03-04-2021, 08:40 PM | #1 |
Rep 951
G11 Screen in F10
Anyone tried it? I see ppl using the G30 or G01 screens. Anyone attempted a G11/G12 7 series 10.25 screen on their NBT retrofit? Please ping me if you have
03-05-2021, 01:35 PM | #2 |
Rep 951
Yeah ppl seem to have use the G30 and G01 screens. I have a new G11 screen that I wanted to use but haven't found anyone who has done this before to get tips from
03-06-2021, 01:16 AM | #3 |
1301
Rep 2,591
I've never seen a G series screen in a F10. Are you confusing it with this retrofit?
https://f10.5post.com/forums/showthread.php?t=1758953
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
woodnook12312.00 |
03-07-2021, 06:03 PM | #4 | |
Rep 1,244
Drives: 2013 F10 M5
I've been considering it myself since I tried the Android HU route from the link you posted and didn't like how it worked, quite clunky with the integration into the OEM system. |
03-11-2021, 06:01 PM | #5 |
Rep 951
So my concern is that not all G series screens are the same dimensions. G30 and G01 have been used/retrofitted successfully. My question is specifically about the G11/G12 7 series screen. I was just looking to see if someone indeed had done this and had tips...since its not a straightforward swap (bracket and overall dimensions are different)
04-23-2021, 01:45 PM | #9 |
Rep 951
nice!! that is what im looking for..(even though their description is weird as in says g11 but in the details says g30 screen. But I get the idea, it requires modifications which I can probably attempt. Thanks
07-05-2023, 09:01 PM | #12 |
15
Rep 19
I bought NBT Evo retofit a few years ago and seller claims it's G11 screen.
It looks pretty simple, you would just take off the F10 screen, remove screen but keep housing. Then remove back of G11 screen and attach the front on top of F10 screen bezel. Looks pretty stock, only downside to this setup is pressing buttons at the bottom of the screen is slightly awkward but you get used to it. |
10-12-2023, 08:53 PM | #13 | |
Rep 639
Drives: 2016 Alpina B6, 2015 535i
11-16-2023, 12:35 AM | #14 | |
Rep 10
Could you make more pictures from your screen please? Is looking very good, I have an G11 screen and I will like yo integrate in F10. Thank you! |
03-24-2024, 09:16 PM | #16 | ||
Rep 832
