatever they called it.
I got my valve stem seals all replaced at no cost to me, about a $6-7k job at the dealer, when mine started consuming oil at 59k miles.
This is most likely your issue.
Somehow I can't find that massive thread on the search. (What's new....)
Not sure if the window has closed on that free work though.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e70 X5 50i M-Sport "The Boss" Loaded
e90 328i - sold
e36 M3 - Gone to become a track star
xALO0.00
      04-16-2024, 03:08 PM   #7
cayx5
The ship has long sailed on the Customer care program and the remedies under the Bang settlement.
xALO0.00
xbimmers
