10-20-2009, 05:37 PM | #23 |
Rep 7,789
10-20-2009, 05:54 PM | #24 | |
Rep 669
as for the camo tape. Could be the LCI X5(I could be wrong tho d: ) [Ehh....cant find a pic to compare)
10-20-2009, 05:59 PM | #25 | |
Rep 884
Drives: 2007 BMW 335i
In chemical processes (like the combined cycle power plants), waste heat is often converted to steam and/or used to heat other processes going on (through heat exchangers). In a combine cycle power plant, you take heat generate from burning natural gas (usually) in a combustion turbine (think jet engine), convert it to high pressure steam and run a steam turbine. So you have essentially used the waste heat from the first combustion process to generate more electricity from the steam turbine. In chemical plants and refining operations, integration of processes to make use of heat generated from one process to provide energy to another is absolutely key to being able the make almost anything economically. In the car, it is probably not economical to put in a steam turbine because of cost, and more likely because the steam you could generate with the temperatures engines run at is not high energy to make "high quality" steam. The main challenge is probably how to cheaply transfer the engine heat away and use it without waste. With the available heat at low temperatures, it is difficult to use it because the inherent maximum efficiency with be [T(hot) - T(cold)]/T(hot) (where T must be in absolute temperature units like Kelvin or Rankine), which probably won't be over 50% with the possible exception of the exhaust gases. T(hot) would be the engine or exhaust temperature and T(cold) would be the ambient temperature.
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access FORMERLY: 128i coupe Alpine White | Sports Package | Black Leather |
10-20-2009, 07:51 PM | #26 |
Rep 7,789
yes, that might be true since the latest spy shots suggest that the next generation X5 will share the headlights with the X6.
10-20-2009, 09:18 PM | #27 |
Rep 974
Actually I've done engine cooking on a motorcycle before... wrap potatoes in foil and lodge them next to the engine. Ride for an hour, and voila! baked potato. Guys riding behind you tend to get hungry though...
10-21-2009, 01:08 PM | #28 | |
Rep 71
Once it is further developed (in some 10 years), it should be a great addition to further enhance efficiency |
10-21-2009, 02:48 PM | #29 |
Rep 884
Cool... more moving parts is always a worry from a maintenance point of view, especially when it is intimately mated with the drive train.
10-21-2009, 07:07 PM | #30 | |
Rep 148
im sorry but i still think its retarded.. and here is why.. since a simple USB connection costs about 400 bux on a BMW, a system like that is not gonna be cheaper then 3000 dollars.. now lets say u consume about 100 worth of gas a week.. .02 % of startups would probebly be around .50 if not cheaper since the percentage saved is ONLY of FUCKING cold starts.. now if ur the retard one that wants to pay 3000 for a system that would save u .50 a week then go ahead.. u see how shity i looked now cuz i caled u retarded. its just my opinion and u can blow me if u dont like it) on electric cars.. instead of doing carbon fiber roof and all that gay stuff they can do solar panel roof and hood that will help with being able to do longer trips.. now i know they are underdeveloped but as much as i LOVE bmw (current owner of 3cars- 1983 518i 2006 330i and 2008 135i) they JUST started thinkin about hybryds and all that bullshit dynamic fancy names they come up with inorder to get better mpgs while toyota and honda been doing it for YEARS.. if u got beef with my im a vegitarian` :P no hard feelings sorry if u r ever in town ill buy u a beer.. Ash |
