TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Wastegate Options/Mods
      02-23-2017, 04:33 PM   #375
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Deezy, I think that 48 psi is psia as in absolute pressure. You need to subtract off atmospheric pressure.
      02-23-2017, 07:35 PM   #376
supermann125
45
Drives: 2011 335d
@iaknown do you know if BPC is modifying the waste gate or having over boost issues with the complete "iaknown" package on their 2+ tune? Would like to know if I'm going to be DIY with that tune so I can handle with everything off
John@BPC
      02-28-2017, 02:03 PM   #377
BB_cuda
BB_cuda's Avatar
765
BPC actually feels the waste gate mod isn't necessary. I believe its in this thread or another related one.
      02-28-2017, 02:33 PM   #378
f00dstamps
Drives: 2010 BMW 335d
I've logged up to 40 lbs of boost on my BPC 2.5 + iaknown turboback exhaust + race pipe. The internal wastegate cannot evacuate the pressure fast enough. I purposely lay off of full throttle because I am still considering an external wastegate option.
      02-28-2017, 03:07 PM   #379
kydiesel35
kydiesel35's Avatar
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
If you send them your dde they can fix overboost issues... 40lbs does sound a little rich for 2.5, may be wrong though.
      03-15-2017, 05:59 PM   #380
Deftronix
170
Drives: 12 X5d & 20 X7 M50i
TDI - did you end up cannibalizing an egr cooler to make the piping? The end that connects to the exhaust manifold looks the exact same as stock (flex pipe and piping that extends passed the flange)? Would like to do this mod for peace of mind afters deletes but dont want to sacrifice my egr. Imagine the angles are pretty tough to get right. Probably have a little more room in the x5d engine bay so maybe a little more forgiving.
      03-15-2017, 06:30 PM   #381
TDIwyse
614
Drives: 2011 335d
I did use the EGR flex pipe at first, but it didn't last. I then moved to a hard pipe ~2 years ago: http://www.e90post.com/forums/showthread.php?t=1111590
However, I still used the compression section and the flange from the original EGR connection. Just got rid of the flex section that is prone to cracking/breaking...
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods
      03-15-2017, 10:24 PM   #382
Yozh
Yozh's Avatar
870
Drives: 2011 335d M-Sport
..dont want to sacrifice my egr.
Can go for something like this from an older E46/X5 with an M57. They come up on eBay europe once in a while for little money.
Deftronix169.50
      03-16-2017, 12:17 AM   #383
Deftronix
170
Love this forum, thanks TDI!
Yozh - That should work perfectly as a starting point, very much appreciate you pointing me in the right direction. Great idea!
      03-16-2017, 12:09 PM   #384
iaknown
Drives: 335D
John@BPC
Some interesting info about this I wanted to pass on..... Although it seems universally agreed that the wastegate mod isn't necessary, I found out some information that disproves it actually does harm to the turbine housing. A while back Bob and I were discussing this and he stated they had a car w/ the mod come in that was losing power during the turbo switch. Turns out the wastegate was most likely cracking from the slight spike of pressure when the turbos transition and the increased surface area on the wg flapper from the mod. He said the turbine housing was replaced and that solved it.....
Well, I found out I had the same issue on my car. When the turbos switched I could see a spike and then a huge drop in boost. But I knew that there had to be a way to lower the spike by adjusting the transition of the turbo switchover. I hounded Jarek about this and he did similar testing on a car he had inhouse on the dyno. He adjusted the switchover characteristics and updated my tune and this solved my issue, the boost is now rock solid and much smoother during the switchover. So a software adjustment was all that was needed. Thought this might interest some of you.....
      03-17-2017, 11:11 PM   #385
Yozh
Yozh's Avatar
870
Originally Posted by iaknown View Post
... I hounded Jarek about this and he did similar testing on a car he had inhouse on the dyno. He adjusted the switchover characteristics and updated my tune and this solved my issue, the boost is now rock solid and much smoother during the switchover. So a software adjustment was all that was needed. Thought this might interest some of you.....
Nice. Jarek is a wizard.
      03-21-2017, 11:06 PM   #386
Deftronix
170
Any of you guys have experience with the SCG-1 boost controller/wideband gauge?
      03-22-2017, 03:41 PM   #387
BB_cuda
BB_cuda's Avatar
765
Iaknown, so you had Jarek change software some to reduce spike at transition. Are you still running the turbo housing that has the opened up WG port? I have open up WG port too and wondering if i'm suffering a little at transition.
      03-22-2017, 09:21 PM   #388
iaknown
Drives: 335D
Yes, and I am still running my ported housing with no issues. It wasn't the 1st time Jarek saw this so I think it motivated him to change the transition a little on all aggressive tunes. You should try to monitor boost closely or even put a camera pointed at the wastegate arm to see, either should tell you if it's cracking.
      03-24-2017, 08:25 AM   #389
BB_cuda
BB_cuda's Avatar
765
Thank you. I presume I could get same correction from Andrew.
      07-01-2017, 04:38 AM   #390
Asonchadwick
Sleepy
75
Drives: bmw
Hi, newby here. I am about to get my exhaust dpf delete does anyone still think i should just enlarge the wastegate hole while i have it all apart or just leave it alone. Ill be going jr 2 race i think and may upgrade later.
      07-08-2017, 07:10 AM   #391
Torqu3
Drives: 2011 335d
2 opinions here. First, just go ahead and spring for the 2.8 and put in new boost hose seals and vacuum lines. That's exactly what I did and have had zero problems. Much easier and less time consuming than upgrading over time. And you'll thank me later for the power and MPG gains.
Second, don't worry about the wastegate. The tunes now are advanced enough that they aren't really necessary. Like it has been said, it won't be damaging if you did want to do it, but you don't really need to do it. Get a Turbosmart BOV from Whitbread Performance Innovations, and all will be good.
      08-21-2018, 01:46 PM   #392
chuckn0rr1s
chuckn0rr1s's Avatar
Drives: BMW 2011 335d
I just did the Stage 2+ tune from BPC I am very happy with the results! Next mods are airlift performance kit, wheels, and Intercooler
