Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > High Pressure Fuel Pump (hpfp) DIY
      06-02-2017, 09:18 AM   #23
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Originally Posted by lnxguy View Post
Any advantages of running the R90 pump with Stg2.8. I'm guessing no, but I thought I'd ask.
I think Jarek@JRAuto would probably be the best person to chime in on this, but Im betting you are correct.....
Based on what Jarek told me about the OEM pump...anything above 17000 mbar, the OEM pump cant keep up and becomes erratic at providing a consistent rail pressure....thus he cant predict the pressure for the tune and it can get smokey or lean.... .....(heres me speculating) my bet is that 2.8 stops asking for more pressure just before it gets to 17000. Thus the tune is very efficient and clean... So a more efficient/consistent pump above that level wouldnt help you make any gains... because it never asks for more than 17000 mbar in the rail....
Also...I am running 2.5....and I just changed to the R90...and I feel no difference from OEM to R90.... I expect a huge difference when I get the stage 3.5 tune from JR (when the requested rail pressure is much higher)
But I could be TOTALLY wrong on that...and would love for Jarek (or TDIwyse) to clear that up.
      06-02-2017, 09:18 AM   #24
335dsleeper
Drives: 09' 335d 10'35D
You should be able to make more power on diesel alone with the R90 vice large amounts of meth.
I think the R90 is a good option for everyone looking to make the most power out of their 335d.
      06-03-2017, 10:15 AM   #25
lnxguy
Drives: 2009 335D
I think the R90 is a good option for everyone looking to make the power power out of their 335d.
Kinda like the 11mm vs 10mm pumps on the rotary pump TDI cars? More fuel within the timing window, better combustion = more powersssss.
'09 335D
      06-03-2017, 10:27 AM   #26
335dsleeper
http://www.e90post.com/forums/showpo...5&postcount=33
      06-06-2017, 09:15 AM   #27
Whitbread
Drives: 335D
Only if the ecu is requesting fuel above the max flow value of the R70 pump will you see a gain by going to the R90. If you're not getting rail pressure drop now, you'll get zero gain just by putting on the R90 pump. Now once overall fuel flow is increased beyond the limit of the R70 in a tune update, then the R90 will provide the power gain by maintaining rail pressure.
      06-06-2017, 09:17 AM   #28
lnxguy
Drives: 2009 335D
Great info, thanks Matt!
'09 335D
      06-06-2017, 09:24 AM   #29
Whitbread
Drives: 335D
No problem, I'm hoping to have 30% over injectors available soon, Exergy has finished fixtures and is working on the engineering of what orifices internally need modified. With piezo injectors, just making the holes in the tip bigger doesn't do much. I'm willing to bet with a modified set of injectors, R90 pump, and hybrids we could be seeing some crazy figures put down .
      06-06-2017, 10:43 AM   #30
charlie fairmont
Drives: His & hers, GC & X5
From a wear or longevity perspective, is one better off with the upgraded pump?
      06-06-2017, 10:56 AM   #31
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Wont make any difference at all. The R90 upgrade only gives any benefit to those that are running a tune that throws a rail pressure error (most likely hybrid turbos).
I know this HPFP thing has been touted as the "next upgrade", but in reality its usefulness is limited to a pretty small circle at the moment. For those with a JR stage 3/4, its pretty much required though.
Anything below that, you will get no benefit at all.
BB_cuda765.00
robnitro160.00
      06-06-2017, 11:53 AM   #32
charlie fairmont
Gotcha, thanks. I'm kinda backwards from most in that I really only want increased reliability and am not too concerned with (and, in fact, a bit disinterested in) tons of power.
      06-06-2017, 03:27 PM   #33
ASBSECU E93
Know's a guy that know's a guy...
ASBSECU E93's Avatar
5637
Drives: 2010 335d; 2008 135i
Who says you can't have both Charlie....
Originally Posted by Lups View Post
She stood there. Pointed a finger at me and laughed at me. That damn bitch.
Poop shit, shit and poop. I'm mildly angry now.
      09-11-2017, 08:19 AM   #34
Got-Torque
10
Drives: 2011 335D M-sport
I'm running a 2.8 tune and getting the dreaded reduced engine power (bunch of rail pressure codes). Shopping for a R90 pump right now.
      09-11-2017, 01:02 PM   #35
Torqu3
Drives: 2011 335d
http://www.fixmyvw.com/bmw-r90-hpfp-...5d-and-x5-35d/
http://www.dieselops.com/bosch-r90-h...-x5d-2009-2011
      09-11-2017, 01:14 PM   #36
335dsleeper
Are you sure you need the R90? You might have another issue causing the rail codes. I believe JR tuned for the stock R70 high pressure pump.
      09-11-2017, 02:29 PM   #37
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
I asked the same thing... He responded via PM that hes been running 2.8 for a while....at first it was strong...but has gotten worse over time....
Hmm...maybe its not the pump...maybe the rail pressure sensor? Might be an idea to contact Rob about his spare one to try it out.
      09-11-2017, 02:42 PM   #38
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Dont forget Whit..... https://*************************/col...sure-fuel-pump
Torqu3320.50
      09-11-2017, 02:46 PM   #39
335dsleeper
There are a few issues that can trigger rail sensor codes. Not to many R70 pumps have failed so, it could be something else. Logging rail pressure at WOT might help narrowing down the issue.
      09-11-2017, 02:55 PM   #40
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Let me guess.....rail pressure sensor, a faulty injector, a failing LPFP....
anything else? And how would you know if its the pump vs any of the above?
      09-11-2017, 07:48 PM   #41
335dsleeper
You also have the regulating valve at the rear of the rail and the hpfp solenoid on the back of the hpfp.
Unfortunately, without codes it's quite difficult. He mentioned he had rail codes. The codes might help identify the issue and the issue might or might not be the hpfp.
      09-12-2017, 06:22 AM   #42
335D Alpha Pappa
43
Drives: 2011 335D
P0089 is the OBD2 error code. IDK what the BMW version is.
You can pull the connector off the Fuel Pressure Regulator (FPR) and the HPFP will default to max pressure all of the time. People do this when the FPR dies and they need to get home.
      09-12-2017, 09:51 AM   #43
Got-Torque
10
Codes were 4560, 4570, 4610.
Fuel filters only have 6k on them (have a 2 micron downstream of the factory one). Can ran great for a few months. Started having issues on full throttle runs, going into reduced power mode. Eventually it started occurring under less and less throttle amounts. Can't go 1/2 throttle for over a second or it will occur now.
I plan to go hybrids and a larger tune eventually so I figured that replacing the pump is money well spent.
My android phone I used for gauges and logging died (battery swelled up) and I haven't replaced it yet so I haven't been able to log anything. Not sure if my Schwaben scan tool will do that or not?
Got a pump coming from Whitbread and a tool in the mail, should get it put on this weekend. I'm also interested to see how my intake runners look after almost 10k miles of meth injection (hoping they are cleaned up)...
      09-12-2017, 02:03 PM   #44
OmahaDZL
OmahaDZL's Avatar
142
Drives: 2010 335D
Well I guess.....If you change the pump and still have issues you will know pretty quickly if it was or wasnt the pump...
I dont know if whitbreads pump comes with that extra 6 inches of hose...I suggest some heavy duty fuel line race hose....the one I used was too soft and it leaked everywhere... because I didnt tighten the hose clamp enough...
