New to m57, need help
02-21-2024, 02:12 PM | #1 |
Rep 74
I just purchased my first diesel vehicle, which has the m57 engine. test drove the car for almost an hour before purchasing, and everything went well. PO had replaced tons of known failure points, turbos included. 45 mins into my 2 hour drive home, the car randomly redlined, almost as if someone were to force downshift it into 3rd gear at 85mph. I slapped it into neutral and when I got onto the shoulder, the vehicle shut off. It will run for only 5-10 seconds before stalling out, and those few seconds are really rough. Codes thrown were for MAF and fuel filter heater. Swapped maf with a buddy and it seemed to help a bit but still misfiring and stalling out. PO replaced maf with a bosch one and given that the car is still misfiring I have no idea where to start. Any info helps!
2009 E90 335i 6M/T
VRSF DCIs, ARM Charge Pipe, Tial BOV, Precision Raceworks Coil Packs, ARM Catless Downpipes, Boost Monkey Cowl Delete Filters, 2" Silicone Inlets, 17t Turbos, ECS Coilovers, Turner Front End Links, Walbro 535 LPFP, BMS High Side Catch Can, ARM 7" IC, 335is Clutch Kit, MHD Stage2+ 93 Oct. |
02-22-2024, 12:29 PM | #3 |
Rep 74
Could be, I’m leaning towards a transmission malfunction causing engine hardware failure
2009 E90 335i 6M/T
02-23-2024, 11:32 AM | #4 |
Rep 1,723
Randomly redlining seems like a runaway condition due to oil being sucked into the intake.. Check your oil level.
Also, anytime you swap a MAF you need to reset adaptations.
'09 335D
02-26-2024, 05:08 PM | #5 | |
Rep 74
Also, it ran for almost a minute today while I was trying some diag, definitely had white smoke out the tailpipe, but upon testing injector return lines all seemed normal. Will upload a video of a live log from a few days ago showing rail pressure shortly.
2009 E90 335i 6M/T
02-29-2024, 11:33 PM | #7 |
Rep 74
It’s new :/
2009 E90 335i 6M/T
02-29-2024, 11:49 PM | #8 |
Rep 74
Got the car to stay on for longer than a minute today and this is what I saw
2009 E90 335i 6M/T
03-01-2024, 03:19 PM | #10 |
Rep 74
Yup. PO did it recently
2009 E90 335i 6M/T
03-01-2024, 03:53 PM | #11 |
Rep 74
Does any one know what rider and jogger are referring to
2009 E90 335i 6M/T
03-05-2024, 10:21 PM | #12 |
Rep 74
Replaced glow plug control module and glow plugs and went back a step. Car no longer stays on under its own power and is back to stalling out within 10 seconds. One this was I did reinstall the original mass airflow sensor as well as reset adaptations. The car once again had low battery but I did try replacing the alternator and the battery is new. Only codes available are an awd enabled code and a steering angle sensor code. Don’t want to throw parts at it so if anybody has any ideas as to how I can further diagnose the car please let me know.
2009 E90 335i 6M/T
03-11-2024, 12:46 PM | #13 |
Rep 74
Update
Replaced injector (and coded it in) in cyl 4 Smoothness codes still in 2&4 Could 2&4 be compensating for a failed cyl 3 injector? Did the test where you unplug injectors while the car was running and cylinder 4 was the only one that wouldn’t stall the car out. Reran the test and now it’s cyl 3 thats not stalling the car out, but the codes remain on 2&4.
2009 E90 335i 6M/T
03-16-2024, 03:22 PM | #14 |
82
Rep 189
Drives: 2010 335D, V-10 Touareg Diesel
Lemans,
Delete all codes. Start and run for 10 seconds. shut off and pull codes. what are the codes now? |
lemansbluen547.00 |
03-16-2024, 03:23 PM | #15 | |
Rep 74
Update: found metal shavings in oil
2009 E90 335i 6M/T
03-16-2024, 03:44 PM | #16 |
Rep 3,910
lemansbluen547.00 kurt0420.00 |
03-16-2024, 03:49 PM | #17 |
Rep 74
She made it 30 whole highway minutes into my ownership 😢
Any ideas where to start the tear down based on symptoms I’ve had? Wondering if I should pull head or check rod bearings first
2009 E90 335i 6M/T
03-18-2024, 02:50 AM | #20 |
Rep 3,910
03-21-2024, 01:49 PM | #21 |
Rep 32
Got here too late to answer but i would tell you from post no1 that you had a runaway engine. Probably the turbos that they replaced were of a bad quality and not original. Check the turbos for play. This engine almost definitely burnt quite a bit oil before so if you just bought it, they should have known this for sure in my opinion. Very doubtful that it just grenaded without any prewarning signs.
Whole engine needs replacement now of course, probably injectors aswell. I would not even try to restore this engine, this will probably have bad everything if you found oil shavings in the oil. Probably easier to just get a salvage motor and do the timing chain along with all the seals and check the turbos for play before on salvaged engine... If this kind of work makes sense of course in USA due to price of labor... |
03-21-2024, 01:55 PM | #22 | |
Rep 74
2009 E90 335i 6M/T
