03-23-2015, 02:04 PM | #45 |
Rep 469
I certainly didn't mind the fixed price today :-). The install was done in Kolding, Denmark.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
04-30-2015, 04:07 AM | #46 | |
18
Rep 201
You're getting this? Not just this? BTW anyone looked into Wavetrac I noticed they have it for the F30/32 Have one in my GTI and it works great!!! really hooks up in the corners http://wavetrac.net/application.htm
"Nor-Cal" Marin County Cars & Coffee Meet http://www.m3post.com/forums/showthread.php?t=972407 "Nor-Cal" Euro Sunday Meets http://www.m3post.com/forums/showthread.php?t=1007355
04-30-2015, 06:42 AM | #47 |
Rep 648
[QUOTE=JT50;17831768]So your getting the complete center section/third member/pumpkin & not just the LSD ??
You're getting this? Hi, Yes we get it all. complete changeover and bmw doesn't need the old one.. Same with Quaife diff. -Total exchange. /Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
04-30-2015, 11:54 AM | #48 |
Rep 469
Check. Got the whole thing and even left with an open diff :-)
JT5018.00 |
04-30-2015, 12:18 PM | #49 |
Rep 10,373
Very nice. I'm trying to justify this expense. I might just have to see how Vegas goes this summer.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
04-30-2015, 11:31 PM | #50 | |
18
Rep 201
Do you have to give Quaife the one from your car
05-01-2015, 05:20 AM | #51 | |
Rep 648
We were to guy's tracking last week. Both 335's. One with Quaife and one with bmw's diff. We're NOT Pro 's but none of us had difficulties maneging our diff.'s Both are just adding so Much more handling and increasing the Fun-Factor. Get any and be happy.
05-01-2015, 05:26 AM | #52 |
Rep 648
Yes, either you send your diff. To Quaife, (long Down time), or you pay a deposit and have your car running again after three Four hours.
05-01-2015, 06:49 AM | #53 | |
Rep 469
I tried tracking the car without the LSD as well last year and there was a huge difference. Actually to a degree where I would argue that the first upgrade to do is the LSD and the second is the PPK (or other tune).
05-01-2015, 11:02 AM | #54 | |
Rep 469
This short video shows the effect of a mechanical limited slip differential (LSD). While sliding a little in the curve the car keeps forward momentum due to the LSD. If the car still had its original open differential it would have made wheel spin on the left wheel. Then the electronic slip diff would have used the brakes to slow down the spinning wheel and move momentum from the left wheel to the right wheel. That could have the effect of making the right wheel spinning which again would cause the eletronic slip diff also to slow down the right wheel (by using the right brake). The result would therefore be that the exit speed would have been way slower if the wheels were spinning with an open diff (as seen in the end of the video). Maybe it doesn't look like much but there is a huge difference in the feel and confidence towards the car. With a LSD the car is more predictable when driving it on the egde.
05-01-2015, 06:11 PM | #57 |
18
Rep 201
Anyone know of a USA supplier for the Quaife LSD complete swap, All I've found is places selling just the diff.
05-11-2015, 08:46 PM | #58 |
18
Rep 201
Wow still no answer??
08-11-2015, 04:38 PM | #59 |
9
Rep 48
I've looked in the states and haven't been able to find a complete swap. I'm thinking of going with the MSLSD since I can get everything within 3 days and installed.
]2013 F30 M SportMods; DocRace Topmount Turbo, Stage 3 Fuel pump,Fuel it Port injection with 500 injectors, Jb4 stage 2, MHD tune, Challenge downpipe, KSport Air ride, Borla Atak. Evolution Racewerks FMIC & charge pipe, M Factory LSD, H&R front & rear swaybar, Turner Front Strut brace, 19" Avant Garde 359 , Carbon fiber hood, spoiler,diffuser & side mirrors, side skirts, white front splitter.
08-11-2015, 04:40 PM | #60 |
9
Rep 48
Has anyone installed the wavetrac LSD?
08-12-2015, 05:00 AM | #61 | |
Rep 603
http://www.turnermotorsport.com/c-37...and-parts.aspx http://www.turnermotorsport.com/t-fa....aspx#MoreCore Only a complete Diff box exchange can be done easy by a garage. Changing the inner LSD part needs a lot of know-how because the Crown wheel is welded, in all the BMW's produced after 2007: |
08-12-2015, 07:37 AM | #62 | |
9
Rep 48
Limited Slip Options No limited slip upgrade, keep the open diff. 2 clutch LSD, Add $2,000.00 (USD) 3 clutch LSD, Add $2,300.00 (USD) 3 clutch LSD with variable ramp angles, Add $2,700.00 (USD) Quaife helical LSD, Add $1,400.00 (USD) OS Giken Superlock multi-plate LSD, Add $2,000.00 (USD) OS Giken TCD multi-plate LSD, Add $2,815.00 (USD). Any suggestions from the group? I track my car occasionally and autocross.
09-24-2015, 06:49 PM | #64 | |
18
Rep 201
Edit; Just realized it says Manual Limited Slip Gearing Upgrades, Does that mean for manual trans only??
09-28-2015, 03:50 AM | #65 | |
Rep 603
You need to make sure you get the one that fits for your car! Very important! Auto and Manual Version are different mechanical wise. I would recommend you contact the desired LSD distributor (i.e. Turner) and check with them, what you need. I also have my doubts on a DIY even if you get the whole box LSD. I've read the exchange guide for the differential and then decided to rather spend like additional $400 on a proper install. (Various special tools are required, otherwise it's probably a PITA) But that's your decision.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
09-30-2015, 01:55 PM | #66 | |
18
Rep 201
