Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Reference Option Code List (SA Codes, VO Codes)
      07-11-2012, 05:50 PM   #1
Elliott@DetailAddict
Drives: E90
Post Reference Option Code List (SA Codes, VO Codes)
Thanks to the original compiler of this list.
List may not be complete.
S000A DUMMY-SALAPA
S001A COUNTRY VERS. NOT CONTROLLED AS PACKAGE
S0BVA FUEL REFUELLING
S0BWA PARTIAL REFUELLING
S100A PAYLOAD INCREASE
S102A CHASSIS, OFFICIALS UTILITY VEHICLE
S102A REINFORCED BRAKES
S103A FOUR SEASONS TYRES
S103A AGGREGATE PROTECTIVE PLATE
S104A MIDDLE EAST VERSION
S105A JOB CONTROL "GERMAN FEDERAL STATE"
S106A SAFETY VEHICLE
S107A PREPARATION, TACHOGRAPH
S108A MOTOR AFTERRUN CONTROL UNIT
S109A SECURITY PLUS
S110A PREPARATION, FITTING, EMERG.-DOCTOR SIGN
S112A BEKLEBUNG LEUCHTROT RAL 3024
S113A BEKLEBUNG POLIZEI BAYERN MINZGR‹N HELL
S114A STICKING, POLICE, MINZGR‹N
S114A POLICE STICKER, NORDDEUTSCHLAND
S115A PARAMEDIC STICKER NRW
S115A NRW FIRE-BRIGADE STICKER
S116A STANDARD HOLDER, LEFT
S117A STANDARD HOLDER, RIGHT
S118A TOP SPEED REDUCTION
S119A ELECTRIC AUXILIARY MODULE
S120A BASIC EQUIPMENT
S121A BRACKET FOR POLICE STOP SIGN
S121A PREP.ACCOMMODATION, STOP SIGNALLING DISC
S122A STICKS HOLDER
S123A AUXILIARY INTERIOR MIRROR
S124A ROOFLINER, OFFICIAL-USE
S125A INTERIOR TRIM, OFFICIAL-USE, OPEN
S126A INTERIOR TRIM, OFFICIAL-USE, CAMOUFLAGED
S127A GUN MOUNT ON FRONT PASSENGER DOOR
S129A GUN MOUNT IN ROOF, FRONT
S130A GUN MOUNT IN CENTRE ARMREST, REAR
S131A WEAPON BRACKET
S139A PRIORITY VEHICLE LIGHT, BLUE
S140A 1 RKLE 130,TONFOLGE,POLIZEISCHALTUNG
S141A HIGH-LOW SIGNAL SYSTEM
S142A TWO ROTATING BEACONS, BLUE
S143A ALARM SWITCH WITH POLICE CIRCUIT
S144A ROT.BEACON,HIGH-LOW SIGNAL, POLICE CIRC.
S145A ALARM SWITCH WITH FIRE-SERVICE CIRCUIT
S146A ADDITIONAL ENERGY SUPPLY
S147A PRIORITY VEHICLE LIGHT
S149A DOUBLE FLASH LIGHT, REMOVABLE
S150A INSTALLATION RTK-4 WITH HANDSET
S151A SONDERSIGNALANLAGE HELLA RTK-6
S152A SPECIAL SIGNALING SYSTEM
S153A ROOF ATTACHM.W/OUT SPEC. SIGNAL SYSTEM
S155A INSTALLATION TOP-4 WITH HANDSET
S159A INSTALLATION AERO-DYNIC SYSTEM
S160A INSTALLATION BECKER SIGNAL SYSTEM LU 322
S162A PREPARATION, INSTALLATION, SIREN
S163A EXHAUST EMISSIONS STANDARD EU6
S165A ITS HEAD AIRBAG DEACTIVATION
S166A PREPARATION, STOP SIGNAL, PARCEL SHELF
S167A EU4 EXHAUST EMISSIONS STANDARD
S168A EU2 EXHAUST EMISSIONS STANDARD
S169A DIESEL CATALYST
S169A EU3 EXHAUST EMISSIONS STANDARD
S170A VORB. FUG 2M-4M BD, AEG(BKA)
S170A PREP, INSTALL RADIO EQUIP. AEG TELEDUX
S171A PREPARATION, INSTALLATION, FUG ASCOM
S172A VORBER. FUG 7B KPL. HANDSCHUHK.
S172A PREPARATION F FUEL WITH ETHANOL CONTENT
S173A VORBER. FUG 7B/8B/9C HANDSCHUHK.
S174A VORB. FUG 8B/9C HANDSCHUHK.
S175A VORB. FUG 8B/9C
S176A VORB. FUG 8B/9C ABGESETZT
S178A SUPPORT, MANUAL RADIO EQUIPMENT
S179A IRRITANT GAS SENSORS
S180A PREPARATION, ROOF ANTENNA
S180A ROOF ANTENNA
S181A PREPARATION/INSTALLATION, ROOF ANTENNA
S182A FIRE EXTINGUISHING SYSTEM
S183A PREPARATION FOR ACTIVE DEFENCE
S184A EMERGENCY EXIT FRONT WINDSHIELD
S185A UNMASKED OFFICIAL VEHICLE
S186A EMERGENCY VEHICLE, CAMOUFLAGED
S187A FLOOR PROTECTION
S188A POWER WINDOW, FRONT, OFFICIAL-USE
S189A POWER WINDOW, FRONT/REAR, OFFICIAL-USE
S190A INTERCOM SYSTEM
S191A POWER WINDOW, FRONT RIGHT, OFFICIAL-USE
S192A POWER WINDOW, FRONT LEFT, OFFICIAL-USE
S193A HEATED WINDSCR. AND SIDE WINDOWS DROPPED
S194A REMOTE CONTROL START SYSTEM
S195A ADDITIONAL FLOOR ARMOURING
S196A FUEL TANK, DRAIN-INHIBITING
S197A ACOUSTIC AND OPTICAL ALARM SYSTEM
S198A ADDITIONAL FRESH-AIR SYSTEM
S199A WITHOUT CATALYTIC CONVERTER
S199A EQUIPMENT FOR LEADED FUEL
S1AFA GEAENDERTES KRAFTSTOFFEINFUELLROHR
S1AKA OUTER FUEL FILTER
S1CAA DUMMY-SALAPA
S1CBA ACEA / CO2 SCOPE
S1CCA AUTO START/STOP FUNCTION
S1CDA BRAKE ENERGY REGENERATION
S200A WITHOUT CATALYTIC CONVERTER
S200A DIESEL PARTICLE FILTER
S201A RAPE METHYL ESTER VERSION (RME)
S202A STEPTRONIC
S203A 4-WHEEL DRIVE
S204A DRIVE LAYOUT, EXPORT
S204A SHORTER FINAL DRIVE RATIO
S205A AUTOMATIC TRANSMISSION
S206A SEQUENTIAL MANUAL TRANSMISSION (SMG)
S207A 6-SPEED MANUAL TRANSMISSION
S208A DSC III DISCONTINUED
S209A DIFFERENTIAL LOCK 25%
S210A DYNAMIC STABILITY CONTROL
S210A DYNAMIC STABILITY CONTROL III
S211A DYNAMIC STABILITY CONTROL
S212A EQUIPMENT, BRAKE SYST. COUNTRY-SPECIFIC
S212A ABS DISCONTINUED
S213A HILL DESCENT CONTROL (HDC)
S213A AUTOMATIC STABILITY CONTROL
S214A AUTOMATIC STABILITY CONTROL (ASC+T)
S215A POWER STEERING, ENGINE-SPEED-DEPENDENT
S216A HYDRO STEERING-SERVOTRONIC
S217A STEERING WHEEL, LEATHER
S217A ACTIVE STEERING
S218A LEATHER SPORTS STEERING WHEEL II
S219A LEATHER-COVERED SPORT ST. WHEEL 380 MM
S220A SELF-LEVELLING SUSPENSION
S221A 2-AXLE SELF-LEVELLING SUSPENSION
S223A ELECTRONIC DAMPER CONTROL (EDC)
S224A DRIVING DYNAMIC CONTROL
S225A DELETED, SPORTS SUSPENSION
S226A SPORTS SUSPENSION SETTINGS
S227A SPORT SUSP.+LOW-SLUNG+RIDE-HEIGHT CTRL.
S228A SPORTS SUSPENSION SETTINGS PLUS
S228A COMFORT SUSPENSION
S229A DYNAMIC DRIVE
S230A EXTRA PACKAGE, EU-SPECIIFC
S230A LOW-SLUNG SPORTS SUSPENSION
S231A DELETED: 250 KM/H LIMITATION
S232A BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 50
S233A INCREASED TOWING CAPABILITY
S234A TRAILER TOW HITCH, HEIGHT ADJUSTABLE
S235A TOWING HITCH, DETACHABLE
S236A BMW LA WHEELS WITH MIXED TYRES
S238A BMW LA WHEEL, DOUBLE SPOKE 93
S239A BMW LA WHEEL STYLING 94
S240A STEERING WHEEL, LEATHER
S241A AIR BAG FOR DRIVER AND PASSENGER
S242A STEERING WHEEL AIRBAG
S243A AIRBAG FOR FRONT PASSENGER
S244A MANUALLY ADJUST. STEERING COLUMN
S245A STEERING WHEEL COLUMN ADJUSTMENT,ELECTR.
S246A MANUALLY ADJUST. STEERING COLUMN
S247A AXIAL ST.-WHEEL ADJUSTMENT, MECHANICAL
S248A STEERING WHEEL HEATER
S249A MULTIFUNCTION F STEERING WHEEL
S250A SIDE AIRBAGS F REAR PASSENGERS
S250A MULTI-FUNCTIONAL STEERING WHEEL
S250A SIDE AIRBAGS FOR REAR PASSENGERS
S251A RUNFLAT INDICATOR
S252A ACTIVE KNEE PROTECTION, DRIVER/PASSENGER
S253A LEATHER STEERING WHEEL COOPER S
S253A MULTI-FUNCTIONAL STEERING WHEEL,WOOD
S254A SPORT STEERING WHL. WITH WOOD RIM
S254A STEERING WHEEL, WOOD
S255A SPORTS LEATHER STEERING WHEEL
S256A SPORTS MULTIFUNCT.STRNG WHL,CRUISE CNTRL
S257A DEACTIVATION, SIDE AIRBAG REAR
S258A TYRES WITH EMERGENCY RUNFLAT SYSTEM
S259A DELETED, SIDE AIRBAG
S260A SIDE AIRBAG FOR DRIVER/PASSENGER
S261A SIDE AIRBAGS FOR REAR PASSENGERS
S262A ITS - HEAD AIRBAG
S263A ITS HEAD AIRBAG/REAR COMPARTMENT
S263A LA WHEELS WITH MIXED TYRES
S264A BMW LIGHT ALLOY WHEEL, STAR SPOKE 55
S265A TYRE PRESSURE CONTROL (TPC)
S266A BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 48
S267A BMW LIGHT ALLOY WHEEL, STAR SPOKE 49
S268A BMW LA WHEEL, STAR SPOKE 95
S269A BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 32
S270A WIDER TYRES
S271A BMW LA WHEEL Z LINE
S272A BMW LA WHEEL Z STAR
S273A BMW LIGHT-ALLOY WHEEL STAR SPOKES 43
S274A BMW LIGHT ALLOY WHEEL, DOUBLE SPOKE 53
S274A BMW LA WHEEL/FLAT STAR STYLING
S275A BMW LA WHEEL, CHROME-PLATED/Z STAR
S276A BMW LA WHEEL, ROUND-SPOKE STYLING
S277A BMW LA WHEEL/DOUBLE SPOKE
S278A BMW LIGHT ALLOY WHEEL BMW STYLING
S278A BMW LA WHEELS WITH MIXED TYRES
S279A BMW LIGHT-ALLOY WHEEL STAR SPOKES 45
S279A BMW LA WHEEL WITHOUT FLAT-RUNNING PROP.
S280A BMW LA WHEEL-SPOKE 176
S281A BMW LA WHEEL, CHR.-PLATED/ROUNDSPOKES
S282A BMW LA WHEEL, SPORT-SPOKE STYLING II
S283A BMW LA WHEEL, BMW STYLING II
S284A BMW LIGHT ALLOY WHEEL, ELLIPS. STYL. 46
S284A BMW LIGHT ALLOY WHEEL BMW STYLING
S285A BMW LIGHT ALLOY WHEEL BMW STYLING
S286A BMW LIGHT ALLOY WHEEL BMW STYLING
S287A BMW LIGHT ALLOY WHEEL, STAR SPOKE 64
S288A BMW LIGHT ALLOY WHEEL, CROSS SPOKE 29
S289A BMW LIGHT ALLOY WHEEL BMW STYLING
S290A BMW LIGHT-ALLOY WHEEL STAR SPOKES 44
S291A BMW LIGHT ALLOY WHEEL, CROSS SPOKE 2 PCE
S292A BMW LIGHT ALLOY WHEEL, CROSS SPOKE 29
S293A BMW LA WHEEL, V SPOKE 54
S293A BMW LA WHEEL W FLAT-RUNNING PROPERTIES
S294A BMW LA WHEEL, MULTI-SPOKE STYLING
S295A BMW LA WHEEL, STAR SPOKE 96
S295A BMW LA WHEEL, EXCLUSIVE STYLING
S296A BMW LA WHEEL, CLASSIC
S297A BMW LA WHEEL STREAMLINE
S297A BMW LA WHEEL,FORGED WHEEL/MULTI-SPOKE
S298A BMW LA WHEEL, DOUBLE SPOKE 98
S298A BMW LA WHEEL TURBINE STYLING
S299A BMW LA WHEELS WITH MIXED TYRES
S2AAA BMW LIGHT ALLOY WHEEL, ELLIPS. STYL. 46
S2ABA BMW LA WHEEL ELLIPSOID SPOKE 162
S2ACA BMW LA WHEEL, ELLIPSOID STYLING 109
S2ADA BMW LA WHEEL ELLIPSOID SPOKE 202
S2AEA BMW LA WHEEL TURBINE STYLING 292
S2AFA BMW LA WHEEL TURBINE STYLING 271
S2AGA BMW LA WHEEL HONEYCOMB STYLING 323
S2AHA BMW LM RAD TURBINENSTYLING 329
S2AKA BMW LM RAD TURBINENSTYLING 329
S2B1A BMW LA WHEEL DOUBLE SPOKE 278
S2B2A BMW LA WHEEL DOUBLE SPOKE 316
S2B3A BMW LA WHEEL DOUBLE SPOKE 321
S2B4A BMW LA WHEEL/DOUBLE SPOKE 195
S2BAA BMW LA WHEEL, DOUBLE SPOKE 88
S2BBA BMW LA WHEEL, DOUBLE SPOKE 98
S2BCA BMW LA WHEEL/DOUBLE SPOKE 111
S2BDA BMW LA WHEEL/DOUBLE SPOKE 112
S2BEA BMW ALLOY WHEEL, DOUBLE SPOKE 148
S2BFA BMW ALLOY WHEEL, DOUBLE SPOKE 154
S2BGA BMW ALLOY WHEEL, DOUBLE SPOKE 161
S2BHA BMW ALLOY WHEEL, DOUBLE SPOKE 156
S2BKA BMW LA WHEEL/DOUBLE SPOKE 174
S2BLA BMW LA WHEEL/DOUBLE SPOKE 174FLAT-RUNN.
S2BMA BMW LA WHEEL/DOUBLE SPOKE 116
S2BNA BMW LA WHEEL/DOUBLE SPOKE 205
S2BPA BMW ALLOY WHEEL,DOUB.SP. 205,ALL SEASON
S2BRA BMW LA WHEEL/DOUBLE SPOKE 247 FLAT-RUNN.
S2BSA BMW LA WHEEL/DOUBLE SPOKE 247 FLAT-RUNN.
S2BTA BMW LA WHEEL/DOUBLE SPOKE 222
S2BUA BMW ALLOY WHEEL,DOUB.SP. 120,ALL SEASON
S2BVA BMW LA WHEEL, DOUBLE SPOKE 266
S2BWA BMW LA WHEEL, DOUBLE SPOKE 268
S2BXA BMW LA WHEEL, DOUBLE SPOKE 253
S2BYA BMW LA WHEEL,DOUBLE SPOKE 278/FLAT-RUNN.
S2BZA BMW ALLOY WHEEL, DOUBLE SPOKE 161
S2C0A BMW LA STAR SPOKE 124 W FLAT-RUNN. PROP.
S2C1A BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 175
S2C2A BMW LA STAR SPOKE 175 W FLAT-RUNN. PROP.
S2C3A MINI ALLOY WHEEL 5 STAR ROCKET 93
S2C4A BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 157
S2C5A BMW LA WHEEL, STAR SPOKE 185
S2C6A BMW LA WHEEL, STAR SPOKE 189
S2C7A BMW LA STAR SPOKE 218 W FLAT-RUNN. PROP.
S2C8A BMW LA WHEEL, STAR SPOKE 200
S2C9A BMW LA WHEEL, STAR SPOKE 209
S2CAA BMW LA WHEEL, STAR SPOKE 119
S2CBA BMW LA WHEEL, STAR SPOKE 113
S2CCA BMW LA WHEEL, STAR SPOKE 132
S2CDA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 136
S2CEA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 137
S2CFA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 138
S2CGA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 140
S2CHA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 142
S2CKA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 143
S2CLA MINI ALLOY WHEEL 5 STAR ROCKET 93
S2CMA MINI LM RAD 5 STAR BULLET M. NOTLAUF
S2CNA MINI ALLOY WHEEL 5-STAR 91
S2CPA BMW LA WHEEL, SPIDER SPOKE 137M.ALL-YEAR
S2CRA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 153
S2CSA BMW LA WHEEL, STAR SPOKE 113
S2CTA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 151
S2CUA BMW LIGHT ALLOY WHEEL, STAR SPOKE 169
S2CVA BMW LIGHT ALLOY WHEEL, STAR SPOKE 170
S2CWA BMW LIGHT ALLOY WHEEL, STAR SPOKE 171
S2CXA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 155
S2CYA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 158
S2CZA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 159
S2DAA BMW LIGHT ALLOY WHEEL, CROSS SPOKE 197
S2DBA BMW LM RAD STERNSPEICHE 327
S2DCA BMW LM RAD STERNSPEICHE 330
S2DDA BMW LM RAD STERNSPEICHE 330
S2EAA BMW LA WHEEL Y-SPOKE 149
S2HAA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 139
S2HBA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 160
S2HCA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 187
S2HDA BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 190
S2HEA BMW LA RADIALSPOKE 32 W FLAT-RUNN. PROP.
S2HFA BMW LA RADIALSPOKE 32 W FLAT-RUNN. PROP.
S2HGA BMW LA WHEEL, RADIAL SPOKE 244
S2HHA BMW LA RADIALSPOKE 244W FLAT-RUNN. PROP.
S2HKA BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 216
S2HLA BMW LA WHEEL, RADIAL SPOKE 252
S2HMA BMW LM RAD RADIALSPEICHE 237
S2K1A BMW LM RAD V-SPEICHE 236
S2K2A BMW LM RAD V-SPEICHE 328
S2K3A BMW LM RAD V-SPEICHE 331
S2K4A BMW LM RAD V-SPEICHE 331
S2KAA BMW LA WHEEL, V SPOKE 110
S2KBA BMW LA WHEEL, V SPOKE 130
S2KCA BMW LIGHT ALLOY WHEEL, V-SPOKE 141
S2KDA BMW LIGHT ALLOY WHEEL, V-SPOKE 168
S2KEA BMW LIGHT ALLOY WHEEL, V-SPOKE 188
S2KFA BMW ALLOY WHEEL M V-SPOKE 217
S2KGA BMW LA WHEEL V-SPOKE 188 / ALL SEASON
S2KHA BMW LIGHT ALLOY WHEEL, V-SPOKE 229
S2KKA BMW LIGHT ALLOY WHEEL, V-SPOKE 206
S2KLA BMW LIGHT ALLOY WHEEL, V-SPOKE 245
S2KMA BMW LA WHEEL, V-SPOKE 245 FLAT-RUNN.
S2KNA BMW LIGHT ALLOY WHEEL, V-SPOKE 255
S2KPA BMW LIGHT ALLOY WHEEL, V-SPOKE 248
S2KRA BMW LIGHT ALLOY WHEEL, V-SPOKE 257
S2KSA BMW LA WHEEL, V-SPOKE 254
S2KTA BMW LA WHEEL, V-SPOKE 277 / FLAT-RUNN.
S2KUA BMW LA WHEEL V-SPOKE 285
S2KVA BMW LA WHEEL V-SPOKE 294
S2KWA BMW LA WHEEL V-SPOKE 296
S2KXA BMW LA WHEEL V-SPOKE 279
S2KYA BMW LA WHEEL V-SPOKE 277
S2KZA BMW LA WHEEL V SPOKE 318
S2LAA BMW LA WHEEL Y-SPOKE 114
S2LBA BMW LA WHEEL Y-SPOKE 131
S2LCA BMW LA WHEEL Y-SPOKE 183
S2LDA BMW LA WHEEL Y-SPOKE 211
S2LEA BMW LA WHEEL Y-SPOKE 214
S2LFA BMW LA WHEEL Y-SPOKE 280
S2LGA BMW LA WHEEL Y SPOKE 315
S2LHA BMW LA WHEEL Y SPOKE 322
S2M0A BMW LA WHEEL, INDIVIDUAL 152 I, 18"
S2M1A BMW LA WHEEL, INDIVIDUAL 152 I, 19"
S2M2A BMW LA WHEEL, INDIVIDUAL 152 I, 20"
S2M4A IND.LEATH.-COV. STEER.WHEEL,LEATH.INLAY
S2M5A BMW LA WHEEL, M V SPOKE 223
S2M6A INDIVID. LEATHER ST.WHEEL W/WOOD INLAY
S2M7A M HIGH PERFORMANCE TYRES
S2M8A BMW LA WHEEL, V-SPOKE 228,INDIVID.
S2M9A BMW LA WHEEL, M V-SPOKE 227
S2MAA MANUAL GEARBOX
S2MBA BMW ALLOY WHEEL, 19" FORGED
S2MBA BMW ALLOY WHEEL, M DOUBLE SPOKE 167
S2MCA BMW ALLOY WHEEL, M RADIAL SPOKE 166
S2MDA M DRIVE
S2MEA BMW ALLOY WHEEL, M DOUBLE SPOKE 194
S2MFA BMW ALLOY WHEEL, M SPIDER SPOKE 193
S2MGA BMW ALLOY WHEEL, M DOUBLE SPOKE 207
S2MHA BMW ALLOY WHEEL, M DOUBLE SPOKE 208
S2MKA M TWIN-CLUTCH TRANSM. WITH DRIVELOGIC
S2MLA BMW ALLOY WHEEL, M DOUBLE SPOKE 192
S2MMA BMW ALLOY WHEEL M Y-SPOKE 191
S2MNA BMW LA WHEEL M DOUBLE SPOKE 192/ALL S.
S2MPA BMW ALLOY WHEEL, M DOUBLE SPOKE 225
S2MRA BMW LA WHEEL, M DOUBLE SPOKE 261
S2MTA BMW LA WHEEL, M DOUBLE SPOKE 220
S2MUA BMW LA WHEEL, M STAR SPOKE 325
S2MVA BMW LA WHEEL, M DOUBLE SPOKE 326
S2MWA BMW LA WHEEL, V SPOKE 265 INDIVIDUAL
S2NAA INTERIOR MIRROR WITH DIGITAL COMPASS
S2NNA BMW LA WHEEL M STYLING 172 19"
S2NNA BMW ALLOY WHEEL, M DOUBLE SPOKE 172
S2NPA BMW LA WHEEL M STYLING 135 18"
S2NPA BMW ALLOY WHEEL, M DOUBLE SPOKE 135
S2NSA BMW LA WHEEL DOUBLE SPOKE 288
S2NTA BMW LA WHEEL, M V SPOKE 299
S2NUA BMW LA WHEEL DOUBLE SPOKE 300
S2NVA BMW LA WHEEL, INDIVIDUAL V SPOKE 301
S2NWA BMW LA WHEEL, M V SPOKE 302
S2NXA BMW LA WHEEL DOUBLE SPOKE 303
S2PAA LOCKABLE WHEEL BOLT
S2R1A BMW LIGHT ALLOY WHEEL, SPIDER SPOKE 138
S2R2A BMW LA WHEEL, START SPOKE 256
S2R3A BMW LA WHEEL, STAR SPOKE 203
S2R4A BMW LA WHEEL, STAR SPOKE 230
S2R5A BMW LA WHEEL, STAR SPOKE 204
S2R6A BMW LA WHEEL, START SPOKE 231
S2R7A MINI LA WHEEL BRIDGE SPOKE/ ALL SEASON
S2R8A BMW LA WHEEL, START SPOKE 241
S2RAA BMW ALLOY WHEEL, TRAPEZOID STYLE 134
S2RBA MINI LM RAD 7 FIN SPOKE M. NOTLAUF
S2RCA ALUMINUM RIM WITH WHEEL COVER
S2RDA BMW LA WHEEL-SPOKE 176/MIXED TYRES
S2REA MINI LA WHEEL WEB SPOKE FLAT-RUNN. PROP.
S2RFA MINI LA WHEEL DELTA SPOKE 96
S2RGA MINI LA WHEEL BRIDGE SPOKE
S2RHA MINI LA WHEEL FLAME SPOKE 97
S2RKA MINI ALLOY WHEEL, 5-START SPOOLER 100
S2RLA MINI ALLOY WHEEL, ROTATOR SPOKE 101
S2RMA MINI LA WHEEL, NIGHT SPOKE,RUNFLAT
S2RNA MINI LA WHEEL, 5-STAR BLASTER,LIMP-HOME
S2RPA MINI LA WHEEL,CROWN SPOKE FLAT-RUNN. PRO
S2RRA MINI LA WHEEL,CROWN SPOKE 104
S2RSA MINI LA WHEEL "5 STAR PACE SPOKE"
S2RTA BMW LA WHEEL TURBINE STYLING 201
S2RUA MINI LA WHEEL BLACK STAR BULLET
S2RVA MINI LA WHEEL IN BLACK
S2RWA MINI LA WHEEL "WEB SPOKE TWO-TONE"ANTHR.
S2RXA BMW LA WHEEL, STAR SPOKE 210
S2RYA BMW LA WHEEL, STAR SPOKE 212
S2RZA BMW LA WHEEL, STAR SPOKE 213
S2S1A BMW LA WHEEL STAR SPOKE 286
S2S2A BMW LA WHEEL STAR SPOKE 287
S2S3A BMW LA WHEEL STAR SPOKE 290
S2S4A BMW LA WHEEL STAR SPOKE 295
S2S5A BMW LA WHEEL MULTI-SPOKE 293
S2S6A BMW LA WHEEL, START SPOKE 258
S2S7A BMW LA WHEEL STAR SPOKE 317
S2S8A BMW LA WHEEL STAR SPOKE 319
S2S9A BMW LA WHEEL STAR SPOKE 320
S2SAA WHEELS W/O EMERGENCY RUNNING PROPERTIES
S2SBA BMW LA WHEEL, START SPOKE 242
S2SCA BMW LA WHEEL, START SPOKE 243
S2SDA BMW LA STAR SPOKE 243 W FLAT-RUNN. PROP.
S2SEA BMW LA STAR SPOKE 246 W FLAT-RUNN. PROP.
S2SFA BMW LA WHEEL, START SPOKE 249
S2SGA BMW LA WHEEL, START SPOKE 232
S2SHA BMW LA WHEEL, START SPOKE 258
S2SKA BMW LA WHEEL, START SPOKE 259
S2SLA BMW LA WHEEL, STAR SPOKE 262
S2SMA BMW LA WHEEL, STAR SPOKE 264
S2SNA BMW LA WHEEL, STAR SPOKE 117
S2SPA BMW LA WHEEL, STAR SPOKE 233
S2SRA BMW LA WHEEL, DOUBLE SPOKE 234
S2STA BMW LA WHEEL, MULTISPOKE 235
S2SUA BMW LA WHEEL, STAR SPOKE 250
S2SVA BMW LA WHEEL, STAR SPOKE 251
S2SWA BMW LA WHEEL STAR SPOKE 272
S2SXA BMW LA WHEEL MULTI-SPOKE 282
S2SYA BMW LA WHEEL STAR SPOKE 283
S2SZA BMW LA WHEEL MULTI-SPOKE 284
S2TAA DIFFERENTIAL LOCK 25%
S2TBA SPORT AUTOMATIC GEARBOX
S2TCA SPORT GEARBOX WITH TWIN CLUTCH
S2TDA AUTOMATIC TRANSM. WITH W/ TWIN CLUTCH
S2VAA CHASSIS & SUSPENS. SETUP"ADAPTIVE DRIVE"
S2VBA TYRE PRESSURE CONTROL (TPC)
S2VFA ADAPTIVE M CHASSIS
S2VHA INTEGRAL ACTIVE FRONT STEERING
S2VKA DYNAMIC PERFORMANCE CONTROL
S2WAA BMW LA WHEEL, W-SPOKE 263
S2WBA BMW LA WHEEL W-SPOKE 291
S2WCA BMW LM RAD W-SPEICHE 332
S2WDA BMW LM RAD W-SPEICHE 332
S2XAA SPORT LEATHER ST. WHEEL W/ SHIFT PADDLES
S2XAA LEATH.-COV.SPORT ST.WHEEL+PADD.+MULTIF.
S300A EMERGENCY SPARE WHEEL
S300A CENTRAL LOCKING WITH ANTI-THEFT SYSTEM
S301A ALL-TERRAIN TYRES
S301A ALARM SYSTEM
S302A ALARM SYSTEM
S303A BMW LIGHT ALLOY WHEEL, ELLIPS. STYL. 60
S303A BURGLAR AL. WITH TILT ALARM SENSOR
S304A BMW LIGHT ALLOY WHEEL, ELLIPS. STYL. 60
S305A REMOTE CONTROL FOR CENTRAL LOCKING
S306A MINI ALLOY WHEEL 7-HOLE 81
S306A CLOSING PACK
S306A REMOTE CONTROL FOR CENTRAL LOCKING
S307A BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 61
S307A SAFETY LOCKING FOR LUGGAGE COMPARTMENT
S308A BMW LIGHT ALLOY WHEEL, CROSS SPOKE 42
S308A COMFORT PACKAGE
S309A BMW LIGHT ALLOY WHEEL, STAR SPOKE 57
S309A BMW LA WHEEL, STAR-SPOKE STYLING
S310A BMW LIGHT ALLOY WHEEL, STAR SPOKE 58
S310A COMFORT PACKAGE
S311A BMW LIGHT ALLOY WHEEL CHROMED
S311A BMW LA WHEEL, STAR SPOKE 69
S312A BMW LA WHEEL, V-STYLING 63
S312A BMW LA WHEELS WITH MIXED TYRES
S313A FOLD-IN OUTSIDE MIRROR
S314A DOOR MIRROR, DRIVER LOCK, HEATED
S315A REAR WINDOW WIPER
S316A AUTOMATIC TRUNK LID MECHANISM
S317A COMFORT ACTUATION, DOORS
S317A SOFT CLOSE AUTOMATIC, LUGGAGE-COMP. LID
S318A INTERIOR SURFACE IN VEHICLE COLOUR
S318A DOUBLE SUN VISORS
S318A SOFT CLOSE AUTOMATIC, DOOR/LUGGAGE COMP.
S319A INTEGRATED UNIVERSAL REMOTE CONTROL
S320A DELETED, MODEL LETTERING
S321A EXTERIOR PARTS IN VEHICLE COLOUR
S321A MODEL LETTERING
S322A REAR CHROME STRIP DISCONTINUED
S322A COMFORT ACCESS
S323A SOFT-CLOSE-AUTOMATIC DOORS
S324A BMW LA WHEEL, ELLIPSOID STYLING 107
S324A FRONT AND REAR SPOILERS
S325A REAR SPOILER
S326A DELETED, REAR SPOILER
S327A ORNAMENTAL STRIPS ON HOOD, WHITE
S328A DOOR SILL
S328A FOOTPLATE, ALUMINIUM
S329A ORNAMENTAL STRIPS ON HOOD, BLACK
S331A BMW LA WHEEL, STAR SPOKE 102
S332A BMW LA WHEEL TURBINE STYLING 106
S333A WIND DEFLECTOR
S333A BMW LA WHEEL, STAR SPOKE 105
S334A BMW LA WHEEL/DOUBLE SPOKE 71
S334A BMW LA WHEEL/DOUBLE SPOKE 103
S338A M SPORTS PACKAGE II
S339A SHADOW-LINE
S340A BUMPER, PARTIALLY PAINTED
S340A RUBBING STRIPS BLACK
S341A BUMPERS COMPLETELY IN BODY COLOUR
S342A INTERIOR TRIM STRIPS, TITAN SHADOW
S343A CHROME LINE INTERIOR, MATT
S344A ALU LINE INTERIEUR
S345A CHROME LINE INTERIEUR
S346A CHROME LINE EXTERIEUR
S347A TITAN LINE EXTERIEUR
S348A HIGHLIGHT EXTERIEUR
S349A HIGHLIGHT INTERIEUR
S350A THERM.INSULAT.GLASS GREEN
S350A BMW COMPOSITE WHEEL, STAR SPOKE 108
S351A BMW LA WHEEL, STAR SPOKE 89
S352A INSULATING DOUBLE-GLAZING
S353A WINDSCREEN&REAR WINDOW,GREEN-TINTEDSTRIP
S354A GREEN WINDSCREEN, GREEN SHADE BAND
S355A LAMINATED GLASS
S355A WINDSCREEN, CLEAR WITH ANTI-GLARE STRIP
S356A CLIMATE COMFORT LAMINATED GLASS
S357A PROTECTIVE GLAZING
S358A CLIMATE COMFORT WINDSCREEN
S359A THERM.INSULAT.GLASS GREEN/CLEAR WINDSCR.
S359A VISIBILITY PACKAGE
S360A BMW LA WHEEL, STAR SPOKE 81
S361A BMW LA WHEEL, PARALLEL SPOKE 82
S361A VENT WINDOW REAR
S362A VENT WINDOW, ELECTRIC, REAR
S363A BMW LIGHT ALLOY WHEEL, RADIAL SPOKE 32
S364A SAFETY TYRES
S365A REAR WINDOW, LAMINATED GLASS
S365A SAFETY TYRES
S366A BMW LA WHEEL, STAR SPOKE 70
S367A MINI LA WHEEL, 8-SPOKE 82
S368A MINI LA WHEEL, 5-STAR 16"
S369A MINI LA WHEEL, S-SPOKE 85
S370A SOFTTOP, BLACK
S370A LAND ROVER LM RAD STYLING 1
S371A LAND ROVER LA WHEEL STYLING 2
S372A FOLDING TOP, DUNKEL-BRAUN
S372A LAND ROVER LM RAD STYLING 3
S373A SOFTTOP, DARK BLUE
S373A LAND ROVER LM RAD STYLING 4
S374A BMW LIGHT ALLOY WHEEL,RADIAL STYLING
S375A CONVERTIBLE TOP, ELECTROMECH., BLACK
S375A BMW LA WHEEL, DOUBLE SPOKE 79
S376A CONVERTIBLE TOP, ELECTROMECH.,DARK BROWN
S376A BMW LA WHEEL, STAR SPOKE 74
S377A CONVERTIBLE TOP, ELECTROMECH., DARK BLUE
S377A BMW LA WHEEL, STAR SPOKE 69
S378A BMW LA WHEEL W FLAT-RUNNING PROPERTIES
S379A BMW LA WHEEL Y-SPOKE 80
S380A HARDTOP-PREPARATION
S381A OUTS.MIRROR BLACK/ROOF VHCLE COLOUR
S382A ROOF AND MIRROR CAPS, WHITE
S383A ROOF AND MIRROR CAPS, BLACK
S384A LIGHT-ALLOY WHEELS, WHITE
S385A ROOF RACK SYSTEM
S385A MINI LA WHEEL, X-LITE 84
S385A OUTSIDE MIRROR/ROOF IN GREY
S386A ROOF RAILING
S387A WIND DEFLECTOR
S388A SOFTTOP, BLACK
S389A SOFTTOP, GREY
S390A SOFTTOP CLASSIC RED
S391A SOFTTOP, DARK BLUE
S392A SOFTTOP, DARK GREEN
S393A CONVERTIBLE TOP, TURQUOISE
S394A SOFTTOP DARK BEIGE
S395A ROLLOVER PROTECTION SYSTEM
S396A SAFETY TYRES
S397A BMW LA WHEEL, STAR SPOKE 83
S398A SOFTTOP, ELECTROMECH. SEMIAUTOM.
S399A SOFTTOP, ELECTROMECH. ALL-AUTOM.
S3ABA MIRROR CAP IN VEHICLE COLOUR
S3ACA TRAILER COUPLING
S3ADA ENGINE-COMPARTMENT LID STRIPES PARK LANE
S3AEA ENGINE-COMPARTMENT LID STRIPES CHECKMATE
S3AFA OUTSIDE MIRROR/ROOF IN SILVER
S3AGA REVERSING CAMERA
S3AHA REVERSING CAMERA AND TOP VIEW
S3AKA ENGINE-COMPARTMENT LID STRIPES SILVER
S3ALA JOHN COOPER WORKS KIT
S3AMA C-PILLARS IN MATT SILVER
S3ANA C-PILLARS IN SILVER
S3APA WINDSCREEN WITH GREY WEDGE
S3ARA PREPARATION, REAR LUGGAGE RACK
S3ASA ROOF RAILS, SILVER
S3ATA DACHRELING ALUMINIUM SATINIERT
S3DVA ROOF-RACK PREPARATION
S3MAA INDIVID. ROOF RAIL, BURNISHED ALUMINIUM
S3MBA INDIV. EXT. LINE, BURNISHED ALUMINIUM
S3MCA INDIV.ROOFRAILING,MIRROR-FIN.SHADOW LINE
S3XLA X LINE
S3YAA CONVERT. TOP, ANTHRACITE, SILVER EFFECT
S3YBA CONVERTIBLE TOP, SILVER EFFECT,DARK BLUE
S3YDA FOLDING TOP, DUNKEL-BRAUN
S400A SLIDE/TILT SUNROOF, MANUALLY OPERATED
S401A LIFT-UP-AND-SLIDE-BACK SUNROOF, ELECTRIC
S402A PANORAMA GLASS ROOF
S403A GLASS ROOF, ELECTRICAL
S404A DOUBLE COVER-SLIDING LIFTING ROOF
S405A EXTERIOR MIRROR CAPS, CHROME-PLATED
S406A ROLL-BACK ROOF
S410A WINDOW LIFTS, ELECTRIC, FRONT
S411A WINDOW LIFTS,ELECTRIC,FRONT/REAR
S412A LUGGAGE-COMPARTMENT FLOOR, EXTENDABLE
S413A LUGGAGE COMPARTMENT NET
S414A ROLLER BLIND, REINFORCED
S414A PARCEL NET, PASSENGER SIDE
S415A SUN-BLIND, REAR
S416A ROLLER SUN VISOR, REAR LATERAL
S417A ROLLER SUN VISOR, REAR DOOR
S418A LUGGAGE COMPARTMENT PACKAGE
S419A GLOVE COMPARTMENT COVER WITH LIGHTING
S420A SUN PROTECTION GLAZING
S421A FIRE EXTINGUISHER, HALON 2 KG
S422A FINE WOOD TRIM, MUSSLE MAPLE
S423A FLOOR MATS, VELOURS
S424A FLOOR CARPET, BLACK
S425A INTERIOR TRIM FINISHERS
S426A INTERIOR TRIM FINISHERS, ALUMINIUM
S427A INTERIOR SURFACE, SILVER
S428A WARNING TRIANGLE AND FIRST AID KIT
S429A INTERIOR SURFACE, ANTHRACITE
S430A INTERIOR/OUTSIDE MIRROR WITH AUTO DIP
S431A INTERIOR REAR-VIEW MIRROR WITH AUTO DIP
S432A RAIN SENSOR/INT. MIRROR AUTO DIM ACTION
S433A INTERIOR TRIM FINISHERS
S434A INTERIOR SURFACE ALUMINIUM
S434A INTERIOR TRIM FINISHERS
S435A FINE WOOD TRIM
S436A PREP,INFINITELY VARIABLE DIP IN/RV/MIR
S436A FINE WOOD TRIM
S437A INSTRUMENT PANEL IN BLACK
S437A FINE WOOD TRIM
S438A FINE WOOD TRIM
S439A INTERIOR TRIM FINISHERS, MATT CHROME
S440A NON-SMOKER PACKAGE
S441A SMOKER PACKAGE
S442A DRINK HOLDER
S443A COMPASS FUNCTION
S444A MULTI-PURPOSE ARMREST
S445A CENTRE CONSOLE TO THE REAR
S445A PACK, STOWAGE TABLES
S447A HIGH LINE INTERIOR LINING
S449A INTERIOR TOLL MIRROR FOR JAPAN
S449A MAKE-UP MIRROR, REAR CABIN
S450A HEIGHT ADJUSTMENT, PASSENGER SEAT
S450A ACTIVE SEAT-BACKREST VENTILATION
S451A HEIGHT ADJUSTMENT, FRONT-PASS.SEAT,MECH.
S451A ACTIVE SEAT FOR DRIVER
S452A ENTRANCE ASSISTANCE IN THE REAR
S452A ACTIVE SEATS IN REAR
S453A CLIMATISED FRONT SEATS
S454A SEAT ADJUSTMENT, ELECTRIC, DRIVER SIDE
S454A AIR-CONDITIONED SEATS, REAR
S455A SEAT ADJUSTMENT, ELECTRIC, DRIVER SIDE
S455A ACTIVE SEAT FOR DRIVER AND PASSENGER
S456A COMFORT SEAT WITH MEMORY
S457A CONTOUR SEAT, FRONT, ELECTR. WITH MEMORY
S458A ELECTR. FRONT SEAT ADJUSTMENT
S459A EL. FRONT SEAT ADJUSTMENT W. MEMORY
S459A SEAT ADJUSTMENT, ELECTRIC, WITH MEMORY
S460A COMFORT SEAT, REAR, ELECTR.ADJUSTABLE
S460A ELECTR.REAR SEAT ADJUSTMENT
S461A ELECTRIC SEAT BACKREST ADJUSTMENT, REAR
S463A INTERIOR SURFACE ALLOY PATINA
S464A SKI BAG
S465A THROUGH-LOADING SYSTEM
S466A ROOF MOULDINGS IN BODY COLOUR
S467A REAR SEAT BENCH W/OUT SINGLE-SEAT SHAPE
S467A TAXI REAR SEATS IN FABRIC
S468A THROUGH-LOADING SYSTEM WITH SKI BAG
S468A SKI BAG
S469A INTEGRATED CHILD SEATS
S470A ISOFIX-SYSTEM
S471A INTERIOR SURFACE GRAPHIT-METALLIC
S472A ARMREST, FRONT, DRIVER/PASSENGER
S473A ARMREST FRONT
S474A DELETED, FRONT ARMREST
S475A ARMREST, FRONT, INCL. ST.-WHEEL ADJMNT
S476A DOOR TRIM PANEL MAGNESIUM-GREY
S477A INTERIOR SURFACE WOOD DECOR
S481A SPORTS SEAT
S482A SPORT SEAT AND SPORT STEERING WHEEL
S488A LUMBAR SUPPORT, DRIVER AND PASSENGER
S489A LUMBAR SUPPORT, FRONT PASSENGER, ELECTR.
S490A LUMBAR SUPPORT FOR REAR SEATS
S490A ADJUSTMENT, SEAT-BACKREST WIDTH
S492A ODDMENTS TRAY, CENTRE CONSOLE
S492A STORAGE COMP. IN CENTRE ARMREST, REAR
S493A STORAGE COMPARTMENT PACKAGE
S494A SEAT HEATING DRIVER/PASSENGER
S495A 3-POINT BELT & HEAD RESTR'NT,REAR MIDDLE
S496A SEAT HEATING, REAR
S497A CENTRE ARMREST, REAR
S498A HEADRESTS MECHANICALLY ADJUSTABLE, REAR
S499A HEADRESTS ELECTRICALLY ADJUSTABLE, REAR
S4A0A INTERIOR TRIM FINISHERS, ALUMINIUM
S4A1A INTERIOR TRIM FINISHERS GRAPHITANE MATT
S4A3A FINE-WOOD TRIM WALNUT LIGHT
S4A4A INTERIOR TRIM FINISHERS ALUMINIUM 'CIRRU
S4A5A INTERIOR COLOUR GOTHAM GREY
S4A6A INTERIOR COLOUR TUSCAN-BEIGE
S4A7A COLOUR LINE DARK GREY
S4A8A COLOUR LINE CREAM WHITE
S4A9A COLOUR LINE MELLOW YELLOW
S4AAA HEADLINING ANTHRACITE
S4ABA FINE WOOD TRIM BURR WALNUT
S4ACA FINE WOOD TRIM POPLAR WOODGRAIN
S4ADA INT. MOULDINGS, LONGIT. FINE SANDING ALU
S4AEA ARMREST FRONT, RETRACTABLE
S4AFA ROOFLINER, BASALT-GRAU
S4AGA INTERIOR TRIM FINISHERS TITANIUM DARK
S4AGA INTERIOR TRIM FINISHERS TITANIUM MATT
S4AHA FINE WOOD TRIM AMERICAN NUTWOOD
S4AKA INTERIOR MOULDINGS, MATT SILVER
S4AKA INTERIOR TRIM FINISHERS SILVER
S4ALA INTERIOR TRIM FINISHERS TITANIUM DARK
S4ANA INTERIOR SURFACE SEVEN
S4APA INTERIOR SURFACE PARK LANE
S4ARA INTERIOR SURFACE CHECKMATE
S4ASA FINE-WOOD TRIM POPLAR GRAIN GREY
S4ATA INTERIOR TRIM FINISHERS BLACK HIGH-GLOSS
S4AUA EXTENDED DECORATIVE SCOPES
S4AVA INTERIOR SURFACE, SIDEWALK
S4AZA FINE-WOOD TRIM BAMBOO GRAIN DARK
S4B0A REAL MYRTLE WOOD-GRAIN TRIM, ANTHRACITE
S4B1A INTERIOR MOULDINGS KASCHMIR-SILVER
S4B2A REAL MYRTLE WOOD-GRAIN TRIM, ANTHRACITE
S4B3A INT. MOULDINGS ALUMIN."AKZENTSCHLIFF"
S4B4A ALU. STRIPS GROUND LNGTHWISE/LEATHER INS
S4B5A SUPERIOR WOOD,ASH,VARIEG., BRIGHT FINISH
S4B6A INT. TRIMSTRIPS, ALUM."FLYWHEEL" BLACK
S4B7A FINE WOOD VERS."FINELINE"HIGHLY SHINY
S4B8A EDELHOLZAUSF. NUSSBAUMWURZEL/INTARSIEN
S4B9A INTERIEURLEISTEN ALU FEINSCHLIFF
S4BAA COLOUR LINE ROOSTER RED
S4BBA COLOUR LINE PACIFIC BLUE
S4BCA INTERIOR SURFACE, FLUID SILVER
S4BDA INTERIOR SURFACE PIANO BLACK
S4BEA INTERIOR SURFACE, ENGLISH OAK
S4BFA INTERIOR SURFACE BRUSHED ALUMINIUM
S4BGA DUMMY-SALAPA
S4BKA ALUM. INTERIOR STRIPS GROUND LENGTHWISE
S4BLA INTERIOR COLOUR REDWOOD RED
S4BMA INTERIOR TRIM FINISH. GRAPHITE SILK MATT
S4BNA FINE-WOOD TRIM ASH GRAIN
S4BPA FINE-WOOD TRIM POPLAR GRAIN LIGHT
S4BRA INTERIOR SURFACE, ALUMINIUM GROUND
S4BSA INTERIOR WORLD HOT CHOCOLATE
S4BTA DUMMY-SALAPA
S4BUA COLOUR LINE HOT CHOCOLATE
S4BWA REAL MAPLE WOOD-GRAIN TRIM
S4BXA INTERIOR STRIPS, HIGH-GLOSS, GREY
S4BYA REAL BAMBOO WOOD-GRAIN TRIM, ANTHRACITE
S4BZA INTERIOR TRIM FINISHERS TITANIUM LIGHT
S4CAA HIGH-GR.WOOD VERS.,VARIEG.ASH ANTHRACITE
S4CBA EDELHOLZAUSF‹HRUNG "FINELINE" NATUR
S4CCA HIGH-GR.WOOD APPL. F. LEATHER ST. WHEEL
S4CDA INTERIOR STRIPS, RUTHENIUM-GRAU METALLIC
S4CEA FINE-WOOD VERSION, FINELINE, ANTHRACITE
S4CFA INTERIOR STRIPS, SPACE-GRAU, METALLIC
S4CGA INTERIOR TRIM STRIPS "SATIN-SILBER" MATT
S4CHA FINE-WOOD VERSION, "FINELINE WAVE"
S4CKA FINE-WOOD VERSION, "FINELINE" LIGHT
S4CLA INTERIEURLEISTEN MARAKESH-BRAUN METALLIC
S4CMA INTERIEURLEISTEN PLATIN-BRONZE METALLIC
S4FAA RECARO SPORTS SEAT
S4FBA OMISSION OF SPORT SEAT
S4M0A INDIVIDUAL FINE NATURAL POPLAR WOOD
S4M1A INDIVIDUAL FINE WOOD MAHAGONI MARITIM
S4M2A INDIVIDUAL FOLDING TABLE IN REAR COMP.
S4M3A INTERIOR MOULDINGS,ALUMINIUM "CUBE PURE"
S4M4A INT. MOULDINGS ALUMINIUM 3D SILVER-GRID
S4M4A INDIVIDUAL STRIP, ALU SILVER GRID
S4M5A INDIVIDUAL LEATHER-COVERED DASHBOARD
S4M6A MILLED ALUMINIUM CONTROLLER
S4M7A INDIVIDUAL FINE WOOD MAHAGONI
S4M8A INDIVIDUAL REAR-READING LIGHT
S4M9A INDIVIDUAL REAR CONSOLE
S4MAA M MULTIFUNCTION SEAT
S4MBA INTERIOR LINE STYLE
S4MCA INTERIOR MOULDINGS CARBON FIBRE
S4MDA INTERIOR MOULDINGS, TECH ART
S4MDA INTERIOR MOULDINGS FIBRE NET EIS-GREY
S4MEA REAL WOOD VERSION, SANTOS
S4MEA FINE WOOD TRIM MADEIRA NUTWOOD
S4MFA DYNAMIC SEAT BACK WIDTH ADJUSTMENT
S4MFA ACTIVE BACKREST WIDTH ADJUSTMENT
S4MGA INT. MOULDINGS ALUMINIUM GLACIER-SILVER
S4MKA FINE WOOD TRIM CARRARA
S4MKA FINE WOOD TRIM OLIVESCHE CARRARA NAT
S4MLA INTERIOR STRIPS, PIANO LACQUER, BLACK
S4MMA INDIVIDUAL STRIPS, LEATHER-COVERED
S4MRA INTERIOR TRIM STRIPS, ALUM. HEXAGON
S4MSA INTERIOR TRIM STRIPS, ALUMINIUM "PENTAN"
S4MTA INT.TRIMSTRIPS,ALUM."SHADOW" DK.BRUSHED
S4MUA HIGH-GRADE WOOD, EUCALYPTUS, RED-BROWN
S4MVA INTERIOR TRIM STRIPS, ALUMINIUM "MICRO"
S4MWA INTERIEURLEISTEN ALUMINIUM CARBON SHADOW
S4MXA INT. TRIM STRIPS, ALUM. SHADOW LONG. GR.
S4MYA INT.TRIM,LEATHER,CARBON STRUCT.,BLACK
S4MZA FINE WOOD,VAR.PLANE-TREE MIRROR,ANTHRAC.
S4NAA INTERIOR MIRROR WITH DIGITAL COMPASS
S4NBA AUTOM. CLIMATE CONTROL WITH 4-ZONE CTRL
S4NCA AUXILIARY HEATING/VENTILATION
S4NDA INSTRUMENT PANEL, LEATHER-COVERED
S4NFA EXTENDED REAR-CABIN AIR CONDITIONING
S4U1A CERAMIC APPLICATION, CONTROL ELEMENTS
S4UAA PARTIALLY ELECTRIC SEAT ADJUSTMENT
S4UBA 3RD SEAT ROW
S4UCA PEDALS "STEEL LINE"
S4UDA SLIDING LOADING FLOOR
S4UEA REAR BENCH SEAT, LONGITUDINALLY ADJUST.
S4UFA SPORT BUTTON
S4UGA REAR SEAT BENCH, 2-SEAT
S4UHA SPORT INSTRUMENTS
S4UKA 5-SEATER
S4ULA FLAT LOAD PLATFORM
S4UMA MASSAGE FUNCTION IN REAR SEAT BACKRESTS
S4UNA THR.LOAD OPENING W/INTEG.STORAGECOMP.
S4UPA ADAPTIVE SECURING SYSTEM
S4URA AMBIENT INTERIOR LIGHT
S4USA 2-SEATER PREPARATION
S4UTA THROUGHLOAD OPENING W/INT. TRANSPORT BAG
S4UUA SOCKET 230V
S4UVA TABLES IN REAR CABIN
S4UWA SOCKET 115V
S4UXA TABLES IN REAR CABIN
S500A HEADL.WASHER SYSTEM/INTENSIVE CLEANING
S502A HEADLIGHT CLEANING SYSTEM
S507A PARK DISTANCE CONTROL (PDC), REAR
S508A PARK DISTANCE CONTROL (PDC)
S509A LASER DISTANCE MEASURING DEVICE (LAM)
S510A HEADLIGHT VERTICAL AIM CONTROL
S512A OMISSION OF HEADLIGHT VERTICAL AIM CNTRL
S519A ADDITIONAL HEADLIGHT
S520A FOG LIGHTS
S521A RAIN SENSOR
S522A XENON LIGHT
S523A AIR CONDITIONING FOR REAR WITH COOL BOX
S524A DRIVING-LIGHT CONTROL
S524A ADAPTIVE HEADLIGHTS
S525A COOLBOX
S526A DELETED, AIR CONDITIONING, REAR
S527A ACTIVATED-CARBON FILTER
S527A DELETED, COOLBOX/BAR COMPARTMENT
S528A AUTOMATIC AIR FLOW CONTROL
S529A MICROFILTER
S530A AIR CONDITIONING
S531A ALL-SEASON ROADSTER
S532A AIR-CONDITIONING SYSTEM ZG
S532A AIR FRESHER
S533A AIR CONDITIONING, REAR
S534A AUTOMATIC AIR CONDITIONING
S536A AUXILIARY HEATING
S537A INDEPENDENT VENTILATION CONTROL
S538A LATENT HEAT ACCUMULATOR
S539A INDEPENDENT HEATING
S539A INDEPENDENT A/C WITH REMOTE CONTROL
S539A REMOTE CONTROL INDEP.HEATING
S540A CRUISE CONTROL
S541A ACTIVE CRUISE CONTROL
S542A CHECK CONTROL
S543A SUPERCHARGER PRESSURE GAUGE
S544A INDIVIDUAL EQUIPMENT
S544A DYNAMIC CRUISE CONTROL
S544A CRUISE CONTROL WITH BRAKE FUNCTION
S545A ADDITIONAL INDICATOR F OIL TEMPERATURE
S545A REVCOUNTER,KM/H SPEEDO,ANALOGUE CLOCK+EC
S546A REVOLUTION COUNTER
S547A COCKPIT CHRONO PACKAGE
S547A ADDITIONAL INSTRUMENTS
S548A KILOMETRE SPEEDO
S549A EXKLUSIV-UHR
S549A RADIO CLOCK
S550A ON-BOARD COMPUTER
S551A ON-BOARD COMPUTER II WITH REMOTE CONTROL
S553A ON-BOARD COMPUTER IV WITH REMOTE CONTROL
S554A ON-BOARD COMPUTER V WITH REMOTE CONTROL
S555A ON-BOARD COMPUTER V WITH REMOTE CONTROL
S556A OUTDOOR TEMPERATURE INDICATOR
S560A READING LIGHT IN REAR COMPARTMENT
S562A READING LIGHT
S563A MAKE-UP MIRROR ILLUMINATED
S563A LIGHT PACKAGE
S564A INTERIOR LIGHT PACKAGE
S570A REINFORCED POWER SUPPLY
S571A REINFORCED POWER SUPPLY
S575A SOCKET, LUGG. COMP. INCL. 2. BATT.
S577A PREPARATION, HIRE CAR
S581A TAXI PACKAGE
S582A DUMMY-SALAPA
S583A BMW LA WHEEL AERO 90
S584A BMW LA WHEEL STYLING 94
S585A BMW LA WHEEL/DOUBLE SPOKE 71
S586A BMW LA WHEEL S-SPOKE
S587A BMW LA WHEEL/DOUBLE SPOKE 116
S588A BMW LA WHEEL, STAR SPOKE 115
S589A BMW LA WHEEL, STAR SPOKE 122
S590A BMW LA WHEEL, STAR SPOKE 123
S591A BMW LA WHEEL, STAR SPOKE 124
S592A BMW LA WHEEL, RADIAL SPOKE 118
S593A BMW LA WHEEL/DOUBLE SPOKE 120
S594A BMW LIGHT ALLOY WHEEL,SPIDER SPOKE 92
S595A BMW LA WHEEL, ELLIPSOID STYLING 121
S596A BMW LIGHT ALLOY WHEEL, V-SPOKE 126
S597A BMW LA WHEEL, STAR SPOKE 89
S5AAA REAR FOG LIGHT
S5ABA TWO-STAGE STOPLAMP DISCONTINUED
S5ACA HIGH-BEAM ASSISTANT
S5ADA LANE DEPARTURE WARNING
S5AEA HIGH SPEED BRAKE SYSTEM
S5AFA SIDE UNDER MONITOR
S5AGA LANE CHANGE WARNING
S5AHA DECODING, DYNAMIC BRAKE LIGHT
S5AKA LED LIGHT ELEMENTS
S5DAA PASSENGER AIRBAG DEACTIVATION
S5DBA RETRACTOR 3-POINT SEAT BELT, REAR CENTER
S5DCA REAR-SEAT HEADRESTS, FOLDING
S5DDA LIFTING JACK
S5DFA ACTIVE CRUISE CONTROL+STOP&GO FUNCTION
S5DKA SIDE VIEW CAMERA
S5DPA PARK ASSIST
S5DRA PARK DISTANCE CONTROL INCL. TOP VIEW
S5DSA EMERGENCY RELEASE, LUGGAGE COMPARTMENT
S5DTA DYNAMIC TRACTION CONTROL
S5GAA PREPARATION ALARM SYSTEM
S601A TV FUNCTION
S602A ON-BOARD MONITOR WITHTV
S603A FOND SCREEN
S604A PERSONAL TRAVEL ASSISTENT
S605A TELEMATICS PREPARATION
S605A BTX/TELEFON
S606A NAVIGATION SYSTEM BUSINESS
S606A NAVIGATION SYSTEM, RADIO
S607A PREPARATION, TELESERVICE
S607A PERSONAL COMPUTER (PC)
S608A TRAVEL NOTE SYSTEM
S608A NAVIGATION SYSTEM WITH ON-BOARD MONITOR
S609A NAVIGATION SYSTEM, PROFESSIONAL
S610A HEAD-UP DISPLAY
S611A BMW NIGHT VISION
S612A BMW ASSIST
S613A INTERNET-BASED SERVICES
S614A INTERNET
S615A EXTENDED BMW ONLINE INFORMATION
S616A BMW ONLINE
S619A EMERGENCY SOS CALL SYSTEM
S620A VOICE CONTROL
S621A FULLY INTEGRATED MOBILE PHONE, KOREA
S621A BMW TELEFON BEDIENH÷R.VORN C-NETZ
S622A SECOND HANDSET IN REAR FOR BMW TELEPHONE
S623A CAR TELEPHONE D-NETWORK (GSM)
S624A FREISPRECHANLAGE F‹R C-NETZ
S624A PREPARTATION BMW HANDY (SIEMENS)
S625A TELEPHONE, D-NETWORK MOBILE PHONE
S625A PREPARATION BMW HANDY (MOTOROLA)
S626A TELEPHONE SIEMENS C2
S627A TELEPHONE SIEMENS C3 HANDSET, FRONT
S627A PREPARTATION BMW HANDY (NOKIA)
S629A CAR TELEPHONE (GSM) W CARD READER, FRONT
S630A CAR PHONE WITH CORDLESS RECEIVER
S631A SECOND RECEIVER IN THE REAR, CORDLESS
S632A VORBER. TEL. C-NETZ BED. VO. U. HI.
S632A PREPARATION BMW HANDY (MOTOROLA)
S633A PREPARATION, MOBILE PHONE, BUSINESS
S633A PREP., TELEPHONE SIEMENS HANDSET, FRONT
S634A FITTINGS TELEPHONE INSTALL. C NET
S635A FITTINGS TELEPHONE INSTALL. D NET
S636A PREP.,TEL.INST'N, MOB.PHONE, D-NETWORK
S637A PREP.,TELEPHONE SIEMENS C3 HANDSET,FRONT
S638A CAR TELEPHONE PROFESSIONAL
S639A PREPARATION F MOBILE PHONE CPL. USA/CDN
S640A PREPARATION F TEL.INSTALLATION UNIVERSAL
S641A PREP. MOBILE PHONE USA UNIVERSAL
S641A PREP. TELEPHONE INSTALLATION BMW,COVERED
S642A MOBILE, FULLY INTEGRATED US STANDARD
S642A PREP. TELEPHONE INSTALLATION BMW, COMPL.
S643A PREP. CAR TEL. D-NETWORK F. AXICON
S644A PREPARATION F MOBILE PHONE W BLUETOOTH
S645A BMW US RADIO
S646A PREPARATION F TELEPH.INSTALLATION JAPAN
S647A BECKER MEXICO ELECTRONIC II O.VF
S648A RADIO BMW CD
S648A RADIO GRUNDIG 3883 RDS
S649A MC PLAYER
S650A CD PLAYER
S650A RADIO BMW REVERSE
S650A CD PLAYER
S651A RADIO BMW REVERSE RDS
S651A MD PLAYER
S652A RADIO BAVARIA C II
S652A DVD PLAYER
S653A RADIO BAVARIA C REVERSE II
S653A BMW DIGITAL RADIO
S653A HIGH DEFINITION RADIO
S654A RADIO BAVARIA C III
S654A DAB TUNER
S655A SATELLITE TUNER
S655A RADIO BAVARIA C BUSINESS
S656A RADIO MINI MC
S656A RADIO, BMW REVERSE/MINI WAVE
S656A RADIO BAVARIA C PROFESSIONAL
S657A RADIO, BMW BUSINESS/MINI BOOST
S657A RADIO BAVARIA C REVERSE III
S658A RADIO BMW BUSINESS CD RDS
S659A RADIO BAVARIA ELECTRONIC CD II
S659A RADIO BMW BUSINESS CD
S660A RADIO BMW REVERSE (C42)
S661A RADIO BMW BUSINESS (C43)
S662A RADIO BMW BUSINESS CD
S663A RADIO BMW PROFESSIONAL CD
S663A RADIO BMW PROFESSIONAL (C44)
S664A RADIO BMW REVERSE RDS
S664A MOBILE PHONE, US STANDARD
S664A MOBILE PHONE PREPARATION
S665A RADIO BMW BUSINESS RDS
S666A RADIO BMW BUSINESS CD RDS
S667A RADIO BMW PROFESSIONAL RDS
S667A RADIO BMW AUDIO
S668A RADIO BMW REVERSE RDS
S669A RADIO BMW BUSINESS RDS
S670A RADIO BMW PROFESSIONAL RDS
S672A CD CHANGER FOR 6 CDS
S673A HIFI SYSTEM USA
S674A HI-FI SYSTEM HARMAN KARDON
S675A SOUND SYSTEM
S675A REAR-CABIN AUDIO SYSTEM
S676A HIFI SPEAKER SYSTEM
S677A HIFI SYSTEM PROFESSIONAL DSP
S678A HEADSET SYSTEM IN REAR COMPARTMENT
S679A SUBWOOFER, HIFI SYSTEM
S679A REAR WINDOW ANTENNA
S680A RADIO ANTENNA, MANUAL
S681A ROOF ANTENNA
S682A REAR SEAT BENCH IN FABRIC
S683A TELEPHONE ANTENNA D-NETWORK
S684A REAR-WINDOW TELEPHONE ANTENNA D-NETWORK
S685A TELEPHONE ANTENNA C-NETWORK
S686A ANTENNA-DIVERSITY
S687A RADIO PREPARATION
S689A PREPARATION FOR IN-CAR VIDEO
S690A CASSETTE HOLDER
S691A CD HOLDER
S692A PREPARATION, BMW 6-CD CHANGER I-BUS
S693A PREPARATION BMW SATELLITE RADIO
S693A REAR SPEAKER SYSTEM
S694A PROVISIONS FOR BMW 6 CD CHANGER
S695A MD-CHANGER
S695A REMOTE CONTROL RADIO
S696A DVD CHANGER
S696A CD CHANGER BUSINESS
S696A CD BOX
S697A AREA-CODE 1 FOR DVD
S697A AUTOMATIC TELEPHONE AERIAL
S698A AREA-CODE 2 FOR DVD
S699A AREA-CODE 3 FOR DVD
S6A1A ALWAYS OPEN TIMER
S6AAA BMW TELESERVICES
S6ABA CONTROL, TELESERVICES
S6FAA PROVISION FOR DVD SYSTEM IN REAR
S6FBA RADIO MINI CD
S6FBA RADIO MINI WAVE CD
S6FCA RADIO MINI BOOST CD
S6FDA MINI HIFI SPEAKER SYSTEM
S6FEA MASK NEW ZEALAND
S6FFA DVD-SYSTEM IN REAR COMPARTMENT
S6FGA REAR-COMPARTMENT ENTERTAINMENT
S6FHA REAR-CABIN ENTERTAINMENT, PROFESSIONAL
S6FKA AUDIO OPERATION IN REAR CABIN
S6FLA USB/AUDIO INTERFACE
S6FNA DVD CHANGER, PREPARATION
S6M1A INDIVIDUAL REAR-COMPARTMENT ENTERTAINM.
S6M2A INDIVID. REAR-COMP.ONLINE INFOTAINMENT
S6NAA CAR TELEPHONE IN REAR COMPARTMENT
S6NBA REAR-CABIN TELEPHONE W/ CORDLESS HANDSET
S6NCA TELEPHONE WITH CORDLESS KEYPAD HANDSET
S6NDA HANDS-FREE KIT, BLUETOOTH + USB/AUDIO
S6NEA MOBILE-PHONE PREP.,BLUETOOTH + USB/AUDIO
S6NFA PREP., SMARTPHONE BLUETOOTH USB/AUDIO
S6UAA PREPARATION CCC
S6UBA PREPARATION VOICE INPUT SYSTEM
S6UBA PREPARATION OF VOICE INPUT SYSTEM
S6UCA PREPARATION FOR TV FUNCTION
S6UDA LANGUAGE VERSION, RUSSIAN
S6UEA ANTI-THEFT PROTECTION FOR NAVIGATION DVD
S6UFA PREPARATION FOR NAVIGATION SYSTEM
S6UGA MINI NAVIGATION SYSTEM
S6UHA TRAFFIC INFORMATION
S6UKA NIGHT VISION WITH PERSON RECOGNITION
S6VAA CIC-ZUSTEUERUNG
S6VBA CCC ASSIGNMENT
S6VCA DUMMY-SALAPA
S700A AREA-CODE 4 FOR DVD
S701A AREA-CODE 5 FOR DVD
S702A AREA-CODE 6 FOR DVD
S704A M SPORTS SUSPENSION
S705A M SPORTS SUSPENSION II
S708A M SPORTS STEERING WHEEL LEATHER
S709A M SPORTS STEERING WHEEL LEATHER
S710A M SPORTS STEERING WHEEL, MULTIFUNCTION
S710A M LEATHER STEERING WHEEL
S711A M SPORTS SEATS
S712A M SPORTS SEAT
S713A REAR SPOILER
S713A OFF-ROAD PACK
S715A M AERODYNAMICS PACKAGE
S716A AERODYNAMICS PACKAGE
S717A COMFORT EDITION
S718A EXCLUSIVE EDITION
S719A SPORTS EDITION
S720A SPORTS LIMITED EDITION
S720A EDITION ZD
S721A EDITION ZB
S722A LIFESTYLE EDITION
S722A EDITION ZF
S723A EXCLUSIVE EDITION
S724A SPORTS EDITION
S724A EDITION ZH
S725A PREMIUM PACKAGE
S725A BASIC PACKAGE
S725A EDITION ZE
S726A EDITION ZN
S727A EDITION ZO
S728A EDITION ZV
S729A EDITION, IMPORTERS
S731A ADDITIONAL EDITION SCOPE
S732A INTERIOR MOULDINGS, CARBON FIBRE PYRIT
S733A INTERIOR MOULDINGS, WOOD, YACHT-LINE
S736A 2ND RADIO REMOTE CONTROL KEY
S737A INTERIOR MOULDINGS, ALU SHADOW, BRUSHED
S738A FINE WOOD TRIM
S739A FINE WOOD TRIM
S750A TV/VIDEO (PAL)
S751A TV/VIDEO NTSC
S752A INDIVIDUAL AUDIO SYSTEM
S753A YOUNG-LINE
S754A M REAR SPOILER
S755A FOLDING SLIDING ROOF
S756A BMW LA WHEEL, ROUND SPOKE, INDIVIDUAL
S757A INDIVIDUAL SOUND PACK
S759A FAMILIY KIT
S760A HIGH GLOSS SHADOW LINE
S761A INDIVIDUAL SUNSHADE GLAZING
S763A INDIVIDUAL SERIES JAPAN
S764A HIGH LINE EQUIPMENT
S766A INDIVIDUAL SERIES JAPAN
S767A 330I -SPORTS VERSION
S767A INDIVIDUAL SERIES "AVUS"
S767A INDIVIDUAL, SPORT
S767A PERFORMANCE PACKAGE
S768A INDIVIDUAL SERIES "CLUBSPORT"
S768A INDIVIDUALS. 95 ATLANTA OLYMP.ED.
S769A INDIVIDUAL SERIES 96 JAPAN
S770A INTERIOR MOULDINGS,ALUMIN. "SILVER CUBE"
S770A INDIVIDUAL SERIES 96 CLASSIC
S771A INTERIOR TRIM STRIPS, TITAN SHADOW
S771A SPORTS EDITION
S772A INTERIOR MOULDINGS,ALUMINIUM"BLACK CUBE"
S772A LUXURY EQUIPMENT
S773A FINE WOOD TRIM
S774A FINE WOOD TRIM
S775A HEADLINING ANTHRACITE
S776A HEADLINING, ALCANTARA
S776A CHROM EQUIPMENT
S777A TRUNK TRIM PANEL ALCANTARA
S778A INDIVIDUAL BMW IDENTIFICATION
S778A ENTRANCE STRIPS "BMW INDIVIDUAL"
S779A CARBON LINE
S780A BMW LA WHEEL, M PARALLEL SPOKE
S781A BMW LA WHEEL M KONTUR
S782A BMW LA WHEEL, M SYSTEM II
S782A SUSPENSION SYSTEM N‹RBURGRING
S783A M DOUBLE-SPOKE,FORGED
S784A M OUTSIDE MIRROR
S785A WHITE DIRECTION INDICATOR LIGHTS
S786A MEASURES, 17" WHEELS
S787A BMW ALLOY WHEEL, M DOUBLE SPOKE 135
S787A BMW LA WHEEL, INDIVIDUAL
S788A BMW LA WHEEL, INDIVIDUAL
S789A BMW LA WHEEL, INDIVIDUAL
S790A BMW ALLOY WHEEL, M DOUBLE SPOKE 97
S790A EXTRA TANK
S791A M TECHNIC SERVOTRONIC
S791A COOLBOX
S792A BMW LA WHEEL M 19" FORGED
S793A SEQUENTIAL M GEARBOX DRIVELOGIC
S795A BMW COMPOSITE WHEEL, M DOUBLE SPOKE 71
S798A CONVERTIBLE TOP, MAGENTA (INDIVIDUAL)
S7ARA AERODYNAMICS PACKAGE
S7BAA MINI REPAIR INCLUSIVE
S7BBA MINI REPAIR INCLUSIVE
S7BCA MINI REPAIR INCLUSIVE
S7BDA MINI REPAIR INCLUSIVE
S7BEA MINI REPAIR INCLUSIVE
S7BFA MINI REPAIR INCLUSIVE
S7BGA MINI REPAIR INCLUSIVE
S7BHA MINI REPAIR INCLUSIVE
S7BKA MINI REPAIR INCLUSIVE
S7CAA MINI REPAIR INCLUSIVE
S7CBA MINI REPAIR INCLUSIVE
S7CCA MINI REPAIR INCLUSIVE
S7CDA MINI REPAIR INCLUSIVE
S7CEA MINI REPAIR INCLUSIVE
S7CFA MINI REPAIR INCLUSIVE
S7CGA MINI REPAIR INCLUSIVE
S7CHA MINI REPAIR INCLUSIVE
S7CKA MINI REPAIR INCLUSIVE
S7D1A BMW SERVICE INCLUSIVE
S7D2A BMW SERVICE + REPAIR INCLUSIVE
S7D3A BMW SERVICE + REPAIR INCLUSIVE
S7D4A BMW SERVICE + REPAIR INCLUSIVE
S7D5A BMW SERVICE + REPAIR INCLUSIVE
S7D6A BMW SERVICE + REPAIR INCLUSIVE
S7D7A BMW BASIC SERVICE INCLUSIVE
S7D8A BMW SERVICE INCLUSIVE
S7DAA BMW SERVICE INCLUSIVE
S7DBA BMW SERVICE INCLUSIVE
S7DCA BMW SERVICE + REPAIR INCLUSIVE
S7DDA BMW SERVICE INCLUSIVE
S7DEA BMW SERVICE INCLUSIVE
S7DFA BMW SERVICE + REPAIR INCLUSIVE
S7DGA BMW SERVICE INCLUSIVE
S7DHA BMW SERVICE + REPAIR INCLUSIVE
S7DKA BMW SERVICE + REPAIR INCLUSIVE
S7DLA BMW SERVICE INCLUSIVE
S7DMA BMW SERVICE INCLUSIVE
S7DNA BMW SERVICE INCLUSIVE
S7DPA BMW SERVICE INCLUSIVE
S7DRA BMW SERVICE INCLUSIVE
S7DSA BMW SERVICE INCLUSIVE
S7DTA BMW SERVICE INCLUSIVE
S7DUA BMW SERVICE INCLUSIVE
S7DVA BMW SERVICE INCLUSIVE
S7DWA BMW SERVICE INCLUSIVE
S7DXA BMW SERVICE INCLUSIVE
S7DYA BMW SERVICE INCLUSIVE
S7DZA BMW SERVICE INCLUSIVE
S7FAA INCLUDING MINI SERVICE
S7FBA INCLUDING MINI SERVICE AND REPAIR
S7FCA INCLUDING MINI SERVICE AND REPAIR
S7FDA INCLUDING MINI SERVICE AND REPAIR
S7FEA INCLUDING MINI SERVICE AND REPAIR
S7FFA INCLUDING MINI SERVICE AND REPAIR
S7FGA MINI BASIC SERVICE INCLUSIVE
S7FHA MINI BASIC SERVICE INCLUSIVE
S7M0A BMW INDIVIDUAL COMPOSITION I
S7M1A BMW INDIVIDUAL COMPOSITION II
S7M5A M EXTERIOR EQUIPMENT
S7M5A BMW INDIVIDUAL EXTERIOR KIT
S7MAA COMPETITION PACKAGE
S7MEA M DRIVERS PACKAGE
S7N1A BMW SERVICE INCLUSIVE
S7N2A BMW SERVICE INCLUSIVE
S7N3A BMW SERVICE + REPAIR INCLUSIVE
S7N4A BMW SERVICE INCLUSIVE
S7N5A BMW SERVICE INCLUSIVE
S7N6A BMW SERVICE + REPAIR INCLUSIVE
S7N7A BMW SERVICE INCLUSIVE
S7N8A BMW SERVICE INCLUSIVE
S7N9A BMW SERVICE + REPAIR INCLUSIVE
S7NAA BMW SERVICE INCLUSIVE
S7NBA BMW SERVICE + REPAIR INCLUSIVE
S7NCA BMW SERVICE INCLUSIVE
S7NDA BMW SERVICE + REPAIR INCLUSIVE
S7NEA BMW SERVICE INCLUSIVE
S7NFA BMW SERVICE + REPAIR INCLUSIVE
S7NGA BMW SERVICE INCLUSIVE
S7NHA BMW SERVICE INCLUSIVE
S7NKA BMW SERVICE INCLUSIVE
S7NLA BMW SERVICE + REPAIR INCLUSIVE
S7NMA BMW SERVICE INCLUSIVE
S7NNA BMW SERVICE + REPAIR INCLUSIVE
S7NPA BMW SERVICE INCLUSIVE
S7NRA BMW SERVICE INCLUSIVE
S7NSA BMW SERVICE + REPAIR INCLUSIVE
S7NTA BMW SERVICE INCLUSIVE
S7NUA BMW SERVICE INCLUSIVE
S7NVA BMW SERVICE + REPAIR INCLUSIVE
S7NWA BMW SERVICE INCLUSIVE
S7NXA BMW SERVICE INCLUSIVE
S7NYA BMW SERVICE INCLUSIVE
S7NZA BMW SERVICE + REPAIR INCLUSIVE
S7P1A MINI BASIC SERVICE INCLUSIVE
S7P2A MINI BASIC SERVICE INCLUSIVE
S7P3A MINI BASIC SERVICE INCLUSIVE
S7P4A MINI BASIC SERVICE INCLUSIVE
S7P5A MINI BASIC SERVICE INCLUSIVE
S7P6A INCLUDING MINI SERVICE
S7P7A INCLUDING MINI SERVICE
S7P8A INCLUDING MINI SERVICE
S7P9A INCLUDING MINI SERVICE
S7PAA INCLUDING MINI SERVICE
S7PBA INCLUDING MINI SERVICE AND REPAIR
S7PCA MINI BASIC SERVICE INCLUSIVE
S7PDA MINI BASIC SERVICE INCLUSIVE
S7PEA INCLUDING MINI SERVICE
S7PFA INCLUDING MINI SERVICE AND REPAIR
S7PGA MINI BASIC SERVICE INCLUSIVE
S7PHA INCLUDING MINI SERVICE
S7PKA INCLUDING MINI SERVICE AND REPAIR
S7PLA MINI BASIC SERVICE INCLUSIVE
S7PMA INCLUDING MINI SERVICE
S7PNA INCLUDING MINI SERVICE AND REPAIR
S7PPA MINI BASIC SERVICE INCLUSIVE
S7PRA INCLUDING MINI SERVICE
S7PSA INCLUDING MINI SERVICE AND REPAIR
S7PTA MINI BASIC SERVICE INCLUSIVE
S7PUA INCLUDING MINI SERVICE
S7PVA INCLUDING MINI SERVICE AND REPAIR
S7PWA MINI BASIC SERVICE INCLUSIVE
S7PXA INCLUDING MINI SERVICE
S7PYA INCLUDING MINI SERVICE AND REPAIR
S7SNA NAVI BUSINESS/MOBILE-PH.PREP. BLUETOOTH
S7SPA NAVI PROFESSIONAL/M.-PH.PREP. BLUETOOTH
S7T1A BASIC SERVICE INCLUSIVE
S7T2A BASIC SERVICE INCLUSIVE
S7T3A BASIC SERVICE INCLUSIVE
S7T4A BASIC SERVICE INCLUSIVE
S7T5A BMW SERVICE INCLUSIVE
S7T6A BMW SERVICE INCLUSIVE
S7T7A BMW SERVICE PLUS
S7T8A BMW SERVICE ULTIMATE
S7TAA BMW BASIC SERVICE INCLUSIVE
S7TBA BMW BASIC SERVICE INCLUSIVE
S7TCA BMW BASIC SERVICE INCLUSIVE
S7TDA BMW BASIC SERVICE INCLUSIVE
S7TEA BMW BASIC SERVICE INCLUSIVE
S7TFA BMW BASIC SERVICE INCLUSIVE
S7TGA BMW BASIC SERVICE INCLUSIVE
S7THA BMW BASIC SERVICE INCLUSIVE
S7TKA BMW BASIC SERVICE INCLUSIVE
S7TLA BMW BASIC SERVICE INCLUSIVE
S7TMA BMW SERVICE INCLUSIVE
S7TNA BMW SERVICE INCLUSIVE
S7TPA BMW SERVICE INCLUSIVE
S7TRA BMW SERVICE INCLUSIVE
S7TSA BMW SERVICE INCLUSIVE
S7TTA BMW SERVICE INCLUSIVE
S7TUA BMW SERVICE INCLUSIVE
S7TVA BMW SERVICE INCLUSIVE
S7TWA BMW SERVICE INCLUSIVE
S7TXA BMW SERVICE INCLUSIVE
S7TYA MINI REPAIR INCLUSIVE
S7TZA MINI REPAIR INCLUSIVE
S7U9A OMISSION OF BMW SERVICE INCLUSIVE
S7UAA BMW SERVICE INCLUSIVE
S7UBA BMW SERVICE PLUS
S7UCA BMW SERVICE ULTIMATE
S7UDA BMW SERVICE INCLUSIVE
S7UEA BMW SERVICE PLUS
S7UFA BMW SERVICE INCLUSIVE
S7UGA BMW SERVICE PLUS
S7UHA BMW SERVICE INCLUSIVE
S7UKA BMW SERVICE PLUS
S7XAA M LEATHER ST.WHEEL+SHIFTPADDLE+MULTIF.
S800A EXHAUST SYSTEM, COMPLETE, COUNTRIES
S803A OMISSION OF THIRD BRAKE LIGHT
S805A ACTIVATED-CARBON FILTER
S806A THIRD STOPLAMP
S815A POOR ROAD PACKAGE
S817A ENGINE DESIGN RON 91
S818A BATTERY MASTER SWITCH
S823A TROPICAL VERSION
S823A HOT-CLIMATE VERSION
S825A RADIO CONTROL OCEANIA
S826A FAHRWERK IN EXPORTABSTIMMUNG
S828A BUMPER, COUNTRY VARIANT
S829A PREPARATION FOR CONVERTIBLE CONVERSION
S831A OMISSION OF RADIO
S832A BATTERY IN LUGGAGE COMPARTMENT
S834A DELETED, 330D FRANCE
S834A OMISSION OF CASSETTE HOLDER
S835A US TOURIST VERSION
S836A OMISSION OF BAVARIA CD 6 SELECTION
S837A OMISSION OF NAVIGATION SYSTEM
S837A OMISSION OF HIFI SPEAKER SYSTEM
S839A PSEUDO CONTROL, OMISSION-OPTIONAL EXTRA
S840A HIGH SPEED SYNCHRONISATION
S840A OMISSION OF REMOTE CONTROL FOR RADIO
S841A OPTIONAL EXTRA PACK, PSEUDO CODE NO.
S842A COLD-CLIMATE VERSION
S843A POWER REDUCTION
S845A ACOUSTIC FASTEN SEAT BELT REMINDER
S847A PREPARATION FOR SAFETY VEHICLE
S847A AUXILIARY BATTERY F. C-NETWORK TELEPHONE
S848A EXPANDED WIRING HARNESS
S849A TAIL LIGHT, COUNTRY-SPECIFIC
S849A DELETED: AUTOMATIC EMERGENCY CALL
S850A ADDITIONAL EXPORT TANK FILLING
S851A LANGUAGE VERSION GERMAN
S852A LANGUAGE VERSION JAPANESE
S853A LANGUAGE VERSION, ENGLISH
S854A LANGUAGE VERSION, FRENCH
S855A LANGUAGE VERSION, ITALIAN
S856A LANGUAGE VERSION, SPANISH
S857A PREPARATION AUTOM.AIR CONDITIONING
S858A LOW COMPRESSION ENGINE
S859A TV DECODING
S859A ADAPTATION/CONTROL IHKA
S860A ADDITIONAL TURN INDICATOR LAMP
S861A DATA RECORD WITHOUT EOBD
S862A DEFINITION OF EXHAUST EMIS.STANDARD/COC
S862A FABRIC SEAT, FRONT, FOR TAXI PACK
S863A DEALER LIST EUROPE
S864A DEALER LIST OVERSEAS
S865A STOWAGE TABLES / FOOTRESTS IN REAR
S866A LANGUAGE VERSION, TRAD. CHINESE
S866A LANGUAGE VERSION, CHINESE SIMPL.
S866A SERVICE CARD GERMANY
S867A LANGUAGE VERSION KOREAN
S868A RADIO PREPARATION FOR ZF/ZI
S868A LANGUAGE VERSION, DUTCH
S869A RADIO PREPARATION FOR ZG/ZZ
S869A LANGUAGE VERSION SWITZERLAND
S870A EQUIPMENT "SALT"
S871A EQUIPMENT "PEPPER"
S872A PREPARATION F TELEPH.INSTALLATION JAPAN
S872A EQUIPMENT "CHILI"
S873A DUMMY-SALAPA
S874A RADIO FREQUENCY 434 MHZ
S875A INFRARED REMOTE CONTROL
S876A RADIO FREQUENCY 315 MHZ
S877A OMISSION OF NON-COMBINED OPERATION
S878A THERMAL GLAZING WITHOUT ANTI-GLARE STRIP
S879A OPERATING INSTRUCTIONS GERMAN
S880A OPERATING INSTRUCTIONS, ENGLISH
S881A OPERATING INSTRUCTIONS, FRENCH
S882A GUTSCHRIFT F‹R ERSTAUSSTATTUNG
S883A OPERATING INSTRUCTIONS, SPANISH
S884A OPERATING INSTRUCTIONS, ITALIAN
S885A OPERATING INSTRUCTIONS, SWEDISH
S886A OPERATING INSTRUCTIONS, DUTCH
S887A OPERATING INSTRUCTIONS, ARABIC
S888A OPERATING INSTRUCTIONS, DANISH
S889A OPERATING INSTRUCTIONS, FINISH
S889A OPERATING INSTRUCTIONS, PORTUGUESE
S890A OPERATING INSTRUCTIONS JAPANESE
S891A OPERATING INSTRUCTIONS, RUSSIAN
S892A OWNER'S HANDBOOK CHINES.TRAD.
S895A ADDITIONAL FAN
S896A DAYTIME DRIVING LIGHTS
S897A CONTINUOUS TONE FOR ANTI-THEFT ALARM
S898A CKD VERSION
S899A OPTICAL SIGNALLING FOR ANTI-THEFT ALARM
S8ABA CHINA JOINT VENTURE
S8ACA DUMMY-SALAPA
S8ADA ALPINA ROADSTER S
S8AEA OWNER'S HANDBOOK/SERVICE BOOKLET, GREEK
S8AFA OWNER'S HANDBOOK/SERVICE BOOKLET, KOREAN
S8AGA CHAUFFEUR HANDBOOK IN ENGLISH
S8ARA OWNER'S HANDBOOK/SERVICE BKLET, ROMANIAN
S8ASA OWNER'S HANDBOOK/SERVICE BKLET, CHINESE
S8EBA STEUERUNG EINZELBETRIEBSERLAUBNIS
S8HAA DUMMY-SALAPA
S8L1A COUNTRY CONTROL
S8LFA COUNTRY CONTROL
S8LHA COUNTRY CONTROL
S8LRA DUMMY-SALAPA
S8LSA COUNTRY CONTROL
S8LTA COUNTRY CONTROL
S8S1A DECODING, DAYTIME RUNNING LAMPS
S8S2A CODING, ALARM SIGNAL
S8S3A AUTOMATIC LOCKING DURING STARTING
S8S4A DECODING, VARIABLE LIGHT DISTRIBUTION
S8S5A DELETED, DIESEL PARTICULATE FILTER
S8S6A PRESPECIFIED FOR EXPORT
S8S7A FLEET VEHICLE WITHOUT TV FUNCTION
S8S8A COUNTRY-SPECIFIC NAVIGATION CONTROL
S8S9A DUMMY-SALAPA
S8SAA NAVIGATION ACCESS REQUEST,COUNTRY-SPEC.
S8SBA TELEMATICS ACCESS REQUEST,COUNTRY-SPEC.
S8SCA TELEMATICS ACCESS REQUEST,COUNTRY-SPEC.
S8SDA UNDERRIDE PROTECTION, NATIONAL VARIANTS
S8SEA 4-SEATS VERSION
S8SFA HIGH LINE SPORT
S8SFA SPECIAL EDITION "SPORT"
S8SGA HIGH LINE EXCLUSIVE
S8SGA SPECIAL EDITION "EXCLUSIVE"
S8SHA THAILAND ENGINE
S8SKA DELETED, INT. LINE GRAPHIT METALLIC
S8SLA TRAILER COUPLING PREPARATION
S8SMA CAR IDENT. NUMBER VISIBLE FROM OUTSIDE
S8SPA CONTROL UNIT CO2
S8SPA CONTROL UNIT COP
S8SRA SPECIAL EDITION "LIFESTYLE"
S8SSA SPECIAL EDITION "SPECIAL CONTROL UNIT"
S8STA MAINTENANCE INTERVAL ENCODING, STAGE 3
S8SUA CAR IDENT. NUMBER SECURITY
S8SVA HANDS-FREE KIT
S8SWA TRANSPORT PROTECTION FOIL
S8SXA PROV.ASSIGNM.FOR TELEMATIC/ONLINE SERV.
S8SYA DUMMY-SALAPA
S8SZA CORNERING LIGHTS DECODING
S8TAA RADIO STAGE, M DRIVE
S8TBA ACOUSTIC KIT
S8TCA DUMMY-SALAPA
S8TDA DUMMY-SALAPA
S8TEA DUMMY-SALAPA
S8TFA ACTIVE PEDESTRIAN PROTECTION
S8TGA ZENTRALSICHERUNG
S8WAA DUMMY-SALAPA
S8WBA DUMMY-SALAPA
S900A ELECTRONIC IMMOBILIZER
S901A GENERAL SPECIAL INSPECTION
S902A SPECIAL INSPECTION PRESS VEHICLES
S903A FOTOFAHRZEUG
S904A INSPECT.F TYPE APPROVAL VEHICLES
S905A INSPECT.F DEMONSTRATION VEHICLES
S906A FOTOFAHRZEUG
S907A JAMES BOND EDITION
S908A DUMMY-SALAPA
S909A DUMMY-SALAPA
S910A DEVELOPMENT VEH. W/OUT HANDOVER INSP.
S911A DEVELOPMENT VEH. W/ HANDOVER INSP.
S915A OMISSION OF OUTER-SKIN PRESERVATION
S916A DEVELOPMENT VEH. W/OUT PRESERVATION
S917A OVERSEAS PRESERVATION
S918A ALPINA B3, INTERN
S919A DOORS, ALUMINIUM
S920A ALPINA WITHOUT REGISTRATION DOCUMENT
S921A ALPINA B8, INTERN
S922A ALPINA ENGINE-OIL COOLER
S923A KIDNEY, NARROW
S923A DELETED, TITAN-LINE
S924A MIRROR, GLASS, LEVEL, FRONT PASSENGER
S924A COLLAPSIBLE SPARE TYRE
S925A DISPATCH PROTECTION PACK
S926A SPARE WHEEL
S927A TOURIST HANDLING
S927A ALL-SEASON TYRES
S928A TYRE CONTROL
S929A DUMMY-SALAPA
S930A DUMMY-SALAPA
S931A DUMMY-SALAPA
S931A WINTER INSTEAD OF SUMMER TYRES EX-FACT.
S932A DUMMY-SALAPA
S933A DUMMY-SALAPA
S934A DUMMY-SALAPA
S936A LIGHT ALLOY WHEEL RIMS "SA"
S936A BMW HANDY B. AUSLIEFER. ANFORDERN
S937A DUMMY-SALAPA
S938A WINTER PACKAGE
S938A INDIVIDUAL SERIES
S939A DUMMY-SALAPA
S940A SPECIAL EQUIPMENT BMW INDIVIDUAL
S941A DUMMY-SALAPA
S942A CANCELLATION OF SPECIAL REQUEST
S943A DUMMY-SALAPA
S944A SUBSEQUENT CONVERSION BY INDIVIDUAL
S945A DUMMY-SALAPA
S946A DUMMY-SALAPA
S947A DUMMY-SALAPA
S954A DUMMY-SALAPA
S960A STEERING DETENT
S961A SPECIAL MOTOR
S962A DELETED, LICENCE PLATE SUPPORT FRONT
S962A ENGINE CHARACTERISTIC CURVES
S963A THAILAND ENGINE 2.4
S964A PSEUDOCONTROL F.COUNTRYVERSION/OPT.EXTRA
S964A NAVI DVD TO BE REQUESTED AT SHIPPING
S965A ADDITIONAL OPT. EQUIPM. (FRONT)+25KG
S966A ADDITIONAL OPT. EQUIPM. (FRONT)+50KG
S967A ADDITIONAL OPT. EQUIPM. (REAR)+25KG
S968A ADDITIONAL OPT. EQUIPM. (REAR)+50KG
S969A ADDITIONAL OPT. EQUIPM. (REAR)+75KG
S969A NAVI DVD TO BE REQUESTED AT SHIPPING
S970A BUSINESS PACKAGE
S976A BACKREST, REINFORCED
S978A INNOVATION PACKAGE
S979A MAJOR CUSTOMER PACKAGE
S979A BUSINESS PACKAGE II
S979A VALUE PACKAGE
S980A EXCLUSIVE PACKAGE
S982A HARDTOP
S983A DUMMY-SALAPA
S984A MAINTENANCE INTERVAL ENCODING
S984A CODING FOR NONE EU COUNTRIES
S985A US RADIO COMPLETION SET
S986A DUMMY-SALAPA
S987A DUMMY-SALAPA
S988A MAINTENANCE INTERVAL ENCODING
S988A OMISSION OF RADIO
S989A DUMMY-SALAPA
S990A DUMMY-SALAPA
S991A DUMMY-SALAPA
S992A CONTROL OF NUMBER-PLATE ATTACHMENT
S993A MODEL YEAR CODE IN VIN
S994A DUMMY-SALAPA
S995A DUMMY-SALAPA
S996A HEA ALT
S997A DUMMY-SALAPA
S998A DUMMY-SALAPA
S999A JOB CONTROL "HEA"
S9AAA OUTER SKIN PROTECTION
S9ABA OUTER SKIN PROTECTION, ELIMINATION
S9AEA DUMMY-SALAPA
S9AWA DELIVERY BMW WELT
S9W1A FAHRZEUGSTEUERUNG WERK
S9WRA WINTER WHEELS
S9XAA ALPINA PACKAGE
SRA1A PICNIC TABLE
SRA2A MAKE-UP MIRROR, REAR CABIN
SRA3A REAR CAN HOLDER
SRA4A HIGHT-QUAL. DESIGN. ANALOG CLOCK, FRONT
SRA5A FLOOR MATS, LAMBSWOOL
SRA6A FLOOR MATS, FRONT AND REAR
SRA7A OUTSIDE MIRROR WITH AUTO DIP
SRA8A REAR COMPARTMENT FOOT REST
SRA9A WARNING TRIANGLE
SRAAA INTERIOR DOOR HANDLE REAR
SRABA BRIEFCASE INTEGRATED
SRACA HUMIDOR
SRADA UMBRELLAS IN VEHICLE
SRAEA LEATHER EQUIPMENT, EXTENDED
SRAGA CLOTHES BAG FOR TRUNK
SRAHA ROLLER COVER FOR LUGGAGE COMPARTMENT
SRAKA COVER, DASHBOARD, VENEERED
SRALA DASHBOARD, COVERED WITH LEATHER
SRAMA BOOT TRIM PANEL IN INTERIOR-COLOR
SRAPA STEERING WHEEL SPOKES , WOODEN
SRARA PICNIC TABLES WITH VENEERED UNDERSIDE
SRASA DRINKS CABINET FOR SINGLE SEATS
SRAUA RR LOGOS ON HEAD RESTRAINTS
SRAWA DRINKS CABINET FOR SEAT BENCH, REAR
SRAXA CONTRAST SEAT PIPING
SRAYA PREPARATION STOLEN VEHICLE TRACKING
SRB1A STEERING-WHEEL SPOKES, METALLISED
SRB2A LIQUIDMETAL BONNET WINDSCREEN
SRB6A ARMORED LIMOUSINE
SRC1A STAINLESS STEEL PACK
SRC2A TEAK DECKING
SRC3A INTERIOR TRIM PANELS, VENEERED
SRC4A EXTENDED WOOD PACK
SRC5A MIRROR-FINISH STAINLESS-STEEL PACK
SRD1A TWO-COLOUR PAINT, SIDE
SRD2A TWO-COLOUR PAINT, CONTINUOUS
SRD3A ORNAMENTAL LINE, SINGLE
SRD4A ORNAMENTAL LINE, DOUBLE
SRD5A SPIRIT OF ECSTACY INDIVIDUAL
SRD6A BLAU CHROM
SRD7A CONTRAST COLOUR, OUTER
SRD8A INTERIOR MONO PACKAGE
SRD9A LINEAR COLOUR PACKAGE
SRE3A SEAT HEATING, FRONT AND REAR
SRE4A UNIVERSAL REMOTE IN INTERIOR MIRROR
SRE5A INDEPENDENT HEATING
SRE7A CHARGING SOCKET
SRE8A REINFORCED POWER SUPPLY
SRE9A SPIRIT OF ECSTACY ELECTR. RETRACTABLE
SREAA CURTAINS IN THE REAR
SREBA AUTOMATIC TRUNK LID MECHANISM
SRECA AIR CONDITIONING, REAR
SREDA ELECTRIC CURTAIN, REAR WINDOW
SREFA SUNSHADE REAR WINDOW, OYSTER
SREGA SUNSHADE REAR WINDOW, BLACK
SREHA SONNENSCHUTZ FONDRAUM OYSTER
SREKA SONNENSCHUTZ FONDRAUM SCHWARZ
SRELA CAMERA SYSTEM
SREMA COOLING COMPARTMENT FOR SINGLE SEATS
SRENA COOLING COMPARTMENT FOR SEAT BENCH, REAR
SREWA EXTENDED WHEELBASE
SRF1A SPARE WHEEL LGHT. ALLOY WH.,CHROME-PLAT.
SRF2A HUB CAP, CHROME-PLATED
SRF3A WHEEL CENTRE CAP WITH RR SYMBOL
SRF4A ROLLS-ROYCE LA WHEEL 21"
SRF5A ROLLS-ROYCE LA WHEEL 21" CHROMIUM-PLATED
SRF6A HUB COVER, SPORTS STYLE CHROME
SRF7A DUMMY-SALAPA
SRF8A ALL-SEASON TYRES
SRF9A CENTRE CAP, STAND. WHEEL, IN CAR COLOUR
SRFAA ROLLS-ROYCE LA WHEEL 20"
SRFBA RR LA WHEEL 20" CHROME-PLATED
SRFCA RR LA WHEEL SEVEN SPOKES 21"
SRFDA RR LA WHEEL SEVEN SPOKES 21" POLISHED
SRG1A PRIVACY GLAZING
SRG1A RR LM RAD STAR DESIGN
SRG2A PRIVACY GLAZING, REAR WINDOW ONLY
SRG3A PRIVACY GLAZING WITH CLEAR WINDSCREEN
SRG4A IR PROTECTION GLAZING F SIDE WINDOW
SRG5A SUNSHADE GLAZING, REAR
SRG7A ROOFLINER, CASHMERE, BLACK
SRG8A LEATHER HEADLINING
SRG9A EXTENDED LEATHER TRIM
SRH1A REAL WOOD VERSION, MAHOGANY CROSSBANDING
SRH2A REAL WOOD VERSION, MAHOGANY CROSSBANDING
SRH3A REAL WOOD VERSION, WALNUT BURR
SRH4A SUPERIOR WOOD TRIM, VARIEG. OAK CROSSB.
SRH5A HIGH-GRADE WOOD TRIM, VARIEGATED OAK
SRH6A REAL WOOD VERSION, ELM CLUSTER CROSSB.
SRH7A HIGH-GRADE WOOD TRIM, ELM CLUSTER
SRH8A REAL WOOD VERS. BIRD'S EYE MAPLE, CROSSB
SRH9A REAL WOOD VERSION, BIRD'S EYE MAPLE.
SRHAA FINE WOOD TRIM BLACK TULIP
SRHBA HIGH-GRADE WOOD TRIM, JACARANDA
SRHCA HIGH-GRADE WOOD TRIM, VARIEGATED ASH
SRHDA FINE WOODGRAIN, PIANO LACQUER, BLACK
SRHEA WOOD INTERIOR TRIM "BROWN OAK"
SRHFA WOOD INTERIOR TRIM "CHESTNUT BURR"
SRHGA FINE WOODGRAIN VERSION, OLIVE GRAIN
SRHHA SUP. WOOD TRIM, FLARE MAHOGANY CROSSB.
SRHKA SUP.WOOD TRIM, SANTOS PALISANDER CROSSB.
SRHMA SUPERIOR WOOD TRIM, VARIEG. ASH CROSSB.
SRHNA WOOD INTERIOR TRIM "ZEBRANO"
SRHPA WOOD INTERIOR SANTOS PALISANDER
SRHRA DARK WENGE STRAIGHT-GRAIN
SRK1A NAVI SYSTEM WITH TV/ON-BOARD MONITOR
SRK2A ROLLS ROYCE ASSIST
SRK5A VOICE INPUT SYSTEM
SRL1A PADDED STEERING WHEEL
SRM1A VISIBLE ENGINE NUMBER
SRM2A TOP SPEED US/CDN
SRM3A EXHAUST TAILPIPES, VISIBLE
SRMKA EAST ASIA EDITION
SRP1A BUSINESS PACKAGE I
SRP2A BUSINESS PACKAGE II
SRPDA IPOD INTEGRATION
SRPPA PARTITION PREPARATION
SRR5A CD CHANGER, FOR 6 CDS
SRR6A DVD CHANGER, FOR 6 DVDS
SRR7A NAVIGATION DVD NORTH AMERICA
SRR8A NAVI DVD EUROPE
SRR9A NAVIGATION DVD ARABIAN GULF
SRRAA NAVI DVD JAPAN
SRRBA NAVI DVD SINGAPORE AND MALAYSIA
SRRDA NAVI DVD CHINA/HONGKONG
SRREA NAVI DVD KOREA
SRRSA STARLIGHT ROOFLINER
SRS1A TWO INDIVIDUAL SEATS, REAR
SRS2A LIFT-UP-AND-SLIDE-BACK SUNROOF, FRONT
SRS3A THEATRE CONFIGURATION LOUNGE SEAT
SRS4A FRONT SUNROOF DISCONTINUED
SRS5A PREPARATION, INSERT, GLOVEBOX
SRS6A EXTENDED STORAGE OPTION
SRSCA STARLIGHT ROOFLINER "BAMBOO"
SRSDA STARLIGHT ROOFLINER "DARK GREY"
SRT1A CAR PHONE WITH CORDLESS RECEIVER
SRT3A PREPARATION F MOBILE PHONE CPL. USA/CDN
SRT4A SECOND RECEIVER IN THE REAR, CORDLESS
SRT5A COMPLETE PREPARATION, MOBILE PHONE
SRT6A INTEGRAL TELEPHONE W CORDLESS HANDSET
SRT7A PREP., MOB. PHONE, BLUETOOTH INTERFACE
SRV1A SOFTTOP, BLACK
SRV2A SOFTTOP DARK BEIGE
SRV3A FOLDING TOP, BLUE
SRV4A FOLDING TOP, RED
SRV5A FOLDING TOP, GREEN
SRV6A CONVERTIBLE TOP, METALLIC APPEARANCE
SRXLA EXTENDED BOOT
SRZ1A DUMMY-SALAPA
SV01A DUMMY-SALAPA
SV02A DUMMY-SALAPA
SV03A DUMMY-SALAPA
SV04A DUMMY-SALAPA
SV05A DUMMY-SALAPA
SV06A DUMMY-SALAPA
SV07A DUMMY-SALAPA
SV08A DUMMY-SALAPA
SV09A DUMMY-SALAPA
SV0AA DUMMY-SALAPA
SV0BA DUMMY-SALAPA
SV0CA DUMMY-SALAPA
SV0DA DUMMY-SALAPA
SV0EA DUMMY-SALAPA
SV0FA DUMMY-SALAPA
SV0GA DUMMY-SALAPA
SV0HA DUMMY-SALAPA
SV0IA DUMMY-SALAPA
SV0JA DUMMY-SALAPA
SV0KA DUMMY-SALAPA
SV0LA DUMMY-SALAPA
SV0MA DUMMY-SALAPA
SV0NA DUMMY-SALAPA
SV0OA DUMMY-SALAPA
SV0PA DUMMY-SALAPA
SV0QA DUMMY-SALAPA
SV0RA DUMMY-SALAPA
SV0SA DUMMY-SALAPA
SV0TA DUMMY-SALAPA
SV0UA DUMMY-SALAPA
SV0VA DUMMY-SALAPA
SV0WA DUMMY-SALAPA
SV0XA DUMMY-SALAPA
SV0YA DUMMY-SALAPA
SV0ZA DUMMY-SALAPA
SV10A DUMMY-SALAPA
SV11A DUMMY-SALAPA
SV12A DUMMY-SALAPA
SV13A DUMMY-SALAPA
SV14A DUMMY-SALAPA
SV15A DUMMY-SALAPA
SV16A DUMMY-SALAPA
SV17A DUMMY-SALAPA
SV18A DUMMY-SALAPA
SV19A DUMMY-SALAPA
SV1AA DUMMY-SALAPA
SV1BA DUMMY-SALAPA
SV1CA DUMMY-SALAPA
SV1DA DUMMY-SALAPA
SV1EA DISCONTINUATION, ROOF RAILS
SV1FA DISCONTINUATION, REAR SEAT BENCH
SV1GA DUMMY-SALAPA
SV1HA DUMMY-SALAPA
SV1IA DUMMY-SALAPA
SV1JA DUMMY-SALAPA
SV1KA DUMMY-SALAPA
SV1LA DUMMY-SALAPA
SV1MA DUMMY-SALAPA
SV1NA DUMMY-SALAPA
SV1OA DUMMY-SALAPA
SV1PA DUMMY-SALAPA
SV1QA DUMMY-SALAPA
SV1RA DUMMY-SALAPA
SV1SA DUMMY-SALAPA
SV1TA DUMMY-SALAPA
SV1UA DUMMY-SALAPA
SV1VA DUMMY-SALAPA
SV1WA DUMMY-SALAPA
SV1YA DUMMY-SALAPA
SV1ZA DUMMY-SALAPA
SV20A DUMMY-SALAPA
SV21A DUMMY-SALAPA
SV22A DUMMY-SALAPA
SV23A DUMMY-SALAPA
SV24A DUMMY-SALAPA
SV25A DUMMY-SALAPA
SV26A DUMMY-SALAPA
SV27A DUMMY-SALAPA
SV28A DUMMY-SALAPA
SV29A DUMMY-SALAPA
SV2AA DUMMY-SALAPA
SV2BA DUMMY-SALAPA
SV2CA DUMMY-SALAPA
SV2DA DUMMY-SALAPA
SV2EA DUMMY-SALAPA
SV2FA DUMMY-SALAPA
SV2GA DUMMY-SALAPA
SV2HA DUMMY-SALAPA
SV2IA DUMMY-SALAPA
SV2JA DUMMY-SALAPA
SV2KA DUMMY-SALAPA
SV2LA DUMMY-SALAPA
SV2MA DUMMY-SALAPA
SV2NA DUMMY-SALAPA
SV2PA DUMMY-SALAPA
SV2QA DUMMY-SALAPA
SV2RA DUMMY-SALAPA
SV2SA DUMMY-SALAPA
SV2TA DUMMY-SALAPA
SV2UA DUMMY-SALAPA
SV2VA DUMMY-SALAPA
SV2WA DUMMY-SALAPA
SV30A SOFT-CLOSE-AUTOMATIC
SV31A DUMMY-SALAPA
SV32A DUMMY-SALAPA
SV33A DUMMY-SALAPA
SV34A DUMMY-SALAPA
SV35A DUMMY-SALAPA
SV36A DUMMY-SALAPA
SV37A DUMMY-SALAPA
SV38A DUMMY-SALAPA
SV39A DUMMY-SALAPA
SV3AA DUMMY-SALAPA
SV3BA DUMMY-SALAPA
SV3CA DUMMY-SALAPA
SV3DA DUMMY-SALAPA
SV3EA DUMMY-SALAPA
SV3FA DUMMY-SALAPA
SV3GA DUMMY-SALAPA
SV40A DUMMY-SALAPA
SV41A DUMMY-SALAPA
SV42A DUMMY-SALAPA
SV43A DUMMY-SALAPA
SV44A DUMMY-SALAPA
SV45A DUMMY-SALAPA
SV46A DUMMY-SALAPA
SV47A DUMMY-SALAPA
SV48A DUMMY-SALAPA
SV49A DUMMY-SALAPA
SV4AA DUMMY-SALAPA
SV4BA DUMMY-SALAPA
SV4CA DUMMY-SALAPA
SV4DA DUMMY-SALAPA
SV50A DUMMY-SALAPA
SV51A DUMMY-SALAPA
SV52A DUMMY-SALAPA
SV53A DUMMY-SALAPA
SV54A DUMMY-SALAPA
SV55A DUMMY-SALAPA
SV56A DUMMY-SALAPA
SV57A DUMMY-SALAPA
SV58A DUMMY-SALAPA
SV59A DUMMY-SALAPA
SV5AA DUMMY-SALAPA
SV5BA DUMMY-SALAPA
SV5CA DUMMY-SALAPA
SV5DA DUMMY-SALAPA
SV60A DUMMY-SALAPA
SV60A DELETED DSC MODULE
SV61A TRAILER COUPLING
SV62A AIRBAG INERT
SV62A ANTENNA
SV63A ENGINE EMERGENCY OFF SWITCH
SV63A AIRBAG DEACTIVATION
SV64A FIRE EXTINGUISHER + EMERGENCY HAMMER
SV64A EMISSION TANK
SV69A MIRROR ATTACHMENT FUNCTION
SV71A CONTAINER, HEADLIGHT WASHER SYS, FRONT
SV72A REAR WINDOW WASHER CONTAINER, FRONT
SV73A STORAGE TRAY IN INSTRUMENT PANEL
SV74A DUMMY-SALAPA
SV75A DUMMY-SALAPA
SV76A DUMMY-SALAPA
SV77A UP-RATED FUEL PUMP
SV78A ABS SENSOR, VARIANT 1
SV79A ABS SENSOR, VARIANT 2
SV7GA DU
      12-26-2012, 04:39 PM   #2
cuco
cuco's Avatar
Drives: 85 BMW R80
why do all codes end with an "A"? I don't see the A on any of my codes in the VO.
Airhead//Caffeine//Junky//Beemer//Fan
      12-27-2012, 07:24 AM   #3
Elliott@DetailAddict
Drives: E90
The S and A drop off.
For instance if you have xenons, the code in the VO would be $522, in the list it is S522A.
      03-12-2013, 06:31 PM   #4
xtreme4ce
xtreme4ce's Avatar
Drives: 2009 328i Sedan JB or BSM? :-)
So what does this mean? Thanks...
S563A LIGHT PACKAGE
      03-12-2013, 07:15 PM   #5
Drives: E90
S563A LIGHT PACKAGE
Ambient Lighting. Interior Ambient lighting, exterior door handle lights etc.
      03-12-2013, 07:59 PM   #6
xtreme4ce
xtreme4ce's Avatar
Awesome...Thank you. Don't mean to be a pest but I have one more... I promise.
Just this one....
S693A SATELLITENTUNER VORBEREITUNG Preparation BMW satellite radio
Thanking you in advance....
      03-13-2013, 10:28 AM   #7
Drives: E90
Just this one....
That one means the pre-wiring for Sirius Radio is there but not the module/hardware itself.
      03-13-2013, 10:32 AM   #8
xtreme4ce
xtreme4ce's Avatar
Thank you sir...I guess you are serious when you say that.
      03-13-2013, 10:36 AM   #9
Drives: E90
Hahah
      03-13-2013, 01:13 PM   #10
xtreme4ce
xtreme4ce's Avatar
Ok edited....hahaha!!!
      03-13-2013, 03:50 PM   #11
Drives: E90
Haha it was a good one though!
      04-24-2013, 07:53 AM   #12
Najt
Drives: e92 325D 2008
THANK YOU!!!!
      04-25-2013, 12:10 AM   #13
Drives: E90
You are welcome sir!
      03-24-2014, 09:00 AM   #14
Ark10bimmer
Drives: 2010 335i xdrive
What is reinforced power supply. What exactly does it consist of.
      05-14-2014, 06:13 PM   #15
AndreyT
AndreyT's Avatar
Drives: 2011 335i Sedan, Sport
No 6NN in the list?
      09-19-2014, 08:51 PM   #16
Jamrockbwoy
Drives: 2015 550i xDrive
what is this list for? is it a list of things that can be coded using NCS Expert?
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
      05-10-2015, 03:42 PM   #17
Pilot1981
Pilot1981's Avatar
Italy
Drives: Bmw 320d xdrive lci
Hi,
To add new VO option for mirror retrofit I sufficient code CAS ECU? Itself copy VO option to FRM ECU?
      05-25-2015, 09:00 PM   #18
kuruptpostaboi
Drives: e90 335i
Hello everyone, thanks for the list.
Currently dealing with an SOS Malfunction code in my 1st gen iDrive (07 335i build date 09/06)
After looking at the VO in my car, i noticed i did not have 612 and 619 which relate to BMW Assist and SOS Emergency Call.
Could this currently be the reason for my error? Do i need to add these to my VO? Thanks!
      06-16-2015, 12:52 AM   #19
Dlovan778
Drives: f10
how do iknow all needed vo codes for my f10
      10-28-2015, 07:23 PM   #20
Mik325tds
Mik325tds's Avatar
Drives: 335d M-Sport
Thank you for the list. Decoding my VIN, it lists $688 as "HARMAN/KARDON SURROUND SOUND SYSTEM" while your list has it as $674 "HI-FI SYSTEM HARMAN KARDON".
Do you know why that is? Or are these two different options and the list is simply missing $688?
      10-28-2015, 07:43 PM   #21
Mik325tds
Mik325tds's Avatar
...and how come I'm the first to appreciate the OP for this list?
      12-13-2015, 04:22 PM   #22
Purdy330
Purdy330's Avatar
Drives: 2011 BMW 335i xDrive
I second the thank you!
