2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding ZGW
      02-01-2024, 05:36 PM   #1
ceka
ceka's Avatar
24
Drives: 530d 11'
ZGW
My cic is messed up so it's time to upgrade to nbt.
I want to learn how to use ista and program the new zgw for the nbt and possibly next year new headlights.
So guess 1st step is to get a zgw and code it. after it works on my car then will get an nbt unit.. ( get everything working except cic, heard it does not work on newer zgw)
I want to upgrade to nbt evo id6
Question, which zgw should I look for on ebay?
confused on
1. zgw 02 mid plus
2. zgw high
3. zgw high plus
4. zgw 4sk
5. zgw 8sk
mid, mid plus, high, high plus, 01, 02, 4sk, 8sk, black body, metal body?
Should be a tutorial on zgws alone.. confusing af
Bought an ENET cable and the USB C to Ethernet Adapter from amazon.
Will download an ista/d.. if someone has a link would be great.
      02-02-2024, 06:07 AM   #2
ptrkp
18
Drives: F10 or F11
You need ZGW-02 HIGH Plus, also you need to upgrade the FRM for the LED headlights
      02-02-2024, 04:06 PM   #3
ceka
ceka's Avatar
24
Drives: 530d 11'
02 high plus not found on ebay..
is high plus same as 02 8sk?
      02-05-2024, 04:19 AM   #4
ptrkp
18
Drives: F10 or F11
Correct, is hard to find, but it is the only one that is the right modell.
Nope
      02-05-2024, 11:12 PM   #5
ceka
ceka's Avatar
24
Drives: 530d 11'
Nope
So anything say says 02 high plus not necessarily this part number..
      02-07-2024, 05:34 AM   #6
ptrkp
18
Drives: F10 or F11
Correct
ceka24.00
      02-13-2024, 09:14 AM   #7
DementedF10
DementedF10's Avatar
Drives: 2012 BMW 535ix
what is a ZGW
      02-13-2024, 01:49 PM   #8
ceka
ceka's Avatar
24
Drives: 530d 11'
https://www.bimmerfest.com/threads/g...e-zgw.1433119/
      02-13-2024, 11:53 PM   #9
ceka
ceka's Avatar
24
Drives: 530d 11'
Originally Posted by DementedF10 View Post
what is a ZGW
It’s like a bridge between modules and other components.
You can change some settings with BimmerCode, but others require a pc, and for this even a newer zgw version that support upgrades.
      02-15-2024, 10:21 AM   #10
DementedF10
Ok, The central gateway module.. Mine shows a memory fault all the time. I would love to update my CIC headunit/display to a NBT or Evo. I dont like the mmi setup 100% but this seems like a whole lotta parts and work for a radio.
      02-15-2024, 10:23 AM   #11
DementedF10
oh btw, What enet cable did you get? I have ista and everything but couldnt pull the trigger on the cable after reading so many conflicting reviews
      02-15-2024, 06:00 PM   #12
ceka
ceka's Avatar
24
Drives: 530d 11'
Yes it's a lot to change from cic to nbt, I will try to learn on the how to.
If not it's a dead project.
Here's the cable and adapter I got.
https://www.amazon.com/dp/B07V3C47YD...roduct_details
https://www.amazon.com/dp/B0837QGZMY...t_details&th=1
5post
