DIY: Setup BMW Standard Tools 2.12 on Windows XP > 10
12-10-2015, 08:32 PM | #1 |
Rep 1,527
Many have asked for the easy way to install BMW Std Tools, and I have developed a proven method that can be done in less than 15 min depending on the processing power of your machine.
The only requirement for this install is Windows XP through Windows 10, 32 or 64 bit version and a working KDCAN cable. Instead of writing a lengthy detail in this post, I generated the instructions that's included in link below. If this install has assisted you in achieving a working set up, please click the appreciate link, thanks! MediaFire: https://www.mediafire.com/folder/a7jvirbs559ib/Software NOTE: For everyone who's having issues setting the default folders, it is because some of the downloads excludes "empty" folders. Therefore, make sure your folder structure on the C drive are as follows (if you're missing a particular folder, create an empty one): C:\EC-APPS\INPA: BIN CFGDAT DEMO DOKU english english.met HELP PRT SGDAT source C:\EC-APPS\NFS: BATCH BIN CFGDAT DATA DOKU FORMAT KMMDAT SGDAT TRACE WORK C:\EDIABAS: API BIN DOKU ECU HARDWARE HELP SIM TRACE TUTORIAL C:\NCSEXPER: BIN CFGDAT DATEN PFL SGDAT STDAT TAB VERPLATZ WORK Chassis family guide for choosing your proper DATEN: http://www.e90post.com/forums/showthread.php?t=642883 Edit 1: Added F series files for INPA. Added support files for N47. Edit 2: Added working copy of NCS Dummy. Edit 3: Updated DATEN link. Edit 4: Added notes about setting default folders in BMW Coding Tool. Edit 5: Updated DATEN link to 60.0. Last edited by wildcatcrazy; 11-21-2016 at 07:46 AM.. Reason: Updated DATEN link. |
135
Hops128i70.50 bNks334426.50 Torgus3781.50 101Duck248.00 carrot29712.50 MooreOfDerek14.50 1stTimeBMW0.00 flexbrah31.50 GottWhat196.00 SilverStreak1839.50 J.J.K.8.00 iamjamen131.50 I6TT13.50 WatashiEd28.50 Tim603482.50 DaanBMW84.00 david in germany730.00 !LEFTCOAST!184.50 bigjae19761572.50 victor24742.50 95wildtt832.50 flowserver6.50 tyrystor0.00 Mwahab58.50 dj_aj35.00 vmhelper0019.50 avi312singh8.00 dave71014.00 albotronic2.00 HRMendez7.00 allerena24.50 Sertone77711.50 Brake_Late1937.50 CantComplain116.50 |
12-12-2015, 08:43 PM | #2 |
9
Rep 37
Just wanted to give a HUGE thanks for this. Downloaded the link, followed your instructions and everything is running great!
Brake_Late1937.50 tchamaz0.00 |
12-12-2015, 09:31 PM | #3 | |
Rep 1,527
Brake_Late1937.50 |
12-21-2015, 01:10 PM | #4 |
21
Rep 75
Installed perfectly smoothly.
Thanks. |
Brake_Late1937.50 |
12-22-2015, 06:16 PM | #5 | |
15
Rep 22
Thanks Dude! you made it so easy |
12-23-2015, 09:57 AM | #6 | |
15
Rep 22
E90 DATEN files
Hey wildcatcrazy, Is it possible to get chasis e90 DATEN files in RAR parts chunks? Its a 4.5GB file and I having problems downloading it. I was able to download all other files with no probs. Thanks again. You rock |
Brake_Late1937.50 |
12-23-2015, 11:03 AM | #7 |
15
Rep 22
Never mind wildcatcrazy.
I was finally able to download it. Thanks again. I wish if there was something this simple instructions and downloads for ISTA NEXT |
Brake_Late1937.50 |
12-24-2015, 12:04 PM | #8 | ||
21
Rep 75
If anyone has a torrent link or rarred bits, kindly help. |
Brake_Late1937.50 |
12-24-2015, 05:42 PM | #9 |
Rep 718
For the NCSExper_64 and EDIABAS folder, when I try to select them in BMW coding tool I am getting an error saying "not a valid NCSEXPER_64 (or EDIABAS) folder"
Any ideas? I have both the folders in the root C: drive and they are both extracted. I'm on Win 10 64bit EDIT: For some reason it looks like not all the files are downloading when I download them. The ECU folder does not download from the EDIABAS folder for example. EDIT 2: I figured it out I think. Mega wasn't downloading empty sub folders. For that reason coding tool was viewing the EDIABAS NCSEXPER and EC-APPS/NFS folders as invalid since those were all missing empty folders. Compared what was on Mega to what I had and created any of the empty folders and it looks like it worked.
12-25-2015, 09:30 AM | #11 | |
Rep 1,527
12-26-2015, 07:48 AM | #12 |
295
Rep 2,202
Is anyone getting trouble on Windows 10 pro 64bit?
Currently at step#16 trying to select default folders for NCSExpert.. etc. Shows error "C:\NCSEXPERT is not a valid NCSEXPER folder." says the same for the others as well.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
12-26-2015, 03:35 PM | #13 | |
Rep 1,527
12-26-2015, 05:51 PM | #15 |
Rep 95
Thanks a ton for this Joseph. I followed the steps and things seem to install and launch just fine
One question I have is that once I imported the DATENs, can I delete the original DATEN folder? It looks like the DATENs are sucked into C:\EC-APPS\NFS\DATA? |
12-26-2015, 07:02 PM | #16 | |
Rep 1,527
12-28-2015, 10:08 PM | #17 |
Rep 36
Hey whats up guys, I have a question about the 3 folders the guide says to delete and then copy them over again. are we supposed to delete or merge them with the other folders? i keep getting errors when i delete them trying to proced with step 17. any help is appreciated, thank you
12-29-2015, 02:17 PM | #18 | |
21
Rep 75
12-30-2015, 06:53 PM | #20 |
Rep 36
Hi, I've reinstalled this a few times and followed the instructions and added the missing files to the 3 folders. Using only e89 daten and I keep getting an error after clicking the Cas module. I took a picture of it but don't know how to upload it here
https://mega.nz/#!Up50nKaa!ytk5stZAW...5QEKr0C-qUPOt8 Last edited by Venoml2k; 12-30-2015 at 06:55 PM.. Reason: insert link to oic |
12-30-2015, 07:17 PM | #21 | |
Rep 1,527
12-30-2015, 07:20 PM | #22 | |
Rep 1,527
coding, inpa, ncs, tool32, winkfp |
