The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Glow plug module and glow plug replacement
      02-20-2023, 07:19 PM   #23
335dlci
Drives: 335d
Originally Posted by E85 Sport View Post
Glow Plug Controller Module sits on a plastic bracket. What is underneath the bracket? Any sensitive electrical connectors?
Part number 12527801765. Item #3 in this diagram:
Source:
realoem.com/bmw/enUS/showparts?id=PN73-USA-03-2009-E90N-BMW-335d&diagId=12_1197
Its metal not plastic.
      02-20-2023, 10:22 PM   #24
E85 Sport
who is this noob
40
Drives: from Spartanburg
Thank you, I corrected my post.
A leaky swirl flap made a mess underneath my intake manifold. I am taking the manifold off to replace the glow plug controller and clean the area. Are there important components behind the bracket that I should be concerned about?
      04-15-2023, 07:36 PM   #25
B58
B58's Avatar
558
Drives: 922 Turbo
Glow plug module is easy. I replaced mine within 15 minutes without removing the manifold. You’ll just need a longer extension and recommend a magnetic type of socket. The glow plugs are easy, but you’ll need to remove the manifold. No coolant or anything had to be drained on my end.
2024 X3 M40i
2014 BMW M5
POBEP367.00
      05-18-2023, 08:51 AM   #26
demon
Fukowee Warrior
demon's Avatar
Drives: 2011 335d Msport blk on blk
Bought a glow plug module because I read - replace the module not the glow plugs, and that it was relatively easy to change without removing all the stuff mentioned in this thread. Also there is a youtube that shows the guy doing it in 15 minutes.
NOT MY EXPERIENCE! - If you loosen the hoses and dip stick and pull them out of the way you can see the module - But there was no way I could get my hand in there to disconnect wires.
Opinion - youtube says to disconnect wires first then take out the bolts. Anyone tried it taking out the bolts then disconnecting cables?
      05-18-2023, 12:17 PM   #27
E85 Sport
who is this noob
40
Youtube is right. Disconnect wires first, while the module is securely bolted in place.
There’s no way I could get my hands/tools in there with the intake manifold in place. Removing the manifold made it much easier to reach the module. I’m an amateur DIYer, so I don’t have to be fast like the professionals.
      03-09-2024, 02:14 PM   #28
AliveAndKicking
Drives: 2011 335d
I have a question! I replaced my glow plugs and control module but still have the codes. Will the codes reset? Or will I have to delete them?
      03-12-2024, 06:09 PM   #29
nonford
nonford's Avatar
Drives: 2011 335d, 2019 X3
Clear the codes.................................
      03-15-2024, 06:27 AM   #30
Lone_Wolf
Drives: E91 325d@250ps/500nm MT
Replace lead for preheater system, outside does not show damage but inside its burned. no. 12427789231.
