      02-28-2024, 11:32 AM   #1
E82HANK
Drives: 11 135i vert
Where is this leak exactly?
Hey guys,
Recently did the water pump and thermo and noticed this. What's leaking or needs replacement? Couldn't really tell.
Thanks!
      02-28-2024, 11:40 AM   #2
jdt10768
jdt10768's Avatar
332
Drives: 2013 128i MSport 6MT
VCG maybe ?
      02-28-2024, 11:50 AM   #3
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Yeqh most likely VCG. Take a look from the top and around the cover. Also Oil filter housing can be leaking.
jwolf63.00
      02-28-2024, 02:29 PM   #4
E82HANK
Thanks, will check!
      02-28-2024, 02:47 PM   #5
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Appears to be the fitting for the turbo oil drain line.... The o-ring that seals the fitting to the block is known to leak with age.
Could be VCG, but that's a long trail to follow, so should be easy enough to verify if it is.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
      03-02-2024, 07:21 PM   #6
blinded
17
Drives: 2009 135i
It looks like it's dripping down the oil drain though, so maybe the gasket at the turbo instead of the o-ring in the block.
