02-14-2021, 10:21 PM | #23 |
Rep 984
Do you guys think the F10 M5 EU5 Injectors on stock fuelling system would be able to extract as much power on a custom E40 tune on full bolt ons and VTT GCs?
02-14-2021, 10:25 PM | #24 |
587
Rep 898
FWIW, while a N55, there's some good data here: https://f87.bimmerpost.com/forums/sh....php?t=1782572
Given the nature of the single piston HPFP, we weren't able to push the stock injectors as hard as the S55 guys can, the EU5 injectors went in the same time as the "stage 3" HPFP. Yes EU5 injectors are not a direct drop in, a tune with proper calibrations, Injector compensation values coded via ISTA is required also.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
chetrickerman10446.50 |
02-15-2021, 02:10 PM | #25 | |
Rep 1,117
Thus wondering how much the F10/EU6 flow as they were revised after several years to correct the issues |
02-15-2021, 07:22 PM | #26 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
02-16-2021, 11:58 AM | #27 | |
Rep 1,117
https://f10.m5post.com/forums/showthread.php?t=1462695 |
03-22-2021, 01:08 AM | #29 |
@lbb_kev
496
Rep 516
What fuel type are you running? Are you running out of injector? HPFP?
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
03-22-2021, 08:28 AM | #30 |
Rep 1,009
Stock fuel system and looking to go E85
Pure F82
03-22-2021, 11:23 AM | #31 |
Rep 955
Well after vehicle diagnosis/OBD check and tune, I'm sure they won't cover it.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
03-22-2021, 11:26 AM | #32 |
@lbb_kev
496
Rep 516
As long as your tuner can calibrate for the EU5 injectors properly, it's a solid upgrade. I run them on my N55 M2 - just buy the injectors and decoupling elements from FCP Euro for the free exchanges.
Looks like your stock HPFPs have more room as well to support the higher ceiling provided by the EU5 injectors, but you'll eventually want the HPFP upgrade anyways: https://f80.bimmerpost.com/forums/sh...&postcount=123
///BMW Junkie473.50 |
03-22-2021, 11:39 AM | #33 |
Rep 5,181
I'm definitely looking this direction for an S55 motor build I'm planning to hang GC turbos on. Before the plan was E85 through EU6 plus PI+LPFP for added fueling and valve wash. Now I'm looking at E85 through the bigger EU5 plus HPFP+LPFP.
The thing that has me on the fence is losing valve wash, but I may be overthinking. I could add meth to get the wash back...my IATs in summer aren't so high I need cooling. Limiting factor for me is my 6MT with stock clutch. I don't like breaking stuff and prefer to add improvements before catastrophes.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
03-22-2021, 11:49 AM | #34 | |
Rep 1,009
Pure F82
03-22-2021, 03:43 PM | #35 | ||
Rep 5,181
03-22-2021, 06:56 PM | #36 |
121
Rep 134
Switch to water instead of meth if you don’t need fuel but have this concern. It cleans, cools and reduces detonation. You don’t blow up your motor when the pump fails. I may have been through some things with aquamist on a previous car. Haha
TopJimmy5495.50 ///BMW Junkie473.50 |
03-22-2021, 07:27 PM | #37 | |
Rep 5,181
03-31-2021, 02:39 PM | #39 |
Rep 5,181
I've heard only one tuner who has perfected the M5 injector swap including smooth idle, and that's Halim@HCP. Kratos said he's been doing testing work for them with the big squirters, and he has it all smoothed out.
03-31-2021, 05:03 PM | #40 | |
Rep 1,009
Pure F82
TopJimmy5495.50 |
04-01-2021, 07:56 AM | #41 |
56
Rep 86
Get someone that knows what's needed to calibrate and tune them correctly, no idle issues. My car idles fine, even with cat warm up turned off. It was even better when I had cold start turned on.
~2022 M4 Comp Xdrive - Bm3, KW V3s, Downpipes, E50 Custom Tune
04-01-2021, 08:04 AM | #42 |
Rep 5,181
Halim's guys replied same day that they can do an EU5 93 tune for $600. They said an E85 tune might cost a little more depending on how many revisions you need.
Unheardmyth21.00 |
04-01-2021, 08:18 AM | #43 | |
56
Rep 86
https://abperformance.ge/ is who tuned my car. Another great option outside of F80paul and HCP.
04-01-2021, 08:44 AM | #44 |
Rep 1,009
How did you reach them? HCP website?
Pure F82
