2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics 6.5" to 8.8" L7 Navigation Display Screen Swap | Very Simple & Cheap (relatively) ;)
      11-23-2016, 10:51 AM   #89
Anderw
Anderw's Avatar
Drives: F80 m3
Originally Posted by SamM_UK View Post
Great info in this thread.
If you retrofit the upgraded iDrive controller that usually goes along with the larger screen, does that work?
Does it require any additional coding over and above what's discussed here to make the screen function?
Only the touch idrive controller requires coding and module that tucks in under the trim with it I believe , the non touch larger controller is plug and play I'm pretty sure
      11-23-2016, 11:33 AM   #90
Sam_M
Tea wot?
210
Drives: 2011 N55 135i 6MT
Is the touch unit what comes with the pro media package on the 235i? Or just the non touch with additional buttons?
      11-23-2016, 07:47 PM   #91
Anderw
Anderw's Avatar
Drives: F80 m3
The controller itself has a touch pad on the top, I'm not sure what needs to be optioned or even if it's available on a 2 series from the factory. It fits the trim as it's the same foot print as A nav optioned idrive, and will work on our Idrive as we share same system as the 3 series (and nbt bmw) that being said the touch is available for f30s and would work on f22
      11-24-2016, 04:58 AM   #92
Sam_M
Tea wot?
210
Thanks
      12-13-2016, 12:57 AM   #93
Anderw
Anderw's Avatar
Drives: F80 m3
Thanks
anytime
      12-13-2016, 04:40 PM   #94
simsimma777
59
Drives: 2019 M850i coupe
Do you happen to know what exactly needs to be coded?
I've already done the screen upgrade, and want to add the Touch Controller.
I have the HU_entrynav if that helps.
Thanks in advance!
      12-14-2016, 12:28 AM   #95
yatesfloyd
Drives: 2016 BMW 228i
Do you think a dealer/shop would know how to code this? I'm a complete noob at coding, so I'd rather have someone else do it.
Also does the screen give you the album cover/info on the Bluetooth connection page of idrive?
      12-14-2016, 03:21 AM   #96
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Thanks in advance!
Haven't done it myself yet but was advised it was these lines
"TBX modules plus...
HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER set to aktiv
HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH set to aktiv"
      12-21-2016, 12:49 PM   #97
Mop007
Drives: F21 2014
Hi,
I am wondering if it is possible to go the other way? My car are parked outside and we have problems with navigations getting stolen. I know it sounds stupid but I would like to install the small screen instead of the big 8´8 so I could sleep well at night again!
Is it possible and will it work?
      12-21-2016, 12:53 PM   #98
Anderw
Anderw's Avatar
Drives: F80 m3
Originally Posted by Mop007 View Post
Hi,
Yeah I don't see why that it wouldn't work the other way around, installing a 6.5 display would lower your screens resolution but it would work
      02-21-2017, 01:17 AM   #99
palomino05
Drives: 2013 328i sedan
My car is a 2013 328, would this still work on my car? i really want to upgrade to 8 inch screen. please help
      03-11-2017, 10:19 AM   #100
Dav3
Dav3's Avatar
949
Just fyi for those who want to retrofit the 8.8 to the original 6.5
Coding wise you need to select "800x400" for resolution and "schmales" for variant
      03-13-2017, 08:11 PM   #101
jul2412
jul2412's Avatar
10
Drives: BMW M240i xdrive
I can confirm the LCI F30 screen 9387453 works on a 2017 M240i!
Great update from the base 6.5'' screen
      03-13-2017, 08:13 PM   #102
Anderw
Anderw's Avatar
Drives: F80 m3
      03-14-2017, 07:44 AM   #103
il_sovero
il_sovero's Avatar
Drives: 218d Msport
I instead confirm that the 10,25 "screen can be mounted on the F22, even with the entrynav, with just minor adjustments.
This is the result:
      03-14-2017, 07:54 AM   #104
jul2412
jul2412's Avatar
10
This is the result:
Wow great, that's huge! What kind of adjustments did you make?
      03-14-2017, 09:43 AM   #105
il_sovero
il_sovero's Avatar
Drives: 218d Msport
This is the result:
Yes, is really huge I have modified the corners of the screen to fit the dash properly, and enlarged the slot in the dash where the screen fits in. An hour and an half of work in total.
      03-16-2017, 08:51 PM   #106
fchen0125
58
Drives: 2015 435xi GC, 2020 X7-40i
Can anyone confirm that this works for the 4 series F36 too ? I would think it should but experiences here are all on the 2 series. Thanks
      03-17-2017, 06:37 AM   #107
il_sovero
il_sovero's Avatar
Drives: 218d Msport
It works! Is the same navigation system. You just need to swap the screen and modify the parameters of your nav ECU using E-sys
      03-23-2017, 09:01 AM   #108
CharlieF576
CharlieF576's Avatar
Drives: BMW 335d xDrive M-Sport Shadow
Looks brilliant! I have one problem doing the upgrade with mine though, I've fitted the screen and there was no problem there but after the coding the display doesn't seem to work...
In the coding the two entries you say to change are:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But when I go online with my car the entries I have are:
HU_ENTRY > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_ENTRY > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But it still doesn't work. In the original post it said you need HU_ENTRY so I'm wondering if anyone could shed some light on this for me.
When you start the car you can hear the radio and stuff, it's just the screen not displaying anything.
      03-23-2017, 12:10 PM   #109
jul2412
jul2412's Avatar
10
Someone correct me if I'm wrong, but you need to have HU_ENTRYNAV, as per original post:
You need to have HU_entrynav not HU_Champ2 for this to work if your car was made either 03/14 or 07/14 later depending on model f2x/f3x check first
      03-23-2017, 12:37 PM   #110
CharlieF576
Sorry to ask such stupid questions. How can I tell the difference?
I have navigation and Bt audio etc available in the idrive (from factory) and here is a picture of my head unit.
EDIT.
I just checked the coding again and I have HU_ENTRYNAV not HU_ENTRY
When I go into HU_ENTRYNAV it comes up with "CAF[HU_NBT] at the top I think I've made much a fuss about nothing...
2addicts
