Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > M57 Tuning, Maintenance, Parts and DIY MEGATHREAD
      06-20-2017, 10:55 AM   #67
derkenblosh
9
Drives: White 335D & White Suburban
you guys can add IDPARTS.COM to the list if they are registered vendors on here yet, they are some stand-up guys for maintenance parts. Used them for all my parts on my Jeep Liberty CRD, and Grand Cherokee CRD
      06-20-2017, 02:17 PM   #68
Torqu3
Drives: 2011 335d
I'll find a place for them. Not sure they are vendors, but I have used them as well. Good folks, good products. Thanks for the tip!
      06-20-2017, 04:12 PM   #69
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
well if you are doing that....then go to the source.. https://www.bmwdirectparts.com/
      06-20-2017, 04:54 PM   #70
Torqu3
Drives: 2011 335d
There are a few websites I am aware of, but I don't have time to list them all out. Later this week I'll get a bunch of maintenance parts places listed and linked.
      06-20-2017, 07:06 PM   #71
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Cool, but that one is the OEM king...its actually Husker BMW of Lincoln (Ne) ...cheapest place to get OEM that Ive found.
      06-22-2017, 03:25 PM   #72
335dsl
13
Drives: 335d jbd
Will i have issues running 225/45/18 and 255/35/18?
      06-22-2017, 05:36 PM   #73
Torqu3
Drives: 2011 335d
None at all. OE Sport sizes are 225/40-18 and 255/35-18. Your setup is only barely bigger in the front.
      06-22-2017, 07:46 PM   #74
335dsl
13
Drives: 335d jbd
Thank you.
      06-23-2017, 07:34 AM   #75
M5_1of400
M5_1of400's Avatar
Drives: 2018 M5 / 2011 X5 35d
I found a shop near Dallas, TX that quoted me that much for it. I confirmed with them it was a walnut blast for the M57. So it isn't just a made up number.
Also, this is more on the end of engine performance. Going stage 2+ you'll be fine with stock brake pads, but I'll add that in.
Torqu3.. What's the name of the shop in Dallas ?
      06-23-2017, 08:15 AM   #76
Torqu3
Drives: 2011 335d
EurAuto. Join the Facebook group! There's a ton of Houston and DFW people. I'm in College Station.
      06-23-2017, 09:01 AM   #77
M5_1of400
M5_1of400's Avatar
Awesome, thanks for the info.. I just got my D so this is "just in case" I need it. By the way.. what's an easiest way to find out if you have a CBU issue?
      06-23-2017, 01:27 PM   #78
Torqu3
Drives: 2011 335d
Pull the EGR and look inside. Boroscope will help a ton with this. Or pull the intake manifold and look. Neither are too hard to do. EGR is easier.
      06-26-2017, 10:44 AM   #79
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
I dunno....I think Id leave the EGR because of those 2 bolts down low and pull the manifold. Personally thats the one Id rather take off... plus, MUCH easier to scope...
      07-06-2017, 11:13 AM   #80
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
To be included... JBD
A topic that are likely to come up for new D owners is the JBD by Burger Tuning (and the more recently released one by Dinan)
The JBD is a VERY simple product that can add quite a few hp/torq to your car for a low cost and very simply. It clips in between the fuel rail pressure sensor and the DDE....when the DDE calls for 15000mbar, the JBD tells it its only getting 10,000.....so the regulator continues to put more pressure to the rail.... thus turning everything up a bit. (numbers are hypothetical to show the concept) This can be adjusted in the JBD with a small screwdriver. Many people have experienced codes being thrown when turned up entirely.....I always ran at 80%-ish and never had an issue. This thing will NOT allow you to override any codes...like EGR or Nox or anything of the sort...you will need a tune for that. And to that end....many people that were previously running JBDs have now retired them for tunes... if you prefer a JBD (or live in CA), they are available on the board, just post that you are looking for one. Figure about 100 plus shipping. As for the Dinan version, its relatively new and connects to your phone via bluetooth and is adjustable. I only have one anecdotal piece of info about it....that it threw codes and didnt work for my friend...thats not to say that his experience is typical, its just all I have heard so far. Good luck.
      07-06-2017, 11:22 AM   #81
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
To be included.. Injectors
Another thing that new 335d owners will undoubtedly run into is injector issues around 100k miles. The BMW dealership will tell you the book says to replace them all, at $650 each. They will not test each injector and replace the bad one. See this thread for info about testing and where to buy injectors at a substantial discount: http://www.e90post.com/forums/showpo...8&postcount=12
      07-12-2017, 09:42 AM   #82
Oilburnerfan
Oilburnerfan's Avatar
Drives: 2011 335d Titanium/Blk M-Sport
Torqu3: Yo stated that the Circuit Werks 335i exhaust could be modified to work? How do you do that and which DP will it interface best with? I like the looks of that system and the price sure is great!
      07-12-2017, 09:54 AM   #83
Torqu3
Drives: 2011 335d
It'll work with any down pipe. What you have to do is weld a y-pipe onto the 335i exhaust and then a 2 bolt flange that will bolt up to the DP. The reason for this is that the typical exhaust setup on the 335d is a single pipe that splits off closer to the rear of the car, but our gasoline cousin uses an exhaust that has 2 pipes running the length of the car. So you have to use a y pipe to join those 2 pipes so they will bolt up to the down pipe. PM Whitbread or get in touch with him by visiting www.*************************. He has more experience with this setup than me.
      07-13-2017, 01:39 PM   #84
335dFan
Jumping Jack Flash
335dFan's Avatar
Drives: 2021 X3 M40i
Thanks for the anecdotal evidence. I have been running JBD @ 100% for about 60k miles. I have learned how to minimize the codes somewhat. Regarding the Dinan, I did look at it a few months back because it seemed that it might be more reliable and less code-sensitive. It didn't seem like it increased the HP/TQ as much as the JBD, but it's hard to easily get good numbers like that.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      07-13-2017, 02:17 PM   #85
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
PM whitbread...he can help you out
      07-31-2017, 02:24 PM   #86
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
This is a miss match diameter wise. If you need to run taller in front (normal size is 225/40/18), the rears would need to go taller too i.e. 255/40/18. Your suggested combo has fronts with side wall ~0.47" (thats' 0.94"/2) taller sidewalls. Change in sidewall height is a radius thing not diametral.
Here are example diameters for Mich Pilot Super Sports (listed specs, not straight math).
size diameter (in)
225/40/18 25.10
225/45/18 25.94
255/35/18 25.00
255/40/18 26.02
General rule is to keep diameters within 4% but I would go closer than that if possible.
If you do as your entry asks, the % difference would = (25.94-25.00)/25.00=.0376 or 3.76%
Going taller in back as well gives %diff=(26.02-25.94)/25.94=0.0031=0.31%
      09-18-2017, 04:40 PM   #87
Torqu3
Drives: 2011 335d
Gonna bump this up since people seem to skim over it.
      10-23-2017, 11:24 AM   #88
TTStevens
Drives: 2009 335d
Looks like I'll be getting my first 335D within a couple weeks and this thread has helped a ton! I've owned a number of diesel trucks so I'm a little familiar with all the alphabet stuff but still learning for the 335D. I see a lot of discussions about "piggybacks" vs tunes. What exactly is the difference if someone could explain it a little better to me? I think I have a general idea, but want to verify that I have it right. Or point me to a thread that breaks it all down. Thanks!
