01-22-2021, 11:08 AM | #1 |
Rep 4
Rim and Tire Help
Hey all, I'm looking at buy new rims and tires for my 2016 328i xDrive.
Rims I'm looking at: https://pmctire.com/en/wheels/fastwh...deport-30.tire Tires I'm looking at: https://pmctire.com/en/tires/micheli...4y-139845.tire I'm a noob to this. Wondering if those tires would fit well on those rims, and if I will experience any rubbing on a stock car? Rims are 18x9.5 30mm offset. Tires are 255 35 r18 Thanks in advance guys |
01-22-2021, 01:23 PM | #2 | |
Rep 4,373
if you're not lowering, the same wheel in 18x8.5 ET30 with same tire in 235/45/18(26.3"dia.) would reduce the unsightly x-drive wheel gap some, has a flush fitment and will look better, imo. the 8.5" width face may be less concave than 9.5", though. if you go with your original planned setup, be sure to post some pics . Last edited by alohasurftoad; 01-22-2021 at 01:36 PM.. |
suey954.50 |
01-22-2021, 01:56 PM | #3 | |
Rep 4
I'm not lowered currently. I've always liked the look of wide tires, so I thought this might look good. But I'm positive you know more than me, so I will take that into consideration haha. I could get the same rims with a 40 offset, now if I'm understanding offset correctly, would that stick out less? Would I maybe have rubbing issues at that offset? I'm trying to go for a more aggressive look, so I thought 9.5 would be better than 8.5. Open to looking at other options though. |
alohasurftoad3124.00 |
01-22-2021, 02:11 PM | #4 | |
Rep 4,373
EDIT...alternatively, if you run staggered, you can do 18x8.5 ET30, 18x9.5 ET40 with 235/45/18 front, 265/40/18 rear or OEM size 225/45/18 front, 255/40/18 rear . Last edited by alohasurftoad; 01-22-2021 at 02:22 PM.. |
suey954.50 |
01-22-2021, 03:09 PM | #5 | |
Rep 4
I guess next question, if I get my original setup, I will have some poke. If I decide to get a widebody kit (who knows, I have dreams and the car is still new to me lol) then it wouldn't look as silly eh? And if I went with original setup, would 255/35 or 255/40 be better? Like I said before, I'm kinda a noob with tires and even after hours of research they still confuse me. Appreciate you man |
01-22-2021, 03:41 PM | #6 | |
Rep 4,373
you original setup will poke and have large vertical wheel gap. i'd use 255/40/18 because it's OEM diameter, less wheel gap than 255/35/18 and your odometer will accrue normal. with 255/35/18 it accrues a small percent more than actual mileage traveled, if you care. 255 with ET30 will poke, though it can be reduced by adding a pinch more negative camber. widebody kit on a 328 4cyl? personally, i would never, but it's your car and you're free to do as you wish. |
suey954.50 |
01-22-2021, 05:23 PM | #7 | |
Rep 4
I will go with 255/40/18 then, thanks for clearing that up. And as for the widebody kit, I have no idea haha. I like that look, but we'll see what the future holds. I think I'll go with the rims I posted, with 255/40/18, and see how it looks. I do want to lower, but I live in Canada and the roads aren't always great + so much snow |
18x9.5, f30, rims, tires |
