      03-14-2024, 02:04 PM   #23
Freewheeling
Drives: BMW 128i
Rocking the cd insert model and it is great and out of the way
      03-15-2024, 04:12 PM   #24
Donkeyshins
Drives: 2010 128i ZSP 6MT
2010 BMW 128i  [0.00]
I have an Induktiv in my oddments tray in front of the gearshift. If I hadn't gotten that, I probably would have gone with a RennLine E90 ExactFit.
(assuming that the RennLine would fit)
I'm ordering one of their E83 phone mounts, as I think that might work better (and I want to see if it actually *will* work). Plus, it's on clearance, so it was $44 instead of $65.
2010 128i ZSP 6MT Coupe
Deep Sea Blue (Tiefseeblau) Metallic
Style 264 Wheels
Lemon Boston Sport Interior
      03-17-2024, 09:43 PM   #25
K9Leader
K9Leader's Avatar
1051
Drives: 2010 328ix E91, 2011 128i E82
2011 BMW 128i  [10.00]
2010 BMW 328i  [10.00]
I have a Scosche magnetic wireless charging mount that I have set up in the "cupholder" - which are, of course, useless for holding cups. It plugs in to the cig outlet and I coil/store the excess wire under the armrest/console cover. If you are trying to use the phone as the nav screen, it doesn't really work, but I have wireless AA on the headunit and also a standalone Garmin GPS so the phone is not needed/used as the nav screen.
K9Leader
2010 328i x-Drive, E91 - Space Gray/Black
2011 128i E82 6MT - Crimson Red/Black
Tornado1M1211.00
      03-18-2024, 03:39 PM   #26
bkilburn814
Drives: 128i M Sport, E30 325i
Looking at getting a ProClip myself as well, debating Center Dash vs Console.
Given the Center Dash partially blocks the center vent, has anyone had phone overheating issues with the Center Dash mount? I suspect I'm overindexing on this as a concern, and I certainly like the location better - much easier peripheral sightline vs dropping my eyes to the Console every time.
      03-18-2024, 11:21 PM   #27
Donkeyshins
If you can hold off for a little while, I can give you an update on the Rennline (which mounts to the dash via a screw under the trim) as that might be what you're looking for.
(TBD, of course, since I'm going to be trying the E83 version in an E82)
Style 264 Wheels
      03-19-2024, 08:26 AM   #28
mkeiser
436
Drives: e82 128i 6mt m sport
No overheating with my Galaxy S22 Ultra using center dash location. I always have it plugged into 25W fast charge as well.
2011 BMW 128i 6MT M Sport - Alpine White on Terracotta w/ Glacier-Silver trim - Koni Yellows w/ H&R Sport Springs, M3 Control Arms, Euro Intake, BMW Performance Exhaust, 3.73 Diff w/ RacingDiffs LSD Conversion, Black Line Taillights, M Performance Grilles, lots-o-maintenance
      03-19-2024, 10:18 PM   #29
bkilburn814
Awesome. I went ahead and ordered a center dash mount, excited to get it wired up - will report back.
GoRomeo963.50
      03-20-2024, 08:12 AM   #30
mkeiser
436
Here's the setup I'm running...
https://www.bestbuy.com/site/anker-3...?skuId=6547358
^ I think I actually have something cheaper and with less charging power.
https://www.bestbuy.com/site/belkin-...?skuId=6477374
^ That plugs into my phone, then I have a USB-C cable and a 3.5mm cable tucked underneath some interior trim and extending to the arm rest area plug ins for cigarette lighter / audio.
      03-21-2024, 12:13 PM   #31
bkilburn814
Nice! I'm lucky enough to have Bluetooth audio streaming enabled in my 2011 (no idea how lol - I don't have iDrive), but I've also had great luck with this Besign Bluetooth adapter. Plugs right into 3.5mm and takes up 1 of the USB-A ports in my charger right under the armrest. Keeps phone cabling nice and clean, just need to run the charger line.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      03-21-2024, 07:35 PM   #32
Donkeyshins
The Rennsport phone mount arrived today. I had to do some massaging of the mount to fit where I wanted it to in the dash, but nothing anyone can't do with just a pair of pliers.
Not bad for $45 and 15 minutes of my time.
Style 264 Wheels
      03-21-2024, 08:53 PM   #33
Tornado1M
Tornado1M's Avatar
Drives: M2cs
How does that attach to the plastic?
Double sided heavy duty tape?
      03-21-2024, 10:54 PM   #34
Donkeyshins
Screw underneath the trim. I had to modify the bracket (just straightening the E83 bends to fit the E82). It basically just needs to be mostly flat with a shallow 30 degree or so bend where the ball & socket attaches.
I’ll pull the trim tomorrow and take a photo of the bracket. If I were so inclined, I’d repaint it (the straightening caused the paint to flake off the bracket), but since it is under the trim, it doesn’t really bother me.
Appreciate 3
      03-24-2024, 06:32 PM   #35
duperdog
duperdog's Avatar
30
Drives: E46 M3, F25 xDrive28i
I've got the Rennline e83 mount in my cart, waiting to see how much I need to modify.
I have one in my e46 and love it!
      03-25-2024, 11:19 AM   #36
raqidona
raqidona's Avatar
Drives: BMW 128i 2010
I have a similar one, mounted with double-sided tape, and it's been holding up great for two years already.
      03-25-2024, 05:40 PM   #37
Donkeyshins
Here's what it looks like post-bending / post-install (I didn't bother painting it, because none of it is visible):
If I were to do it over again, I might try and get a flat / pre-bent bracket from Rennline and do the bends / painting myself since the bends aren't perfect and there was definitely some deformation from having to hammer some bits flat.
(come to think of it, I might just reach out to them and see if they'd be willing to sell me one)
Style 264 Wheels
Appreciate 4
Tornado1M1211.00
Kalya46.50
      03-25-2024, 07:47 PM   #38
RFChas
33
Drives: 128i, 335i, X3 35, X3 M40
I'm just using the Kenu airframe vent thing for an iPhone, and puts the phone in good line of site, and don't need a case for phone. Get the hang of it after a while. I use my CD player! Y'all own CDs yes? Sound pretty good in a car they do. Cheers all
      03-25-2024, 08:53 PM   #39
duperdog
duperdog's Avatar
30
Did you try heating and bending in a vise or just hammered at it? Doesn't look too bad. Going to pull the trigger on it anyway. Thanks for being the guinea pig!
      03-26-2024, 02:46 PM   #40
Donkeyshins
Doesn't need to be heated - it's 20ga sheet metal. I hammered to flatten it out (since complex bends) and then bent using some parallel-jaw linesman pliers. What I should have done is dug up my sheet metal bender (probably what I will do if I can get a flat version with which to start from scratch).
Style 264 Wheels
      03-27-2024, 01:56 PM   #41
Donkeyshins
And, unfortunately, Rennline won't sell me a blank.
Style 264 Wheels
      03-28-2024, 10:17 PM   #42
duperdog
duperdog's Avatar
30
I wonder if any of the other models are “straighter “?
      03-29-2024, 10:23 AM   #43
Donkeyshins
It's not just how straight it is, it's how long it is to reach the screw on the dash. I might just remove it, measure it out, and see if I can get something laser cut from Send Cut Send out of slightly thicker (18ga) stainless. Then I can bend it on my bench.
Style 264 Wheels
      04-25-2024, 05:18 PM   #44
Xaerophreak
Drives: BMW 135i, Lexus GX460
I am trying out this solution from Amazon. Simple ring mag mount. I don't need all that screen space.
