The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southwest > Smog las vegas
      07-15-2020, 05:59 PM   #1
1sicke92
1sicke92's Avatar
69
Drives: 09 E92 N54
Smog las vegas
Hello everyone,
I'm up for smog, and I've recently moved from CA. I'm FBO so obvi catless dps. What can I do to pass smog without removing my DPs and replacing with stock ones?
I hear the DP fix is unreliable and and PITA to get it to work if it even ever works.
I have my JB4 on Map 0, and will flash MHD to Map 0/Stock as well and complete a few drive cycles. But any tips about how to get around it or how to only fail X amount of monitors would be appreciated!
FBO + PURE STAGE 2 + MHD FLASH
      12-22-2021, 01:36 AM   #2
jamesph82
Drives: 2011 335i e90
What did you end up doing? How did it go? I'm in Vegas and my smog is coming up soon.
      12-27-2021, 09:08 AM   #3
PJLux
97
Drives: BMW E90 328i
As far as I know they only scan for codes.
      12-27-2021, 03:23 PM   #4
jamesph82
Thanks for responding. Santa got me some catless downpipes and MHD so this is something I have been thinking about.
      01-05-2022, 05:12 PM   #5
1sicke92
1sicke92's Avatar
69
Drives: 09 E92 N54
I tried the DP Fix and it didn't work, so I swapped off the catless DPs for the stock cats, and passed
      01-05-2022, 08:07 PM   #6
jamesph82
So you change it out every year?
      01-05-2022, 09:00 PM   #7
1sicke92
1sicke92's Avatar
69
Drives: 09 E92 N54
yes, it gets easier every time you do it
      02-02-2022, 01:55 PM   #8
Haideezy
Boost>N/A
Drives: 2007 BMW 335i Sedan
Has anyone tried passing smog with a high flow cat downpipes?
      02-02-2022, 03:41 PM   #9
1sicke92
1sicke92's Avatar
69
Drives: 09 E92 N54
From what I know hi flow cat dps will always go bad. Now, for a brand new pair would they pass? I'm not too sure. Maybe someone else can chime in who's used them in the past.
      02-02-2022, 07:47 PM   #10
Haideezy
Boost>N/A
Guess I’ll just put the stock cats back on before I move there.
      02-03-2022, 12:38 PM   #11
PJLux
97
Well here's an advanced "welcome" to the valley. Moving here for work?
      02-04-2022, 12:32 AM   #12
Haideezy
Boost>N/A
Yessir, moving there for work. Thanks for the warm welcome lol
      02-04-2022, 03:43 AM   #13
PJLux
97
Well the cost of living is favorable in comparison to S. CA, so that should be a plus. As far as the SMOG check goes they only scan, no tailpipe sniffer, so you may be able to get away with your setup. I have all my cats so I can't say 100%.
      02-04-2022, 06:11 PM   #14
Haideezy
Boost>N/A
Not sure if I want to keep swapping stock parts back on every year just for smog. My motor has a bunch of miles on it and the turbos are on its last leg. For the cost of rebuilding the motor and new turbos, I might as well just do an LS swap and turn the E90 into a dedicated track car lol.
      02-05-2022, 02:03 PM   #15
opjose
opjose's Avatar
242
Drives: 335xi
A 7 dp fix does the job.
Clear the codes, enable the fix, check the state with auto-doctor to assure readiness and pass the test.
      03-09-2022, 08:30 PM   #16
Haideezy
Boost>N/A
Damn, smog is pretty easy here. They don't check for anything lol, my hood didn't even get opened. Definitely going with downpipes fix next time around.
      03-13-2022, 10:46 AM   #17
PJLux
97
Not sure when they stopped popping hoods but they used to in the past. Glad to hear it went well for ya.
      03-14-2022, 11:28 PM   #18
Haideezy
Boost>N/A
Of course my rear turbo starts leaking oil after I put the stock cats back on lol. Pretty sure it was on its way out, the added back pressure probably pushed it over the edge haha.
      03-15-2022, 08:31 AM   #19
PJLux
97
Were you able to bring your tools or are you going to have a shop sort it out? I take mine to Southwest Bimmers for jobs I don't particularly want to do myself.
      03-15-2022, 08:01 PM   #20
Haideezy
Boost>N/A
I brought a small tool box with me that should have all the tools I’ll need to dig into this. Putting it on a lift this Saturday to pull the downpipes and passenger side motor mount bracket off to thoroughly inspect the leak. I’m hoping it’s just a oil feed line or return line leak. Hard to tell with all the crud in the way.
      02-06-2024, 04:03 AM   #21
AlpineWhiteeeM3
Drives: 2008 e90 M3
Hey guys! Just wanted to let you guys know that you don't have to put stock DP every year, as long as you have MHD/BM3, disable the CEL and make sure all the monitors are good then you're good to go! I have done this a billion times with my previous 335i and my current 340i always passed smog with catless DP. Hope that helped!
      04-17-2024, 10:00 PM   #22
Technics_
42
Drives: '09 E92 335i 6MT
Just moved to Vegas and have catless DP's. How were you able to show all monitors ready without the DP Fix or something similar?
