      02-08-2024, 08:03 PM   #1
Slow_1series
Slow_1series's Avatar
Drives: Bmw 128i
Led eyebrow flickers/doesn't turn on
Hey, I’m new to the forums and was wondering if someone had a fix for my eyebrow issue since I can’t seem to figure it out. The eyebrow on my driver side headlight tends to flicker or turn off completely but when I role up or down my window it turns on fully, but after a second it starts flickering again. I’m thinking it’s a ground issue, but I want to know for sure before I starting tearing things apart.
      02-08-2024, 08:28 PM   #2
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
See if there is any moisture causing this issie. Check for water leaks in the trunk or inside the car?
      03-08-2024, 11:33 PM   #3
Slow_1series
Drives: Bmw 128i
No moisture in the trunk or the car as far as i’m concerned. Is there a bulb I could replace?
      03-09-2024, 08:52 AM   #4
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Check for codes if you can?
      03-09-2024, 11:07 AM   #5
Slow_1series
Drives: Bmw 128i
No codes and i’ve already checked fuses.
      03-09-2024, 11:11 PM   #6
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Maybe someone who owns a newer 1er like yiour can chime in Im not familiar with that kimd of headlight configuration. Mine dioes not have headlights with eyelid ligjt.
